path: root/scripts/dtc
2012-10-17dtc: fix for_each_*() to skip first object if deletedStephen Warren
The previous definition of for_each_*() would always include the very first object within the list, irrespective of whether it was marked deleted, since the deleted flag was not checked on the first object, but only on any "next" object. Fix for_each_*() to check the deleted flag in the loop body every iteration to correct this. (upstream dtc commit 1762ab42ef77db7ab2776d0d6cba3515150f518a) Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-10-01dtc: import latest upstream dtcStephen Warren
This updates scripts/dtc to commit 317a5d9 "dtc: zero out new label objects" from git://git.jdl.com/software/dtc.git. This adds features such as: * /bits/ syntax for cell data. * Math expressions within cell data. * The ability to delete properties or nodes. * Support for #line directives in the input file, which allows the use of cpp on *.dts. * -i command-line option (/include/ path) * -W/-E command-line options for error/warning control. * Removal of spew to STDOUT containing the filename being compiled. * Many additions to the libfdt API. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Jon Loeliger <jdl@jdl.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-03-24scripts: dtc: fix compile warningsFelipe Balbi
Fix following compile warnings: scripts/dtc/flattree.c: In function ‘flat_read_mem_reserve’: scripts/dtc/flattree.c:700:14: warning: variable ‘p’ set but not used [-Wunused-but-set-variable] scripts/dtc/dtc.c: In function ‘main’: scripts/dtc/dtc.c:104:17: warning: variable ‘check’ set but not used [-Wunused-but-set-variable] Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-01-14dtc: Implement -d option to write out a dependency fileStephen Warren
This will allow callers to rebuild .dtb files when any of the /include/d .dtsi files are modified, not just the top-level .dts file. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-06-09dtc: regen parserArnaud Lacombe
Cc: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
2011-06-09dtc: migrate parser to implicit rulesArnaud Lacombe
2011-01-03of/flattree: Update dtc to current mainline.John Bonesio
Pull in recent changes from the main dtc repository. These changes primarily allow multiple device trees to be declared which are merged by dtc. This feature allows us to include a basic dts file and then provide more information for the specific system through the merging functionality. Changes pulled from git://git.jdl.com/software/dtc.git commit id: 37c0b6a0, "dtc: Add code to make diffing trees easier" Signed-off-by: John Bonesio <bones@secretlab.ca> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-02scripts/dtc: Fix a resource leakMartin Ettl
during a check of the current git head of the linux kernel with the static code analysis tool cppcheck (http://sourceforge.net/apps/mediawiki/cppcheck/index.php?title=Main_Page) the tool discovered a resource leak in linux-2.6/scripts/dtc/fstree.c. Please refer the attached patch, that fixes the issue. Fixes https://bugzilla.kernel.org/show_bug.cgi?id=15363 Signed-off-by: Martin Ettl <ettl.martin@gmx.de> Cc: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-11-15dtc: Mark various internal functions staticJosh Triplett
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
2009-11-15dtc: Set "noinput" in the lexer to avoid an unused functionJosh Triplett
Regenerate the corresponding generated lexer. Regenerating the lexer with current flex also provides prototypes for various yy* functions, making some -Wmissing-prototypes warnings go away as well. Signed-off-by: Josh Triplett <josh@joshtriplett.org>
2009-06-26powerpc: Have git ignore generated files from dtc compileJon Smirl
Have git ignore generated files from dtc compile Signed-off-by: Jon Smirl <jonsmirl@gmail.com> Acked-by: David Gibson <david@gibson.dropbear.id.au> Acked-by: Sean MacLennan <smaclennan@pikatech.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-05-02Move dtc and libfdt sources from arch/powerpc/boot to scripts/dtcDavid Gibson
The powerpc kernel always requires an Open Firmware like device tree to supply device information. On systems without OF, this comes from a flattened device tree blob. This blob is usually generated by dtc, a tool which compiles a text description of the device tree into the flattened format used by the kernel. Sometimes, the bootwrapper makes small changes to the pre-compiled device tree blob (e.g. filling in the size of RAM). To do this it uses the libfdt library. Because these are only used on powerpc, the code for both these tools is included under arch/powerpc/boot (these were imported and are periodically updated from the upstream dtc tree). However, the microblaze architecture, currently being prepared for merging to mainline also uses dtc to produce device tree blobs. A few other archs have also mentioned some interest in using dtc. Therefore, this patch moves dtc and libfdt from arch/powerpc into scripts, where it can be used by any architecture. The vast bulk of this patch is a literal move, the rest is adjusting the various Makefiles to use dtc and libfdt correctly from their new locations. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
