[ Upstream commit 31013836a71e07751a6827f9d2ad41ef502ddaff ]
The basepath may contain special characters, which would confuse the regex
matcher. ${var#prefix} does the right thing.
Link: http://lkml.kernel.org/r/20190518055946.181563-1-drinkcat@chromium.org
Fixes: 67a28de47faa8358 ("scripts/decode_stacktrace: only strip base path when a prefix of the path")
Signed-off-by: Nicolas Boichat <drinkcat@chromium.org>
Reviewed-by: Stephen Boyd <swboyd@chromium.org>
[ Upstream commit c04e32e911653442fc834be6e92e072aeebe01a1 ]
At least for ARM64 kernels compiled with the crosstoolchain from
Debian/stretch or with the toolchain from kernel.org the line number is
not decoded correctly by 'decode_stacktrace.sh':
$ echo "[ 136.513051] f1+0x0/0xc [kcrash]" | \
CROSS_COMPILE=/opt/gcc-8.1.0-nolibc/aarch64-linux/bin/aarch64-linux- \
./scripts/decode_stacktrace.sh /scratch/linux-arm64/vmlinux \
/scratch/linux-arm64 \
/nfs/debian/lib/modules/4.20.0-devel
[ 136.513051] f1 (/linux/drivers/staging/kcrash/kcrash.c:68) kcrash
If addr2line from the toolchain is used the decoded line number is correct:
[ 136.513051] f1 (/linux/drivers/staging/kcrash/kcrash.c:57) kcrash
Link: http://lkml.kernel.org/r/20190527083425.3763-1-manut@linutronix.de
Signed-off-by: Manuel Traut <manut@linutronix.de>
Acked-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
[ Upstream commit 67a28de47faa83585dd644bd4c31e5a1d9346c50 ]
Running something like:
decodecode vmlinux .
leads to interested results where not only the leading "." gets stripped
from the displayed paths, but also anywhere in the string, displaying
something like:
kvm_vcpu_check_block (arch/arm64/kvm/virt/kvm/kvm_mainc:2141)
which doesn't help further processing.
Fix it by only stripping the base path if it is a prefix of the path.
Link: http://lkml.kernel.org/r/20181210174659.31054-3-marc.zyngier@arm.com
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Kirill reported that the decode_stacktrace.sh script was broken by the
following commit:
bb5e5ce545f2 ("x86/dumpstack: Remove kernel text addresses from stack dump")
Fix it by updating the per-line absolute address check to also check for
function-based address lines like the following:
write_sysrq_trigger+0x51/0x60
I didn't remove the check for absolute addresses because it's still
needed for ARM.
Reported-by: Kirill A. Shutemov <kirill@shutemov.name>
Tested-by: Kirill A. Shutemov <kirill@shutemov.name>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Sasha Levin <alexander.levin@verizon.com>
Fixes: bb5e5ce545f2 ("x86/dumpstack: Remove kernel text addresses from stack dump")
Link: http://lkml.kernel.org/r/20161128230635.4n2ofgawltgexgcg@treble
scripts/decode_stacktrace.sh presently displays module symbols as
func+0x0ff/0x5153 [module]
Add a third argument: the pathname of a directory where the script
should look for the file module.ko so that the output appears as
func (foo/bar.c:123) module
Without the argument or if the module file isn't found the script prints
such symbols as is without decoding.
Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
Fix the stack decoder for the ARM architecture.
An ARM stack is designed as :
[ 81.547704] [<c023eb04>] (bucket_find_contain) from [<c023ec88>] (check_sync+0x40/0x4f8)
[ 81.559668] [<c023ec88>] (check_sync) from [<c023f8c4>] (debug_dma_sync_sg_for_cpu+0x128/0x194)
[ 81.571583] [<c023f8c4>] (debug_dma_sync_sg_for_cpu) from [<c0327dec>] (__videobuf_s
The current script doesn't expect the symbols to be bound by
parenthesis, and triggers the following errors :
awk: cmd. line:1: error: Unmatched ( or \(: / (check_sync$/
[ 81.547704] (bucket_find_contain) from (check_sync+0x40/0x4f8)
Fix it by chopping starting and ending parenthesis from the each symbol
name.
As a side note, this probably comes from the function
dump_backtrace_entry(), which is implemented differently for each
architecture. That makes a single decoding script a bit a challenge.
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Michal Marek <mmarek@suse.cz>
Right now when people try to report issues in the kernel they send stack
dumps to eachother, which looks something like this:
[ 6.906437] [<ffffffff811f0e90>] ? backtrace_test_irq_callback+0x20/0x20
[ 6.907121] [<ffffffff84388ce8>] dump_stack+0x52/0x7f
[ 6.907640] [<ffffffff811f0ec8>] backtrace_regression_test+0x38/0x110
[ 6.908281] [<ffffffff813596a0>] ? proc_create_data+0xa0/0xd0
[ 6.908870] [<ffffffff870a8040>] ? proc_modules_init+0x22/0x22
[ 6.909480] [<ffffffff810020c2>] do_one_initcall+0xc2/0x1e0
However, most of the text you get is pure garbage.
The only useful thing above is the function name. Due to the amount of
different kernel code versions and various configurations being used,
the kernel address and the offset into the function are not really
helpful in determining where the problem actually occured.
Too often the result of someone looking at a stack dump is asking the
person who sent it for a translation for one or more 'addr2line'
translations. Which slows down the entire process of debugging the
issue (and really annoying).
The decode_stacktrace script is an attempt to make the output more
useful and easy to work with by translating all kernel addresses in the
stack dump into line numbers. Which means that the stack dump would
look like this:
[ 635.148361] dump_stack (lib/dump_stack.c:52)
[ 635.149127] warn_slowpath_common (kernel/panic.c:418)
[ 635.150214] warn_slowpath_null (kernel/panic.c:453)
[ 635.151031] _oalloc_pages_slowpath+0x6a/0x7d0
[ 635.152171] ? zone_watermark_ok (mm/page_alloc.c:1728)
[ 635.152988] ? get_page_from_freelist (mm/page_alloc.c:1939)
[ 635.154766] __alloc_pages_nodemask (mm/page_alloc.c:2766)
It's pretty obvious why this is better than the previous stack dump
before.
Usage is pretty simple:
./decode_stacktrace.sh [vmlinux] [base path]
Where vmlinux is the vmlinux to extract line numbers from and base path
is the path that points to the root of the build tree, for example:
./decode_stacktrace.sh vmlinux /home/sasha/linux/ < input.log > output.log
The stack trace should be piped through it (I, for example, just pipe
the output of the serial console of my KVM test box through it).
