path: root/scripts/kconfig/mconf.c
2011-06-06kconfig: nuke LKC_DIRECT_LINK cruftArnaud Lacombe
This interface is not (and has never been ?) used by any frontend, just get rid of it. Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
2011-06-06kconfig: annotate non-trivial fall-troughArnaud Lacombe
2010-09-19kconfig: replace KERNELVERSION usage by the mainmenu's promptArnaud Lacombe
Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Reviewed-by: Michal Marek <mmarek@suse.cz>
2010-09-19kconfig: rephrase help texts/comments not to include the package nameArnaud Lacombe
Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Reviewed-by: Randy Dunlap <rdunlap@xenotime.net> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Reviewed-by: Michal Marek <mmarek@suse.cz>
2010-09-19kconfig: allow build-time definition of the internal config prefixArnaud Lacombe
2010-09-19kconfig: rephrase help text not to mention the internal prefixArnaud Lacombe
2010-06-02menuconfig: improive help text a bitLi Zefan
Suggested-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-04-14menuconfig: add support to show hidden options which have promptsLi Zefan
Usage: Press <Z> to show all config symbols which have prompts. Quote Tim Bird: | I've been bitten by this numerous times. I most often | use ftrace on ARM, but when I go back to x86, I almost | always go through a sequence of searching for the | function graph tracer in the menus, then realizing it's | completely missing until I disable CC_OPTIMIZE_FOR_SIZE. | | Is there any way to have the menu item appear, but be | unsettable unless the SIZE option is disabled? I'm | not a Kconfig guru... I myself found this useful too. For example, I need to test ftrace/tracing and want to be sure all the tracing features are enabled, so I enter the "Tracers" menu, and press <Z> to see if there is any config hidden. I also noticed gconfig and xconfig have a button "Show all options", but that's a bit too much, and I think normally what we are not interested in those configs which have no prompt thus can't be changed by users. Exmaple: --- Tracers -*- Kernel Function Tracer - - Kernel Function Graph Tracer [*] Interrupts-off Latency Tracer - - Preemption-off Latency Tracer [*] Sysprof Tracer Here you can see 2 tracers are not selectable, and then can find out how to make them selectable. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-02-02kconfig: new configuration interface (nconfig)nir.tzachar@gmail.com
This patch was inspired by the kernel projects page, where an ncurses replacement for menuconfig was mentioned (by Sam Ravnborg). Building on menuconfig, this patch implements a more modern look interface using ncurses and ncurses' satellite libraries (menu, panel, form). The implementation does not depend on lxdialog, which is currently distributed with the kernel. Signed-off-by: Nir Tzachar <nir.tzachar@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-02-02menuconfig: wrap long help linesVadim Bendebury (вб)
Help text for certain config options is very extensive (the text includes the names of all other options the option in question depends on). Long lines are not wrapped, making it impossible to see the list without scrolling horizontally. This patch adds some logic which wraps help screen lines at word boundaries to prevent truncating. Tested by running ARCH=powerpc make menuconfig O=/tmp/build which shows that the long lines are now wrapped, and ARCH=powerpc make xconfig O=/tmp/build to demonstrate that it still compiles and operates as expected. Signed-off-by: Vadim Bendebury <vbendeb@google.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-20kconfig: make use of menu_get_ext_help in menuconfigCheng Renquan
The removed functions are moved into menu.c for sharing with gconfig & xconfig & config. Signed-off-by: Cheng Renquan <crquan@gmail.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-07-17kconfig: initialize the screen before using curses(3) functionsArnaud Lacombe
This is needed on non ncurses based implementation to get a properly initialized `stdscr' in main(). Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-06-09kconfig: handle comment entries within choice/endchoicePeter Korsgaard
Implement support for comment entries within choice groups. Comment entries are displayed visually distinct from normal configs, and selecting them is a no-op. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-05-04kconfig: fix MAC OS X warnings in menuconfigSam Ravnborg
Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Timur Tabi <timur@freescale.com>
2008-02-03kconfig: mark config as changed when loading an alternate configSam Ravnborg
Michal Zachar <mgzachar@mail.t-com.sk> reported that menuconfig did not save the new config when loading an alternate config unless he altered it manually. Mark config as changed upon load of alternate config fixed this. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Roman Zippel <zippel@linux-m68k.org>
2008-01-28kconfig: gettext support for menuconfigEGRY Gabor
Full gettext support for menuconfig. Signed-off-by: Egry Gabor <gaboregry1@t-online.hu> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2008-01-28kconfig: make kconfig MinGW friendlyLadislav Michl
Kconfig is powerfull tool. So powerfull that more and more software projects are using it for configuration. So instead of fixing some of them one by one, lets fix it in kernel and wait for sync. This work was originaly done for PTXdist - GPL licensed build system for userlands and cross-compilers, but it will not hurt kernel kconfig either. PTXdist menuconfig now works on Windows linked with PDCurses and compiled using MinGW - there is no termios and signals. * Do not include <sys/wait.h> and <signal.h> (comes from times when lxdialog was separate process) * Do not mess with termios directly and let curses tell screen size. Comment to commit c8dc68ad0fbd934e78e913b8a8d7b45945db4930 says check for screen size could be removed later, but because it didn't happen for more than year I left it here as well. * Save cursor position added by Sam Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2007-10-12kconfig/menuconfig: distinguish between selected-by-another options and commentsMatej Laitl
