commit f880eea68fe593342fa6e09be9bb661f3c297aec upstream.
Use specific prototype instead of an opaque pointer so that the
compiler can catch function prototype mismatch.
Reviewed-by: Mathieu Malaterre <malat@debian.org>
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
commit ec91e78d378cc5d4b43805a1227d8e04e5dfa17d upstream.
Commit e49ce14150c6 ("modpost: use linker section to generate table.")
was not so cool as we had expected first; it ended up with ugly section
hacks when commit dd2a3acaecd7 ("mod/file2alias: make modpost compile
on darwin again") came in.
Given a certain degree of unknowledge about the link stage of host
programs, I really want to see simple, stupid table lookup so that
this works in the same way regardless of the underlying executable
format.
Acked-by: Mathieu Malaterre <malat@debian.org>
[nc: Omit rpmsg, sdw, tbsvc, and typec as they do not exist here]
The commit 8724ecb07229 ("Input: allow matching device IDs on property
bits") started using property bits when generating module aliases for input
handlers, but did not adjust the generation of MODALIAS attribute on input
device uevents, breaking automatic module loading. Given that no handler
currently uses property bits in their module tables, let's revert this part
of the commit for now.
Reported-by: Damien Wyart <damien.wyart@gmail.com>
Tested-by: Damien Wyart <damien.wyart@gmail.com>
Fixes: 8724ecb07229 ("Input: allow matching device IDs on property bits")
Let's allow matching input devices on their property bits, both in-kernel
and when generating module aliases.
Tested-by: Roderick Colenbrander <roderick.colenbrander@sony.com>
Move the definition of fsl_mc_device_id to its proper location in
mod_devicetable.h, and add fsl-mc bus support to devicetable-offsets.c
and file2alias.c to enable device table matching. With this patch udev
based module loading of fsl-mc drivers is supported.
Signed-off-by: Stuart Yoder <stuart.yoder@nxp.com>
Because of an improper dereference, a stray 'C' character was output to
the modalias when no 'compatible' was specified. This is the case for
some old PowerMac drivers which only set the 'name' property. Fix it to
let them match again.
Reported-by: Mathieu Malaterre <malat@debian.org>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Tested-by: Mathieu Malaterre <malat@debian.org>
Cc: Philipp Zabel <p.zabel@pengutronix.de>
Cc: Andreas Schwab <schwab@linux-m68k.org>
Fixes: 6543becf26fff6 ("mod/file2alias: make modalias generation safe for cross compiling")
Cc: stable@vger.kernel.org # v3.9+
Since the wildcard at the end of OF module aliases is gone, autoloading
of modules that don't match a device's last (most generic) compatible
value fails.
For example the CODA960 VPU on i.MX6Q has the SoC specific compatible
"fsl,imx6q-vpu" and the generic compatible "cnm,coda960". Since the
driver currently only works with knowledge about the SoC specific
integration, it doesn't list "cnm,cod960" in the module device table.
This results in the device compatible
"of:NvpuT<NULL>Cfsl,imx6q-vpuCcnm,coda960" not matching the module alias
"of:N*T*Cfsl,imx6q-vpu" anymore, whereas before commit 2f632369ab79
("modpost: don't add a trailing wildcard for OF module aliases") it
matched the module alias "of:N*T*Cfsl,imx6q-vpu*".
This patch adds two module aliases for each compatible, one without the
wildcard and one with "C*" appended.
$ modinfo coda | grep imx6q
alias: of:N*T*Cfsl,imx6q-vpuC*
Fixes: 2f632369ab79 ("modpost: don't add a trailing wildcard for OF module aliases")
Link: http://lkml.kernel.org/r/1462203339-15340-1-git-send-email-p.zabel@pengutronix.de
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
Cc: Javier Martinez Canillas <javier@osg.samsung.com>
Cc: Brian Norris <computersforpeace@gmail.com>
Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Cc: <stable@vger.kernel.org> [4.5+]
Commit ac551828993e ("modpost: i2c aliases need no trailing wildcard")
removed the wildcard at the end of the I2C module aliases because I2C
devices have no IDs so the aliases are just arbitrary device names.
This is also true for OF modaliases since a compatible string is used to
define a specific IP hardware block. So the modalias should match a
specific compatible string and not attempt to match a compatible string
whose name matches the beginning of another one.
