run simultaneously without deadlock
commit 10dce8af34226d90fa56746a934f8da5dcdba3df upstream.
Commit 9c225f2655e3 ("vfs: atomic f_pos accesses as per POSIX") added
locking for file.f_pos access and in particular made concurrent read and
write not possible - now both those functions take f_pos lock for the
whole run, and so if e.g. a read is blocked waiting for data, write will
deadlock waiting for that read to complete.
This caused regression for stream-like files where previously read and
write could run simultaneously, but after that patch could not do so
anymore. See e.g. commit 581d21a2d02a ("xenbus: fix deadlock on writes
to /proc/xen/xenbus") which fixes such regression for particular case of
/proc/xen/xenbus.
The patch that added f_pos lock in 2014 did so to guarantee POSIX thread
safety for read/write/lseek and added the locking to file descriptors of
all regular files. In 2014 that thread-safety problem was not new as it
was already discussed earlier in 2006.
However even though 2006'th version of Linus's patch was adding f_pos
locking "only for files that are marked seekable with FMODE_LSEEK (thus
avoiding the stream-like objects like pipes and sockets)", the 2014
version - the one that actually made it into the tree as 9c225f2655e3 -
is doing so irregardless of whether a file is seekable or not.
See
https://lore.kernel.org/lkml/53022DB1.4070805@gmail.com/
https://lwn.net/Articles/180387
https://lwn.net/Articles/180396
for historic context.
The reason that it did so is, probably, that there are many files that
are marked non-seekable, but e.g. their read implementation actually
depends on knowing current position to correctly handle the read. Some
examples:
kernel/power/user.c snapshot_read
fs/debugfs/file.c u32_array_read
fs/fuse/control.c fuse_conn_waiting_read + ...
drivers/hwmon/asus_atk0110.c atk_debugfs_ggrp_read
arch/s390/hypfs/inode.c hypfs_read_iter
Despite that, many nonseekable_open users implement read and write with
pure stream semantics - they don't depend on passed ppos at all. And for
those cases where read could wait for something inside, it creates a
situation similar to xenbus - the write could be never made to go until
read is done, and read is waiting for some, potentially external, event,
for potentially unbounded time -> deadlock.
Besides xenbus, there are 14 such places in the kernel that I've found
with semantic patch (see below):
drivers/xen/evtchn.c:667:8-24: ERROR: evtchn_fops: .read() can deadlock .write()
drivers/isdn/capi/capi.c:963:8-24: ERROR: capi_fops: .read() can deadlock .write()
drivers/input/evdev.c:527:1-17: ERROR: evdev_fops: .read() can deadlock .write()
drivers/char/pcmcia/cm4000_cs.c:1685:7-23: ERROR: cm4000_fops: .read() can deadlock .write()
net/rfkill/core.c:1146:8-24: ERROR: rfkill_fops: .read() can deadlock .write()
drivers/s390/char/fs3270.c:488:1-17: ERROR: fs3270_fops: .read() can deadlock .write()
drivers/usb/misc/ldusb.c:310:1-17: ERROR: ld_usb_fops: .read() can deadlock .write()
drivers/hid/uhid.c:635:1-17: ERROR: uhid_fops: .read() can deadlock .write()
net/batman-adv/icmp_socket.c:80:1-17: ERROR: batadv_fops: .read() can deadlock .write()
drivers/media/rc/lirc_dev.c:198:1-17: ERROR: lirc_fops: .read() can deadlock .write()
drivers/leds/uleds.c:77:1-17: ERROR: uleds_fops: .read() can deadlock .write()
drivers/input/misc/uinput.c:400:1-17: ERROR: uinput_fops: .read() can deadlock .write()
drivers/infiniband/core/user_mad.c:985:7-23: ERROR: umad_fops: .read() can deadlock .write()
drivers/gnss/core.c:45:1-17: ERROR: gnss_fops: .read() can deadlock .write()
In addition to the cases above another regression caused by f_pos
locking is that now FUSE filesystems that implement open with
FOPEN_NONSEEKABLE flag, can no longer implement bidirectional
stream-like files - for the same reason as above e.g. read can deadlock
write locking on file.f_pos in the kernel.
