path: root/scripts/mod
2013-11-15Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild changes from Michal Marek: - LTO fixes, but the kallsyms part had to be reverted - Pass -Werror=implicit-int and -Werror=strict-prototypes to the compiler by default - snprintf fix in modpost - remove GREP_OPTIONS from the environment to be immune against exotic grep option settings * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kallsyms: Revert back to 128 max symbol length Kbuild: Ignore GREP_OPTIONS env variable scripts: kallsyms: Use %zu to print 'size_t' scripts/bloat-o-meter: use .startswith rather than fragile slicing scripts/bloat-o-meter: ignore changes in the size of linux_banner kbuild: replace unbounded sprintf call in modpost kbuild, bloat-o-meter: fix static detection Kbuild: Handle longer symbols in kallsyms.c kbuild: Increase kallsyms max symbol length Makefile: enable -Werror=implicit-int and -Werror=strict-prototypes by default
2013-11-15Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module updates from Rusty Russell: "Mainly boring here, too. rmmod --wait finally removed, though" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: modpost: fix bogus 'exported twice' warnings. init: fix in-place parameter modification regression asmlinkage, module: Make ksymtab and kcrctab symbols and __this_module __visible kernel: add support for init_array constructors modpost: Optionally ignore secondary errors seen if a single module build fails module: remove rmmod --wait option.
2013-11-13scripts/mod/modpost.c: handle non ABS crc symbolsAndi Kleen
For some reason I managed to trick gcc into create CRC symbols that are not absolute anymore, but weak. Make modpost handle this case. Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-07modpost: fix bogus 'exported twice' warnings.Rusty Russell
Andi's change in e0f244c63fc9 ("asmlinkage, module: Make ksymtab and kcrctab symbols and __this_module __visible") make the crc appear first in the symbol table. modpost creates an entry when it sees the CRC, then when it sees the actual symbol, it complains that it's seen it before. The preloaded flag already exists for the equivalent case where we loaded from Module.symvers, so use that. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Tested-by: The Awesome Power Of linux-next Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-11-06kbuild: replace unbounded sprintf call in modpostKees Cook
The modpost tool could overflow its stack buffer if someone was running with an insane shell environment. Regardless, it's technically a bug, so this fixes it to truncate the string instead of seg-faulting. Found by Coverity. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-10-29asmlinkage, module: Make ksymtab and kcrctab symbols and __this_module __visibleAndi Kleen
Make the ksymtab symbols for EXPORT_SYMBOL visible. This prevents the LTO compiler from adding a .NUMBER prefix, which avoids various problems in later export processing. Cc: rusty@rustcorp.com.au Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-09-23modpost: Optionally ignore secondary errors seen if a single module build failsGuenter Roeck
Commit ea4054a23 (modpost: handle huge numbers of modules) added support for building a large number of modules. Unfortunately, the commit changed the semantics of the makefile: Instead of passing only existing object files to modpost, make now passes all expected object files. If make was started with option -i, this results in a modpost error if a single file failed to build. Example with the current btrfs build falure on m68k: fs/btrfs/btrfs.o: No such file or directory make[1]: [__modpost] Error 1 (ignored) This error is followed by lots of errors such as: m68k-linux-gcc: error: arch/m68k/emu/nfcon.mod.c: No such file or directory m68k-linux-gcc: fatal error: no input files compilation terminated. make[1]: [arch/m68k/emu/nfcon.mod.o] Error 1 (ignored) This doesn't matter much for normal builds, but it is annoying for builds started with "make -i" due to the large number of secondary errors. Those errors unnececessarily clog any error log and make it difficult to find the real errors in the build. Fix the problem by adding a new parameter '-n' to modpost. If this parameter is specified, modpost reports but ignores missing object files. With this patch, error output from above problem is (with make -i): m68k-linux-ld: cannot find fs/btrfs/ioctl.o: No such file or directory make[2]: [fs/btrfs/btrfs.o] Error 1 (ignored) ... fs/btrfs/btrfs.o: No such file or directory (ignored) Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Michael Marek <mmarek@suse.cz> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-08-20scripts/mod/modpost.c: permit '.cranges' secton for sh64 architecture.Chen Gang
