path: root/scripts/kconfig/zconf.hash.c_shipped
2008-01-28kconfig: remove "enable"Adrian Bunk
Kconfig had a synonym "enable" for "select" that was neither documented nor used. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kconfig: environment symbol supportRoman Zippel
Add the possibility to import a value from the environment into kconfig via the option syntax. Beside flexibility this has the advantage providing proper dependencies. Documented the options syntax. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: update _shipped files for kconfig syntax cleanupSam Ravnborg
Update _shipped files so regular user does not need to have bison/flex/gperf installed. Code changes were contained in previous commit. Used following program versions (on fedora): bison (GNU Bison) 2.3 flex 2.5.33 GNU gperf 3.0.2 Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-06-09kconfig: add symbol option config syntaxRoman Zippel
This adds the general framework to the parser to define options for config symbols with a syntax like: config FOO option bar[="arg"] Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-11-09[PATCH] kconfig: simplify symbol type parsingRoman Zippel
This simplifies the parser a bit by merging the various symbol types into a single token and adds the type to the keyword hash. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] kconfig: use gperf for kconfig keywordsRoman Zippel
Use gperf to generate a hash for the kconfig keywords. This greatly reduces the size of the generated scanner and makes it easier to extend kconfig. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