For example, the following driver module:
$ modinfo cros_ec_keyb | grep alias
alias: platform:cros-ec-keyb
alias: of:N*T*Cgoogle,cros-ec-keyb*
will be tried to be loaded for an alias of:N*T*Cgoogle,cros-ec-keyb-v2
but there could be a different driver that supports the device for that
compatible string so it's better to remove the trailing wildcard for OF.
Also, remove the word "always" from the add_wildcard() function comment
since that was carried from the time where a wildcard was always added
at the end of the module alias for all the devices.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Suggested-by: Brian Norris <computersforpeace@gmail.com>
Reviewed-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Consistently use uuid_le type in the Hyper-V driver code.
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"Here is the first batch of updates for sound system on 4.4-rc1.
Again at this time, the update looks fairly calm; no big changes in
either ALSA core or ASoC infrastructures, rather all small cleanups,
in addition to the new stuff as usual.
The biggest changes are about Firewire sound devices. It gained lots
of new device support, and MIDI functionality. Also there are updates
for a few still working-in-progress stuff (topology API and ASoC
skylake), too. But overall, this update should give no big surprise.
Some highlights are below:
Core:
- A few more Kconfig items for tinification; it's marked as EXPERT,
so normal user should't be bothered :)
- Refactoring with a new PCM hw_constraint helper
- Removal of unused transfer_ack_{begin,end} PCM callbacks
Firewire:
- Restructuring of code subtree, lots of refactoring
- Support AMDTP variants
- New driver for Digidesign 002/003 family
- Adds support for TASCAM FireOne to ALSA OXFW driver
- Add MIDI support to TASCAM and Digi00x devices
HD-Audio:
- Automated modalias generation for codec drivers, finally
- Improvement on heuristics for setting mixer name
- A few fixes for longstanding bugs on Creative CA0132 cards
- Addition of audio rate callback with i915 communication
- Fix suspend issue on recent Dell XPS
- Intel Lewisburg controller support
ASoC:
- Updates to the topology userspace interface
- Big updates to the Renesas support (rcar)
- More updates for supporting Intel Sky Lake systems
- New drivers for Asahi Kasei Microdevices AK4613, Allwinnner A10,
Cirrus Logic WM8998, Dialog DA7219, Nuvoton NAU8825, Rockchip
S/PDIF, and Atmel class D amplifier
USB-Audio:
- A fix for newer Roland MIDI devices
- Quirks and workarounds for Zoom R16/24 device
Misc:
- A few fixes for some old Cirrus CS46xx PCI sound boards
- Yet another fixes for some old ESS Maestro3 PCI sound boards"
* tag 'sound-4.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (330 commits)
ALSA: hda - Add Intel Lewisburg device IDs Audio
ALSA: hda - Apply pin fixup for HP ProBook 6550b
ALSA: hda - Fix lost 4k BDL boundary workaround
ALSA: maestro3: Fix Allegro mute until master volume/mute is touched
ALSA: maestro3: Enable docking support for Dell Latitude C810
ALSA: firewire-digi00x: add another rawmidi character device for MIDI control ports
ALSA: firewire-digi00x: add MIDI operations for MIDI control port
ALSA: firewire-digi00x: rename identifiers of MIDI operation for physical ports
ALSA: cs46xx: Fix suspend for all channels
ALSA: cs46xx: Fix Duplicate front for CS4294 and CS4298 codecs
ALSA: DocBook: Add soc-ops.c and soc-compress.c
ALSA: hda - Add / fix kernel doc comments
ALSA: Constify ratden/ratnum constraints
ALSA: hda - Disable 64bit address for Creative HDA controllers
ALSA: hda/realtek - Dell XPS one ALC3260 speaker no sound after resume back
ALSA: hda/ca0132 - Convert leftover pr_info() and pr_err()
ASoC: fsl: Use #ifdef instead of #if for CONFIG_PM_SLEEP
ASoC: rt5645: Sort the order for register bit defines
ASoC: dwc: add check for master/slave format
ASoC: rt5645: Add the HWEQ for the speaker output
For generating modalias entries automatically, move the definition of
struct hda_device_id to linux/mod_devicetable.h and add the handling
of this record in file2alias helper. The new modalias is represented
with combination of vendor id, device id, and api version as
"hdaudio:vNrNaN".