Need permit '.cranges' section for sh64 architecture, or modpost will report warning: LD init/built-in.o WARNING: init/built-in.o (.cranges): unexpected non-allocatable section. Did you forget to use "ax"/"aw" in a .S file? Note that for example <linux/init.h> contains section definitions for use in .S files. Signed-off-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-07-10Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild updates from Michal Marek: - fix for make headers_install argv explosion with too long path - scripts/setlocalversion does not call git update-index needlessly - fix for the src.rpm produced by make rpm-pkg. The new make image_name can be useful also for other packaging tools. - scripts/mod/devicetable-offsets.o is not rebuilt during each make run - make modules_install dependency fix - scripts/sortextable portability fix - fix for kbuild to generate the output directory for all object files in subdirs. - a couple of minor fixes * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: create directory for dir/file.o tools/include: use stdint types for user-space byteshift headers Makefile: Fix install error with make -j option Fix a build warning in scripts/mod/file2alias.c improve modalias building scripts/mod: Spelling s/DEVICEVTABLE/DEVICETABLE/ kbuild: fix error when building from src rpm scripts/setlocalversion on write-protected source tree Makefile.lib: align DTB quiet_cmd kbuild: fix make headers_install when path is too long
2013-07-07Merge branch 'cpuinit-delete' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull first stage of __cpuinit removal from Paul Gortmaker: "The two commits here 1) dummy out all the __cpuinit macros so that we no longer generate such sections, and then 2) remove all the section processing that we used to do for those sections. This makes all the __cpuinit and friends no-ops, so that we can remove the use cases of it at our leisure. Expect stage 2, which does the tree wide removal sweep at the end of the merge window." * 'cpuinit-delete' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: modpost: remove all traces of cpuinit/cpuexit sections init.h: remove __cpuinit sections from the kernel
2013-07-03Merge branch 'akpm' (updates from Andrew Morton)Linus Torvalds
Merge first patch-bomb from Andrew Morton: - various misc bits - I'm been patchmonkeying ocfs2 for a while, as Joel and Mark have been distracted. There has been quite a bit of activity. - About half the MM queue - Some backlight bits - Various lib/ updates - checkpatch updates - zillions more little rtc patches - ptrace - signals - exec - procfs - rapidio - nbd - aoe - pps - memstick - tools/testing/selftests updates * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (445 commits) tools/testing/selftests: don't assume the x bit is set on scripts selftests: add .gitignore for kcmp selftests: fix clean target in kcmp Makefile selftests: add .gitignore for vm selftests: add hugetlbfstest self-test: fix make clean selftests: exit 1 on failure kernel/resource.c: remove the unneeded assignment in function __find_resource aio: fix wrong comment in aio_complete() drivers/w1/slaves/w1_ds2408.c: add magic sequence to disable P0 test mode drivers/memstick/host/r592.c: convert to module_pci_driver drivers/memstick/host/jmb38x_ms: convert to module_pci_driver pps-gpio: add device-tree binding and support drivers/pps/clients/pps-gpio.c: convert to module_platform_driver drivers/pps/clients/pps-gpio.c: convert to devm_* helpers drivers/parport/share.c: use kzalloc Documentation/accounting/getdelays.c: avoid strncpy in accounting tool aoe: update internal version number to v83 aoe: update copyright date aoe: perform I/O completions in parallel ...
