commit 60f2c82ed20bde57c362e66f796cf9e0e38a6dbb upstream.
While no uses in the kernel triggered this case, it was possible to have
a false negative where a struct contains other structs which contain only
function pointers because of unreachable code in is_pure_ops_struct().
Signed-off-by: Joonwon Kang <kjw1627@gmail.com>
Link: https://lore.kernel.org/r/20190727155841.GA13586@host
Fixes: 313dd1b62921 ("gcc-plugins: Add the randstruct plugin")
Cc: stable@vger.kernel.org
commit 7210e060155b9cf557fb13128353c3e494fa5ed3 upstream.
The gcc-common.h file did not take into account certain macros that
might have already been defined in the build environment. This updates
the header to avoid redefining the macros, as seen on a Darwin host
using gcc 4.9.2:
HOSTCXX -fPIC scripts/gcc-plugins/arm_ssp_per_task_plugin.o - due to: scripts/gcc-plugins/gcc-common.h
In file included from scripts/gcc-plugins/arm_ssp_per_task_plugin.c:3:0:
scripts/gcc-plugins/gcc-common.h:153:0: warning: "__unused" redefined
In file included from /usr/include/stdio.h:64:0,
from /Users/hns/Documents/Projects/QuantumSTEP/System/Library/Frameworks/System.framework/Versions-jessie/x86_64-apple-darwin15.0.0/gcc/arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabi/4.9.2/plugin/include/system.h:40,
from /Users/hns/Documents/Projects/QuantumSTEP/System/Library/Frameworks/System.framework/Versions-jessie/x86_64-apple-darwin15.0.0/gcc/arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabi/4.9.2/plugin/include/gcc-plugin.h:28,
from /Users/hns/Documents/Projects/QuantumSTEP/System/Library/Frameworks/System.framework/Versions-jessie/x86_64-apple-darwin15.0.0/gcc/arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabi/4.9.2/plugin/include/plugin.h:23,
from scripts/gcc-plugins/gcc-common.h:9,
/usr/include/sys/cdefs.h:161:0: note: this is the location of the previous definition
Reported-and-tested-by: "H. Nikolaus Schaller" <hns@goldelico.com>
Fixes: 189af4657186 ("ARM: smp: add support for per-task stack canaries")
commit b86729109c5fd0a480300f40608aac68764b5adf upstream.
GCC 8 changed the order of some fields and is very picky about ordering
in static initializers, so instead just move to dynamic initializers,
and drop the redundant already-zero field assignments.
Suggested-by: Valdis Kletnieks <valdis.kletnieks@vt.edu>
Cc: Lance Albertson <lance@osuosl.org>
commit 80d172431696482d9acd8d2c4ea78fed8956e2a1 upstream.
GCC requires another #include to get the gcc-plugins to build cleanly.
Signed-off-by: Valdis Kletnieks <valdis.kletnieks@vt.edu>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
In the Linux kernel, struct type variables are rarely passed by-value,
and so functions that initialize such variables typically take an input
reference to the variable rather than returning a value that can
subsequently be used in an assignment.
If the initalization function is not part of the same compilation unit,
the lack of an assignment operation defeats any analysis the compiler
can perform as to whether the variable may be used before having been
initialized. This means we may end up passing on such variables
uninitialized, resulting in potential information leaks.
So extend the existing structleak GCC plugin so it will [optionally]
apply to all struct type variables that have their address taken at any
point, rather than only to variables of struct types that have a __user
annotation.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
This enables the automatic structure selection logic in the randstruct
GCC plugin. The selection logic randomizes all structures that contain
only function pointers, unless marked with __no_randomize_layout.
The NIU ethernet driver intentionally stores a page struct pointer on
top of the "mapping" field. Whitelist this case:
drivers/net/ethernet/sun/niu.c: In function ‘niu_rx_pkt_ignore’:
drivers/net/ethernet/sun/niu.c:3402:10: note: found mismatched ssa struct pointer types: ‘struct page’ and ‘struct address_space’
*link = (struct page *) page->mapping;
The big_key payload structure intentionally stores a struct path in
two void pointers to avoid header soup. Whitelist this case:
security/keys/big_key.c: In function ‘big_key_read’:
security/keys/big_key.c:293:16: note: found mismatched rhs struct pointer types: ‘struct path’ and ‘void *’
struct path *path = (struct path *)&key->payload.data[big_key_path];
This is another false positive in bad cast detection:
net/unix/af_unix.c: In function ‘unix_skb_scm_eq’:
net/unix/af_unix.c:1621:31: note: found mismatched rhs struct pointer types: ‘struct unix_skb_parms’ and ‘char’
const struct unix_skb_parms *u = &UNIXCB(skb);
UNIXCB is:
#define UNIXCB(skb) (*(struct unix_skb_parms *)&((skb)->cb))
And ->cb is:
char cb[48] __aligned(8);
This is a rather crazy cast, but appears to be safe in the face of
randomization, so whitelist it in the plugin.