This patch itself doesn't convert the existing modaliases. Since they
were added manually, this patch won't give any regression by itself at
this point.
[Modified the modalias format to adapt the api_version field, and drop
invalid ANY_ID definition by tiwai]
Signed-off-by: Subhransu S. Prusty <subhransu.s.prusty@intel.com>
Reviewed-by: Vinod Koul <vinod.koul@intel.com>
Tested-by: Subhransu S Prusty <subhransu.s.prusty@intel.com>
The device alias now looks like mei:S:uuid:N:*
In that way we can bind different drivers to clients with
different protocol versions if required.
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
scripts/mod/file2alias.c:add_uuid() convert UUID into a single string
which does not conform to the standard little endian UUID formatting.
This patch changes add_uuid() to output same format as %pUL and modifies
the mei driver to match the change.
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
Device drivers typically use ACPI _HIDs/_CIDs listed in struct device_driver
acpi_match_table to match devices. However, for generic drivers, we do not
want to list _HID for all supported devices. Also, certain classes of devices
do not have _CID (e.g. SATA, USB). Instead, we can leverage ACPI _CLS,
which specifies PCI-defined class code (i.e. base-class, subclass and
programming interface). This patch adds support for matching ACPI devices using
the _CLS method.
To support loadable module, current design uses _HID or _CID to match device's
modalias. With the new way of matching with _CLS this would requires modification
to the current ACPI modalias key to include _CLS. This patch appends PCI-defined
class-code to the existing ACPI modalias as following.
acpi:<HID>:<CID1>:<CID2>:..:<CIDn>:<bbsspp>:
E.g:
# cat /sys/devices/platform/AMDI0600:00/modalias
acpi:AMDI0600:010601:
where bb is th base-class code, ss is te sub-class code, and pp is the
programming interface code
Since there would not be _HID/_CID in the ACPI matching table of the driver,
this patch adds a field to acpi_device_id to specify the matching _CLS.
static const struct acpi_device_id ahci_acpi_match[] = {
{ ACPI_DEVICE_CLASS(PCI_CLASS_STORAGE_SATA_AHCI, 0xffffff) },
In this case, the corresponded entry in modules.alias file would be:
alias acpi*:010601:* ahci_platform
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org>
Signed-off-by: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB updates from Greg KH:
"Here's the big USB patchset for 4.2-rc1. As is normal these days, the
majority of changes are in the gadget drivers, with a bunch of other
small driver changes.
All of these have been in linux-next with no reported issues"
* tag 'usb-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (175 commits)
usb: dwc3: Use ASCII space in Kconfig
usb: chipidea: add work-around for Marvell HSIC PHY startup
usb: chipidea: allow multiple instances to use default ci_default_pdata
dt-bindings: Consolidate ChipIdea USB ci13xxx bindings
phy: add Marvell HSIC 28nm PHY
phy: Add Marvell USB 2.0 OTG 28nm PHY
dt-bindings: Add Marvell PXA1928 USB and HSIC PHY bindings
USB: ssb: use devm_kzalloc
USB: ssb: fix error handling in ssb_hcd_create_pdev()
usb: isp1760: check for null return from kzalloc
cdc-acm: Add support of ATOL FPrint fiscal printers
usb: chipidea: usbmisc_imx: Remove unneeded semicolon
USB: usbtmc: add device quirk for Rigol DS6104
USB: serial: mos7840: Use setup_timer
phy: twl4030-usb: add ABI documentation
phy: twl4030-usb: remove incorrect pm_runtime_get_sync() in probe function.
phy: twl4030-usb: remove pointless 'suspended' test in 'suspend' callback.
phy: twl4030-usb: make runtime pm more reliable.
drivers:usb:fsl: Fix compilation error for fsl ehci drv
usb: renesas_usbhs: Don't disable the pipe if Control write status stage
A previous commit, c93b76b34b4d ("mei: bus: report also uuid in module
alias") caused a build error as I missed applying a needed patch to add
some macros to uapi/linux/uuid.h. Instead of those additional macros,
change the mei code to use the existing uuid structure directly.