menuconfig currently represents options implied by another option ('select' directive in Kconfig) by prefixing them with '---'. Unfortunately the same notation is used for comments. If the implied option is module capable, user can still switch between Y and M, all without any feedback until she visits option's help. (try saying M to MAC80211 and then toggling CFG80211) This patch changes notation of selected-by-another items by introducing 2 new representations for implied options: {*} or {M} for options selected by another modularized one, thus builtin or module capable, -*- or -M- for options that cannot be at the moment changed by user. The idea is to represent actual capability of the option by braces (dashes) around and to always report actual state by * or M inside. Signed-off-by: Matej Laitl <strohel@gmail.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kconfig: fix segv fault in menuconfigSam Ravnborg
With specific configurations requesting help for certain menu lines caused menuconfig to crash. This was tracked down to a null pointer bug. Thanks to "Miles Lane" <miles.lane@gmail.com> for inital reporting and to Gabriel C <nix.or.die@googlemail.com> for the backtrace that helped me locating the bug. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kconfig: make comments stand out in menuconfigSam Ravnborg
Matěj Laitl <strohel@gmail.com> noticed that there was no way to distingush between comments and un-selectable menu lines. This patch marks comments with *** comment *** Cc: Matěj Laitl <strohel@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-25kconfig: attach help text to menusSam Ravnborg
Roman Zippel wrote: > A simple example would be > help texts, right now they are per symbol, but they should really be per > menu, so archs can provide different help texts for something. This patch does this and at the same time introduce a few API funtions used to access the help text. The relevant api functions are introduced in the various frontends. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2007-07-17kconfig: strip 'CONFIG_' automatically in kernel configuration searchBernhard Walle
Modify the ncurses configuration tool ('make menuconfig') in a way that the user can enter the search string (/) both with or without the leading 'CONFIG_'. This simplifies using copy & paste from .config files because you can select the whole word. Signed-off-by: Bernhard Walle <bwalle@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-02kconfig/menuconfig: do not hardcode '.config'Sam Ravnborg
Export and use the function conf_get_configname() to retreive the default configuration filename. Suggested by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-02menuconfig: remember alternate config filenameSam Ravnborg
When loading an alternate configuration use that file as current configuration filename. Make the filename visible in the dialog. Default continue to be .config. Inspired by patch from: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Cyrill Gorcunov <gorcunov@gmail.com>
2006-12-13[PATCH] kconfig: new function "bool conf_get_changed(void)"Karsten Wiese
Run "make xconfig" on a freshly untarred kernel-tree. Look at the floppy disk icon of the qt application, that has just started: Its in a normal, active state. Mouse click on it: .config is being saved. This patch series changes things so taht after the mouse click on the floppy disk icon, the icon is greyed out. If you mouse click on it now, nothing happens. If you change some CONFIG_*, the floppy disk icon returns to "active state", that is, if you mouse click it now, .config is written. This patch: Returns sym_change_count to reflect the .config's change state. All read only accesses of sym_change_count are replaced by calls to conf_get_changed() . mconfig.c is manipulated to ask for saving only when conf_get_changed() returned true. Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-30kconfig/menuconfig: do not let ncurses clutter screen on exitSam Ravnborg
Do not initialize ncurses twice - it causes unpredicable results. My display was sometimes weird after running make menuconfig and I had to execute 'reset' to properly restore my display. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-30kconfig/lxdialog: support resizeSam Ravnborg
In all dialogs now properly catch KEY_RESIZE and take proper action. In mconf try to behave sensibly when a dialog routine returns -ERRDISPLAYTOOSMALL. The original check for a screnn size of 80x19 is kept for now. It may make sense to remove it later, but thats anyway what much text is adjusted for. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-30kconfig/lxdialog: let <ESC><ESC> behave as expectedSam Ravnborg
<ESC><ESC> is used to step one back in the dialogs. When lxdialog became built-in pressing <ESC> once would cause one step back and pressing <ESC><ESC> would cause two steps back. This patch - based on concept from Roman Zippel <zippel@linux-m68k.org> - makes one <ESC> a noop and pressing <ESC><ESC> will cause one step backward. In addition the final yes/no dialog now has the option to go back to the the kernel configuration. So if you get too far out you can now go back to configuring the kernel without saving and starting all over again. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-30kconfig/menuconfig: lxdialog is now built-inSam Ravnborg