2013-07-03rapidio: add udev notificationAlexandre Bounine
Add RapidIO-specific modalias generation to enable udev notifications about RapidIO-specific events. The RapidIO modalias string format is shown below: "rapidio:vNNNNdNNNNavNNNNadNNNN" Where: v - Device Vendor ID (16 bit), d - Device ID (16 bit), av - Assembly Vendor ID (16 bit), ad - Assembly ID (16 bit), as they are reported in corresponding Capability Registers (CARs) of each RapidIO device. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@Prodrive.nl> Cc: Micha Nelissen <micha.nelissen@Prodrive.nl> Cc: Stef van Os <stef.van.os@Prodrive.nl> Cc: Jean Delvare <jdelvare@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03Fix a build warning in scripts/mod/file2alias.cDaniel Tang
On some systems, __used is already defined in sys/cdefs.h and causes a build warning: scripts/mod/file2alias.c:85:1: warning: "__used" redefined In file included from /usr/include/stdio.h:64, from scripts/mod/modpost.h:1, from scripts/mod/file2alias.c:13: /usr/include/sys/cdefs.h:146:1: warning: this is the location of the previous definition This adds an extra check before defining the __used macro to see if the macro was already defined elsewhere. Signed-off-by: Daniel Tang <dt.tangr@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-06-28improve modalias buildingJan Beulich
For one, there's no point in the respective pieces to be rebuilt unconditionally on each and every rebuild. Second there's no need to invent a custom rule for generating the .s file from the .c source - we can simply use the generic rule here. And finally, $(obj) should be used to refer to files in the build tree (rather than spelling out the subdirectory). Signed-off-by: Jan Beulich <jbeulich@suse.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-06-28scripts/mod: Spelling s/DEVICEVTABLE/DEVICETABLE/Geert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-06-26modpost: remove all traces of cpuinit/cpuexit sectionsPaul Gortmaker
Delete all audit rules that were checking how the .cpuXYZ related sections were inter-operating with other __init like sections, now that __cpuinit is gone. Update the linker script to not have any knowledge of .cpuinit sections. [lds.h update courtesy of Ralf Baechle <ralf@linux-mips.org>] Cc: Arnd Bergmann <arnd@arndb.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2013-05-20modpost.c: Add .text.unlikely to TEXT_SECTIONSTom Rini
gcc's places cold functions into the .text.unlikely section and we need to check this section as well for section mismatches otherwise we may have false negatives for this test. Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: linux-kernel@vger.kernel.org Cc: linux-kbuild@vger.kernel.org Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (wording update)
2013-05-07Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild changes from Michal Marek: "Kbuild commits for v3.10-rc1: - Fix make mrproper after mod/file2alias rework - Fix ld-option Makefile function - Rewrite headers_install to shell to drop Perl dependency. There are some more patches I have to look at, so I might send another pull request later. Or just queue them for 3.11." * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: Fix cleaning in scripts/mod headers_install.pl: convert to headers_install.sh kbuild: fix ld-option function
2013-05-06Fix cleaning in scripts/modAndreas Schwab
Make sure devicetable-offsets.h is cleaned in the scripts/mod directory Signed-off-by: Andreas Schwab <schwab@linux-m68k.org> Tested-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-05-05Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull mudule updates from Rusty Russell: "We get rid of the general module prefix confusion with a binary config option, fix a remove/insert race which Never Happens, and (my favorite) handle the case when we have too many modules for a single commandline. Seriously, the kernel is full, please go away!" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: modpost: fix unwanted VMLINUX_SYMBOL_STR expansion X.509: Support parse long form of length octets in Authority Key Identifier module: don't unlink the module until we've removed all exposure. kernel: kallsyms: memory override issue, need check destination buffer length MODSIGN: do not send garbage to stderr when enabling modules signature modpost: handle huge numbers of modules. modpost: add -T option to read module names from file/stdin. modpost: minor cleanup. genksyms: pass symbol-prefix instead of arch module: fix symbol versioning with symbol prefixes CONFIG_SYMBOL_PREFIX: cleanup.