FUSE's FOPEN_NONSEEKABLE was added in 2008 in a7c1b990f715 ("fuse:
implement nonseekable open") to support OSSPD. OSSPD implements /dev/dsp
in userspace with FOPEN_NONSEEKABLE flag, with corresponding read and
write routines not depending on current position at all, and with both
read and write being potentially blocking operations:
See
https://github.com/libfuse/osspd
https://lwn.net/Articles/308445
https://github.com/libfuse/osspd/blob/14a9cff0/osspd.c#L1406
https://github.com/libfuse/osspd/blob/14a9cff0/osspd.c#L1438-L1477
https://github.com/libfuse/osspd/blob/14a9cff0/osspd.c#L1479-L1510
Corresponding libfuse example/test also describes FOPEN_NONSEEKABLE as
"somewhat pipe-like files ..." with read handler not using offset.
However that test implements only read without write and cannot exercise
the deadlock scenario:
https://github.com/libfuse/libfuse/blob/fuse-3.4.2-3-ga1bff7d/example/poll.c#L124-L131
https://github.com/libfuse/libfuse/blob/fuse-3.4.2-3-ga1bff7d/example/poll.c#L146-L163
https://github.com/libfuse/libfuse/blob/fuse-3.4.2-3-ga1bff7d/example/poll.c#L209-L216
I've actually hit the read vs write deadlock for real while implementing
my FUSE filesystem where there is /head/watch file, for which open
creates separate bidirectional socket-like stream in between filesystem
and its user with both read and write being later performed
simultaneously. And there it is semantically not easy to split the
stream into two separate read-only and write-only channels:
https://lab.nexedi.com/kirr/wendelin.core/blob/f13aa600/wcfs/wcfs.go#L88-169
Let's fix this regression. The plan is:
1. We can't change nonseekable_open to include &~FMODE_ATOMIC_POS -
doing so would break many in-kernel nonseekable_open users which
actually use ppos in read/write handlers.
2. Add stream_open() to kernel to open stream-like non-seekable file
descriptors. Read and write on such file descriptors would never use
nor change ppos. And with that property on stream-like files read and
write will be running without taking f_pos lock - i.e. read and write
could be running simultaneously.
3. With semantic patch search and convert to stream_open all in-kernel
nonseekable_open users for which read and write actually do not
depend on ppos and where there is no other methods in file_operations
which assume @offset access.
4. Add FOPEN_STREAM to fs/fuse/ and open in-kernel file-descriptors via
steam_open if that bit is present in filesystem open reply.
It was tempting to change fs/fuse/ open handler to use stream_open
instead of nonseekable_open on just FOPEN_NONSEEKABLE flags, but
grepping through Debian codesearch shows users of FOPEN_NONSEEKABLE,
and in particular GVFS which actually uses offset in its read and
write handlers
https://codesearch.debian.net/search?q=-%3Enonseekable+%3D
https://gitlab.gnome.org/GNOME/gvfs/blob/1.40.0-6-gcbc54396/client/gvfsfusedaemon.c#L1080
https://gitlab.gnome.org/GNOME/gvfs/blob/1.40.0-6-gcbc54396/client/gvfsfusedaemon.c#L1247-1346
https://gitlab.gnome.org/GNOME/gvfs/blob/1.40.0-6-gcbc54396/client/gvfsfusedaemon.c#L1399-1481
so if we would do such a change it will break a real user.
5. Add stream_open and FOPEN_STREAM handling to stable kernels starting
from v3.14+ (the kernel where 9c225f2655 first appeared).
This will allow to patch OSSPD and other FUSE filesystems that
provide stream-like files to return FOPEN_STREAM | FOPEN_NONSEEKABLE
in their open handler and this way avoid the deadlock on all kernel
versions. This should work because fs/fuse/ ignores unknown open
flags returned from a filesystem and so passing FOPEN_STREAM to a
kernel that is not aware of this flag cannot hurt. In turn the kernel
that is not aware of FOPEN_STREAM will be < v3.14 where just
FOPEN_NONSEEKABLE is sufficient to implement streams without read vs
write deadlock.
This patch adds stream_open, converts /proc/xen/xenbus to it and adds
semantic patch to automatically locate in-kernel places that are either
required to be converted due to read vs write deadlock, or that are just
safe to be converted because read and write do not use ppos and there
are no other funky methods in file_operations.
Regarding semantic patch I've verified each generated change manually -
that it is correct to convert - and each other nonseekable_open instance
left - that it is either not correct to convert there, or that it is not
converted due to current stream_open.cocci limitations.