Fixes: c93b76b34b4d
Cc: Tomas Winkler <tomas.winkler@intel.com>
Cc: Samuel Ortiz <sameo@linux.intel.com>
In order to automate modules matching add device uuid
which is reported in client enumeration, keep also
the name that is needed in for nfc distinguishing radio vendor
Report mei:name:uuid
Cc: linux-api@vger.kernel.org
UTMI+ Low Pin Interface (ULPI) is a commonly used PHY
interface for USB 2.0. The ULPI specification describes a
standard set of registers which the vendors can extend for
their specific needs. ULPI PHYs provide often functions
such as charger detection and ADP sensing and probing.
There are two major issues that the bus type is meant to
tackle:
Firstly, ULPI registers are accessed from the controller.
The bus provides convenient method for the controller
drivers to share that access with the actual PHY drivers.
Secondly, there are already platforms that assume ULPI PHYs
are runtime detected, such as many Intel Baytrail based
platforms. They do not provide any kind of hardware
description for the ULPI PHYs like separate ACPI device
object that could be used to enumerate a device from.
Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
Acked-by: David Cohen <david.a.cohen@linux.intel.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
Add MIPS Common Device Memory Map (CDMM) support in the form of a bus in
the standard Linux device model. Each device attached via CDMM is
discoverable via an 8-bit type identifier and may contain a number of
blocks of memory mapped registers in the CDMM region. IRQs are expected
to be handled separately.
Due to the per-cpu (per-VPE for MT cores) nature of the CDMM devices,
all the driver callbacks take place from workqueues which are run on the
right CPU for the device in question, so that the driver doesn't need to
be as concerned about which CPU it is running on. Callbacks also exist
for when CPUs are taken offline, so that any per-CPU resources used by
the driver can be disabled so they don't get forcefully migrated. CDMM
devices are created as children of the CPU device they are attached to.
Any existing CDMM configuration by the bootloader will be inherited,
however platforms wishing to enable CDMM should implement the weak
mips_cdmm_phys_base() function (see asm/cdmm.h) so that the bus driver
knows where it should put the CDMM region in the physical address space
if the bootloader hasn't already enabled it.
A mips_cdmm_early_probe() function is also provided to allow early boot
or particularly low level code to set up the CDMM region and probe for a
specific device type, for example early console or KGDB IO drivers for
the EJTAG Fast Debug Channel (FDC) CDMM device.
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/9599/
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module updates from Rusty Russell:
"Nothing major: the stricter permissions checking for sysfs broke a
staging driver; fix included. Greg KH said he'd take the patch but
hadn't as the merge window opened, so it's included here to avoid
breaking build"
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
staging: fix up speakup kobject mode
Use 'E' instead of 'X' for unsigned module taint flag.
VERIFY_OCTAL_PERMISSIONS: stricter checking for sysfs perms.
kallsyms: fix percpu vars on x86-64 with relocation.
kallsyms: generalize address range checking
module: LLVMLinux: Remove unused function warning from __param_check macro
Fix: module signature vs tracepoints: add new TAINT_UNSIGNED_MODULE
module: remove MODULE_GENERIC_TABLE
module: allow multiple calls to MODULE_DEVICE_TABLE() per module
module: use pr_cont
Commit 78551277e4df5: "Input: i8042 - add PNP modaliases" had a bug, where the
second call to MODULE_DEVICE_TABLE() overrode the first resulting in not all
the modaliases being exposed.
This fixes the problem by including the name of the device_id table in the
__mod_*_device_table alias, allowing us to export several device_id tables
per module.
Suggested-by: Kay Sievers <kay@vrfy.org>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Signed-off-by: Tom Gundersen <teg@jklm.no>
The x86 CPU feature modalias handling existed before it was reimplemented
generically. This patch aligns the x86 handling so that it
(a) reuses some more code that is now generic;
(b) uses the generic format for the modalias module metadata entry, i.e., it
now uses 'cpu:type:x86,venVVVVfamFFFFmodMMMM:feature:,XXXX,YYYY' instead of
the 'x86cpu:vendor:VVVV:family:FFFF:model:MMMM:feature:,XXXX,YYYY' that was
used before.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Acked-by: H. Peter Anvin <hpa@linux.intel.com>
This patch adds support for advertising optional CPU features over udev
using the modalias, and for declaring compatibility with/dependency upon
such a feature in a module.
