path: root/scripts/mkuboot.sh
2011-01-07mkuboot.sh: Fail if mkimage is missingRoland Stigge
on building an uImage, I get: $ make uImage CHK include/linux/version.h CHK include/generated/utsrelease.h make[1]: `include/generated/mach-types.h' is up to date. CALL scripts/checksyscalls.sh CHK include/generated/compile.h Kernel: arch/arm/boot/Image is ready SHIPPED arch/arm/boot/compressed/lib1funcs.S AS arch/arm/boot/compressed/lib1funcs.o LD arch/arm/boot/compressed/vmlinux OBJCOPY arch/arm/boot/zImage Kernel: arch/arm/boot/zImage is ready UIMAGE arch/arm/boot/uImage "mkimage" command not found - U-Boot images will not be built Image arch/arm/boot/uImage is ready $ I.e. it says: "uImage is ready" even though the uImage file doesn't exist because mkimage is missing. I propose the attached patch. Signed-off-by: Roland Stigge <stigge@antcom.de> Signed-off-by: Michal Marek <mmarek@suse.cz>
2007-05-02kbuild/mkuboot.sh: allow spaces in CROSS_COMPILEUwe kleine-König
I'm currently using CROSS_COMPILE="ccache arm-linux-". With that the bash builtin command "type" searches for ccache and arm-linux-mkimage and so sets MKIMAGE="/path/to/ccache" as I don't have arm-linux-mkimage. Then the script dies with an error, that ccache doesn't support the argument -A. This patch adds some quoting such that it works again for me. Please note that this patch doesn't help you if you use ${CROSSCOMPILE}-mkimage and ccache as mkuboot.sh now searches for the command "ccache arm-linux-mkimage". Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-02-14[PATCH] search a little harder for mkimageMike Frysinger
Check to see if `${CROSS_COMPILE}mkimage` exists and if not, fall back to the standard `mkimage` The Blackfin toolchain includes mkimage, but we dont want to namespace collide with any of the user's system setup, so we prefix it with our toolchain name. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Oleg Verych <olecom@flower.upol.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