The script also does not convert files that should be valid to convert,
but that currently have .llseek = noop_llseek or generic_file_llseek for
unknown reason despite file being opened with nonseekable_open (e.g.
drivers/input/mousedev.c)
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Yongzhi Pan <panyongzhi@gmail.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: David Vrabel <david.vrabel@citrix.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: Miklos Szeredi <miklos@szeredi.hu>
Cc: Tejun Heo <tj@kernel.org>
Cc: Kirill Tkhai <ktkhai@virtuozzo.com>
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
Cc: Nikolaus Rath <Nikolaus@rath.org>
Cc: Han-Wen Nienhuys <hanwen@google.com>
Signed-off-by: Kirill Smelkov <kirr@nexedi.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
For consistency with other reference counting APIs in the kernel, add
drm_property_blob_get() and drm_property_blob_put() to reference count
DRM blob properties.
Compatibility aliases are added to keep existing code working. To help
speed up the transition, all the instances of the old functions in the
DRM core are already replaced in this commit.
A semantic patch is provided that can be used to convert all drivers to
the new helpers.
Reviewed-by: Sean Paul <seanpaul@chromium.org>
Acked-by: Christian König <christian.koenig@amd.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
Link: http://patchwork.freedesktop.org/patch/msgid/20170228144643.5668-7-thierry.reding@gmail.com
drm_gem_object_get() and drm_gem_object_put(), as well as an unlocked
variant of the latter, to reference count GEM buffer objects.
The existing semantic patch for the DRM subsystem-wide conversion is
extended to account for these new helpers.
Link: http://patchwork.freedesktop.org/patch/msgid/20170228144643.5668-6-thierry.reding@gmail.com
drm_framebuffer_get() and drm_framebuffer_put() to reference count DRM
framebuffers.
Link: http://patchwork.freedesktop.org/patch/msgid/20170228144643.5668-5-thierry.reding@gmail.com
drm_connector_get() and drm_connector_put() functions to reference count
connectors.
The existing semantic patch for mode object reference count conversion
is extended for these new helpers.
Link: http://patchwork.freedesktop.org/patch/msgid/20170228144643.5668-4-thierry.reding@gmail.com
drm_mode_object_get() and drm_mode_object_put() to reference count DRM
mode objects.
the new helpers.
Link: http://patchwork.freedesktop.org/patch/msgid/20170228144643.5668-3-thierry.reding@gmail.com
Add missing support for the devm_request_threaded_irq in
the rules of context, report and org modes.
Misc:
To be consistent with other scripts, change confidence level
of the script to 'Moderate'.
Signed-off-by: Vaishali Thakkar <vaishali.thakkar@oracle.com>
Acked-by: Julia Lawall <julia.lawall@lip6.fr>
Signed-off-by: Michal Marek <mmarek@suse.com>
To eliminate false positives given by the context mode, add
necessary arguments for the function request_threaded_irq.
Currently because of the left associativity of the operators, pattern
IRQF_ONESHOT | flags does not match with the pattern when we have more
than one flag after the disjunction. This eventually results in giving
false positives by the script. This patch eliminates these FPs by
improving the rule.
Add a script to check for unneeded conversions to bool.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Report code constructs where the if and else branch are functionally
identical. In cases where this is intended it really should be
documented - most reported cases probably are bugs.
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
pm_runtime.cocci starts with one rule that searches for a variety of
functions calls, followed by various rules that report errors. Previously,
the only connection between the first rule and the rest was to check that
the first rule had matched somewhere. Change the rules to propagate a
position from the first rule to the others, to make sure that the sites
reported on are the same as the sites that were identified as having the
relevant functions.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Memdup_user encapsulates a memory allocation with the flag GFP_KERNEL, so
only allow this flag in the original code.
Make use of the new Requires: tag to be able to specify coccinelle binary
version requirements. The cocci file device_node_continue.cocci requires at
least coccinelle 1.0.4.
Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org>
Acked-by: Nicolas Palix <nicolas.palix@imag.fr>
krealloc() must not be used against devm_*() allocated
memory regions:
- if a bigger memory is to be allocated, krealloc() and
__krealloc() could return a different pointer than the
one given to them, creating a memory region which is not
managed, thus it will not be automatically released on
device removal.
- if a bigger memory is to be allocated, krealloc() could
kfree() the managed memory region which is passed to it.
The old pointer is left registered as a resource for the
device. On device removal, this dangling pointer will be
used and an unrelated memory region could be released.