2013-04-29modpost: fix unwanted VMLINUX_SYMBOL_STR expansionJames Hogan
Commit a4b6a77b77ba4f526392612c2365797fab956014 ("module: fix symbol versioning with symbol prefixes") broke the MODVERSIONS loading of any module using memcmp (e.g. ipv6) on x86_32, as it's defined to __builtin_memcmp which is expanded by VMLINUX_SYMBOL_STR. Use __VMLINUX_SYMBOL_STR instead which doesn't expand the argument. Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Reported-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: H. Peter Anvin <hpa@zytor.com> Tested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Tested-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: <stable@vger.kernel.org> # 3.9
2013-04-05modpost: add -T option to read module names from file/stdin.Rusty Russell
Because there are too many modules in the world. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-04-05modpost: minor cleanup.Rusty Russell
We want a strends() function next, so make one and use it appropriately, making new_module() arg const while we're at it. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-03-29mei: bus: Initial MEI Client bus type implementationSamuel Ortiz
mei client bus will present some of the mei clients as devices for other standard subsystems Implement the probe, remove, match, device addtion routines, along with the sysfs and uevent ones. mei_cl_device_id is also added to mod_devicetable.h A mei-cleint-bus.txt document describing the rationale and the API usage is also added while ABI/testing/sysfs-bus-mei describeis the modalias ABI. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-20module: fix symbol versioning with symbol prefixesJames Hogan
Fix symbol versioning on architectures with symbol prefixes. Although the build was free from warnings the actual modules still wouldn't load as the ____versions table contained unprefixed symbol names, which were being compared against the prefixed symbol names when checking the symbol versions. This is fixed by modifying modpost to add the symbol prefix to the ____versions table it outputs (Modules.symvers still contains unprefixed symbol names). The check_modstruct_version() function is also fixed as it checks the version of the unprefixed "module_layout" symbol which would no longer work. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Michal Marek <mmarek@suse.cz> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Jonathan Kliegman <kliegs@chromium.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (use VMLINUX_SYMBOL_STR)
2013-03-15CONFIG_SYMBOL_PREFIX: cleanup.Rusty Russell
We have CONFIG_SYMBOL_PREFIX, which three archs define to the string "_". But Al Viro broke this in "consolidate cond_syscall and SYSCALL_ALIAS declarations" (in linux-next), and he's not the first to do so. Using CONFIG_SYMBOL_PREFIX is awkward, since we usually just want to prefix it so something. So various places define helpers which are defined to nothing if CONFIG_SYMBOL_PREFIX isn't set: 1) include/asm-generic/unistd.h defines __SYMBOL_PREFIX. 2) include/asm-generic/vmlinux.lds.h defines VMLINUX_SYMBOL(sym) 3) include/linux/export.h defines MODULE_SYMBOL_PREFIX. 4) include/linux/kernel.h defines SYMBOL_PREFIX (which differs from #7) 5) kernel/modsign_certificate.S defines ASM_SYMBOL(sym) 6) scripts/modpost.c defines MODULE_SYMBOL_PREFIX 7) scripts/Makefile.lib defines SYMBOL_PREFIX on the commandline if CONFIG_SYMBOL_PREFIX is set, so that we have a non-string version for pasting. (arch/h8300/include/asm/linkage.h defines SYMBOL_NAME(), too). Let's solve this properly: 1) No more generic prefix, just CONFIG_HAVE_UNDERSCORE_SYMBOL_PREFIX. 2) Make linux/export.h usable from asm. 3) Define VMLINUX_SYMBOL() and VMLINUX_SYMBOL_STR(). 4) Make everyone use them. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: James Hogan <james.hogan@imgtec.com> Tested-by: James Hogan <james.hogan@imgtec.com> (metag)
2013-02-27Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild changes from Michal Marek: - Alias generation in modpost is cross-compile safe. - kernel/timeconst.h is now generated using a bc script instead of perl. - scripts/link-vmlinux.sh now works with an alternative $KCONFIG_CONFIG. - destination-y for exported headers is supported in Kbuild files again. - depmod is called with -P $CONFIG_SYMBOL_PREFIX on architectures that need it. - CONFIG_DEBUG_INFO_REDUCED disables var-tracking - scripts/setlocalversion works with too much translated locales ;) * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: Fix reading of .config in link-vmlinux.sh kbuild: Unset language specific variables in setlocalversion script Kbuild: Disable var tracking with CONFIG_DEBUG_INFO_REDUCED depmod: pass -P $CONFIG_SYMBOL_PREFIX kbuild: Fix destination-y for installed headers scripts/link-vmlinux.sh: source variables from KCONFIG_CONFIG kernel: Replace timeconst.pl with a bc script mod/file2alias: make modalias generation safe for cross compiling
