commit 883d50f56d263f70fd73c0d96b09eb36c34e9305 upstream.
Since kernel 4.9, the thread_info has been moved into task_struct, no
longer locates at the bottom of kernel stack.
See commits c65eacbe290b ("sched/core: Allow putting thread_info into
task_struct") and 15f4eae70d36 ("x86: Move thread_info into
task_struct").
Before fix:
(gdb) set $current = $lx_current()
(gdb) p $lx_thread_info($current)
$1 = {flags = 1470918301}
(gdb) p $current.thread_info
$2 = {flags = 2147483648}
After fix:
$1 = {flags = 2147483648}
Link: http://lkml.kernel.org/r/20180118210159.17223-1-imxikangjie@gmail.com
Fixes: 15f4eae70d36 ("x86: Move thread_info into task_struct")
Signed-off-by: Xi Kangjie <imxikangjie@gmail.com>
Acked-by: Jan Kiszka <jan.kiszka@siemens.com>
Acked-by: Kieran Bingham <kbingham@kernel.org>
This reverts commit e127a73d41ac ("scripts/gdb: add a Radix Tree
Parser")
The python implementation of radix-tree was merged at the same time as
the radix-tree system was heavily reworked from commit e9256efcc8e3
("radix-tree: introduce radix_tree_empty") to 3bcadd6fa6c4 ("radix-tree:
free up the bottom bit of exceptional entries for reuse") and no longer
functions, but also prevents other gdb scripts from loading.
This functionality has not yet hit a release, so simply remove it for
now
Link: http://lkml.kernel.org/r/1467127337-11135-6-git-send-email-kieran@bingham.xyz
Signed-off-by: Kieran Bingham <kieran@bingham.xyz>
Python doesn't do automatic expansion of paths. In case one passes path
of the from ~/foo/bar the gdb scripts won't automatically expand that
and as a result the symbols files won't be loaded.
Fix this by explicitly expanding all paths which begin with "~"
Link: http://lkml.kernel.org/r/1467127337-11135-5-git-send-email-kieran@bingham.xyz
Signed-off-by: Nikolay Borisov <n.borisov.lkml@gmail.com>
Reviewed-by: Jan Kiszka <jan.kiszka@siemens.com>
Since scripts/gdb/linux/constants.py is autogenerated, this should have
been added to .gitignore when it was introduced.
Fixes: f197d75fcad1 ("scripts/gdb: provide linux constants")
Link: http://lkml.kernel.org/r/1467127337-11135-4-git-send-email-kieran@bingham.xyz
Signed-off-by: Omar Sandoval <osandov@fb.com>
The autogenerated constants.py file was only being built on the initial
call, and if the constants.py.in file changed. As we are utilising the
CPP hooks, we can successfully use the call if_changed_dep rules to
determine when to rebuild the file based on it's inclusions.
Link: http://lkml.kernel.org/r/1467127337-11135-3-git-send-email-kieran@bingham.xyz
Reported-by: Jan Kiszka <jan.kiszka@web.de>
The constants.py generation, involves a rule to link into the main
makefile. This rule has no command and generates a spurious warning
message in the build logs when CONFIG_SCRIPTS_GDB is enabled.
Fix simply by giving a no-op action
Link: http://lkml.kernel.org/r/1467127337-11135-2-git-send-email-kieran@bingham.xyz
Reported-by: Jan Kiszka <jan.kiszka@siemens.com>
The recent fixes to lx-dmesg, now allow the command to print
successfully on Python3, however the python interpreter wraps the bytes
for each line with a b'<text>' marker.
To remove this, we need to decode the line, where .decode() will default
to 'UTF-8'
Link: http://lkml.kernel.org/r/d67ccf93f2479c94cb3399262b9b796e0dbefcf2.1462865983.git.jan.kiszka@siemens.com
Acked-by: Dom Cote <buzdelabuz2@gmail.com>
Tested-by: Dom Cote <buzdelabuz2@gmail.com>
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
When built against Python 3, GDB differs in the return type for its
read_memory function, causing the lx-dmesg command to fail.