- if the requested size is equal to 0, krealloc() can also
just behave like kfree(). Here too, the old pointer is
kept associated with the device. On device removal, this
invalid pointer will be used and an unrelated memory
For all these reasons, krealloc() must not be used on a
pointer returned by devm_*() functions.
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Signed-off-by: Yann Droneaud <ydroneaud@opteya.com>
Updates free/devm_free.cocci to recognize functions added by:
- commit 64c862a839a8 ('devres: add kernel standard devm_k.alloc functions')
- commit e31108cad3de ('devres: introduce API "devm_kstrdup"')
- commit 3046365bb470 ('devres: introduce API "devm_kmemdup')
- commit 43339bed7010 ('devres: Add devm_get_free_pages API')
- commit 75f2a4ead5d5 ('devres: Add devm_kasprintf and devm_kvasprintf API')
See also Documentation/driver-model/devres.txt
Cc: Joe Perches <joe@perches.com>
Cc: Manish Badarkhe <badarkhe.manish@gmail.com>
Cc: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Cc: Eli Billauer <eli.billauer@gmail.com>
Cc: Himangi Saraogi <himangi774@gmail.com>
Cc: Geert Uytterhoeven <geert+renesas@glider.be>
Cc: Wolfram Sang <w.sang@pengutronix.de>
Cc: Daniel Thompson <daniel.thompson@linaro.org>
Since commit 3ef0e5ba4673 ('slab: introduce kzfree()'),
kfree() is no more the only function to be considered:
kzfree() should be recognized too.
In particular, kzfree() must not be called on memory
allocated through devm_*() functions.
Add new rules to detect the cases where sizeof is used in
function calls as a argument.
Also, for the patch mode third rule should behave same as
second rule with arguments reversed. So, change that as well.
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull misc kbuild updates from Michal Marek:
"This is the non-critical part of kbuild:
- Coccinelle fixes, one semantic patch less in this round [Vaishali
Thakkar, Wolfram Sang, Kees Cook]
- rpm-pkg support for (open)SUSE's update-bootloader [Jiří Kosian]
- rpm-pkg restored support for $RPMOPTS [Srinivas Pandruvada]
- deb-pkg fixes for the linux-headers package [Bjørn Mork, Azriel
Samson]"
* 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
coccicheck: Fix missing 0 index in kill loop
scripts/package/Makefile: rpmbuild add support of RPMOPTS
builddeb: fix missing headers in linux-headers package
builddeb: include objtool binary in headers package
kbuild/mkspec: support 'update-bootloader'-based systems
scripts: coccinelle: remove check to move constants to right
Coccinelle: setup_timer: Add space in front of parentheses
The header mentions this check depends on personal taste. I agree.
Running coccicheck on patches before I apply them, this SmPL produced
enough false positives for me that I'd rather see it removed.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Add space in front of the offending parentheses to silent the
parse error for older Coccinelle versions. This makes the rule
usable with all Coccinelle versions.
Reported-by: Nishanth Menon <nm@ti.com>
Fixes: c5eda8fd10c6 ("Coccinelle: Add api/setup_timer.cocci")
In order to protect against file removal races, debugfs files created via
debugfs_create_file() now get wrapped by a struct file_operations at their
opening.
If the original struct file_operations are known to be safe against removal
races by themselves already, the proxy creation may be bypassed by creating
the files through debugfs_create_file_unsafe().
In order to help debugfs users who use the common
DEFINE_SIMPLE_ATTRIBUTE() + debugfs_create_file()
idiom to transition to removal safe struct file_operations, the helper
macro DEFINE_DEBUGFS_ATTRIBUTE() has been introduced.
Thus, the preferred strategy is to use
DEFINE_DEBUGFS_ATTRIBUTE() + debugfs_create_file_unsafe()
now.
Introduce a Coccinelle script that searches for
DEFINE_SIMPLE_ATTRIBUTE()-defined struct file_operations handed into
debugfs_create_file(). Suggest to turn these usages into the
pattern.
Signed-off-by: Nicolai Stange <nicstange@gmail.com>
Acked-by: Julia Lawall <Julia.Lawall@lip6.fr>
Use the timer API function setup_timer instead of structure field
assignments to initialize a timer.
Rule r is only use in org or report mode, so only execute it in those
cases.
Rule r is only used in org or report mode, so only execute it in those
cases.
cases.
cases.
& is no longer allowed in column 0, since Coccinelle 1.0.4.
