path: root/scripts/genksyms
2011-03-17genksyms: Regenerate lexer and parserMichal Marek
Regenerated the parser after "genksyms: Track changes to enum constants". Signed-off-by: Michal Marek <mmarek@suse.cz> Acked-by: Sam Ravnborg <sam@ravnborg.org>
2011-03-17genksyms: Track changes to enum constantsMichal Marek
Enum constants can be used as array sizes; if the enum itself does not appear in the symbol expansion, a change in the enum constant will go unnoticed. Example patch that changes the ABI but does not change the checksum with current genksyms: | enum e { | E1, | E2, |+ E3, | E_MAX | }; | | struct s { | int a[E_MAX]; | } | | int f(struct s *s) { ... } | EXPORT_SYMBOL(f) Therefore, remember the value of each enum constant and expand each occurence to <constant> <value>. The value is not actually computed, but instead an expression in the form (last explicitly assigned value) + N is used. This avoids having to parse and semantically understand whole of C. Note: The changes won't take effect until the lexer and parser are rebuilt by the next patch. Signed-off-by: Michal Marek <mmarek@suse.cz> Acked-by: Sam Ravnborg <sam@ravnborg.org>
2011-03-17genksyms: simplify usage of find_symbol()Michal Marek
Allow searching for symbols of an exact type. The lexer does this and a subsequent patch will add one more usage. Signed-off-by: Michal Marek <mmarek@suse.cz> Acked-by: Sam Ravnborg <sam@ravnborg.org>
2011-03-17genksyms: Add helpers for building string listsMichal Marek
2011-03-17genksyms: Simplify printing of symbol typesMichal Marek
Instead of special-casing SYM_NORMAL, do not map any name to it. Also explicitly set the single-letter name of the symbol type, which will be needed by a further patch. The only user-visible change is one debug printf. Signed-off-by: Michal Marek <mmarek@suse.cz> Acked-by: Sam Ravnborg <sam@ravnborg.org>
2011-03-17genksyms: Simplify lexerMichal Marek
The V2_TOKENS state is active all the time. Signed-off-by: Michal Marek <mmarek@suse.cz> Acked-by: Sam Ravnborg <sam@ravnborg.org>
2011-03-17genksyms: Do not paste the bison header file to lex.cMichal Marek
The header is already #included, no need to include it a second time. lex.c_shipped was regenerated using flex-2.5.35. Signed-off-by: Michal Marek <mmarek@suse.cz> Acked-by: Sam Ravnborg <sam@ravnborg.org>
2010-11-25scripts/genksyms: fix header usageArnaud Lacombe
FreeBSD does not like <malloc.h> when __STDC__ is defined, use the standard <stdlib.h> instead. Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-02-02genksyms: close ref_file after useAlexander Beregalov
It is the last place when the file is read, so close it. Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-12genksyms: properly consider EXPORT_UNUSED_SYMBOL{,_GPL}()Jan Beulich
Despite being unused these should also get a CRC calculated. Primarily I view this as a consistency thing. But I also think this is one of the reasons why __crc_* need to be weak (which I think should be avoided, and hence we should have the goal to eliminate this so that failure to calculate a proper CRC for a symbol causes the build to fail). Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Anibal Monsalve Salazar <anibal@debian.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-11-15genksyms: Mark is_reserved_word staticJosh Triplett
The genksyms keyword gperf hash provides a function is_reserved_word. genksyms #includes the resulting generated file keywords.c, so the function gets used only in the same source file that defines it. Mark is_reserved_word static, and regenerate the corresponding generated file. Signed-off-by: Josh Triplett <josh@joshtriplett.org>
2009-09-23Documentation/: fix warnings from -Wmissing-prototypes in HOSTCFLAGSLadinu Chandrasinghe
Fix up -Wmissing-prototypes in compileable userspace code, mainly under Documentation/. Signed-off-by: Ladinu Chandrasinghe <ladinu.pub@gmail.com> Signed-off-by: Trevor Keith <tsrk@tsrk.net> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-14Revert "kbuild: strip generated symbols from *.ko"Sam Ravnborg
This reverts commit ad7a953c522ceb496611d127e51e278bfe0ff483. And commit: ("allow stripping of generated symbols under CONFIG_KALLSYMS_ALL") 9bb482476c6c9d1ae033306440c51ceac93ea80c These stripping patches has caused a set of issues: 1) People have reported compatibility issues with binutils due to lack of support for `--strip-unneeded-symbols' with objcopy 2.15.92.0.2 Reported by: Wenji 2) ccache and distcc no longer works as expeced Reported by: Ted, Roland, + others 3) The installed modules increased a lot in size Reported by: Ted, Davej + others Reported-by: Wenji Huang <wenji.huang@oracle.com> Reported-by: "Theodore Ts'o" <tytso@mit.edu> Reported-by: Dave Jones <davej@redhat.com> Reported-by: Roland McGrath <roland@redhat.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-12-19allow stripping of generated symbols under CONFIG_KALLSYMS_ALLJan Beulich