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
The LSM initialization routines walk security_hook_heads as an array
of struct list_head instead of via names to avoid a ton of needless
source. Whitelist this to avoid the false positive warning from the
plugin:
security/security.c: In function ‘security_init’:
security/security.c:59:20: note: found mismatched op0 struct pointer types: ‘struct list_head’ and ‘struct security_hook_heads’
struct list_head *list = (struct list_head *) &security_hook_heads;
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: James Morris <james.l.morris@oracle.com>
This randstruct plugin is modified from Brad Spengler/PaX Team's code
in the last public patch of grsecurity/PaX based on my understanding
of the code. Changes or omissions from the original code are mine and
don't reflect the original grsecurity/PaX code.
The randstruct GCC plugin randomizes the layout of selected structures
at compile time, as a probabilistic defense against attacks that need to
know the layout of structures within the kernel. This is most useful for
"in-house" kernel builds where neither the randomization seed nor other
build artifacts are made available to an attacker. While less useful for
distribution kernels (where the randomization seed must be exposed for
third party kernel module builds), it still has some value there since now
all kernel builds would need to be tracked by an attacker.
In more performance sensitive scenarios, GCC_PLUGIN_RANDSTRUCT_PERFORMANCE
can be selected to make a best effort to restrict randomization to
cacheline-sized groups of elements, and will not randomize bitfields. This
comes at the cost of reduced randomization.
Two annotations are defined,__randomize_layout and __no_randomize_layout,
which respectively tell the plugin to either randomize or not to
randomize instances of the struct in question. Follow-on patches enable
the auto-detection logic for selecting structures for randomization
that contain only function pointers. It is disabled here to assist with
bisection.
Since any randomized structs must be initialized using designated
initializers, __randomize_layout includes the __designated_init annotation
even when the plugin is disabled so that all builds will require
the needed initialization. (With the plugin enabled, annotations for
automatically chosen structures are marked as well.)
The main differences between this implemenation and grsecurity are:
- disable automatic struct selection (to be enabled in follow-up patch)
- add designated_init attribute at runtime and for manual marking
- clarify debugging output to differentiate bad cast warnings
- add whitelisting infrastructure
- support gcc 7's DECL_ALIGN and DECL_MODE changes (Laura Abbott)
- raise minimum required GCC version to 4.7
Earlier versions of this patch series were ported by Michael Leibowitz.
The c-common.h file moved in stock gcc 4.7, not gcc 4.6. However, most
people building plugins with gcc 4.6 are using the Debian or Ubuntu
version, which includes a patch to move the headers to the 4.7 location.
In case anyone trips over this with a stock gcc 4.6, add a pointer to the
patch used by Debian/Ubuntu.
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux
Pull gcc-plugins fix from Kees Cook:
"Fixes a typo in sancov plugin, exposed in earlier compiler versions"
* tag 'gcc-plugins-v4.11-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux:
gcc-plugins: fix sancov_plugin for gcc-5
The name of the local variable was inadvertantly changed from
sancov_plugin_pass_info to sancov_pass_info:
scripts/gcc-plugins/sancov_plugin.c: In function ‘int plugin_init(plugin_name_args*, plugin_gcc_version*)’:
scripts/gcc-plugins/sancov_plugin.c:136:67: error: ‘sancov_plugin_pass_info’ was not declared in this scope
This changes the conditional reference to this variable as well.
Fixes: 5a45a4c5c3f5 ("gcc-plugins: consolidate on PASS_INFO macro")
This plugin detects any structures that contain __user attributes and
makes sure it is being fully initialized so that a specific class of
information exposure is eliminated. (This plugin was originally designed
to block the exposure of siginfo in CVE-2013-2141.)
Ported from grsecurity/PaX. This version adds a verbose option to the
plugin and the Kconfig.
Now that PASS_INFO() exists, use it in the other existing gcc plugins,
instead of always open coding the same thing.
Based on updates to the grsecurity/PaX gcc plugins.
This updates the GCC plugins gcc-common.h from PaX Team to include
more helpers and header files, specifically adds the PASS_INFO()
macro to make plugin declarations nicer and a helper for proper
const string building.
This updates gcc-common.h from Emese Revfy for gcc 7. This fixes issues seen
by Kugan and Arnd. Build tested with gcc 5.4 and 7 snapshot.
This fixes build errors seen on gcc-4.9.3 or gcc-5.3.1 for an ARM:
arm-soc/init/initramfs.c: In function 'error':
arm-soc/init/initramfs.c:50:1: error: unrecognizable insn:
(insn 26 25 27 5 (set (reg:SI 111 [ local_entropy.243 ])
(rotatert:SI (reg:SI 116 [ local_entropy.243 ])
(const_int -30 [0xffffffffffffffe2]))) -1
(nil))
Patch from PaX Team <pageexec@freemail.hu>
Reported-by: Brad Spengler <spender@grsecurity.net>
This patch fix spelling typos in printk and kconfig.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
The stack frame size could grow too large when the plugin used long long
on 32-bit architectures when the given function had too many basic blocks.
