path: root/scripts/get_maintainer.pl
2014-07-08scripts: Teach get_maintainer.pl about the new "R:" tagJoe Perches
We can now designate reviewers in the MAINTAINERS file with the new "R:" tag, so this commit teaches get_maintainers.pl to add their email addresses. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2014-02-10get_maintainer: fix detection of git repositoryRichard Genoud
Since git v1.7.7, the .git directory can be a file when, for example, the kernel is a submodule of another git super project. So, the check "-d .git" is not working anymore in this case. Using a more generic check like "-e .git" corrects this behaviour. Signed-off-by: Richard Genoud <richard.genoud@gmail.com> Cc: Andy Whitcroft <apw@canonical.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23get_maintainer: add commit author information to --rolestatsJoe Perches
get_maintainer currently uses "Signed-off-by" style lines to find interested parties to send patches to when the MAINTAINERS file does not have a specific section entry with a matching file pattern. Add statistics for commit authors and lines added and deleted to the information provided by --rolestats. These statistics are also emitted whenever --rolestats and --git are selected even when there is a specified maintainer. This can have the effect of expanding the number of people that are shown as possible "maintainers" of a particular file because "authors", "added_lines", and "removed_lines" are also used as criterion for the --max-maintainers option separate from the "commit_signers". The first "--git-max-maintainers" values of each criterion are emitted. Any "ties" are not shown. For example: (forcedeth does not have a named maintainer) Old output: $ ./scripts/get_maintainer.pl -f drivers/net/ethernet/nvidia/forcedeth.c "David S. Miller" <davem@davemloft.net> (commit_signer:8/10=80%) Jiri Pirko <jiri@resnulli.us> (commit_signer:2/10=20%) Patrick McHardy <kaber@trash.net> (commit_signer:2/10=20%) Larry Finger <Larry.Finger@lwfinger.net> (commit_signer:1/10=10%) Peter Zijlstra <peterz@infradead.org> (commit_signer:1/10=10%) netdev@vger.kernel.org (open list:NETWORKING DRIVERS) linux-kernel@vger.kernel.org (open list) New output: $ ./scripts/get_maintainer.pl -f drivers/net/ethernet/nvidia/forcedeth.c "David S. Miller" <davem@davemloft.net> (commit_signer:8/10=80%) Jiri Pirko <jiri@resnulli.us> (commit_signer:2/10=20%,authored:2/10=20%,removed_lines:3/33=9%) Patrick McHardy <kaber@trash.net> (commit_signer:2/10=20%,authored:2/10=20%,added_lines:12/95=13%,removed_lines:10/33=30%) Larry Finger <Larry.Finger@lwfinger.net> (commit_signer:1/10=10%,authored:1/10=10%,added_lines:35/95=37%) Peter Zijlstra <peterz@infradead.org> (commit_signer:1/10=10%) "Peter Hüwe" <PeterHuewe@gmx.de> (authored:1/10=10%,removed_lines:15/33=45%) Joe Perches <joe@perches.com> (authored:1/10=10%) Neil Horman <nhorman@tuxdriver.com> (added_lines:40/95=42%) Bill Pemberton <wfp5p@virginia.edu> (removed_lines:3/33=9%) netdev@vger.kernel.org (open list:NETWORKING DRIVERS) linux-kernel@vger.kernel.org (open list) Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29get_maintainer: use filename-only regex match for TegraStephen Warren
Create a new N: entry type in MAINTAINERS which performs a regex match against filenames; either those extracted from patch +++ or --- lines, or those specified on the command-line using the -f option. This provides the same benefits as using a K: regex option to match a set of filenames (see commit eb90d0855b75 "get_maintainer: allow keywords to match filenames"), but without the disadvantage that "random" file content, such as comments, will ever match the regex. Hence, revert most of that commit. Switch the Tegra entry from using K: to N: [akpm@linux-foundation.org: fix typo in docs, per Marcin] Reported-by: Marcin Slusarz <marcin.slusarz@gmail.com> Suggested-by: Joe Perches <joe@perches.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27get_maintainer: allow keywords to match filenamesStephen Warren
Allow K: entries in MAINTAINERS to match directly against filenames; either those extracted from patch +++ or --- lines, or those specified on the command-line using the -f option. This potentially allows fewer lines in a MAINTAINERS entry, if all the relevant files are scattered throughout the whole kernel tree, yet contain some common keyword. An example would be using an ARM SoC name as the keyword to catch all related drivers. I don't think setting exact_pattern_match_hash would be appropriate here; at least for intended Tegra use case, this feature is to ensure that all Tegra-related driver changes get Cc'd to the Tegra mailing list. Setting exact_pattern_match_hash would prevent git history parsing for e.g. S-o-b tags, which still seems like it would be useful. Hence, this flag isn't set. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21get_maintainer.pl: find maintainers for removed filesGeert Uytterhoeven