Building upon parts of the module stripping patch, this patch introduces similar stripping for vmlinux when CONFIG_KALLSYMS_ALL=y. Using CONFIG_KALLSYMS_STRIP_GENERATED reduces the overhead of CONFIG_KALLSYMS_ALL from 245k/310k to 65k/80k for the (i386/x86-64) kernels I tested with. The patch also does away with the need to special case the kallsyms- internal symbols by making them available even in the first linking stage. While it is a generated file, the patch includes the changes to scripts/genksyms/keywords.c_shipped, as I'm unsure what the procedure here is. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-12-19kbuild: strip generated symbols from *.koJan Beulich
This patch changes the way __crc_ symbols are being resolved from using ld to do so to using the assembler, thus allowing these symbols to be marked local (the linker creates then as global ones) and hence allow stripping (for modules) or ignoring (for vmlinux) them. While at this, also strip other generated symbols during module installation. One potentially debatable point is the handling of the flags passeed to gcc when translating the intermediate assembly file into an object: passing $(c_flags) unchanged doesn't work as gcc passes --gdwarf2 to gas whenever is sees any -g* option, even for -g0, and despite the fact that the compiler would have already produced all necessary debug info in the C->assembly translation phase. I took the approach of just filtering out all -g* options, but an alternative to such negative filtering might be to have a positive filter which might, in the ideal case allow just all the -Wa,* options to pass through. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-12-03genksyms: allow to ignore symbol checksum changesAndreas Gruenbacher
This adds an "override" keyword for use in *.symvers / *.symref files. When a symbol is overridden, the symbol's old definition will be used for computing checksums instead of the new one, preserving the previous checksum. (Genksyms will still warn about the change.) This is meant to allow distributions to hide minor actual as well as fake ABI changes. (For example, when extra type information becomes available because additional headers are included, this may change checksums even though none of the types used have actully changed.) This approach also allows to get rid of "#ifdef __GENKSYMS__" hacks in the code, which are currently used in some vendor kernels to work around checksum changes. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-12-03genksyms: track symbol checksum changesAndreas Gruenbacher
Sometimes it is preferable to avoid changes of exported symbol checksums (to avoid breaking externally provided modules). When a checksum change occurs, it can be hard to figure out what caused this change: underlying types may have changed, or additional type information may simply have become available at the point where a symbol is exported. Add a new --reference option to genksyms which allows it to report why checksums change, based on the type information dumps it creates with the --dump-types flag. Genksyms will read in such a dump from a previous run, and report which symbols have changed (and why). The behavior can be controlled for an entire build as follows: If KBUILD_SYMTYPES is set, genksyms uses --dump-types to produce *.symtypes dump files. If any *.symref files exist, those will be used as the reference to check against. If KBUILD_PRESERVE is set, checksum changes will fail the build. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-31kbuild: genksyms: Include extern information in dumpsAndreas Gruenbacher
The extern flag currently is not included in type dump files (genksyms --dump-types). Include that flag there for completeness. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-31kbuild: genksyms parser: fix the __attribute__ ruleAndreas Gruenbacher
We are having two kinds of problems with genksyms today: fake checksum changes without actual ABI changes, and changes which we would rather like to ignore (such as an additional field at the end of a structure that modules are not supposed to touch, for example). I have thought about ways to improve genksyms and compute checksums differently to avoid those problems, but in the end I don't see a fundamentally better way. So here are some genksyms patches for at least making the checksums more easily manageable, if we cannot fully fix them. In addition to the bugfixes (the first two patches), this allows genksyms to track checksum changes and report why a checksum changed (third patch), and to selectively ignore changes (fourth patch). This patch: Gcc __attribute__ definitions may occur repeatedly, e.g., static int foo __attribute__((__used__)) __attribute__((aligned (16))); The genksyms parser does not understand this, and generates a syntax error. Fix this case. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-30kbuild: scripts/genksyms/lex.l: add %option noinputAdrian Bunk
gcc 4.3 correctly determines that input() is unused and gives the following warning: <-- snip --> ... HOSTCC scripts/genksyms/lex.o scripts/genksyms/lex.c:1487: warning: ‘input’ defined but not used ... <-- snip --> Fix it by adding %option noinput to scripts/genksyms/lex.l and regeneration of scripts/genksyms/lex.c_shipped. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-24remove the v850 portAdrian Bunk
