commit b3c0a4dab7e35a9b6d69c0415641d2280fdefb2b upstream.
Because of an improper dereference, a stray 'C' character was output to
the modalias when no 'compatible' was specified. This is the case for
some old PowerMac drivers which only set the 'name' property. Fix it to
let them match again.
Reported-by: Mathieu Malaterre <malat@debian.org>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Tested-by: Mathieu Malaterre <malat@debian.org>
Cc: Philipp Zabel <p.zabel@pengutronix.de>
Cc: Andreas Schwab <schwab@linux-m68k.org>
Fixes: 6543becf26fff6 ("mod/file2alias: make modalias generation safe for cross compiling")
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module updates from Rusty Russell:
"Nothing exciting, minor tweaks and cleanups"
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
scripts: [modpost] add new sections to white list
modpost: Add flag -E for making section mismatches fatal
params: don't ignore the rest of cmdline if parse_one() fails
modpost: abort if a module symbol is too long
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"Here is the first batch of updates for sound system on 4.4-rc1.
Again at this time, the update looks fairly calm; no big changes in
either ALSA core or ASoC infrastructures, rather all small cleanups,
in addition to the new stuff as usual.
The biggest changes are about Firewire sound devices. It gained lots
of new device support, and MIDI functionality. Also there are updates
for a few still working-in-progress stuff (topology API and ASoC
skylake), too. But overall, this update should give no big surprise.
Some highlights are below:
Core:
- A few more Kconfig items for tinification; it's marked as EXPERT,
so normal user should't be bothered :)
- Refactoring with a new PCM hw_constraint helper
- Removal of unused transfer_ack_{begin,end} PCM callbacks
Firewire:
- Restructuring of code subtree, lots of refactoring
- Support AMDTP variants
- New driver for Digidesign 002/003 family
- Adds support for TASCAM FireOne to ALSA OXFW driver
- Add MIDI support to TASCAM and Digi00x devices
HD-Audio:
- Automated modalias generation for codec drivers, finally
- Improvement on heuristics for setting mixer name
- A few fixes for longstanding bugs on Creative CA0132 cards
- Addition of audio rate callback with i915 communication
- Fix suspend issue on recent Dell XPS
- Intel Lewisburg controller support
ASoC:
- Updates to the topology userspace interface
- Big updates to the Renesas support (rcar)
- More updates for supporting Intel Sky Lake systems
- New drivers for Asahi Kasei Microdevices AK4613, Allwinnner A10,
Cirrus Logic WM8998, Dialog DA7219, Nuvoton NAU8825, Rockchip
S/PDIF, and Atmel class D amplifier
USB-Audio:
- A fix for newer Roland MIDI devices
- Quirks and workarounds for Zoom R16/24 device
Misc:
- A few fixes for some old Cirrus CS46xx PCI sound boards
- Yet another fixes for some old ESS Maestro3 PCI sound boards"
* tag 'sound-4.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (330 commits)
ALSA: hda - Add Intel Lewisburg device IDs Audio
ALSA: hda - Apply pin fixup for HP ProBook 6550b
ALSA: hda - Fix lost 4k BDL boundary workaround
ALSA: maestro3: Fix Allegro mute until master volume/mute is touched
ALSA: maestro3: Enable docking support for Dell Latitude C810
ALSA: firewire-digi00x: add another rawmidi character device for MIDI control ports
ALSA: firewire-digi00x: add MIDI operations for MIDI control port
ALSA: firewire-digi00x: rename identifiers of MIDI operation for physical ports
ALSA: cs46xx: Fix suspend for all channels
ALSA: cs46xx: Fix Duplicate front for CS4294 and CS4298 codecs
ALSA: DocBook: Add soc-ops.c and soc-compress.c
ALSA: hda - Add / fix kernel doc comments
ALSA: Constify ratden/ratnum constraints
ALSA: hda - Disable 64bit address for Creative HDA controllers
ALSA: hda/realtek - Dell XPS one ALC3260 speaker no sound after resume back
ALSA: hda/ca0132 - Convert leftover pr_info() and pr_err()
ASoC: fsl: Use #ifdef instead of #if for CONFIG_PM_SLEEP
ASoC: rt5645: Sort the order for register bit defines
ASoC: dwc: add check for master/slave format
ASoC: rt5645: Add the HWEQ for the speaker output
In our ARC toolchain the default linker script includes special
sections used for code and data located in special fast memory.