The mapping between feature numbers and actual features should be provided
by the architecture in a file called <asm/cpufeature.h> which exports the
following functions/macros:
- cpu_feature(FEAT), a preprocessor macro that maps token FEAT to a
numeric index;
- bool cpu_have_feature(n), returning whether this CPU has support for
feature #n;
- MAX_CPU_FEATURES, an upper bound for 'n' in the previous function.
The feature can then be enabled by setting CONFIG_GENERIC_CPU_AUTOPROBE
for the architecture.
For instance, a module that registers its module init function using
module_cpu_feature_match(FEAT_X, module_init_function)
will be probed automatically when the CPU's support for the 'FEAT_X'
feature is advertised over udev, and will only allow the module to be
loaded by hand if the 'FEAT_X' feature is supported.
Commit afe2dab4f6 ("USB: add hex/bcd detection to usb modalias generation")
changed the routine that generates alias ranges. Before that change, only
digits 0-9 were supported; the commit tried to fix the case when the range
includes higher values than 0x9.
Unfortunately, the commit didn't fix the case when the range includes both
0x9 and 0xA, meaning that the final range must look like [x-9A-y] where
x <= 0x9 and y >= 0xA -- instead the [x-9A-x] range was produced.
Modprobe doesn't complain as it sees no difference between no-match and
bad-pattern results of fnmatch().
Fixing this simple bug to fix the aliases.
Also changing the hardcoded beginning of the range to uppercase as all the
other letters are also uppercase in the device version numbers.
Fortunately, this affects only the dvb-usb-dib0700 module, AFAIK.
Signed-off-by: Jan Moskyto Matejka <mq@suse.cz>
Cc: stable <stable@vger.kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kbuild updates from Michal Marek:
- fix for make headers_install argv explosion with too long path
- scripts/setlocalversion does not call git update-index needlessly
- fix for the src.rpm produced by make rpm-pkg. The new make
image_name can be useful also for other packaging tools.
- scripts/mod/devicetable-offsets.o is not rebuilt during each make run
- make modules_install dependency fix
- scripts/sortextable portability fix
- fix for kbuild to generate the output directory for all object files
in subdirs.
- a couple of minor fixes
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
kbuild: create directory for dir/file.o
tools/include: use stdint types for user-space byteshift headers
Makefile: Fix install error with make -j option
Fix a build warning in scripts/mod/file2alias.c
improve modalias building
scripts/mod: Spelling s/DEVICEVTABLE/DEVICETABLE/
kbuild: fix error when building from src rpm
scripts/setlocalversion on write-protected source tree
Makefile.lib: align DTB quiet_cmd
kbuild: fix make headers_install when path is too long
Add RapidIO-specific modalias generation to enable udev notifications
about RapidIO-specific events.
The RapidIO modalias string format is shown below:
"rapidio:vNNNNdNNNNavNNNNadNNNN"
Where:
v - Device Vendor ID (16 bit),
d - Device ID (16 bit),
av - Assembly Vendor ID (16 bit),
ad - Assembly ID (16 bit),
as they are reported in corresponding Capability Registers (CARs)
of each RapidIO device.
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Cc: Matt Porter <mporter@kernel.crashing.org>
Cc: Li Yang <leoli@freescale.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: Andre van Herk <andre.van.herk@Prodrive.nl>
Cc: Micha Nelissen <micha.nelissen@Prodrive.nl>
Cc: Stef van Os <stef.van.os@Prodrive.nl>
Cc: Jean Delvare <jdelvare@suse.de>
On some systems, __used is already defined in sys/cdefs.h and causes
a build warning:
scripts/mod/file2alias.c:85:1: warning: "__used" redefined
In file included from /usr/include/stdio.h:64,
from scripts/mod/modpost.h:1,
from scripts/mod/file2alias.c:13:
/usr/include/sys/cdefs.h:146:1: warning: this is the location of the previous definition
This adds an extra check before defining the __used macro to see if
the macro was already defined elsewhere.
Signed-off-by: Daniel Tang <dt.tangr@gmail.com>
mei client bus will present some of the mei clients
as devices for other standard subsystems
Implement the probe, remove, match, device addtion routines, along with
the sysfs and uevent ones. mei_cl_device_id is also added to
mod_devicetable.h
A mei-cleint-bus.txt document describing the rationale and the API usage
is also added while ABI/testing/sysfs-bus-mei describeis the modalias ABI.
