[ Upstream commit 72214a24a7677d4c7501eecc9517ed681b5f2db2 ]
In Python3+ print is a function so the old syntax is not correct
anymore:
$ ./scripts/bloat-o-meter vmlinux.o vmlinux.o.old
File "./scripts/bloat-o-meter", line 61
print "add/remove: %s/%s grow/shrink: %s/%s up/down: %s/%s (%s)" % \
SyntaxError: invalid syntax
Fix by calling print as a function.
Tested on python 2.7.11, 3.5.1
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: <stable@vger.kernel.org>
This avoids double-counting size changes in syscall implementations.
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
str.startswith has existed since at least Python 2.0, in 2000; use it
rather than a fragile comparison against an initial slice of a string,
which requires hard-coding the length of the string to compare against.
linux_banner can change size due to changes in the compiler, build number,
or the user@host the system was compiled on; ignore size changes in
linux_banner entirely.
Disable static detection: the static currently drops a lot of useful
information including clones generated by gcc. Drop this. The statics
will appear now without static. prefix.
But remove the LTO .NUMBER postfixes that look ugly
I'm not sure why the read-only data section is excluded from the report,
it seems as relevant as the other data sections (b and d).
I've stripped the symbols starting with __mod_ as they can have their
names dynamically generated and thus comparison between binaries is not
possible.
Acked-by: Nathan Lynch <ntl@pobox.com>
bloat-o-meter assumes that a '.' anywhere in a symbol's name means that it
is static and prepends 'static.' to the first part of the symbol name,
discarding the portion of the name that follows the '.'. However, the
names of function entry points begin with '.' in the ppc64 ABI. This
causes all function text size changes to be accounted to a single 'static.'
entry in the output when comparing ppc64 kernels.
Change getsizes() to ignore the first character of the symbol name when
searching for '.'.
Signed-off-by: Nathan Lynch <ntl@pobox.com>
Cc: Matt Mackall <mpm@selenic.com>
Upgrade scripts/bloat-o-meter to handle the names gcc 4 gives static
symbols.
Signed-off-by: Rob Landley <rob@landley.net>
Signed-off-by: Matt Mackall <mpm@selenic.com>
Make it executable like it should be. Do the same for other files intended to be
executed by the user - the ones called by the build process needn't be
executable as they already work (as argument to their interpreter).
Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
This is a rewrite of Andi Kleen's bloat-o-meter with sorting and reporting of
gainers/decliners. Sample output:
add/remove: 0/8 grow/shrink: 2/0 up/down: 88/-4424 (-4336)
function old new delta
__copy_to_user_ll 59 103 +44
__copy_from_user_ll 59 103 +44
fill_note 32 - -32
maydump 58 - -58
dump_seek 67 - -67
writenote 180 - -180
elf_dump_thread_status 274 - -274
fill_psinfo 308 - -308
fill_prstatus 466 - -466
elf_core_dump 3039 - -3039
The summary line says:
no functions added, 8 removed
two functions grew, none shrunk
we gained 88 bytes and lost 4424 (or -4336 net)
This work was sponsored in part by CE Linux Forum
Cc: Andi Kleen <ak@muc.de>