2013-01-24mod/file2alias: make modalias generation safe for cross compilingAndreas Schwab
Use the target compiler to compute the offsets for the fields of the device_id structures, so that it won't be broken by different alignments between the host and target ABIs. This also fixes missing endian corrections for some modaliases. Signed-off-by: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-01-21modpost: Ignore ARC specific non-alloc sectionsVineet Gupta
ARC relocatable object files contain one/more .gnu.linkonce.arcextmap.* sections (collated by kernel/vmlinux.lds into .arcextmap in final link). This section is used by debuggers to display the extension instructions and need-not be loaded by target (hence !SHF_ALLOC) The final kernel binary only needs .arcextmap entry in modpost's ignore list (section_white_list[]). However when building modules, modpost scans each object file individually, hence tripping on non-aggregated .gnu.linkonce.arcextmap.* entries as well. Thus need for the 2 entires ! Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-11-30modpost.c: Stop checking __dev* section mismatchesGreg Kroah-Hartman
Now that the __dev* sections are not being generated, we don't need to check for them in modpost.c. Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-12Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild changes from Michal Marek: "The main part of kbuild for v3.7 contains: - Fix for scripts/Makefile.modpost to not choke on a '.ko' substring in the build directory path - Two warning fixes (modpost and main Makefile) - __compiletime_error works also with gcc 4.3 - make tar{gz,bz2,xz}-pkg uses default compression settings instead of saving as many bytes as possible (this should actually be in the misc branch, I don't know why I applied it here)." * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: compiler-gcc4.h: correct verion check for __compiletime_error modpost: Permit .GCC.command.line sections Kbuild: use normal compression settings for tar*-pkg scripts/Makefile.modpost: error in finding modules from .mod files. kbuild: Remove useless warning while appending KCFLAGS
2012-10-11modpost: Permit .GCC.command.line sectionsJonathan Kliegman
Allow .GCC.command.line sections in modules to prevent modpost warnings: WARNING: sound/usb/snd-usbmidi-lib.o (.GCC.command.line): unexpected non-allocatable section. Did you forget to use "ax"/"aw" in a .S file? Note that for example <linux/init.h> contains section definitions for use in .S files. Signed-off-by: Jonathan Kliegman <kliegs@chromium.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-10-09Merge tag 'xtensa-next-20121008' of git://github.com/czankel/xtensa-linuxLinus Torvalds
Pull Xtensa patchset from Chris Zankel: "The Xtensa tree has been broken for some time now, and this patchset brings it back to life. It has been part of the linux-next tree for some time. Most changes are inside the xtensa subdirectory; the other changes mostly add another rule to already existing #ifdefs to exclude Xtensa, where required. The only 'common' change is to add two more sections ('.xt.prop' and '.xt.lit') to the white list in modpost." * tag 'xtensa-next-20121008' of git://github.com/czankel/xtensa-linux: (27 commits) xtensa: Setup CROSS_COMPILE at the top xtensa: drop CONFIG_EMBEDDED_RAMDISK xtensa: fix TIOCGSERIAL and TIOCSSERIAL definitions xtensa: provide dummy gcc intrinsics xtensa: add missing symbol exports parport: disable for xtensa arch xtensa: rename MISC SR definition to avoid name clashes hisax: disable build for big-endian xtensa xtensa: fix CODA build xtensa: fix parallel make xtensa: ISS: drop unused io.c xtensa: ISS: exit simulator in case of halt or poweroff xtensa: ISS: change keyboard polling rate xtensa: ISS: add platform_pcibios_init xtensa: ISS: add dummy serial.h for ISS platform xtensa: change default platform clock frequency to 10MHz xtensa: add ARCH_WANT_OPTIONAL_GPIOLIB to xtensa config xtensa: set NO_IOPORT to 'n' by default xtensa: adopt generic io routines xtensa: fix ioremap ...
