path: root/scripts/coccinelle/locks
2010-10-28Coccinelle: Find nested lock+irqsave functions that use the same flags ↵Julia Lawall
variables. Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Nicolas Palix <npalix.work@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-08-31Coccinelle: Add locks/mini_lock.cocciNicolas Palix
Find missing unlocks. This semantic match considers the specific case where the unlock is missing from an if branch, and there is a lock before the if and an unlock after the if. False positives are due to cases where the if branch represents a case where the function is supposed to exit with the lock held, or where there is some preceding function call that releases the lock. Signed-off-by: Nicolas Palix <npalix@diku.dk> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-08-31Coccinelle: Add locks/double_lock.cocciNicolas Palix
Find double locks. False positives may occur when some paths cannot occur at execution, due to the values of variables, and when there is an intervening function call that releases the lock. Signed-off-by: Nicolas Palix <npalix@diku.dk> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-08-31Coccinelle: Add locks/call_kern.cocciNicolas Palix
Find functions that refer to GFP_KERNEL but are called with locks held. The proposed change of converting the GFP_KERNEL is not necessarily the correct one. It may be desired to unlock the lock, or to not call the function under the lock in the first place. Signed-off-by: Nicolas Palix <npalix@diku.dk> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Michal Marek <mmarek@suse.cz>