Now that we have an improved read_16() we can use the new
read_memoryview() abstraction to make lx-dmesg return valid data on both
current Python APIs
Tested with python 3.4 and 2.7
Tested with gdb 7.7
Link: http://lkml.kernel.org/r/28477b727ff7fe3101fd4e426060e8a68317a639.1462865983.git.jan.kiszka@siemens.com
Signed-off-by: Dom Cote <buzdelabuz2+git@gmail.com>
[kieran@bingham.xyz: Adjusted commit log to better reflect code changes]
Tested-by: Kieran Bingham <kieran@bingham.xyz> (Py2.7,Py3.4,GDB10)
Change the read_u16 function so it accepts both 'str' and 'byte' as type
for the arguments.
When calling read_memory() from gdb API, depending on if it was built
with 2.7 or 3.X, the format used to return the data will differ ( 'str'
for 2.7, and 'byte' for 3.X ).
Add a function read_memoryview() to be able to get a 'memoryview' object
back from read_memory() both with python 2.7 and 3.X .
Tested with gdb 7.7
Link: http://lkml.kernel.org/r/73621f564503137a002a639d174e4fb35f73f462.1462865983.git.jan.kiszka@siemens.com
The tasks module already provides helpers to find the task struct by
pid, and the thread_info by task struct; however this is cumbersome to
utilise on the gdb commandline.
Wrap these two functionalities together in an extra single helper to
allow exploring the thread info, from a PID value
Link: http://lkml.kernel.org/r/dadc5667f053ec811eb3e3033d99d937fedbc93b.1462865983.git.jan.kiszka@siemens.com
Signed-off-by: Kieran Bingham <kieran.bingham@linaro.org>
Linux makes use of the Radix Tree data structure to store pointers
indexed by integer values. This structure is utilised across many
structures in the kernel including the IRQ descriptor tables, and
several filesystems.
This module provides a method to lookup values from a structure given
its head node.
Usage:
The function lx_radix_tree_lookup, must be given a symbol of type struct
radix_tree_root, and an index into that tree.
The object returned is a generic integer value, and must be cast
correctly to the type based on the storage in the data structure.
For example, to print the irq descriptor in the sparse irq_desc_tree at
index 18, try the following:
(gdb) print (struct irq_desc)$lx_radix_tree_lookup(irq_desc_tree, 18)
Link: http://lkml.kernel.org/r/d2028c55e50cf95a9b7f8ca0d11885174b0cc709.1462865983.git.jan.kiszka@siemens.com
We won't see more than 2 billion CPUs any time soon, and having cpu_list
return long makes the output of lx-cpus a bit ugly.
Link: http://lkml.kernel.org/r/dcb45c3b0a59e0fd321fa56ff7aa398458c689b3.1462865983.git.jan.kiszka@siemens.com
The linux kernel provides macro's for iterating against values from the
cpu_list masks. By providing some commonly used masks, we can mirror
the kernels helper macros with easy to use generators.
Link: http://lkml.kernel.org/r/d045c6599771ada1999d49612ee30fd2f9acf17f.1462865983.git.jan.kiszka@siemens.com
lx-mounts will identify current mount points based on the 'init_task'
namespace by default, as we do not yet have a kernel thread list
implementation to select the current running thread.
Optionally, a user can specify a PID to list from that process'
namespace
Link: http://lkml.kernel.org/r/e614c7bc32d2350b4ff1627ec761a7148e65bfe6.1462865983.git.jan.kiszka@siemens.com
Provide iomem_resource and ioports_resource printers and command hooks
It can be quite interesting to halt the kernel as it's booting and check
to see this list as it is being populated.
It should be useful in the event that a kernel is not booting, you can
identify what memory resources have been registered
Link: http://lkml.kernel.org/r/f0a6b9fa9c92af4d7ed2e7343ccc84150e9c6fc5.1462865983.git.jan.kiszka@siemens.com
Walk the VFS entries, pre-pending the iname strings to generate a full
VFS path name from a dentry.