2012-10-03modpost: fix modpost warnings for xtensaMax Filippov
Suppress warnings for two informational sections (.xt.lit and .xt.prop) used by the Xtensa architecture. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2012-09-07staging/ipack: Fix bug introduced by IPack device matchingJens Taprogge
~0 can not be casted to u8. Instead of using the IPACK_ANY_ID for the format field we introduce a new IPACK_ANY_FORMAT specifically for that field and defined as 0xff. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Jens Taprogge <jens.taprogge@taprogge.org> Acked-by: Samuel Iglesias Gonsálvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-04Staging: ipack: implement ipack device table.Jens Taprogge
The modaliases look like ipack:fXvNdM, where X is the format version (8 bit) and N and M are the vendor and device ID represented as 32 bit hexadecimal numbers each. Using 32 bits allows us to define IPACK_ANY_ID as (~0) without interfering with the valid ids. The resulting modalias string for ipoctal.ko looks like this (once ipoctal provides a device table): alias: ipack:f01v000000F0d00000048* alias: ipack:f01v000000F0d0000002A* alias: ipack:f01v000000F0d00000022* (output from modinfo) Signed-off-by: Jens Taprogge <jens.taprogge@taprogge.org> Signed-off-by: Samuel Iglesias Gonsálvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-26Merge tag 'usb-3.6-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB patches from Greg Kroah-Hartman: "Here's the big USB patch set for the 3.6-rc1 merge window. Lots of little changes in here, primarily for gadget controllers and drivers. There's some scsi changes that I think also went in through the scsi tree, but they merge just fine. All of these patches have been in the linux-next tree for a while now. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fix up trivial conflicts in include/scsi/scsi_device.h (same libata conflict that Jeff had already encountered) * tag 'usb-3.6-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (207 commits) usb: Add USB_QUIRK_RESET_RESUME for all Logitech UVC webcams usb: Add quirk detection based on interface information usb: s3c-hsotg: Add header file protection macros in s3c-hsotg.h USB: ehci-s5p: Add vbus setup function to the s5p ehci glue layer USB: add USB_VENDOR_AND_INTERFACE_INFO() macro USB: notify phy when root hub port connect change USB: remove 8 bytes of padding from usb_host_interface on 64 bit builds USB: option: add ZTE MF821D USB: sierra: QMI mode MC7710 moved to qcserial USB: qcserial: adding Sierra Wireless devices USB: qcserial: support generic Qualcomm serial ports USB: qcserial: make probe more flexible USB: qcserial: centralize probe exit path USB: qcserial: consolidate usb_set_interface calls USB: ehci-s5p: Add support for device tree USB: ohci-exynos: Add support for device tree USB: ehci-omap: fix compile failure(v1) usb: host: tegra: pass correct pointer in ehci_setup() USB: ehci-fsl: Update ifdef check to work on 64-bit ppc USB: serial: keyspan: Removed unrequired parentheses. ...
