path: root/scripts/gcc-version.sh
2012-10-03kbuild: Fix gcc -x syntaxJean Delvare
The correct syntax for gcc -x is "gcc -x assembler", not "gcc -xassembler". Even though the latter happens to work, the former is what is documented in the manual page and thus what gcc wrappers such as icecream do expect. This isn't a cosmetic change. The missing space prevents icecream from recognizing compilation tasks it can't handle, leading to silent kernel miscompilations. Besides me, credits go to Michael Matz and Dirk Mueller for investigating the miscompilation issue and tracking it down to this incorrect -x parameter syntax. Signed-off-by: Jean Delvare <jdelvare@suse.de> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: stable@vger.kernel.org Cc: Bernhard Walle <bernhard@bwalle.de> Cc: Michal Marek <mmarek@suse.cz> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-06-09Remove bashisms from scriptsdann frazier
The '-e' option to echo and brace expansion are not guaranteed to be supported by a POSIX-compliant /bin/sh (e.g. dash) Signed-off-by: dann frazier <dannf@debian.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: fix buglet in gcc-version.shSam Ravnborg
Greg Schafer <gschafer@zip.com.au> reported: ==== $make mrproper scripts/gcc-version.sh: [[: command not found This is on a very old host with an ancient bash as /bin/sh. But I have CONFIG_SHELL set and pointing to a modern bash. Something is wrong. This doesn't happen with 2.6.23 ==== Fixed using a more common string equality test. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Greg Schafer <gschafer@zip.com.au> Cc: Jesper Juhl <jesper.juhl@gmail.com>
2007-10-12kbuild: improve scripts/gcc-version.sh output a bit when called without argsJesper Juhl
Currently, if you call scripts/gcc-version.sh without arguments it will generate this output : $ sh scripts/gcc-version.sh scripts/gcc-version.sh: line 12: [: =: unary operator expected scripts/gcc-version.sh: line 16: -E: command not found scripts/gcc-version.sh: line 17: -E: command not found 0000 Not too pretty. I believe this is an improvement : $ sh scripts/gcc-version.sh Error: No compiler specified. Usage: scripts/gcc-version.sh <gcc-command> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-16kbuild: New 'cc-fullversion' macroSegher Boessenkool
Prints a six-digit string including the GCC patchlevel. Also fix the 'usage' comment for cc-version. Signed-off-by: Segher Boessenkool <segher@kernel.crashing.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