For removed files, get_maintainer.pl doesn't find any maintainers (besides the default linux-kernel@vger.kernel.org), as it only looks at the "+++" lines, which are "/dev/null" for removals. Fix this by extending the parsing to the "---" lines. E.g. for the two line test patch below the real score maintainers will now be found: --- a/arch/score/include/asm/dma-mapping.h +++ /dev/null Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-06-20get_maintainer: Fix --help warningJoe Perches
Using --help emits a concatenation error. Fix it. Signed-off-by: Joe Perches <joe@perches.com> Reported-by: Paul Bolle <pebolle@tiscali.nl> Tested-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23get_maintainer.pl: add support for moderated listsRichard Weinberger
Currently get_maintainer.pl reports moderated lists as open, which is just wrong. Signed-off-by: Richard Weinberger <richard@nod.at> Acked-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23get_maintainer: use a default "unknown" S: status/roleJoe Perches
When an "S:" status line is unavailable, use a default "unknown" role. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10get_maintainers.pl: follow renames when looking up commit signersIan Campbell
I happen to have had a commit to various network drivers since the big renaming/reorg which happened to drivers/net recently. This means that I now appear to be in the top few commit signers (by %age) for many of them so am getting sent all sorts of stuff and people who are involved with the driver are not. e.g. (to pick one at random): $ ./scripts/get_maintainer.pl -f drivers/net/ethernet/nvidia/forcedeth.c "David S. Miller" <davem@davemloft.net> (commit_signer:5/7=71%) Ian Campbell <ian.campbell@citrix.com> (commit_signer:2/7=29%) Eric Dumazet <eric.dumazet@gmail.com> (commit_signer:1/7=14%) Jeff Kirsher <jeffrey.t.kirsher@intel.com> (commit_signer:1/7=14%) Jiri Pirko <jpirko@redhat.com> (commit_signer:1/7=14%) netdev@vger.kernel.org (open list:NETWORKING DRIVERS) linux-kernel@vger.kernel.org (open list) With the following patch the renames are followed and the result appears much more sensible: $ ./scripts/get_maintainer.pl -f drivers/net/ethernet/nvidia/forcedeth.c "David S. Miller" <davem@davemloft.net> (commit_signer:31/34=91%) Joe Perches <joe@perches.com> (commit_signer:11/34=32%) Szymon Janc <szymon@janc.net.pl> (commit_signer:5/34=15%) Jiri Pirko <jpirko@redhat.com> (commit_signer:3/34=9%) Paul <paul.gortmaker@windriver.com> (commit_signer:2/34=6%) netdev@vger.kernel.org (open list:NETWORKING DRIVERS) linux-kernel@vger.kernel.org (open list) Signed-off-by: Ian Campbell <Ian.Campbell@citrix.com> Acked-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-25scripts/get_maintainer.pl: update Linus's git repositoryRalf Thielow
Change to new git tree - (git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git). Signed-off-by: Ralf Thielow <ralf.thielow@googlemail.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25get_maintainers.pl: improve .mailmap parsingJoe Perches
Entries that used formats other than "Proper Name <commit@email.xx>" were not parsed properly. Try to improve the parsing so that the entries in the forms of: Proper Name <proper@email.xx> <commit@email.xx> and Proper Name <proper@email.xx> Commit Name <commit@email.xx> are transformed correctly. Signed-off-by: Joe Perches <joe@perches.com> Reviewed-by: Florian Mickler <florian@mickler.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22get_maintainer.pl: allow "K:" pattern tests to match non-patch textJoe Perches
Extend the usage of the K section in the MAINTAINERS file to support matching regular expressions to any arbitrary text that may precede the patch itself. For example, the commit message or mail headers generated by git-format-patch. Signed-off-by: Joe Perches <joe@perches.com> Original-patch-by: L. Alberto Giménez <agimenez@sysvalve.es> Acked-by: L. Alberto Giménez <agimenez@sysvalve.es> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13scripts/get_maintainer.pl: use --git-fallback more oftenJoe Perches
On Fri, 2010-11-05 at 13:50 -0700, Andrew Morton wrote: > z:/usr/src/git26> perl scripts/get_maintainer.pl -file mm/mempolicy.c > linux-mm@kvack.org > linux-kernel@vger.kernel.org Turns out this is an arguable defect in the script. The MAINTAINERS entry for mm is: MEMORY MANAGEMENT L: linux-mm@kvack.org W: http://www.linux-mm.org S: Maintained F: include/linux/mm.h F: mm/ There's a maintainer entry, but no named individual, so the script doesn't use git history via --git-fallback. This is also a defect for MAINTAINERS with status entries marked "Orphan" or "Odd fixes". The script now checks a section for any "M:" entry and that an "S:" entry is supported or maintained. If both those conditions are not satisified, use --git-fallback as appropriate. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13scripts/get_maintainer.pl: make --rolestats the defaultJoe Perches