Tested-by: Nishanth Menon <nm@ti.com>
Cc: stable@vger.kernel.org
Unsigned expressions cannot be lesser than zero. Presence of comparisons
'unsigned (<|<=|>|>=) 0' often indicates a bug, usually wrong type of variable.
The patch beside finding such comparisons tries to eliminate false positives,
mainly by bypassing range checks.
gcc can detect such comparisons also using -Wtype-limits switch, but it warns
also in correct cases, making too much noise.
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
Extend checking on tables containing structures which are initialized
without specifying member name. Added new tables for checking:
i2c_device_id and platform_device_id.
Signed-off-by: Daniel Granat <d.granat@samsung.com>
Extend ifnullfree to the various destroy functions that were recently
extended to tolerate NULL arguments.
Adjust tests to compare against NULL, to match cases that explicitly make
that comparison.
Remove removal and re-addition of freeing functions.
Add position variable on usb_free_urb in the non-patch case.
Device node iterators perform an of_node_put on each iteration, so putting
an of_node_put before a continue results in a double put.
Fix a couple spelling mistakes.
This effectively reverts 932058a5d5f9 ("coccinelle: misc: semantic patch
to delete overly complex return code processing").
There can be both symmetry and readability reasons for not wanting to do
the final function call as part of the return statement and to maintain
a clear separation of success and error paths.
Since this is in no way mandated by the coding standard, let's just
remove this semantic patch to avoid having "clean up" patches being
posted over and over in response to these Coccinelle warnings.
Signed-off-by: Johan Hovold <johan@kernel.org>
The original version only considered the case where the then branch
contains only one call to PTR_ERR. Reimplement the whole thing to allow
multiple calls, with potentially different arguments.
Move constants to the right in binary operators.
Merge second patch-bomb from Andrew Morton:
"Almost all of the rest of MM. There was an unusually large amount of
MM material this time"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (141 commits)
zpool: remove no-op module init/exit
mm: zbud: constify the zbud_ops
mm: zpool: constify the zpool_ops
mm: swap: zswap: maybe_preload & refactoring
zram: unify error reporting
zsmalloc: remove null check from destroy_handle_cache()
zsmalloc: do not take class lock in zs_shrinker_count()
zsmalloc: use class->pages_per_zspage
zsmalloc: consider ZS_ALMOST_FULL as migrate source
zsmalloc: partial page ordering within a fullness_list
zsmalloc: use shrinker to trigger auto-compaction
zsmalloc: account the number of compacted pages
zsmalloc/zram: introduce zs_pool_stats api
zsmalloc: cosmetic compaction code adjustments
zsmalloc: introduce zs_can_compact() function
zsmalloc: always keep per-class stats
zsmalloc: drop unused variable `nr_to_migrate'
mm/memblock.c: fix comment in __next_mem_range()
mm/page_alloc.c: fix type information of memoryless node
memory-hotplug: fix comments in zone_spanned_pages_in_node() and zone_spanned_pages_in_node()
add [pci|dma]_pool_zalloc coccinelle check.
replaces instances of [pci|dma]_pool_alloc() followed by memset(0)
with [pci|dma]_pool_zalloc().
Signed-off-by: Sean O. Stalley <sean.stalley@intel.com>
Cc: Vinod Koul <vinod.koul@intel.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Gilles Muller <Gilles.Muller@lip6.fr>
Cc: Nicolas Palix <nicolas.palix@imag.fr>
Cc: Michal Marek <mmarek@suse.cz>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
i2c_add_driver (through i2c_register_driver) sets the owner field so we
can drop it also from i2c drivers, just like from platform drivers.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Insert a blank line in order to improve the readability of the
generated patch and also make it consistent with the other
.cocci files.
Improve the commit log of the generated patch by mentioning the commit
log that makes threaded IRQs without a primary handler to be requested
with the IRQF_ONESHOT flag.
Acked- by: Valentin Rothberg <valentinrothberg@gmail.com>
This semantic patch replaces explicit computations of vma page count
with explicit function call.
Signed-off-by: Dmitry Kalinkin <dmitry.kalinkin@gmail.com>
Correct form is 'always requested'.
According to Documentation/SubmittingPatches:
"Describe your changes in imperative mood, e.g. "make xyzzy do frotz"
instead of "[This patch] makes xyzzy do frotz" or "[I] changed xyzzy
to do frotz", as if you are giving orders to the codebase to change
its behaviour.
So do as recommended.
its behaviour."
Make the sentence sensible.
its behaviour."
.cocci files.