Use the target compiler to compute the offsets for the fields of the
device_id structures, so that it won't be broken by different alignments
between the host and target ABIs.
This also fixes missing endian corrections for some modaliases.
Signed-off-by: Andreas Schwab <schwab@linux-m68k.org>
~0 can not be casted to u8. Instead of using the IPACK_ANY_ID for the format
field we introduce a new IPACK_ANY_FORMAT specifically for that field and
defined as 0xff.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Jens Taprogge <jens.taprogge@taprogge.org>
Acked-by: Samuel Iglesias Gonsálvez <siglesias@igalia.com>
The modaliases look like ipack:fXvNdM, where X is the format version (8
bit) and N and M are the vendor and device ID represented as 32 bit
hexadecimal numbers each. Using 32 bits allows us to define IPACK_ANY_ID
as (~0) without interfering with the valid ids.
The resulting modalias string for ipoctal.ko looks like this (once
ipoctal provides a device table):
alias: ipack:f01v000000F0d00000048*
alias: ipack:f01v000000F0d0000002A*
alias: ipack:f01v000000F0d00000022*
(output from modinfo)
Signed-off-by: Samuel Iglesias Gonsálvez <siglesias@igalia.com>
Some composite USB devices provide multiple interfaces
with different functions, all using "vendor-specific"
for class/subclass/protocol. Another OS use interface
numbers to match the driver and interface. It seems
these devices are designed with that in mind - using
static interface numbers for the different functions.
This adds support for matching against the
bInterfaceNumber, allowing such devices to be supported
without having to resort to testing against interface
number whitelists and/or blacklists in the probe.
Signed-off-by: Bjørn Mork <bjorn@mork.no>
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
Pull HID subsystem updates from Jiri Kosina:
"Apart from various driver updates and added support for a number of
new devices (mostly multitouch ones, but not limited to), there is one
change that is worth pointing out explicitly: creation of HID device
groups and proper autoloading of hid-multitouch, implemented by Henrik
Rydberg."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (50 commits)
HID: wacom: fix build breakage without CONFIG_LEDS_CLASS
HID: waltop: Extend barrel button fix
HID: hyperv: Set the hid drvdata correctly
HID: wacom: Unify speed setting
HID: wacom: Add speed setting for Intuos4 WL
HID: wacom: Move Graphire raport header check.
HID: uclogic: Add support for UC-Logic TWHL850
HID: explain the signed/unsigned handling in hid_add_field()
HID: handle logical min/max signedness properly in parser
HID: logitech: read all 32 bits of report type bitfield
HID: wacom: Add LED selector control for Wacom Intuos4 WL
HID: hid-multitouch: fix wrong protocol detection
HID: wiimote: Fix IR data parser
HID: wacom: Add tilt reporting for Intuos4 WL
HID: multitouch: MT interface matching for Baanto
HID: hid-multitouch: Only match MT interfaces
HID: Create a common generic driver
HID: hid-multitouch: Switch to device groups
HID: Create a generic device group
HID: Allow bus wildcard matching
Most HID drivers do not need to know what bus driver is in use.
A generic group driver can drive any hid device, and the device
list should not need to be duplicated for each new bus.
This patch adds wildcard matching to the HID bus, simplifying device
list handling for group drivers.
Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
Acked-by: Benjamin Tissoires <benjamin.tissoires@gmail.com>
HID devices are only partially presented to userland. Hotplugged
devices emit events containing a modalias based on the basic bus,
vendor and product entities. However, in practise a hid device can
depend on details such as a single usb interface or a particular item
in a report descriptor.
This patch adds a device group to the hid device id, and broadcasts it
using uevent and the device modalias. The module alias generation is
modified to match. As a consequence, a device with a non-zero group
will be processed by the corresponding group driver instead of by the
generic hid driver.
The symbol table on x86-64 starts to have entries that have names
like:
_GLOBAL__sub_I_65535_0___mod_x86cpu_device_table
They are of type STT_FUNCTION and this one had a length of 18. This
matched the device ID validation logic and it barfed because the
length did not meet the device type's criteria.
FATAL: arch/x86/crypto/aesni-intel: sizeof(struct x86cpu_device_id)=16 is not a modulo of the size of section __mod_x86cpu_device_table=18.