To avoid warnings we add these sections i.e. .cmem* and .fmt_slot*
to white list.
Signed-off-by: Noam Camus <noamc@ezchip.com>
Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com>
For generating modalias entries automatically, move the definition of
struct hda_device_id to linux/mod_devicetable.h and add the handling
of this record in file2alias helper. The new modalias is represented
with combination of vendor id, device id, and api version as
"hdaudio:vNrNaN".
This patch itself doesn't convert the existing modaliases. Since they
were added manually, this patch won't give any regression by itself at
this point.
[Modified the modalias format to adapt the api_version field, and drop
invalid ANY_ID definition by tiwai]
Signed-off-by: Subhransu S. Prusty <subhransu.s.prusty@intel.com>
Reviewed-by: Vinod Koul <vinod.koul@intel.com>
Tested-by: Subhransu S Prusty <subhransu.s.prusty@intel.com>
The section mismatch warning can be easy to miss during the kernel build
process. Allow it to be marked as fatal to be easily caught and prevent
bugs from slipping in.
Setting CONFIG_SECTION_MISMATCH_WARN_ONLY=y causes these warnings to be
non-fatal, since there are a number of section mismatches when using
allmodconfig on some architectures, and we do not want to break these
builds by default.
Signed-off-by: Nicolas Boichat <drinkcat@chromium.org>
Change-Id: Ic346706e3297c9f0d790e3552aa94e5cff9897a6
The device alias now looks like mei:S:uuid:N:*
In that way we can bind different drivers to clients with
different protocol versions if required.
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
scripts/mod/file2alias.c:add_uuid() convert UUID into a single string
which does not conform to the standard little endian UUID formatting.
This patch changes add_uuid() to output same format as %pUL and modifies
the mei driver to match the change.
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull core kbuild updates from Michal Marek:
- modpost portability fix
- linker script fix
- genksyms segfault fix
- fixdep cleanup
- fix for clang detection
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
kbuild: Fix clang detection
kbuild: fixdep: drop meaningless hash table initialization
kbuild: fixdep: optimize code slightly
genksyms: Regenerate parser
genksyms: Duplicate function pointer type definitions segfault
kbuild: Fix .text.unlikely placement
Avoid conflict with host definitions when cross-compiling
Certain platforms (e. g. BSD-based ones) define some ELF constants
according to host. This patch fixes problems with cross-building
Linux kernel on these platforms (e. g. building ARM 32-bit version
on x86-64 host).
Signed-off-by: Pavel Fedin <p.fedin@samsung.com>
Signed-off-by: Michal Marek <mmarek@suse.com>
Module symbols have a limited length, but currently the build system
allows the build finishing even if the driver code contains a too long
symbol name, which eventually overflows the modversion_info[] item.
The compiler may catch at compiling *.mod.c like
CC xxx.mod.o
xxx.mod.c:18:16: warning: initializer-string for array of chars is too long
but it's merely a warning.
This patch adds the check of the symbol length in modpost and stops
the build properly.
Currently MODULE_NAME_LEN is defined in modpost.c instead of referring
to the definition in kernel header because including linux/module.h is
messy and we must cover cross-compilation.
Pull power management and ACPI updates from Rafael Wysocki:
"These are fixes on top of the previous PM+ACPI pull requests
(including one fix for a 4.1 regression) and two commits adding
_CLS-based device enumeration support to the ACPI core and the ATA
subsystem that waited for the latest ACPICA changes to be merged.
Specifics:
- Fix for an ACPI resources management regression introduced during
the 4.1 cycle (that unfortunately went into -stable) effectively
reverting the bad commit along with the recent fixups on top of it
and using an alternative approach to address the underlying issue
(Rafael J Wysocki).