This script now requires a user to add --norolestats to the command line so it's harder to feed the output of this script to programs that send mass emails. Update --help to correct command line defaults. Change version to 0.26. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26scripts/get_maintainer.pl: don't deduplicate unnamed addresses ie: mailing listsJoe Perches
Fix a defect with the first mailing list address being used for each subsequent mailing list. Updated to 0.26-beta6. Signed-off-by: Joe Perches <joe@perches.com> Cc: Florian Mickler <florian@mickler.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26scripts/get_maintainer.pl: use mailmap in name deduplication and other updatesJoe Perches
Use Florian Mickler's mailmap routine to reduce name duplication. o Add subroutine deduplicate_email to centralize code o Add hashes for deduplicate_(name|address)_hash o Remove now unused @interactive_to o Whitespace neatening o Add command line --help text o Add --mailmap command line option control o Interactive changes: - Add toggles for maintainer, git and list selections - Default selection is all - Add mailmap control Update to 0.26-beta5 Signed-off-by: Joe Perches <joe@perches.com> Cc: Florian Mickler <florian@mickler.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26scripts/get_maintainer.pl: correct indentation in a few placesJoe Perches
And a miscellaneous conversion of You to you in a help message Signed-off-by: Joe Perches <joe@perches.com> Cc: Florian Mickler <florian@mickler.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26scripts/get_maintainer.pl: fix mailmap handlingFlorian Mickler
Implement it, like it is described in git-shortlog. Signed-off-by: Florian Mickler <florian@mickler.org> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26scripts/get_maintainer.pl: use case insensitive name de-duplicationJoe Perches
Case insensitive name and email address matching can help reduce duplication when authors don't always use the exact same signature. o Add a --interactive per-file exact_match hash so git history can be checked on per-file only when there is no direct maintainer o Make @interactive_to list global so save_commits_by_<foo> can check email names & addresses against this list for duplication o Don't allow --interactive and --sections o rename subroutine get_maintainer to get_maintainers o Added help text option to --interactive menu prompt Update version to 0.26-beta4 Signed-off-by: Joe Perches <joe@perches.com> Cc: Florian Mickler <florian@mickler.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26scripts/get_maintainer.pl: improve --interactive UIJoe Perches
o Added searching by git-blame as well as git-history o Added different selection toggles o Added ability to list commits by author or by sign-off-type o Use custom git and hg formats to make searching for subject/author a bit easier. o Move inlined section matching and searching git/hg history to new get_maintainer subroutine o Added subroutines save_commits_by_author and save_commits_by_signer o Removed subroutines vcs_get_shortlog and vcs_email_shortlog o Rename camelcase signaturePattern to signature_pattern Update to 0.26 beta3 Signed-off-by: Joe Perches <joe@perches.com> Cc: Florian Mickler <florian@mickler.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26scripts/get_maintainer.pl: add interactive modeFlorian Mickler
This is a first version of an interactive mode for scripts/get_maintainer.pl. It allows the user to interact with the script. Each cc candidate can be selected and deselected and a shortlog of authored commits can be displayed for each candidate. The menu is displayed via STDERR, the end result is outputted to STDOUT. This unusual mechanism allows using get_maintainer.pl in interactive mode via git send-email --cc-cmd. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26scripts/get_maintainer.pl: use .get_maintainer.conf from . then $HOME then ↵Joe Perches
scripts On Mon, 2010-09-13 at 00:01 -0400, Valdis.Kletnieks@vt.edu wrote: > Any chance of getting that to be ~/.get_maintainer.conf rather than > ./.get_maintainer.conf? I've just gotten bit like the 3rd or 4th time by > "oh but you didn't create that file in *this* tree" > (I usually have a linus git tree, a linux-next tree, and 3-4 -mm trees) Sure. Add a search path for the .conf file. 3 paths are added: . customized per-tree configurations $HOME user global configuration when per-tree configs don't exist ./scripts lk defaults to override script Signed-off-by: Joe Perches <joe@perches.com> Cc: Valdis Kletnieks <Valdis.Kletnieks@vt.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26scripts/get_maintainer.pl: add default --git-fallback, remove default --gitJoe Perches