Trying to compile the v850 port brings many compile errors, one of them exists since at least kernel 2.6.19. There also seems to be noone willing to bring this port back into a usable state. This patch therefore removes the v850 port. If anyone ever decides to revive the v850 port the code will still be available from older kernels, and it wouldn't be impossible for the port to reenter the kernel if it would become actively maintained again. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-28kbuild: fixup genksyms usage/getoptMike Frysinger
The usage does not mention the "-a,--arch" or "-T,--dump-types" options, so add them. The calls to getopt() seem to mention options that no longer exist (some "k" and "p" thingy) but omits the "h" option which means using '-h' actually triggers the error code path, so update those as well. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: apply genksyms changesSam Ravnborg
This patch updates the _shipped files for genksyms. See previous patch for actual functional changes. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: __extension__ support in genksyms (fix unknown CRC warning)Sam Ravnborg
Recently the __extension__ keyword has been introduced in the kernel. Teach genksyms about this keyword so it can generate correct CRC for exported symbols that uses a symbol marked __extension__. For now only the typedef variant: __extension__ typedef ... is supported. Later we may add more variants as needed. This patch contains the actual source file changes. The following patch will hold modifications to the generated files (*_shipped) and only after the second patch the fix has effect. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: fix genksyms MakefileSam Ravnborg
When enabling GENERATE_PARSER the genksyms Makefile failed to create _shipped version of generated files. Modifying keywords.gperf failed to cause a rebuild of genksyms. Fixed by specifying keywowrds .c as explicit prerequisite of the lexer. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-07blackfin architectureBryan Wu
This adds support for the Analog Devices Blackfin processor architecture, and currently supports the BF533, BF532, BF531, BF537, BF536, BF534, and BF561 (Dual Core) devices, with a variety of development platforms including those avaliable from Analog Devices (BF533-EZKit, BF533-STAMP, BF537-STAMP, BF561-EZKIT), and Bluetechnix! Tinyboards. The Blackfin architecture was jointly developed by Intel and Analog Devices Inc. (ADI) as the Micro Signal Architecture (MSA) core and introduced it in December of 2000. Since then ADI has put this core into its Blackfin processor family of devices. The Blackfin core has the advantages of a clean, orthogonal,RISC-like microprocessor instruction set. It combines a dual-MAC (Multiply/Accumulate), state-of-the-art signal processing engine and single-instruction, multiple-data (SIMD) multimedia capabilities into a single instruction-set architecture. The Blackfin architecture, including the instruction set, is described by the ADSP-BF53x/BF56x Blackfin Processor Programming Reference http://blackfin.uclinux.org/gf/download/frsrelease/29/2549/Blackfin_PRM.pdf The Blackfin processor is already supported by major releases of gcc, and there are binary and source rpms/tarballs for many architectures at: http://blackfin.uclinux.org/gf/project/toolchain/frs There is complete documentation, including "getting started" guides available at: http://docs.blackfin.uclinux.org/ which provides links to the sources and patches you will need in order to set up a cross-compiling environment for bfin-linux-uclibc This patch, as well as the other patches (toolchain, distribution, uClibc) are actively supported by Analog Devices Inc, at: http://blackfin.uclinux.org/ We have tested this on LTP, and our test plan (including pass/fails) can be found at: http://docs.blackfin.uclinux.org/doku.php?id=testing_the_linux_kernel [m.kozlowski@tuxland.pl: balance parenthesis in blackfin header files] Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Aubrey Li <aubrey.li@analog.com> Signed-off-by: Jie Zhang <jie.zhang@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-06-24kbuild: replace abort() with exit(1)Sam Ravnborg
We have had no use of the coredump file for a long time. So just exit(1) and avoid coredumping. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-06-24kbuild: support for %.symtypes filesAndreas Gruenbacher