- Fix for a memory leak and an incorrect return value in an error
code path in the ACPI LPSS (Low-Power Subsystem) driver (Rafael J
Wysocki).
- Fix for a leftover dangling pointer in an error code path in the
new wakeup IRQ support code (Rafael J Wysocki).
- Fix to prevent infinite loops (due to errors in other places) from
happening in the core generic PM domains support code (Geert
Uytterhoeven).
- Hibernation documentation update/clarification (Uwe Geuder).
- Support for _CLS-based device enumeration in the ACPI core and in
the ATA subsystem (Suravee Suthikulpanit)"
* tag 'pm+acpi-4.2-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
PM / wakeirq: Avoid setting power.wakeirq too hastily
ata: ahci_platform: Add ACPI _CLS matching
ACPI / scan: Add support for ACPI _CLS device matching
PM / hibernate: clarify resume documentation
PM / Domains: Avoid infinite loops in attach/detach code
ACPI / LPSS: Fix up acpi_lpss_create_device()
ACPI / PNP: Reserve ACPI resources at the fs_initcall_sync stage
The tilegx and tilepro compilers use .coldtext for their unlikely
executed text section name, so an __attribute__((cold)) function
will (when compiled with higher optimization levels) land in
the .coldtext section.
Modify modpost to add .coldtext to the set of OTHER_TEXT_SECTIONS
so we don't get warnings about referencing such a section in an
__ex_table block, and then also modify arch/tile/lib/memcpy_user_64.c
so that it uses plain ".coldtext" instead of ".coldtext.memcpy".
The latter naming is a relic of an earlier use of -ffunction-sections,
which we no longer use by default.
Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Device drivers typically use ACPI _HIDs/_CIDs listed in struct device_driver
acpi_match_table to match devices. However, for generic drivers, we do not
want to list _HID for all supported devices. Also, certain classes of devices
do not have _CID (e.g. SATA, USB). Instead, we can leverage ACPI _CLS,
which specifies PCI-defined class code (i.e. base-class, subclass and
programming interface). This patch adds support for matching ACPI devices using
the _CLS method.
To support loadable module, current design uses _HID or _CID to match device's
modalias. With the new way of matching with _CLS this would requires modification
to the current ACPI modalias key to include _CLS. This patch appends PCI-defined
class-code to the existing ACPI modalias as following.
acpi:<HID>:<CID1>:<CID2>:..:<CIDn>:<bbsspp>:
E.g:
# cat /sys/devices/platform/AMDI0600:00/modalias
acpi:AMDI0600:010601:
where bb is th base-class code, ss is te sub-class code, and pp is the
programming interface code
Since there would not be _HID/_CID in the ACPI matching table of the driver,
this patch adds a field to acpi_device_id to specify the matching _CLS.
static const struct acpi_device_id ahci_acpi_match[] = {
{ ACPI_DEVICE_CLASS(PCI_CLASS_STORAGE_SATA_AHCI, 0xffffff) },
In this case, the corresponded entry in modules.alias file would be:
alias acpi*:010601:* ahci_platform
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org>
Signed-off-by: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB updates from Greg KH:
"Here's the big USB patchset for 4.2-rc1. As is normal these days, the
majority of changes are in the gadget drivers, with a bunch of other
small driver changes.
All of these have been in linux-next with no reported issues"
* tag 'usb-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (175 commits)
usb: dwc3: Use ASCII space in Kconfig
usb: chipidea: add work-around for Marvell HSIC PHY startup
usb: chipidea: allow multiple instances to use default ci_default_pdata
dt-bindings: Consolidate ChipIdea USB ci13xxx bindings
phy: add Marvell HSIC 28nm PHY
phy: Add Marvell USB 2.0 OTG 28nm PHY
dt-bindings: Add Marvell PXA1928 USB and HSIC PHY bindings
USB: ssb: use devm_kzalloc
USB: ssb: fix error handling in ssb_hcd_create_pdev()
usb: isp1760: check for null return from kzalloc
cdc-acm: Add support of ATOL FPrint fiscal printers
usb: chipidea: usbmisc_imx: Remove unneeded semicolon
USB: usbtmc: add device quirk for Rigol DS6104
USB: serial: mos7840: Use setup_timer
phy: twl4030-usb: add ABI documentation
phy: twl4030-usb: remove incorrect pm_runtime_get_sync() in probe function.
