path: root/scripts/docproc.c
2016-05-14docproc: print a comment about autogeneration for rst outputJani Nikula
Leave a hint to folks which file to edit instead. Signed-off-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-05-14docproc: add support for reStructuredText format via --rst optionJani Nikula
Expect reStructuredText input and have kernel-doc produce reStructuredText output with the new --rst option. Also add --docbook option for completeness. If no option is given, default to reStructuredText if the input file has ".rst" extension, DocBook otherwise. Directives for reStructuredText use .. ! instead of just !, to make them reStructuredText comments. Signed-off-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-05-14docproc: abstract terminating lines at first spaceJani Nikula
Cleaner code. Also fixes a bug when F or P directives didn't in fact have space. Signed-off-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-05-14docproc: abstract docproc directive detectionJani Nikula
Helps follow-up work. No functional changes. Signed-off-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-05-14docproc: reduce unnecessary indentationJani Nikula
Improves clarity. No functional changes. Signed-off-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-05-14docproc: add variables for subcommand and filenameJani Nikula
2014-06-10kbuild: trivial - use tabs for code indent where possibleMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-11-13kernel-doc: improve "no structured comments found" errorJohannes Berg
When using '!Ffile function' in a docbook template, and the function no longer exists, you get a "no structured comments found" error from the kernel-doc processing script. It's useful to know which functions it was looking for, so print them out in this case. Also do the same for '!Pfile doc-section' The same error also happens when using '!Efile' when some exported functions aren't documented (in the same file.) There's a very large number of such functions though, so don't print the message in this case -- right now it would give ~850 messages. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Cc: Rob Landley <rob@landley.net> Cc: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-16docproc: cleanup brace placementJesper Juhl
The placement of the opening brace "{" after 'if' statements in scripts/docproc.c is inconsistent. Most are placed on the same line as the 'if' statement itself as per CodingStyle, but a few are not. This patch cleans up the inconsistency. We save a few source lines and the file then uses the same style throughout, which is nice. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-02kbuild: move scripts/basic/docproc.c to scripts/docproc.cPeter Foley
Move docproc from scripts/basic to scripts so it is only built for *doc targets instead of every time the kernel is built.