Link: http://lkml.kernel.org/r/4328fdb2d15ba7f1b21ad21c2eecc38d9cfc4d13.1462865983.git.jan.kiszka@siemens.com
If CONFIG_MODULES is not enabled, lx-lsmod tries to find a non-existent
symbol and generates an unfriendly traceback:
(gdb) lx-lsmod
Address Module Size Used by
Traceback (most recent call last):
File "scripts/gdb/linux/modules.py", line 75, in invoke
for module in module_list():
File "scripts/gdb/linux/modules.py", line 24, in module_list
module_ptr_type = module_type.get_type().pointer()
File "scripts/gdb/linux/utils.py", line 28, in get_type
self._type = gdb.lookup_type(self._name)
gdb.error: No struct type named module.
Error occurred in Python command: No struct type named module.
Catch the error and return an empty module_list() for a clean command
output as follows:
(gdb) lx-lsmod
(gdb)
Link: http://lkml.kernel.org/r/94d533819437408b85ae5864f939dd7ca6fbfcd6.1462865983.git.jan.kiszka@siemens.com
If we attempt to read a value that is not available to GDB, an exception
is raised. Most of the time, this is a good thing; however on occasion
we will want to be able to determine if a symbol is available.
By catching the exception to simply return None, we can determine if we
tried to read an invalid value, without the exception taking our
execution context away from us
Link: http://lkml.kernel.org/r/c72b25c06fc66e1d68371154097e2cbb112555d8.1462865983.git.jan.kiszka@siemens.com
Simplify the module list functions with the new list_for_each_entry
abstractions
Link: http://lkml.kernel.org/r/ad0101c9391088608166fcec26af179868973d86.1462865983.git.jan.kiszka@siemens.com
Facilitate linked-list items by providing a generator to return the
dereferenced, and type-cast objects from a kernel linked list
Link: http://lkml.kernel.org/r/2b0998564e6e5abe53585d466f87e491331fd2a4.1462865983.git.jan.kiszka@siemens.com
Cc: Jeff Mahoney <jeffm@suse.com>
Some macro's and defines are needed when parsing memory, and without
compiling the kernel as -g3 they are not available in the debug-symbols.
We use the pre-processor here to extract constants to a dedicated module
for the linux debugger extensions
Top level Kbuild is used to call in and generate the constants file,
while maintaining dependencies on autogenerated files in
include/generated
Link: http://lkml.kernel.org/r/bc3df9c25f57ea72177c066a51a446fc19e2c27f.1462865983.git.jan.kiszka@siemens.com
Cc: Michal Marek <mmarek@suse.cz>
This takes the MODULE_REF_BASE into account.
Link: http://lkml.kernel.org/r/d926d2d54caa034adb964b52215090cbdb875249.1462865983.git.jan.kiszka@siemens.com
Commit 7523e4dc5057 ("module: use a structure to encapsulate layout.")
factored out the module_layout structure. Adjust the symbol loader and
the lsmod command to this.
Reviewed-by: Kieran Bingham <kieran.bingham@linaro.org>
Tested-by: Kieran Bingham <kieran.bingham@linaro.org> (qemu-{ARM,x86})
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Jason Wessel <jason.wessel@windriver.com>
Cc: <stable@vger.kernel.org> [4.4+]
lx-cmdline Report the Linux Commandline used in the current kernel
[jan.kiszka@siemens.com: remove blank line from help output and fix pep8 warning]
lx-version Report the Linux Version of the current kernel.
Add a command to identify the version specified by the banner in the
debugged kernel.
This lets the user identify the kernel of the running kernel, and will
let later scripts compare the banner of the attached kernel against the
banner in the vmlinux symbols files to verify that the files are
correct.
Signed-off-by: Thiébaud Weksteen <thiebaud@weksteen.fr>
Cc: Thiébaud Weksteen <thiebaud@weksteen.fr>
This makes the usage more flexible.
