path: root/scripts/coccicheck
2012-02-24coccicheck: change handling of C={1,2} when M= is setGreg Dietsche
This patch reverts a portion of d0bc1fb4 so that coccicheck will work properly when C=1 or C=2. Reported-and-tested-by: Brice Goglin <Brice.Goglin@inria.fr> Signed-off-by: Greg Dietsche <Gregory.Dietsche@cuw.edu> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-01-14coccicheck: add M= option to control which dir is processedGreg Dietsche
Examples: make coccicheck M=drivers/net/wireless/ make coccicheck SUBDIRS=drivers/net/wireless/ Version 2: fix patch file names when using M= tell coccinelle where the include files are Version 3: Add second include option to support out of tree development Fix error message Signed-off-by: Greg Dietsche <Gregory.Dietsche@cuw.edu> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-10-28Coccinelle: Add contextual messageNicolas Palix
Change the message displayed to the user according to the current mode used. Fix trailing white-space and spelling Signed-off-by: Nicolas Palix <npalix.work@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-10-13Coccinelle: Use the -no_show_diff option for org and report modeNicolas Palix
This allows to write the semantic patches with code sharing for the matching parts. Signed-off-by: Nicolas Palix <npalix.work@gmail.com> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-10-13Coccinelle: Add a new mode named 'chain'Nicolas Palix
spatch now returns -1 when a virtual rule (given with -D on the command line) is not defined in the semantic patch. Using this spatch feature, coccicheck is now tries several modes by default, in the order: patch, report, context, org Signed-off-by: Nicolas Palix <npalix.work@gmail.com> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-10-13Coccinelle: Improve user information with a new kind of commentNicolas Palix
Improve user information with a new kind of comment about semantic patch output. Fix spelling. Signed-off-by: Nicolas Palix <npalix.work@gmail.com> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-06-28Add support for the C variable in the coccicheck scriptNicolas Palix
This patch makes it possible to use the Coccinelle checker with the C variable of the build system. To check only newly edited code, the following command may be used: 'make C={1,2} CHECK="scripts/coccicheck"' This runs every semantic patch in scripts/coccinelle by default. The COCCI variable may additionally be used to only apply a single semantic patch. Signed-off-by: Nicolas Palix <npalix@diku.dk> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-06-12Add a target to use the Coccinelle checkerNicolas Palix
A 'coccicheck' target is added. It can be called with four different modes. Each one generates a different kind of output, i.e. context, patch, org, report, according to the corresponding mode to be activated. The new target calls the 'coccicheck' front-end in the 'scripts' directory with the MODE argument. Every SmPL file in the subdirectories of 'scripts/coccinelle' is then given to the front-end and applied to the entire source tree. The four modes behave as follows: 'report' generates a list in the following format: file:line:column-column: message 'patch' proposes a fix, when possible. 'context' highlights lines of interest and their context in a diff-like style. Lines of interest are indicated with '-'. 'org' generates a report in the Org mode format of Emacs. Signed-off-by: Nicolas Palix <npalix@diku.dk> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