phy: twl4030-usb: remove pointless 'suspended' test in 'suspend' callback.
phy: twl4030-usb: make runtime pm more reliable.
drivers:usb:fsl: Fix compilation error for fsl ehci drv
usb: renesas_usbhs: Don't disable the pipe if Control write status stage
A previous commit, c93b76b34b4d ("mei: bus: report also uuid in module
alias") caused a build error as I missed applying a needed patch to add
some macros to uapi/linux/uuid.h. Instead of those additional macros,
change the mei code to use the existing uuid structure directly.
Fixes: c93b76b34b4d
Cc: Tomas Winkler <tomas.winkler@intel.com>
Cc: Samuel Ortiz <sameo@linux.intel.com>
In order to automate modules matching add device uuid
which is reported in client enumeration, keep also
the name that is needed in for nfc distinguishing radio vendor
Report mei:name:uuid
Cc: linux-api@vger.kernel.org
UTMI+ Low Pin Interface (ULPI) is a commonly used PHY
interface for USB 2.0. The ULPI specification describes a
standard set of registers which the vendors can extend for
their specific needs. ULPI PHYs provide often functions
such as charger detection and ADP sensing and probing.
There are two major issues that the bus type is meant to
tackle:
Firstly, ULPI registers are accessed from the controller.
The bus provides convenient method for the controller
drivers to share that access with the actual PHY drivers.
Secondly, there are already platforms that assume ULPI PHYs
are runtime detected, such as many Intel Baytrail based
platforms. They do not provide any kind of hardware
description for the ULPI PHYs like separate ACPI device
object that could be used to enumerate a device from.
Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
Acked-by: David Cohen <david.a.cohen@linux.intel.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
"Quentin opened a can of worms by adding extable entry checking to
modpost, but most architectures seem fixed now. Thanks to all
involved.
Last minute rebase because I noticed a "[PATCH]" had snuck into a
commit message somehow"
modpost: don't emit section mismatch warnings for compiler optimizations
modpost: expand pattern matching to support substring matches
modpost: do not try to match the SHT_NUL section.
modpost: fix extable entry size calculation.
modpost: fix inverted logic in is_extable_fault_address().
modpost: handle -ffunction-sections
modpost: Whitelist .text.fixup and .exception.text
params: handle quotes properly for values not of form foo="bar".
modpost: document the use of struct section_check.
modpost: handle relocations mismatch in __ex_table.
scripts: add check_extable.sh script.
modpost: mismatch_handler: retrieve tosym information only when needed.
modpost: factorize symbol pretty print in get_pretty_name().
modpost: add handler function pointer to sectioncheck.
modpost: add .sched.text and .kprobes.text to the TEXT_SECTIONS list.
modpost: add strict white-listing when referencing sections.
module: do not print allocation-fail warning on bogus user buffer size
kernel/module.c: fix typos in message about unused symbols
Currently an allyesconfig build [gcc-4.9.1] can generate the following:
WARNING: vmlinux.o(.text.unlikely+0x3864): Section mismatch in
reference from the function cpumask_empty.constprop.3() to the
variable .init.data:nmi_ipi_mask
which comes from the cpumask_empty usage in arch/x86/kernel/nmi_selftest.c.
Normally we would not see a symbol entry for cpumask_empty since it is:
static inline bool cpumask_empty(const struct cpumask *srcp)
however in this case, the variant of the symbol gets emitted when GCC does
constant propagation optimization.
Fix things up so that any locally optimized constprop variants don't warn
when accessing variables that live in the __init sections.
Currently the match() function supports a leading * to match any
prefix and a trailing * to match any suffix. However there currently
is not a combination of both that can be used to target matches of
whole families of functions that share a common substring.
Here we expand the *foo and foo* match to also support *foo* with
the goal of targeting compiler generated symbol names that contain
strings like ".constprop." and ".isra."