Add a gdb script to verify the consistency of lists.
Commit 2f35c41f58a9 ("module: Replace module_ref with atomic_t refcnt")
changes the way refcnt is handled but did not update the gdb script to
use the new variable.
Since refcnt is not per-cpu anymore, we can directly read its value.
Signed-off-by: Adrien Schildknecht <adrien+dev@schischi.me>
Cc: Pantelis Koukousoulas <pktoss@gmail.com>
This got lost during the initial merge process: Python requires an
__init__.py script, even if empty, in order to accept a directory as
package. Add it, this time as a non-empty file.
While reporting the (refreshed) list of modules on automatic updates we
may hit the page boundary of the output console and cause a stop if
pagination is enabled. However, gdb does not accept user input while
running over the breakpoint handler. So we get stuck, and the user is
forced to interrupt gdb.
Resolve this by disabling pagination during automatic symbol updates. We
restore the user's configuration once done.
Cc: Ben Widawsky <ben@bwidawsk.net>
Cc: Borislav Petkov <bp@suse.de>
Yet another code simplification.
Analogously to the task list, convert the module list to a generator
function. It noticeably simplifies the code.
The iterator does not return any task_struct from the thread_group list
because the first condition in the 'if not t or ...' will only be the
first time None.
Instead of keeping track of the state ourself in the next() function, we
fall back using Python's generator.
Signed-off-by: Daniel Wagner <daniel.wagner@bmw-carit.de>
Using the gdb scripts leaves byte-compiled python files in the scripts/
directory. These should be ignored by git.
[jan.kiszka@siemens.com: drop redundant mrproper rule as suggested by Michal]
Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org>
I tried to use these scripts in an ubuntu 14.04 host (gdb 7.7 compiled
against python 3.3) but there were several errors.
I believe this patch fixes these issues so that the commands now work (I
tested lx-symbols, lx-dmesg, lx-lsmod).
Main issues that needed to be resolved:
* In python 2 iterators have a "next()" method. In python 3 it is
__next__() instead (so let's just add both).
* In older python versions there was an implicit conversion
in object.__format__() (used when an object is in string.format())
where it was converting the object to str first and then
calling str's __format__(). This has now been removed so
we must explicitly convert to str the objects for which
we need to keep this behavior.
* In dmesg.py: in python 3 log_buf is now a "memoryview" object
which needs to be converted to a string in order to use string
methods like "splitlines()". Luckily memoryview exists in
python 2.7.6 as well, so we can convert log_buf to memoryview
and use the same code in both python 2 and python 3.
This version of the patch has now been tested with gdb 7.7 and both python
3.4 and python 2.7.6 (I think asking for at least python 2.7.6 is a
reasonable requirement instead of complicating the code with version
checks etc).
Signed-off-by: Pantelis Koukousoulas <pktoss@gmail.com>
This adds a lsmod-like command to list all currently loaded modules of the
target.
Will be used first to count module references. It is optimized to read
the mask only once per stop.
This is a shorthand for *$lx_per_cpu("current_task"), i.e. a convenience
function to retrieve the currently running task of the active context.
This function allows to obtain a per-cpu variable, either of the current
or an explicitly specified CPU.
Note: sparc64 version is untested.
This helper probes the type of the gdb server. Supported are QEMU and
KGDB so far. Knowledge about the gdb server is required e.g. to
retrieve the current CPU or current task.
thread_info
Add the internal helper get_thread_info that calculates the thread_info
from a given task variable. Also export this service as a convenience
function.
Note: ia64 version is untested.
This helper caches to result of "show architecture" and matches the
provided arch (sub-)string against that output.
Add the helper task_by_pid that can look up a task by its PID. Also
export it as a convenience function.
This class allows to iterate over all tasks of the target.
This pokes into the log buffer of the debugged kernel, dumping it to the
gdb console. Helping in case the target should or can no longer execute
dmesg itself.
Cc: Kay Sievers <kay@vrfy.org>