Adding commit signers when there is a listed MAINTAINER for a file can make the output list longer than necessary. Change the --git default from on to off. Add a new --git-fallback option (default on) used to add commit signers only when there is no MAINTAINER for a file. git history is used when --git-fallback is enabled and the pattern directory depth is not the same as the file directory depth. For instance: X86 ARCHITECTURE (32-BIT AND 64-BIT) M: Thomas Gleixner <tglx@linutronix.de> M: Ingo Molnar <mingo@redhat.com> M: "H. Peter Anvin" <hpa@zytor.com> M: x86@kernel.org T: git git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86.git S: Maintained F: Documentation/x86/ F: arch/x86/ If using "./scripts/get_maintainer -f arch/x86/lib/atomic64_32.c", the pattern for "arch/x86/" does not match the directory depth of "arch/x86/lib" so the MAINTAINERS entries and git history is used to produce: $ ./scripts/get_maintainer.pl -f --rolestats arch/x86/lib/atomic64_32.c Thomas Gleixner <tglx@linutronix.de> (maintainer:X86 ARCHITECTURE...) Ingo Molnar <mingo@redhat.com> (maintainer:X86 ARCHITECTURE...) "H. Peter Anvin" <hpa@zytor.com> (maintainer:X86 ARCHITECTURE...,commit_signer:1/1=100%) x86@kernel.org (maintainer:X86 ARCHITECTURE...) Luca Barbieri <luca@luca-barbieri.com> (commit_signer:1/1=100%) linux-kernel@vger.kernel.org (open list) Luca Barbieri is added because he signed the only commit to arch/x86/lib/atomic64_32.c during the last year and he meets the other default qualifications. --git-min-percent (default:10) --git-min-signatures (default:1) If current users of ./scripts/get_maintainers.pl have scripts that use --nogit that expect git history to be excluded, those scripts should be updated to include --nogit-fallback or a .get_maintainer.conf file should be created with --nogit-fallback. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26scripts/get_maintainer.pl: don't search MAINTAINERS for keywords or emailsJoe Perches
Keyword matching uses K: patterns from MAINTAINERS, so if looking for the MAINTAINERS maintainer, don't search MAINTAINERS for pattern matches. MAINTAINERS also has rather a lot of email addresses and is easily searched using grep "^M:", so skip it. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26scripts/get_maintainer.pl: use correct indentationJoe Perches
Fix an overly indented block. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26scripts/get_maintainer.pl: Add --git-blame --rolestats "Authored lines" ↵Joe Perches
information When options --git-blame and --rolestats are specified, add the maintainers with the qualifying --git-min-percent amount of lines authored of the complete file. Does not add more authors than specified by --git-max-maintainers. For anyone using hg, this option works but is _very_ slow. It's orders of magnitude slower than git slow. The get_maintainer.pl version was incremented to 0.25. This can be used with or without --git. For instance: $ ./scripts/get_maintainer.pl --git-blame --nogit --rolestats -f lib/bitmap.c Paul Jackson <pj@sgi.com> (authored lines:406/613=66%,commits:7/20=35%) Akinobu Mita <mita@miraclelinux.com> (authored lines:87/613=14%,commits:3/20=15%) Reinette Chatre <reinette.chatre@linux.intel.com> (authored lines:42/613=7%) Andrew Morton <akpm@linux-foundation.org> (commits:16/20=80%) Paul Mundt <lethal@linux-sh.org> (commits:3/20=15%) Randy Dunlap <randy.dunlap@oracle.com> (commits:2/20=10%) $ ./scripts/get_maintainer.pl --git-blame --git --rolestats -f lib/bitmap.c Andrew Morton <akpm@linux-foundation.org> (commit_signer:4/5=80%,commits:16/20=80%) Akinobu Mita <akinobu.mita@gmail.com> (commit_signer:2/5=40%,authored lines:87/613=14%,commits:3/20=15%) Jack Steiner <steiner@sgi.com> (commit_signer:1/5=20%) Ben Hutchings <ben@decadent.org.uk> (commit_signer:1/5=20%) Lee Schermerhorn <lee.schermerhorn@hp.com> (commit_signer:1/5=20%) Paul Jackson <pj@sgi.com> (authored lines:406/613=66%,commits:7/20=35%) Reinette Chatre <reinette.chatre@linux.intel.com> (authored lines:42/613=7%) Paul Mundt <lethal@linux-sh.org> (commits:3/20=15%) Randy Dunlap <randy.dunlap@oracle.com> (commits:2/20=10%) linux-kernel@vger.kernel.org (open list) Signed-off-by: Joe Perches <joe@perches.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25scripts/get_maintainer.pl: default to not include unspecified tagsFlorian Mickler