Fix definition of struct x86cpu_device_id in mod_devicetable.h
These are some kind of compiler tool internal stuff being emitted and
not something we want to inspect in modpost's device ID table
validation code.
So skip the symbol if it is not of type STT_OBJECT.
Acked-by: Sam Ravnborg <sam@ravnborg.org>
This was done to resolve a conflict in the drivers/base/cpu.c file.
commit e49ce14150c64b29a8dd211df785576fa19a9858 breaks cross compiling
the linux kernel on darwin hosts.
This fix introduce some minimal glue to adopt linker section handling
for darwin hosts.
Signed-off-by: Andreas Bießmann <andreas@biessmann.de>
CC: Rusty Russell <rusty@rustcorp.com.au>
CC: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
CC: Jochen Friedrich <jochen@scram.de>
CC: Samuel Ortiz <sameo@linux.intel.com>
CC: "K. Y. Srinivasan" <kys@microsoft.com>
Tested-by: Bernhard Walle <bernhard@bwalle.de>
Handling of isapnp module aliases was broken by commit
626596e295d477c0fefa08cd5daa7dd011b1bb2c by changing "isapnp" string to "isa".
The code was then modified by commit
e49ce14150c64b29a8dd211df785576fa19a9858 but this bug remained.
Change the string back to "isapnp".
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
We currently include commas on both sides of the feature ID in a
modalias, but this prevents the lowest numbered feature of a CPU from
being matched. Since all feature IDs have the same length, we do not
need to worry about substring matches, so omit commas from the
modalias entirely.
Avoid generating multiple adjacent wildcards when there is no
feature ID to match.
Acked-by: Thomas Renninger <trenn@suse.de>
Acked-by: H. Peter Anvin <hpa@zytor.com>
This was done to resolve a merge and build problem with the
drivers/acpi/processor_driver.c file.
There's a growing number of drivers that support a specific x86 feature
or CPU. Currently loading these drivers currently on a generic
distribution requires various driver specific hacks and it often
doesn't work.
This patch adds auto probing for drivers based on the x86 cpuid
information, in particular based on vendor/family/model number
and also based on CPUID feature bits.
For example a common issue is not loading the SSE 4.2 accelerated
CRC module: this can significantly lower the performance of BTRFS
which relies on fast CRC.
Another issue is loading the right CPUFREQ driver for the current CPU.
Currently distributions often try all all possible driver until
one sticks, which is not really a good way to do this.
It works with existing udev without any changes. The code
exports the x86 information as a generic string in sysfs
that can be matched by udev's pattern matching.
This scheme does not support numeric ranges, so if you want to
handle e.g. ranges of model numbers they have to be encoded
in ASCII or simply all models or families listed. Fixing
that would require changing udev.
Another issue is that udev will happily load all drivers that match,
there is currently no nice way to stop a specific driver from
being loaded if it's not needed (e.g. if you don't need fast CRC)
But there are not that many cpu specific drivers around and they're
all not that bloated, so this isn't a particularly serious issue.
Originally this patch added the modalias to the normal cpu
sysdevs. However sysdevs don't have all the infrastructure
needed for udev, so it couldn't really autoload drivers.
This patch instead adds the CPU modaliases to the cpuid devices,
which are real devices with full support for udev. This implies
that the cpuid driver has to be loaded to use this.
This patch just adds infrastructure, some driver conversions
in followups.
Thanks to Kay for helping with some sysfs magic.
v2: Constifcation, some updates
v4: (trenn@suse.de):
- Use kzalloc instead of kmalloc to terminate modalias buffer
- Use uppercase hex values to match correctly against hex values containing
letters
Cc: Dave Jones <davej@redhat.com>
Cc: Kay Sievers <kay.sievers@vrfy.org>
Cc: Jen Axboe <axboe@kernel.dk>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Huang Ying <ying.huang@intel.com>
Cc: Len Brown <lenb@kernel.org>
Signed-off-by: Thomas Renninger <trenn@suse.de>
bus."
This reverts commit 5dd7bf59e0e8563265b3e5b33276099ef628fcc7.
This change is wrong on many levels. First and foremost, it causes a
regression. On boot on Assabet, which this patch gives a codec id of
'ucb1x00', it gives:
ucb1x00 ID not found: 1005
0x1005 is a valid ID for the UCB1300 device.