Trying to match the SHT_NUL section isn't useful and causes build failures
on parisc and mn10300 since the addition of section strict white-listing
and __ex_table sanitizing.
Signed-off-by: Quentin Casasnovas <quentin.casasnovas@oracle.com>
Reported-by: Guenter Roeck <linux@roeck-us.net>
Fixes: 050e57fd5936 ("modpost: add strict white-listing when referencing....")
Fixes: 52dc0595d540 ("modpost: handle relocations mismatch in __ex_table.")
Tested-by: Guenter Roeck <linux@roeck-us.net>
As Guenter pointed out, we were never really calculating the extable entry
size because the pointer arithmetic was simply wrong. We want to check
we're handling the second relocation in __ex_table to infer an entry size,
but we were using (void*) pointers instead of Elf_Rel[a]* ones.
This fixes the problem by moving that check in the caller (since we can
deal with different types of relocations) and add is_second_extable_reloc()
to make the whole thing more readable.
CC: Rusty Russell <rusty@rustcorp.com.au>
As Guenter pointed out, we want to assert that extable_entry_size has been
discovered and not the other way around. Moreover, this sanity check is
only valid when we're not dealing with the first relocation in __ex_table,
since we have not discovered the extable entry size at that point.
This was leading to a divide-by-zero on some architectures and make the
build fail.
52dc0595d540 introduced OTHER_TEXT_SECTIONS for identifying what
sections could validly have __ex_table entries. Unfortunately, it
wasn't tested with -ffunction-sections, which some architectures
use.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
32-bit and 64-bit ARM use these sections to store executable code, so
they must be whitelisted in modpost's table of valid text sections.
Signed-off-by: Thierry Reding <treding@nvidia.com>
struct section_check is used as a generic way of describing what
relocations are authorized/forbidden when running modpost. This commit
tries to describe how each field is used.
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (Fixed "mist"ake)
__ex_table is a simple table section where each entry is a pair of
addresses - the first address is an address which can fault in kernel
space, and the second address points to where the kernel should jump to
when handling that fault. This is how copy_from_user() does not crash the
kernel if userspace gives a borked pointer for example.
If one of these addresses point to a non-executable section, something is
seriously wrong since it either means the kernel will never fault from
there or it will not be able to jump to there. As both cases are serious
enough, we simply error out in these cases so the build fails and the
developper has to fix the issue.
In case the section is executable, but it isn't referenced in our list of
authorized sections to point to from __ex_table, we just dump a warning
giving more information about it. We do this in case the new section is
executable but isn't supposed to be executed by the kernel. This happened
with .altinstr_replacement, which is executable but is only used to copy
instructions from - we should never have our instruction pointer pointing
in .altinstr_replacement. Admitedly, a proper fix in that case would be to
just set .altinstr_replacement NX, but we need to warn about future cases
like this.
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (added long casts)
This will be useful when we want to have special handlers which need to go
through more hops to print useful information to the user.
sched.text and .kprobes.text should behave exactly like .text with regards
to how we should warn about referencing sections which might get discarded
at runtime.
Prints a warning when a section references a section outside a strict
white-list. This will be useful to print a warning if __ex_table
references a non-executable section.
Add MIPS Common Device Memory Map (CDMM) support in the form of a bus in
the standard Linux device model. Each device attached via CDMM is
discoverable via an 8-bit type identifier and may contain a number of
blocks of memory mapped registers in the CDMM region. IRQs are expected
to be handled separately.
Due to the per-cpu (per-VPE for MT cores) nature of the CDMM devices,
all the driver callbacks take place from workqueues which are run on the
right CPU for the device in question, so that the driver doesn't need to
be as concerned about which CPU it is running on. Callbacks also exist
for when CPUs are taken offline, so that any per-CPU resources used by
the driver can be disabled so they don't get forcefully migrated. CDMM
devices are created as children of the CPU device they are attached to.
