commit 914b087ff9e0e9a399a4927fa30793064afc0178 upstream.
When $DEPMOD is not found, only print a warning instead of exiting
with an error message and error status:
Warning: 'make modules_install' requires /sbin/depmod. Please install it.
This is probably in the kmod package.
Change the Error to a Warning because "not all build hosts for cross
compiling Linux are Linux systems and are able to provide a working
port of depmod, especially at the file patch /sbin/depmod."
I.e., "make modules_install" may be used to copy/install the
loadable modules files to a target directory on a build system and
then transferred to an embedded device where /sbin/depmod is run
instead of it being run on the build system.
Fixes: 934193a654c1 ("kbuild: verify that $DEPMOD is installed")
Reported-by: H. Nikolaus Schaller <hns@goldelico.com>
Cc: stable@vger.kernel.org
Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi>
Cc: Lucas De Marchi <lucas.de.marchi@gmail.com>
Cc: Michal Marek <michal.lkml@markovi.net>
Cc: Jessica Yu <jeyu@kernel.org>
Cc: Chih-Wei Huang <cwhuang@linux.org.tw>
Signed-off-by: Maxim Zhukov <mussitantesmortem@gmail.com>
commit 934193a654c1f4d0643ddbf4b2529b508cae926e upstream.
Verify that 'depmod' ($DEPMOD) is installed.
This is a partial revert of commit 620c231c7a7f
("kbuild: do not check for ancient modutils tools").
Also update Documentation/process/changes.rst to refer to
kmod instead of module-init-tools.
Fixes kernel bugzilla #198965:
https://bugzilla.kernel.org/show_bug.cgi?id=198965
Cc: stable@vger.kernel.org # any kernel since 2012
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
On architectures which have symbol prefixes, depmod emits lots of
warnings like this:
WARNING: $module.ko needs unknown symbol $symbol
This is because depmod isn't being passed the -P <symbol_prefix>
arguments to specify the symbol prefix to ignore. This option is
included since the 3.13 release of module-init-tools.
Update scripts/depmod.sh to take extra arguments for the symbol prefix
(required but may be empty), and update the main Makefile to always pass
"$(CONFIG_SYMBOL_PREFIX)" to scripts/depmod.sh.
If the provided symbol prefix is non-empty, scripts/depmod.sh checks if
depmod --version reports module-init-tools with a version number < 3.13
otherwise it appends -P $SYMBOL_PREFIX to the depmod command line.
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: Michal Marek <mmarek@suse.cz>
Cc: linux-kbuild@vger.kernel.org
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: uclinux-dist-devel@blackfin.uclinux.org
scripts/depmod.sh checks for the output of '-V' expecting that it has
module-init-tools in it. It's a hack to prevent users from using
modutils instead of module-init-tools, that only works with 2.4.x
kernels. This however prints an annoying warning for kmod tool, that is
currently replacing module-init-tools.
Rather than putting another check for kmod's version, just remove it
since users of 2.4.x kernel are unlikely to upgrade to 3.x, and if they
do, let depmod fail in that case because they should know what they are
doing.
Acked-by: WANG Cong <amwang@redhat.com>
Acked-By: Kay Sievers <kay.sievers@vrfy.org>
Let depmod.sh create a temporary directory in /tmp instead of writing to
the build directory as root. The mktemp utility should be available on
any recent system (and there is already scripts/gen_initramfs_list.sh
relying on it).
Reported-by: Christian Kujau <lists@nerdbynature.de>
depmod from module-init-tools < 3.13 and the busybox depmod check if the
kernel release starts with <num>.<num>.<num>. To support these versions,
we create a symlink with two numbers prepended.
Do not bloat the Makefile with multiline shell statements. No
user-visible change intended.