This changes the default of the option --git-all-signature-types to be disabled by default. The effect being, that only certain (currently Signed-Off-By:, Acked-by: and Reviewed-By:) tags are used to get adresses of potential maintainers. Motivated is this change by the desire to not 'spam' people unnecessary: A Tested-By or a Reported-By is not ment as a hint that those people want to/are able to review patches to the code in question. In a quest to find resilient statistics for this i came up with this: I produced a list of all the tag-signers not already covered with a signed-off/acked/reviewed tag somewhere in the last year of git history. Those were 650 addresses of "assumed non-developers". And to check if those "assumed non-developers" are professional testers/reporters worth cc'ing, i then counted their total appearences in the git log: 469 were mentioned only once. 123 were mentioned twice. 38 three times 8 four times 5 six times 5 five times 1 eight times 1 fourteen times I believe this supports my thesis, that the ''non-maintainer-tags'' are not actively useful for patch-review. (except probably the guy mentioned fourteen times...) But of course one could also find arguments to poke holes in this statistics, for example does this statistic not include code-locality: A tested-by on a patch that touches some specific piece of code can be more worth than a signed-off in another part of the tree. But... let's play it safe and let's err on the "safe" side meaning to not spam those people when in doubt. We already have the signed-off's and Maintainers file. So this should be ok. And if need be, the maintainers can always forward the patch. [i probably could make a diploma thesis out of this changelog :)] Signed-off-by: Florian Mickler <florian@mickler.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Joe Perches <joe@perches.com> Cc: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25scripts/get_maintainer.pl: add .get_maintainer.conf default options fileJoe Perches
Allow the use of a .get_maintainer.conf file to control the default options applied when scripts/get_maintainer.pl is run. .get_maintainer.conf can contain any valid command-line argument. File contents are prepended to any additional command line arguments. Multiple lines may be used, blank lines ignored, # is a comment. Updated scripts/get_maintainer.pl version to 0.24 Signed-off-by: Joe Perches <joe@perches.com> Reviewed-by: Florian Mickler <florian@mickler.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25scripts/get_maintainer.pl: optionally ignore non-maintainer signaturesJoe Perches
When using --git to determine who to send a patch to, get_maintainers will currently include all signatures. This can include signers that simply report an issue or test a patch. Signers that use this tag are not necessarily good candidates to review new patches. This patch allows get_maintainers to optionally restrict output to only signatures that use Signed-off-by:, Acked-by:, or Reviewed-by:. Signed-off-by: is included because those are people who are responsible for the code. Acked-by: is questionable, but as signers that use this tag tend to be active linux gatekeepers, false positives are tolerable. Reviewed-by: is included because signers responsible for the code thought that the review feedback for a changeset by that signer was valuable. This patch has been modified from Florian's original submission to change the supported signature types to the canonical forms and use slightly different spacing. A couple of spacing issues were also corrected in the original source. The command line argument was also renamed. Original-patch-by: Florian Mickler <florian@mickler.org> Signed-off-by: Florian Mickler <florian@mickler.org> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-24get_maintainer: repair STDIN usageWolfram Sang
Commit 22dd5b0cba50a197aaa3bd2790a29ee2e8e4e372 (fix perlcritic warnings) broke the ability to handle STDIN because the three argument version of open() cannot handle standard IO-streams (which is mentioned in PerlBestPractices, too). Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06scripts/get_maintainer.pl: fix possible infinite loopJoe Perches
If MAINTAINERS section entries are misformatted, it was possible to have an infinite loop. Correct the defect by always moving the index to the end of section + 1 Also, exit check for exclude as soon as possible. Signed-off-by: Joe Perches <joe@perches.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06get_maintainer: quote email address with periodStephen Hemminger
Picky mail systems won't accept email addresses where recipient has period in name; ie. David S. Miller <davemloft.net> will not work. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06get_maintainer: fix perlcritic warningsStephen Hemminger
perlcritic is a standard checker for Perl Best Practices. This patch fixes most of the warnings in the get_maintainer script. If kernel programmers are going to have checkpatch they should write clean scripts as well... Bareword file handle opened at line 176, column 1. See pages 202,204 of PBP. (Severity: 5) Two-argument "open" used at line 176, column 1. See page 207 of PBP. (Severity: 5) Bareword file handle opened at line 207, column 5. See pages 202,204 of PBP. (Severity: 5) Two-argument "open" used at line 207, column 5. See page 207 of PBP. (Severity: 5) Bareword file handle opened at line 246, column 6. See pages 202,204 of PBP. (Severity: 5) Two-argument "open" used at line 246, column 6. See page 207 of PBP. (Severity: 5) Bareword file handle opened at line 258, column 2. See pages 202,204 of PBP. (Severity: 5) Two-argument "open" used at line 258, column 2. See page 207 of PBP. (Severity: 5) Expression form of "eval" at line 983, column 17. See page 161 of PBP. (Severity: 5) Expression form of "eval" at line 985, column 17. See page 161 of PBP. (Severity: 5) Subroutine prototypes used at line 1186, column 1. See page 194 of PBP. (Severity: 5) Subroutine prototypes used at line 1206, column 1. See page 194 of PBP. (Severity: 5) Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06scripts/get_maintainer.pl: add ability to read from STDINJoe Perches