Any existing CDMM configuration by the bootloader will be inherited,
however platforms wishing to enable CDMM should implement the weak
mips_cdmm_phys_base() function (see asm/cdmm.h) so that the bus driver
knows where it should put the CDMM region in the physical address space
if the bootloader hasn't already enabled it.
A mips_cdmm_early_probe() function is also provided to allow early boot
or particularly low level code to set up the CDMM region and probe for a
specific device type, for example early console or KGDB IO drivers for
the EJTAG Fast Debug Channel (FDC) CDMM device.
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/9599/
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 updates from Catalin Marinas:
- eBPF JIT compiler for arm64
- CPU suspend backend for PSCI (firmware interface) with standard idle
states defined in DT (generic idle driver to be merged via a
different tree)
- Support for CONFIG_DEBUG_SET_MODULE_RONX
- Support for unmapped cpu-release-addr (outside kernel linear mapping)
- set_arch_dma_coherent_ops() implemented and bus notifiers removed
- EFI_STUB improvements when base of DRAM is occupied
- Typos in KGDB macros
- Clean-up to (partially) allow kernel building with LLVM
- Other clean-ups (extern keyword, phys_addr_t usage)
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (51 commits)
arm64: Remove unneeded extern keyword
ARM64: make of_device_ids const
arm64: Use phys_addr_t type for physical address
aarch64: filter $x from kallsyms
arm64: Use DMA_ERROR_CODE to denote failed allocation
arm64: Fix typos in KGDB macros
arm64: insn: Add return statements after BUG_ON()
arm64: debug: don't re-enable debug exceptions on return from el1_dbg
Revert "arm64: dmi: Add SMBIOS/DMI support"
arm64: Implement set_arch_dma_coherent_ops() to replace bus notifiers
of: amba: use of_dma_configure for AMBA devices
arm64: Correct ftrace calls to aarch64_insn_gen_branch_imm()
arm64:mm: initialize max_mapnr using function set_max_mapnr
setup: Move unmask of async interrupts after possible earlycon setup
arm64: LLVMLinux: Fix inline arm64 assembly for use with clang
arm64: pageattr: Correctly adjust unaligned start addresses
net: bpf: arm64: fix module memory leak when JIT image build fails
arm64: add PSCI CPU_SUSPEND based cpu_suspend support
arm64: kernel: introduce cpu_init_idle CPU operation
Similar to ARM, AArch64 is generating $x and $d syms... which isn't
terribly helpful when looking at %pF output and the like. Filter those
out in kallsyms, modpost and when looking at module symbols.
Seems simplest since none of these check EM_ARM anyway, to just add it
to the strchr used, rather than trying to make things overly
complicated.
initcall_debug improves:
dmesg_before.txt: initcall $x+0x0/0x154 [sg] returned 0 after 26331 usecs
dmesg_after.txt: initcall init_sg+0x0/0x154 [sg] returned 0 after 15461 usecs
Signed-off-by: Kyle McMartin <kyle@redhat.com>
Avoid the variable length array (vla), just use PATH_MAX instead.
This not only makes this code clang friedly, it also leads to a
code size reduction:
51765 2224 12416 66405 10365 scripts/mod/modpost.old
51677 2224 12416 66317 1030d scripts/mod/modpost.new
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Internally used symbols of modpost don't need to be externally visible;
make them static. Also constify the string arrays so they resist in the
r/o section instead of being runtime writable.
Those changes lead to a small size reduction as can be seen below:
51381 2640 12416 66437 10385 scripts/mod/modpost.old
51765 2224 12416 66405 10365 scripts/mod/modpost.new
For several years, the pattern "foo$" has effectively been treated as
equivalent to "foo" due to a bug in the (misnamed) helper
number_prefix(). This hasn't been observed to cause any problems, so
remove the broken $ functionality and change all foo$ patterns to foo.
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
The scripts/mod/modpost.c triggers the following warning:
scripts/mod/modpost.c: In function ‘remove_dot’:
scripts/mod/modpost.c:1710:10: warning: ignoring return value of ‘strtoul’, declared with attribute warn_unused_result [-Wunused-result]
The remove_dot function that calls strtoul does not care about the
numeric value of the string that is parsed but only looks for the
end of the numeric sequence. As such, it's equivalent to just skip
over all digits.
