path: root/scripts/checkstack.pl
2014-08-08scripts/checkstack.pl: automatically handle 32-bit and 64-bit mode for ARCH=x86Konstantin Khlebnikov
This patch adds support for ARCH=x86 into checkstack. Commit ffee0de411fd ("x86: Default to ARCH=x86 to avoid overriding CONFIG_64BIT") had merged ARCH=i386 and ARCH=x86_64 into one ARCH=x86. checkstack.pl searches patterns of machine instructions which are usually used for allocating stack frames. checkstalk.pl needs either i386 or x86_64, x86 isn't enough: $ make checkstack objdump -d vmlinux $(find . -name '*.ko') | \ perl linux/scripts/checkstack.pl x86 wrong or unknown architecture "x86" Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Richard Weinberger <richard@nod.at> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-10kbuild: trivial - remove trailing empty linesMasahiro Yamada
2013-03-02scripts/checkstack.pl: Add metag supportJames Hogan
Adapt checkstack.pl so that it works for metag. Signed-off-by: James Hogan <james.hogan@imgtec.com>
2011-05-18Haavard Skinnemoen has left AtmelJean Delvare
Haavard's e-mail address at Atmel is no longer valid. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Havard Skinnemoen <hskinnemoen@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-07scripts: improve checkstackStephen Hemminger
Cleanup checkstack script: * Turn on strict checking * Fix resulting error message because the declaration syntax was incorrect. * Remove incorrect and misleading use of prototype - prototype not required for this type of sort function because $a and $b are being used in this contex - if prototype was being used it should be for both arguments * Use closure for sort function Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Cong Wang <amwang@redhat.com> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2008-10-22sparc: Add checkstack supportMartin Habets
Add sparc support to checkstack. Signed-off-by: Martin Habets <errandir_news@mph.eclipse.co.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-10[S390] Fix checkstack for s390Christian Borntraeger
With -march=z990 and later gcc can use the long displacement facility insruction lay for stack register handling. This patch adopts checkstack to catch lay in addition to ahi and aghi. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-07-25fix checkstack.pl arch detectionEric Sandeen
uname -m was leaving a newline in $arch, and not passing the tests. Also, printing the unknown arch on failure is probably helpful. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25find dynamic stack allocations in checkstack.plEric Sandeen
Currently, checkstack.pl only looks for fixed subtractions from the stack pointer. However, things like this: void function(int size) { char stackbuster[size << 2]; ... are certainly worth pointing out, I think. This could perhaps be done more cleanly, and the following patch only adds "dynamic" REs for x86 and x86_64, but it works: 0x00b0 crypto_cbc_decrypt_inplace [cbc]: Dynamic (%rax) 0x00ad crypto_pcbc_decrypt_inplace [pcbc]: Dynamic (%rax) 0x02f6 crypto_pcbc_encrypt_inplace [pcbc]: Dynamic (%rax) 0x036c _crypto_xcbc_digest_setkey [xcbc]: Dynamic (%rax) ... (Inspired by Keith Owens' old stack-check script) Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06Claim maintainership for block2mtd and update email addressesJoern Engel
I have been prime author and maintainer of block2mtd from day one, but neither MAINTAINERS nor the module source makes this fact clear. And while I'm at it, update my email addresses tree-wide, as the old address currently bounces and change my name to "joern" as unicode will likely continue to cause trouble until the end of this century. Signed-off-by: Joern Engel <joern@lazybastard.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-20Merge branch 'master' of ↵Linus Torvalds
hera.kernel.org:/pub/scm/linux/kernel/git/kyle/parisc-2.6 * 'master' of hera.kernel.org:/pub/scm/linux/kernel/git/kyle/parisc-2.6: (29 commits) [PARISC] fix uninitialized variable warning in asm/rtc.h [PARISC] Port checkstack.pl to parisc [PARISC] Make palo target work when $obj != $src [PARISC] Zap unused variable warnings in pci.c [PARISC] Fix tests in palo target [PARISC] Fix palo target [PARISC] Restore palo target [PARISC] Attempt to clean up parisc/Makefile [PARISC] Fix infinite loop in /proc/iomem [PARISC] Quiet sysfs_create_link __must_check warnings in pdc_stable [PARISC] Squelch pci_enable_device __must_check warning in superio [PARISC] Kill off broken irqstack code [PARISC] Remove hardcoded uses of PAGE_SIZE [PARISC] Clean up pointless ASM_PAGE_SIZE_DIV use [PARISC] Kill off the last vestiges of ASM_PAGE_SIZE [PARISC] Kill off ASM_PAGE_SIZE use [PARISC] Beautify parisc vmlinux.lds.S [PARISC] Clean up a resource_size_t warning in sba_iommu [PARISC] Kill incorrect cast warning in unwinder [PARISC] Kill zone_to_nid printk warning ... Fixed trivial conflict in include/asm-parisc/tlbflush.h manually
2007-10-20[PARISC] Port checkstack.pl to pariscKyle McMartin
Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2007-10-19fix a trivial typo in scripts/checkstack.plJoern Engel
Trivial change in a comment. Signed-off-by: Joern Engel <joern@logfs.org> Signed-off-by: Andre Haupt <andre@finow14.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Add stack checking for BlackfinMike Frysinger
Simply fill out the bits in checkstack.pl for Blackfin. I thought I already sent this, but I don't see it in -mm anywhere ... Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-11[AVR32] checkstack supportHaavard Skinnemoen
Add regexes to recognize stack frame adjustments in AVR32 code. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2006-08-25[POWERPC] make checkstack work with ARCH=powerpcJohannes Berg
This patch adds 'powerpc' architecture support to checkstack.pl. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-25[PATCH] checkstack: print module namesRandy Dunlap
Finding "init_module" high stack usage problems is challenging when there are over 1600 "init_module" functions in the kernel tree, so make checkstack.pl print out the filename where the stack usage occurs. This is useful for code built as loadable modules. For built-in code, it just prints the kernel image file name, like "vmlinux". Examples: (before patch:) 0x0000000d callback: 1928 0xffffffff81678c09 huft_build: 1560 0x0018 init_module: 1512 (after patch:) 0x0000000d callback [divacapi]: 1928 0xffffffff81678c09 huft_build [vmlinux]: 1560 0x0018 init_module [hdaps]: 1512 Also change one if-series to use elsif to cut down on unneeded tests. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Joern Engel <joern@wh.fh-wedel.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11kbuild: fix mode of checkstack.pl and other files.Paolo 'Blaisorblade' Giarrusso
Make it executable like it should be. Do the same for other files intended to be executed by the user - the ones called by the build process needn't be executable as they already work (as argument to their interpreter). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