Secondly, this patch is way over the top in terms of complexity. The
only device which has been seen to be connected with this MCP code is
the UCB1x00 (UCB1200, UCB1300 etc) devices, and they all use the same
driver. Adding a match table, requiring the codec string to match the
hardware ID read out of the ID register, etc is completely over the top
when we can just read the hardware ID register.
Autogenerated GPG tag for Rusty D1ADB8F1: 15EE 8D6C AB0E 7F0C F999 BFCB D920 0E6C D1AD B8F1
* tag 'for-linus' of git://github.com/rustyrussell/linux:
module_param: check that bool parameters really are bool.
intelfbdrv.c: bailearly is an int module_param
paride/pcd: fix bool verbose module parameter.
module_param: make bool parameters really bool (drivers & misc)
module_param: make bool parameters really bool (arch)
module_param: make bool parameters really bool (core code)
kernel/async: remove redundant declaration.
printk: fix unnecessary module_param_name.
lirc_parallel: fix module parameter description.
module_param: avoid bool abuse, add bint for special cases.
module_param: check type correctness for module_param_array
modpost: use a table rather than a giant if/else statement.
modules: sysfs - export: taint, coresize, initsize
kernel/params: replace DEBUGP with pr_debug
module: replace DEBUGP with pr_debug
module: struct module_ref should contains long fields
module: Fix performance regression on modules with large symbol tables
module: Add comments describing how the "strmap" logic works
Fix up conflicts in scripts/mod/file2alias.c due to the new linker-
generated table approach to adding __mod_*_device_table entries. The
ARM sa11x0 mcp bus needed to be converted to that too.
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (59 commits)
rtc: max8925: Add function to work as wakeup source
mfd: Add pm ops to max8925
mfd: Convert aat2870 to dev_pm_ops
mfd: Still check other interrupts if we get a wm831x touchscreen IRQ
mfd: Introduce missing kfree in 88pm860x probe routine
mfd: Add S5M series configuration
mfd: Add s5m series irq driver
mfd: Add S5M core driver
mfd: Improve mc13xxx dt binding document
mfd: Fix stmpe section mismatch
mfd: Fix stmpe build warning
mfd: Fix STMPE I2c build failure
mfd: Constify aat2870-core i2c_device_id table
gpio: Add support for stmpe variant 801
mfd: Add support for stmpe variant 801
mfd: Add support for stmpe variant 610
mfd: Add support for STMPE SPI interface
mfd: Separate out STMPE controller and interface specific code
misc: Remove max8997-muic sysfs attributes
mfd: Remove unused wm831x_irq_data_to_mask_reg()
Fix up trivial conflict in drivers/leds/Kconfig due to addition of
LEDS_MAX8997 and LEDS_TCA6507 next to each other.
This means (most) future busses need only have one hunk in their
patch. Also took the opportunity to check that function matches the
type.
Again, inspired by Alessandro's patch series.
Cc: Alessandro Rubini <rubini@gnudd.com>
We look for symbols of form __mod_<busname>_device_table, and for all
but three cases we use a standard interation function (do_table) to
walk over the contents and dump out the aliases.
Alessandro Rubini did this first, I just repainted the bikeshed a bit.
Signed-off-by: Jochen Friedrich <jochen@scram.de>
This patch adds the necessary support in file2alias.c to define
suitable aliases based on the amba_id table in AMBA driver modules.
This should be sufficient to allow such modules to be auto-loaded
via udev. The AMBA bus driver's uevent hotplug code is also
modified to pass an approriate MODALIAS string in the event.
For simplicity, the AMBA ID is treated an an opaque 32-bit numeber.
Module alises use patterns as appropriate to describe the value-
mask pairs described in the driver's amba_id list.
The proposed alias format is (extended regex):
^amba:d(HEX){8}$
Where HEX is a single upper-case HEX digit or a pattern (? or []
expression) matching a single upper-case HEX digit, as expected by
udev.
"d" is short for "device", following existing alias naming
conventions for other device types. This adds some flexibility for
unambiguously extending the alias format in the future by adding
additional leading and trailing fields, if this turns out to be
necessary.
Signed-off-by: Dave Martin <dave.martin@linaro.org>
Acked-by: Pawel Moll <pawel.moll@arm.com>
