path: root/scripts/gen_initramfs_list.sh
2006-11-25[PATCH] initramfs: handle more than one source dir or file listThomas Chou
Fix bug 7401. Handle more than one source dir or file list to the initramfs gen scripts. The Kconfig help for INITRAMFS_SOURCE claims that you can specify multiple space-separated sources in order to allow unprivileged users to build an image. There are two bugs in the current implementation that prevent this from working. First, we pass "file1 dir2" to the gen_initramfs_list.sh script, which it obviously can't open. Second, gen_initramfs_list.sh -l outputs multiple definitions for deps_initramfs -- one for each argument. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-30kbuild: fix gen_initramfs_list.shSam Ravnborg
Create correct dependencies when specifying your own file with list of files etc. to include in initramfs. Reported by: Andre Noll <maan@skl-net.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-04-11kbuild: rebuild initramfs if content of initramfs changesSam Ravnborg
initramfs.cpio.gz being build in usr/ and included in the kernel was not rebuild when the included files changed. To fix this the following was done: - let gen_initramfs.sh generate a list of files and directories included in the initramfs - gen_initramfs generate the gzipped cpio archive so we could simplify the kbuild file (Makefile) - utilising the kbuild infrastructure so when uid/gid root mapping changes the initramfs will be rebuild With this change we have a much more robust initramfs generation. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