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Pull kbuild misc updates from Michal Marek:
"This is the non-critical part of kbuild for v3.16-rc1:
- make deb-pkg can do s390x and arm64
- new patterns in scripts/tags.sh
- scripts/tags.sh skips userspace tools' sources (which sometimes
have copies of kernel structures) and symlinks
- improvements to the objdiff tool
- two new coccinelle patches
- other minor fixes"
* 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
scripts: objdiff: support directories for the augument of record command
scripts: objdiff: fix a comment
scripts: objdiff: change the extension of disassembly from .o to .dis
scripts: objdiff: improve path flexibility for record command
scripts: objdiff: remove unnecessary code
scripts: objdiff: direct error messages to stderr
scripts: objdiff: get the path to .tmp_objdiff more simply
deb-pkg: Add automatic support for s390x architecture
coccicheck: Add unneeded return variable test
kbuild: Fix a typo in documentation
kbuild: trivial - use tabs for code indent where possible
kbuild: trivial - remove trailing empty lines
coccinelle: Check for missing NULL terminators in of_device_id tables
scripts/tags.sh: ignore symlink'ed source files
scripts/tags.sh: add regular expression replacement pattern for memcg
builddeb: add arm64 in the supported architectures
builddeb: use $OBJCOPY variable instead of objcopy
scripts/tags.sh: ignore code of user space tools
scripts/tags.sh: add pattern for DEFINE_HASHTABLE
.gitignore: ignore Module.symvers in all directories
"Most of this is cleaning up various driver sysfs permissions so we can
re-add the perm check (we unified the module param and sysfs checks,
but the module ones were stronger so we weakened them temporarily).
Param parsing gets documented, and also "--" now forces args to be
handed to init (and ignored by the kernel).
Module NX/RO protections get tightened: we now set them before calling
parse_args()"
module: set nx before marking module MODULE_STATE_COMING.
samples/kobject/: avoid world-writable sysfs files.
drivers/hid/hid-picolcd_fb: avoid world-writable sysfs files.
drivers/staging/speakup/: avoid world-writable sysfs files.
drivers/regulator/virtual: avoid world-writable sysfs files.
drivers/scsi/pm8001/pm8001_ctl.c: avoid world-writable sysfs files.
drivers/hid/hid-lg4ff.c: avoid world-writable sysfs files.
drivers/video/fbdev/sm501fb.c: avoid world-writable sysfs files.
drivers/mtd/devices/docg3.c: avoid world-writable sysfs files.
speakup: fix incorrect perms on speakup_acntsa.c
cpumask.h: silence warning with -Wsign-compare
Documentation: Update kernel-parameters.tx
param: hand arguments after -- straight to init
modpost: Fix resource leak in read_dump()
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial into next
Pull trivial tree changes from Jiri Kosina:
"Usual pile of patches from trivial tree that make the world go round"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (23 commits)
staging: go7007: remove reference to CONFIG_KMOD
aic7xxx: Remove obsolete preprocessor define
of: dma: doc fixes
doc: fix incorrect formula to calculate CommitLimit value
doc: Note need of bc in the kernel build from 3.10 onwards
mm: Fix printk typo in dmapool.c
modpost: Fix comment typo "Modules.symvers"
Kconfig.debug: Grammar s/addition/additional/
wimax: Spelling s/than/that/, wording s/destinatary/recipient/
aic7xxx: Spelling s/termnation/termination/
arm64: mm: Remove superfluous "the" in comment
of: Spelling s/anonymouns/anonymous/
dma: imx-sdma: Spelling s/determnine/determine/
ath10k: Improve grammar in comments
ath6kl: Spelling s/determnine/determine/
of: Improve grammar for of_alias_get_id() documentation
drm/exynos: Spelling s/contro/control/
radio-bcm2048.c: fix wrong overflow check
doc: printk-formats: do not mention casts for u64/s64
doc: spelling error changes
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Function read_dump() memory maps the input via grab_file(), but fails to call
the corresponding unmap function. Add the missing call to release_file().