Doesn't need or accept '-' as a trailing option to read stdin. Doesn't print usage() after bad options. Adds --usage as command line equivalent of --help Suggested-by: Borislav Petkov <petkovbb@googlemail.com> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06scripts/get_maintainer.pl: change --sections to print in the same style as ↵Joe Perches
MAINTAINERS Signed-off-by: Joe Perches <joe@perches.com> Cc: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06scripts/get_maintainer.pl: add --sections, print entire matched subsystemJoe Perches
Print the complete contents of the matched subsystems in pattern match depth order. Sample output: $ ./scripts/get_maintainer.pl --sections -f drivers/net/usb/smsc95xx.c USB SMSC95XX ETHERNET DRIVER M:Steve Glendinning <steve.glendinning@smsc.com> L:netdev@vger.kernel.org S:Supported F:drivers/net/usb/smsc95xx.* USB SUBSYSTEM M:Greg Kroah-Hartman <gregkh@suse.de> L:linux-usb@vger.kernel.org W:http://www.linux-usb.org T:quilt kernel.org/pub/linux/kernel/people/gregkh/gregkh-2.6/ S:Supported F:Documentation/usb/ F:drivers/net/usb/ F:drivers/usb/ F:include/linux/usb.h F:include/linux/usb/ NETWORKING DRIVERS L:netdev@vger.kernel.org W:http://www.linuxfoundation.org/en/Net T:git git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6.git S:Odd Fixes F:drivers/net/ F:include/linux/if_* F:include/linux/*device.h THE REST M:Linus Torvalds <torvalds@linux-foundation.org> L:linux-kernel@vger.kernel.org Q:http://patchwork.kernel.org/project/LKML/list/ T:git git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.git S:Buried alive in reporters F:* F:*/ Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06scripts/get_maintainer.pl: add --file-emails, find embedded email addressesJoe Perches
Add an imperfect option to search a source file for email addresses. New option: --file-emails or --fe email addresses in files are freeform text and are nearly impossible to parse. Still, might as well try to do a somewhat acceptable job of finding them. This code should find all addresses that are in the form addr@domain.tld The code assumes that up to 3 alphabetic words along with dashes, commas, and periods that preceed the email address are a name. If 3 words are found for the name, and one of the first two words are a single letter and period, or just a single letter then the 3 words are use as name otherwise the last 2 words are used. Some variants that are shown correctly: John Smith <jksmith@domain.org> Random J. Developer <rjd@tld.com> Random J. Developer (rjd@tld.com) J. Random Developer rjd@tld.com Variants that are shown nominally correctly: Written by First Last (funny-addr@somecompany.com) is shown as: First Last <funny-addr@somecompany.com> Variants that are shown incorrectly: Some Really Long Name <srln@foo.bar> MontaVista Software, Inc. <source@mvista.com> are returned as: Long Name <srln@foo.bar> "Software, Inc" <source@mvista.com> --roles and --rolestats show "(in file)" for matches. For instance: Without -file-emails: $ ./scripts/get_maintainer.pl -f -nogit -roles net/core/netpoll.c David S. Miller <davem@davemloft.net> (maintainer:NETWORKING [GENERAL]) linux-kernel@vger.kernel.org (open list) With -fe: $ ./scripts/get_maintainer.pl -f -fe -nogit -roles net/core/netpoll.c David S. Miller <davem@davemloft.net> (maintainer:NETWORKING [GENERAL]) Matt Mackall <mpm@selenic.com> (in file) Ingo Molnar <mingo@redhat.com> (in file) linux-kernel@vger.kernel.org (open list) netdev@vger.kernel.org (open list:NETWORKING [GENERAL]) The number of email addresses in the file in not limited. Neither is the number of returned email addresses. Signed-off-by: Joe Perches <joe@perches.com> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-02get_maintainer.pl: teach git log to use --no-colorRichard Kennedy
When git has been set to always use color in .gitconfig then I get the warning message Bad divisor in main::vcs_assign: 0 This is caused by vcs_file_signoffs not matching any commits due to the pattern not understand the colour codes. Fix this by telling git log to never use colour. Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk> Acked-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11scripts/get_maintainer.pl: fix file exclusion X: logicJoe Perches