Here is a patch that adds a new -T option to genksyms for generating dumps of the type definition that makes up the symbol version hashes. This allows to trace modversion changes back to what caused them. The dump format is the name of the type defined, followed by its definition (which is almost C): s#list_head struct list_head { s#list_head * next , * prev ; } The s#, u#, e#, and t# prefixes stand for struct, union, enum, and typedef. The exported symbols do not define types, and thus do not have an x# prefix: nfs4_acl_get_whotype int nfs4_acl_get_whotype ( char * , t#u32 ) The symbol type defintion of a single file can be generated with: make fs/jbd/journal.symtypes If KBUILD_SYMTYPES is defined, all the *.symtypes of all object files that export symbols are generated. The single *.symtypes files can be combined into a single file after a kernel build with a script like the following: for f in $(find -name '*.symtypes' | sort); do f=${f#./} echo "/* ${f%.symtypes}.o */" cat $f echo done \ | sed -e '\:UNKNOWN:d' \ -e 's:[,;] }:}:g' \ -e 's:\([[({]\) :\1:g' \ -e 's: \([])},;]\):\1:g' \ -e 's: $::' \ $f \ | awk ' /^.#/ { if (defined[$1] == $0) { print $1 next } defined[$1] = $0 } { print } ' When the kernel ABI changes, diffing individual *.symtype files, or the combined files, against each other will show which symbol changes caused the ABI changes. This can save a tremendous amount of time. Dump the types that make up modversions Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-03-25Merge master.kernel.org:/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/sam/kbuild: (46 commits) kbuild: remove obsoleted scripts/reference_* files kbuild: fix make help & make *pkg kconfig: fix time ordering of writes to .kconfig.d and include/linux/autoconf.h Kconfig: remove the CONFIG_CC_ALIGN_* options kbuild: add -fverbose-asm to i386 Makefile kbuild: clean-up genksyms kbuild: Lindent genksyms.c kbuild: fix genksyms build error kbuild: in makefile.txt note that Makefile is preferred name for kbuild files kbuild: replace PHONY with FORCE kbuild: Fix bug in crc symbol generating of kernel and modules kbuild: change kbuild to not rely on incorrect GNU make behavior kbuild: when warning symbols exported twice now tell user this is the problem kbuild: fix make dir/file.xx when asm symlink is missing kbuild: in the section mismatch check try harder to find symbols kbuild: fix section mismatch check for unwind on IA64 kbuild: kill false positives from section mismatch warnings for powerpc kbuild: kill trailing whitespace in modpost & friends kbuild: small update of allnoconfig description kbuild: make namespace.pl CROSS_COMPILE happy ... Trivial conflict in arch/ppc/boot/Makefile manually fixed up
2006-03-20[PATCH] add EXPORT_SYMBOL_GPL_FUTURE()Greg Kroah-Hartman
This patch adds the ability to mark symbols that will be changed in the future, so that kernel modules that don't include MODULE_LICENSE("GPL") and use the symbols, will be flagged and printed out to the system log. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-12kbuild: clean-up genksymsSam Ravnborg
o remove all inlines o declare everything static which is only used by genksyms.c o delete unused functions o delete unused variables o delete unused stuff in genksyms.h o properly ident genksyms.h Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-03-12kbuild: Lindent genksyms.cSam Ravnborg
No fix-ups applied yet. Just the raw Lindent output. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-03-12kbuild: fix genksyms build errorSam Ravnborg
genksyms needs to know when a symbol must have a "_" prefex as is true for a few architectures. Pass $(ARCH) as commandline argument and hardcode what architectures that needs this info. Previous attemt to take it from elfconfig.h was br0ken since elfconfig.h is a generated file. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-03-08kbuild: Fix bug in crc symbol generating of kernel and modulesLuke Yang
The scripts/genksyms/genksyms.c uses hardcoded "__crc_" prefix for crc symbols in kernel and modules. The prefix should be replaced by "MODULE_SYMBOL_PREFIX##__crc_" otherwise there will be warnings when MODULE_SYMBOL_PREFIX is not NULL. I am sorry my last patch for this issue is actually wrong. I revert it in this patch. Signed-off-by: Luke Yang <luke.adi@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-01-01gitignore: misc filesBrian Gerst
Ignore all files generated from *_shipped files, plus a few others. Signed-off-by: Brian Gerst <bgerst@didntduck.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-12-26kbuild: Create _shipped files for genksymsSam Ravnborg
Generate _shipped files so the genksyms change in previous commit is enabled. The files are generated with latest versions of the tools: bison (GNU Bison) 2.0 flex version 2.5.4 GNU gperf 3.0.1 Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-12-26kbuild: Fix genksyms handling of DEFINE_PER_CPU(struct foo_s *, bar);Robin Holt
This is a one-line change to parse.y. To take advantage of this the scripts/genksyms/*_shipped files needs to be rebuild - this is the next patch. When a .c file contains: DEFINE_PER_CPU(struct foo_s *, bar); the .cpp output looks like: __attribute__((__section__(".data.percpu"))) __typeof__(struct foo_s *) per_cpu__bar; With the existing parse.y, the value inside the paranthesis of __typeof__() does not evaluate as a type_specifier and therefore per_cpu__bar does not get assigned a type for genksyms which results in the EXPORT_PER_CPU_SYMBOL() not generating a CRC value. I have compared the Modules.symvers with and without this patch and for ia64's defconfig, the only change is: Before 0x00000000 per_cpu____sn_nodepda vmlinux After 0x9d3f3faa per_cpu____sn_nodepda vmlinux per_cpu____sn_nodepda was the original source of my problems. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