lxdialog was previously called as an external program causing screen to flicker when used. With this patch lxdialog is now built-in. It is loosly based om previous work by: Petr Baudis <pasky@ucw.cz> Following is a list of changes: o Moved build of dialog routings to kconfig Makefile o menubox + checklist uses a new item list to hold all menu items o in util.c implmented helper function to deal with item list o menubox now uses parameters to save scroll state (avoids temp file) o textbox now get text to be displayed as parameter and not a file o make sure to properly delete subwin's before main windows o killed unused files: lxdialog.c msgbox.c o modified return value for ESC to match direct calling o in a few places the code has been adjusted to 80 char wide o in textbox a small refactoring was made to make code remotely readable o in mconf removed all unused stuff (functions/variables) Following is a list of know short comings: a) pressing ESC twice will be interpreted as two ESC presses b) resize does not work. menuconfig needs to be restarted to be adjusted Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-30kconfig/lxdialog: add a new theme bluetitle which is now defaultSam Ravnborg
The bluetitle theme is a slightly modified version of the colorscheme that -mm users has been used to. The bluetitle is more readable especially on some LCD screens so it is now default. Anyone that really wants the old color selection can get it by selecting the classic color theme: make MENUCONFIG_COLOR=classic menuconfig The bluetitle theme was modified by Roman Zippel <zippel@linux-m68k.org> to further improve readability on LCD screens. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-30kconfig/lxdialog: add support for color themes and add blackbg themeSam Ravnborg
The blackbg theme was originally made by: Han Boetes It was copied from a patch by "Randy.Dunlap" <rdunlap@xenotime.net> which was also the inspiration source for the color theme support. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-01-16kbuild: create .kernelrelease at *config stepSam Ravnborg
To enable 'make kernelrelease' earlier now create .kernelrelease when one of the *config targets are used. Also introduce KERNELVERSION - only user is kconfig. KERNELVERSION was needed to display kernel version in menuconfig - KERNELRELEASE is not valid until configuration has completed. kconfig files modified to use KERNELVERSION. Bug reported by: Rene Rebe <rene@exactcode.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-12-16kconfig: move lxdialog to scripts/kconfig/lxdialogSam Ravnborg
The only lxdialog user i kconfig - for menuconfig. So move it to reflect this. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-10-30[PATCH] clarify menuconfig /(search) help textRandy Dunlap
Add explicit text about - where menuconfig '/' (search) searches for strings, - that substrings are allowed, and - that regular expressions are supported. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] Kill signed charsJ.A. Magallon
scripts/ is full of mismatches between char* params an signed char* arguments, and viceversa. gcc4 now complaints loud about this. Patch below deletes all those 'signed'. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] mconf.c needs locale.hJean-Christophe Dubois
This is failing on my cross-compilation environment (From a solaris system) using gcc-3.4.1 (as the compiler can't find a prototype for the setlocale() function). Signed-off-by: Jean-Christophe Dubois <jdubois@mc.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] Kconfig i18n supportArnaldo Carvalho de Melo
This patch adds i18n support for make *config, allowing users to have the config process in their own language. No printk was harmed in the process, don't worry, so all the bug reports, kernel messages, etc, remain in english, just the user tools to configure the kernel are internationalized. Users not interested in translations can just unset the related LANG, LC_ALL, etc env variables and have the config process in plain english, something like: LANG= make menuconfig is enough for having the whole config process in english. Or just don't install any translation file. Translations for brazilian portuguese are being done by a team of volunteers at: http://www.visionflex.inf.br/kernel_ptbr/pmwiki.php/Principal/Traducoes To start the translation process: make update-po-config This will generate the pot template named scripts/kconfig/linux.pot, copy it to, say, ~/es.po, to start the translation for spanish. To test your translation, as root issue this command: msgfmt -o /usr/share/locale/es/LC_MESSAGES/linux.mo ~/es.po Replace "es" with your language code. Then execute, for instance: make menuconfig The current patch doesn't use any optimization to reduce the size of the generated .mo file, it is possible to use the config option as a key, but this doesn't prevent the current patch from being used or the translations done under the current scheme to be in any way lost if we chose to do any kind of keying. Thanks to Fabricio Vaccari for starting the pt_BR (brazilian portuguese) translation effort, Thiago Maciera for helping me with the gconf.cc (QT frontent) i18n coding and to all the volunteers that are already working on the first translation, to pt_BR. I left the question on whether to ship the translations with the stock kernel sources to be discussed here, please share your suggestions. Signed-off-by: Arnaldo Carvalho de Melo <acme@conectiva.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org Signed-off-by: Andrew Morton <akpm@osdl.org>