The following command doesn't generate any output. `./scripts/get_maintainer.pl --no-git -f drivers/net/wireless/wl12xx/wl1271_acx.c` An excluded "X:" pattern match in any section would cause a file not to match any other section. Signed-off-by: Joe Perches <joe@perches.com> Reported-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15scripts/get_maintainer.pl: support multiple VCSs - add mercurialJoe Perches
Restructure a bit for multiple version control systems support. Use a hash for each supported VCS that contains the commands and patterns used to find commits, logs, and signers. --git command line options are still used for hg except for --git-since. Use --hg-since instead. The number of commits can differ for git and hg, so --rolestats might be different. Style changes: Use common push style push(@foo...), simplify a return Bumped version to 0.23. Signed-off-by: Joe Perches <joe@perches.com> Cc: Marti Raudsepp <marti@juffo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15scripts/get_maintainer.pl: fix --non with --git-blame and cleanupsJoe Perches
Fix email matching without name --n and --git-blame Using --non and --git-blame caused maintainer signature matching to fail. Fixed that by adding 3rd argument to sub format_email to control show/hide name portion of address Slurp -f file instead of reading line-by-line for K: pattern matching. Suggested by Wolfram Sang as more efficient Refactor git command execution Break into 2 functions, execute/analyze Share code between --git and --git-blame Don't warn multiple times when git isn't installed Improve stats reporting --git-min-percent and -- rolestats now count the total number of commits for either the period of --git-since or if using --git-blame the commits used by the current file and calculate commit % as # of commits signed / total commits * 100 Code style cleaning Use consistent sub foo { my (args...) = @_; Signed-off-by: Joe Perches <joe@perches.com> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Greg KH <greg@kroah.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15scripts/get_maintainer.pl: add --roles and --rolestatsJoe Perches
--roles shows the role of each email address, i.e. why it was selected. --rolestats selects --roles and adds git log/blame signers #'s and % Multiple roles are possible (supporter, maintainer, git-signer...) --roles or --rolestats is meant to help identify appropriate maintainers to notify and should not be used with "git send-email --cc-cmd" Example output: Existing: $ ./scripts/get_maintainer.pl -f arch/x86/kernel/acpi/boot.c Corentin Chary <corentincj@iksaif.net> Karol Kozimor <sziwan@users.sourceforge.net> Len Brown <len.brown@intel.com> Pavel Machek <pavel@ucw.cz> Rafael J. Wysocki <rjw@sisk.pl> Thomas Gleixner <tglx@linutronix.de> Ingo Molnar <mingo@redhat.com> H. Peter Anvin <hpa@zytor.com> x86@kernel.org Yinghai Lu <yhlu.kernel@gmail.com> Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> acpi4asus-user@lists.sourceforge.net linux-pm@lists.linux-foundation.org linux-kernel@vger.kernel.org With --roles $ ./scripts/get_maintainer.pl --roles -f arch/x86/kernel/acpi/boot.c Corentin Chary <corentincj@iksaif.net> (maintainer:ASUS ACPI EXTRAS...) Karol Kozimor <sziwan@users.sourceforge.net> (maintainer:ASUS ACPI EXTRAS...) Len Brown <len.brown@intel.com> (supporter:SUSPEND TO RAM,git-signer) Pavel Machek <pavel@ucw.cz> (supporter:SUSPEND TO RAM) Rafael J. Wysocki <rjw@sisk.pl> (supporter:SUSPEND TO RAM) Thomas Gleixner <tglx@linutronix.de> (maintainer:X86 ARCHITECTURE...) Ingo Molnar <mingo@redhat.com> (maintainer:X86 ARCHITECTURE...,git-signer) H. Peter Anvin <hpa@zytor.com> (maintainer:X86 ARCHITECTURE...) x86@kernel.org (maintainer:X86 ARCHITECTURE...) Yinghai Lu <yhlu.kernel@gmail.com> (git-signer) Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> (git-signer) acpi4asus-user@lists.sourceforge.net (open list:ASUS ACPI EXTRAS...) linux-pm@lists.linux-foundation.org (open list:SUSPEND TO RAM) linux-kernel@vger.kernel.org (open list) With --rolestats $ ./scripts/get_maintainer.pl --rolestats -f arch/x86/kernel/acpi/boot.c Corentin Chary <corentincj@iksaif.net> (maintainer:ASUS ACPI EXTRAS...) Karol Kozimor <sziwan@users.sourceforge.net> (maintainer:ASUS ACPI EXTRAS...) Len Brown <len.brown@intel.com> (supporter:SUSPEND TO RAM,git-signer:16/79=20%) Pavel Machek <pavel@ucw.cz> (supporter:SUSPEND TO RAM) Rafael J. Wysocki <rjw@sisk.pl> (supporter:SUSPEND TO RAM) Thomas Gleixner <tglx@linutronix.de> (maintainer:X86 ARCHITECTURE...) Ingo Molnar <mingo@redhat.com> (maintainer:X86 ARCHITECTURE...,git-signer:29/79=37%) H. Peter Anvin <hpa@zytor.com> (maintainer:X86 ARCHITECTURE...) x86@kernel.org (maintainer:X86 ARCHITECTURE...) Yinghai Lu <yhlu.kernel@gmail.com> (git-signer:12/79=15%) Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> (git-signer:6/79=8%) acpi4asus-user@lists.sourceforge.net (open list:ASUS ACPI EXTRAS...) linux-pm@lists.linux-foundation.org (open list:SUSPEND TO RAM) linux-kernel@vger.kernel.org (open list) With --rolestats and --git-blame $ ./scripts/get_maintainer.pl --rolestats --git-blame -f arch/x86/kernel/acpi/boot.c Corentin Chary <corentincj@iksaif.net> (maintainer:ASUS ACPI EXTRAS...) Karol Kozimor <sziwan@users.sourceforge.net> (maintainer:ASUS ACPI EXTRAS...) Len Brown <len.brown@intel.com> (supporter:SUSPEND TO RAM,git-signer:16/79=20%,commits:22/154=14%) Pavel Machek <pavel@ucw.cz> (supporter:SUSPEND TO RAM) Rafael J. Wysocki <rjw@sisk.pl> (supporter:SUSPEND TO RAM) Thomas Gleixner <tglx@linutronix.de> (maintainer:X86 ARCHITECTURE...) Ingo Molnar <mingo@redhat.com> (maintainer:X86 ARCHITECTURE...,git-signer:29/79=37%,commits:36/154=23%) H. Peter Anvin <hpa@zytor.com> (maintainer:X86 ARCHITECTURE...) x86@kernel.org (maintainer:X86 ARCHITECTURE...) Yinghai Lu <yhlu.kernel@gmail.com> (git-signer:12/79=15%,commits:9/154=6%) Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> (git-signer:6/79=8%) Andi Kleen <ak@suse.de> (commits:11/154=7%) Andrew Morton <akpm@osdl.org> (commits:10/154=6%) acpi4asus-user@lists.sourceforge.net (open list:ASUS ACPI EXTRAS...) linux-pm@lists.linux-foundation.org (open list:SUSPEND TO RAM) linux-kernel@vger.kernel.org (open list) Other changes: Format git-signers email addresses a bit to reduce bad signatures Command line bad arguments emitted a verbose usage(), just show --help Version number bumped to .22 Ben Hutchings had the idea and created a good deal of this implementation. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-12get_maintainer: fix usage commentRoel Kluin
With the `s' it just won't work. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29scripts/get_maintainer.pl: add patch/file search for keywordsJoe Perches
Based on an idea from Wolfram Sang. Add search for MAINTAINERS line "K:" regex pattern match in a patch or file Matches are added after file pattern matches Add --keywords command line switch (default 1, on) Change version to 0.21 Signed-off-by: Joe Perches <joe@perches.com> Cc: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22scripts/get_maintainer.pl: add maintainers in order listed in matched sectionJoe Perches
Previous behavior was "bottom-up" in each section from the pattern "F:" entry that matched. Now information is entered into the various lists in the "as entered" order for each matched section. This also allows the F: entry to be put anywhere in a section, not just as the last entries in the section. And a couple of improvements: Don't alphabetically sort before outputting the matched scm, status, subsystem and web sections. Ignore content after a single email address so these entries are acceptable M: name <address> whatever other comment And a fix: Make an M: entry without a name again use the name from an immediately preceding P: line if it exists. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22scripts/get_maintainer.pl: add --remove-duplicatesJoe Perches
Allow control over the elimination of duplicate email names and addresses --remove-duplicates will use the first email name or address presented --noremove-duplicates will emit all names and addresses --remove-duplicates is enabled by default For instance: $ ./scripts/get_maintainer.pl -f drivers/char/tty_ioctl.c Greg Kroah-Hartman <gregkh@suse.de> Alan Cox <alan@linux.intel.com> Mike Frysinger <vapier@gentoo.org> Alexey Dobriyan <adobriyan@gmail.com> linux-kernel@vger.kernel.org $ ./scripts/get_maintainer.pl -f --noremove-duplicates drivers/char/tty_ioctl.c Greg Kroah-Hartman <gregkh@suse.de> Alan Cox <alan@redhat.com> Alan Cox <alan@linux.intel.com> Alan Cox <alan@lxorguk.ukuu.org.uk> Mike Frysinger <vapier@gentoo.org> Alexey Dobriyan <adobriyan@gmail.com> linux-kernel@vger.kernel.org Using --remove-duplicates could eliminate multiple maintainers that share the same name but not the same email address. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22scripts/get_maintainer.pl: using --separator implies --nomultilineJoe Perches
If a person sets a separator, it's only used if --nomultiline is set. Don't make the command line also include --nomultiline in that case. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22scripts/get_maintainer.pl: add .mailmap use, shell and email cleanupsJoe Perches
Add reading and using .mailmap file if it exists Convert address entries in .mailmap to first encountered address Don't terminate shell commands with \n Strip characters found after sign-offs by: name <address> [stripped] Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22scripts/get_maintainer.pl: better email routines, use perl not shell where ↵Joe Perches
possible Added format_email and parse_email routines to reduce inline use. Added email_address_inuse to eliminate multiple maintainer entries for the same email address, the first name encountered is used. Used internal perl equivalents of shell cmd use of grep|cut|sort|uniq Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