The gcc warning was:
drivers/pci/hotplug/ibmphp_ebda.c: In function 'ibmphp_access_ebda':
drivers/pci/hotplug/ibmphp_ebda.c:409:1: warning: the frame size of 1108 bytes is larger than 1024 bytes [-Wframe-larger-than=]
This switches latent_entropy from u64 to unsigned long.
Thanks to PaX Team and Emese Revfy for the patch.
This explicitly exports symbols that gcc expects from plugins.
Based on code from Emese Revfy.
This adds a new gcc plugin named "latent_entropy". It is designed to
extract as much possible uncertainty from a running system at boot time as
possible, hoping to capitalize on any possible variation in CPU operation
(due to runtime data differences, hardware differences, SMP ordering,
thermal timing variation, cache behavior, etc).
At the very least, this plugin is a much more comprehensive example for
how to manipulate kernel code using the gcc plugin internals.
The need for very-early boot entropy tends to be very architecture or
system design specific, so this plugin is more suited for those sorts
of special cases. The existing kernel RNG already attempts to extract
entropy from reliable runtime variation, but this plugin takes the idea to
a logical extreme by permuting a global variable based on any variation
in code execution (e.g. a different value (and permutation function)
is used to permute the global based on loop count, case statement,
if/then/else branching, etc).
To do this, the plugin starts by inserting a local variable in every
marked function. The plugin then adds logic so that the value of this
variable is modified by randomly chosen operations (add, xor and rol) and
random values (gcc generates separate static values for each location at
compile time and also injects the stack pointer at runtime). The resulting
value depends on the control flow path (e.g., loops and branches taken).
Before the function returns, the plugin mixes this local variable into
the latent_entropy global variable. The value of this global variable
is added to the kernel entropy pool in do_one_initcall() and _do_fork(),
though it does not credit any bytes of entropy to the pool; the contents
of the global are just used to mix the pool.
Additionally, the plugin can pre-initialize arrays with build-time
random contents, so that two different kernel builds running on identical
hardware will not have the same starting values.
Signed-off-by: Emese Revfy <re.emese@gmail.com>
[kees: expanded commit message and code comments]
This adds support for building more complex gcc plugins that live in a
subdirectory instead of just in a single source file.
Reported-by: PaX Team <pageexec@freemail.hu>
[kees: clarified commit message]
There's no reason to repeat the same names in the Makefile when the .so
files have already been listed. The .o list can be generated from them.
The sancov gcc plugin inserts a __sanitizer_cov_trace_pc() call
at the start of basic blocks.
This plugin is a helper plugin for the kcov feature. It supports
all gcc versions with plugin support (from gcc-4.5 on).
It is based on the gcc commit "Add fuzzing coverage support" by Dmitry Vyukov
(https://gcc.gnu.org/viewcvs/gcc?limit_changes=0&view=revision&revision=231296).
Signed-off-by: Michal Marek <mmarek@suse.com>
Add a very simple plugin to demonstrate the GCC plugin infrastructure. This GCC
plugin computes the cyclomatic complexity of each function.
The complexity M of a function's control flow graph is defined as:
M = E - N + 2P
where
E = the number of edges
N = the number of nodes
P = the number of connected components (exit nodes).
This patch allows to build the whole kernel with GCC plugins. It was ported from
grsecurity/PaX. The infrastructure supports building out-of-tree modules and
building in a separate directory. Cross-compilation is supported too.
Currently the x86, arm, arm64 and uml architectures enable plugins.
The directory of the gcc plugins is scripts/gcc-plugins. You can use a file or a directory
there. The plugins compile with these options:
* -fno-rtti: gcc is compiled with this option so the plugins must use it too
* -fno-exceptions: this is inherited from gcc too
* -fasynchronous-unwind-tables: this is inherited from gcc too
* -ggdb: it is useful for debugging a plugin (better backtrace on internal
errors)
* -Wno-narrowing: to suppress warnings from gcc headers (ipa-utils.h)
* -Wno-unused-variable: to suppress warnings from gcc headers (gcc_version
variable, plugin-version.h)
The infrastructure introduces a new Makefile target called gcc-plugins. It
supports all gcc versions from 4.5 to 6.0. The scripts/gcc-plugin.sh script
chooses the proper host compiler (gcc-4.7 can be built by either gcc or g++).
This script also checks the availability of the included headers in
scripts/gcc-plugins/gcc-common.h.
The gcc-common.h header contains frequently included headers for GCC plugins
and it has a compatibility layer for the supported gcc versions.
The gcc-generate-*-pass.h headers automatically generate the registration
structures for GIMPLE, SIMPLE_IPA, IPA and RTL passes.
Note that 'make clean' keeps the *.so files (only the distclean or mrproper
targets clean all) because they are needed for out-of-tree modules.
Based on work created by the PaX Team.