Detected by Coverity: CID 1192419
Signed-off-by: Christian Engelmayer <cengelma@gmx.at>
"Nothing major: the stricter permissions checking for sysfs broke a
staging driver; fix included. Greg KH said he'd take the patch but
hadn't as the merge window opened, so it's included here to avoid
breaking build"
staging: fix up speakup kobject mode
Use 'E' instead of 'X' for unsigned module taint flag.
VERIFY_OCTAL_PERMISSIONS: stricter checking for sysfs perms.
kallsyms: fix percpu vars on x86-64 with relocation.
kallsyms: generalize address range checking
module: LLVMLinux: Remove unused function warning from __param_check macro
Fix: module signature vs tracepoints: add new TAINT_UNSIGNED_MODULE
module: remove MODULE_GENERIC_TABLE
module: allow multiple calls to MODULE_DEVICE_TABLE() per module
module: use pr_cont
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core and sysfs updates from Greg KH:
"Here's the big driver core / sysfs update for 3.15-rc1.
Lots of kernfs updates to make it useful for other subsystems, and a
few other tiny driver core patches.
All have been in linux-next for a while"
* tag 'driver-core-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (42 commits)
Revert "sysfs, driver-core: remove unused {sysfs|device}_schedule_callback_owner()"
kernfs: cache atomic_write_len in kernfs_open_file
numa: fix NULL pointer access and memory leak in unregister_one_node()
Revert "driver core: synchronize device shutdown"
kernfs: fix off by one error.
kernfs: remove duplicate dir.c at the top dir
x86: align x86 arch with generic CPU modalias handling
cpu: add generic support for CPU feature based module autoloading
sysfs: create bin_attributes under the requested group
driver core: unexport static function create_syslog_header
firmware: use power efficient workqueue for unloading and aborting fw load
firmware: give a protection when map page failed
firmware: google memconsole driver fixes
firmware: fix google/gsmi duplicate efivars_sysfs_init()
drivers/base: delete non-required instances of include <linux/init.h>
kernfs: fix kernfs_node_from_dentry()
ACPI / platform: drop redundant ACPI_HANDLE check
kernfs: fix hash calculation in kernfs_rename_ns()
kernfs: add CONFIG_KERNFS
sysfs, kobject: add sysfs wrapper for kernfs_enable_ns()
Pull x86 LTO changes from Peter Anvin:
"More infrastructure work in preparation for link-time optimization
(LTO). Most of these changes is to make sure symbols accessed from
assembly code are properly marked as visible so the linker doesn't
remove them.
My understanding is that the changes to support LTO are still not
upstream in binutils, but are on the way there. This patchset should
conclude the x86-specific changes, and remaining patches to actually
enable LTO will be fed through the Kbuild tree (other than keeping up
with changes to the x86 code base, of course), although not
necessarily in this merge window"
* 'x86-asmlinkage-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (25 commits)
Kbuild, lto: Handle basic LTO in modpost
Kbuild, lto: Disable LTO for asm-offsets.c
Kbuild, lto: Add a gcc-ld script to let run gcc as ld
Kbuild, lto: add ld-version and ld-ifversion macros
Kbuild, lto: Drop .number postfixes in modpost
Kbuild, lto, workaround: Don't warn for initcall_reference in modpost
lto: Disable LTO for sys_ni
lto: Handle LTO common symbols in module loader
lto, workaround: Add workaround for initcall reordering
lto: Make asmlinkage __visible
x86, lto: Disable LTO for the x86 VDSO
initconst, x86: Fix initconst mistake in ts5500 code
initconst: Fix initconst mistake in dcdbas
asmlinkage: Make trace_hardirqs_on/off_caller visible
asmlinkage, x86: Fix 32bit memcpy for LTO
asmlinkage Make __stack_chk_failed and memcmp visible
asmlinkage: Mark rwsem functions that can be called from assembler asmlinkage
asmlinkage: Make main_extable_sort_needed visible
asmlinkage, mutex: Mark __visible
asmlinkage: Make trace_hardirq visible