2012-06-16scripts/modpost: check for bad references in .pci.fixups areaSebastian Andrzej Siewior
Functions used for PCI fixups (like DECLARE_PCI_FIXUP_HEADER) are often marked __init. This is okay as long as nobody is using PCI hotplug. However if one does execute | echo 1 > /sys/bus/pci/rescan and we hit a module which is marked __init istead of __devinit then we go boom because the code is removed after the kernel booted. This patch help to see those section mismatches. Cc: Michal Marek <mmarek@suse.cz> Cc: linux-kbuild@vger.kernel.org Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-06-13USB: allow match on bInterfaceNumberBjørn Mork
Some composite USB devices provide multiple interfaces with different functions, all using "vendor-specific" for class/subclass/protocol. Another OS use interface numbers to match the driver and interface. It seems these devices are designed with that in mind - using static interface numbers for the different functions. This adds support for matching against the bInterfaceNumber, allowing such devices to be supported without having to resort to testing against interface number whitelists and/or blacklists in the probe. Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-23modpost: use proper kernel style for autogenerated filesGreg Kroah-Hartman
If the kernel build process is creating files automatically, the least it can do is create them in a properly formatted manner. Sure, it's a minor issue, but being consistent is nice. Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Alessio Igor Bogani <abogani@kernel.org> Cc: Tony Lindgren <tony@atomide.com> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-05-23modpost: Stop grab_file() from leaking filedescriptors if fstat() failsJesper Juhl
In case the open() call succeeds but the subsequent fstat() call fails, then we'll return without close()'ing the filedescriptor. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-05-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid Pull HID subsystem updates from Jiri Kosina: "Apart from various driver updates and added support for a number of new devices (mostly multitouch ones, but not limited to), there is one change that is worth pointing out explicitly: creation of HID device groups and proper autoloading of hid-multitouch, implemented by Henrik Rydberg." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (50 commits) HID: wacom: fix build breakage without CONFIG_LEDS_CLASS HID: waltop: Extend barrel button fix HID: hyperv: Set the hid drvdata correctly HID: wacom: Unify speed setting HID: wacom: Add speed setting for Intuos4 WL HID: wacom: Move Graphire raport header check. HID: uclogic: Add support for UC-Logic TWHL850 HID: explain the signed/unsigned handling in hid_add_field() HID: handle logical min/max signedness properly in parser HID: logitech: read all 32 bits of report type bitfield HID: wacom: Add LED selector control for Wacom Intuos4 WL HID: hid-multitouch: fix wrong protocol detection HID: wiimote: Fix IR data parser HID: wacom: Add tilt reporting for Intuos4 WL HID: multitouch: MT interface matching for Baanto HID: hid-multitouch: Only match MT interfaces HID: Create a common generic driver HID: hid-multitouch: Switch to device groups HID: Create a generic device group HID: Allow bus wildcard matching ...
2012-05-01HID: Allow bus wildcard matchingHenrik Rydberg
Most HID drivers do not need to know what bus driver is in use. A generic group driver can drive any hid device, and the device list should not need to be duplicated for each new bus. This patch adds wildcard matching to the HID bus, simplifying device list handling for group drivers. Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Acked-by: Benjamin Tissoires <benjamin.tissoires@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-05-01HID: Add device group to modaliasHenrik Rydberg
HID devices are only partially presented to userland. Hotplugged devices emit events containing a modalias based on the basic bus, vendor and product entities. However, in practise a hid device can depend on details such as a single usb interface or a particular item in a report descriptor. This patch adds a device group to the hid device id, and broadcasts it using uevent and the device modalias. The module alias generation is modified to match. As a consequence, a device with a non-zero group will be processed by the corresponding group driver instead of by the generic hid driver. Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Acked-by: Benjamin Tissoires <benjamin.tissoires@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-04-23Merge branch 'rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull build system failure fix from Michal Marek: "This fixes build failure with newer gcc that adds some internal symbols that end in "__mod_*_device_table", but are not actually the tables themselves." * 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: Fix modpost failures in fedora 17
2012-04-18Fix modpost failures in fedora 17David Miller
The symbol table on x86-64 starts to have entries that have names like: _GLOBAL__sub_I_65535_0___mod_x86cpu_device_table They are of type STT_FUNCTION and this one had a length of 18. This matched the device ID validation logic and it barfed because the length did not meet the device type's criteria. -------------------- FATAL: arch/x86/crypto/aesni-intel: sizeof(struct x86cpu_device_id)=16 is not a modulo of the size of section __mod_x86cpu_device_table=18. Fix definition of struct x86cpu_device_id in mod_devicetable.h -------------------- These are some kind of compiler tool internal stuff being emitted and not something we want to inspect in modpost's device ID table validation code. So skip the symbol if it is not of type STT_OBJECT. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-04-09modpost: Fix modpost license checking of vmlinux.oFrank Rowand
Commit f02e8a6596b7 ("module: Sort exported symbols") sorts symbols placing each of them in its own elf section. This sorting and merging into the canonical sections are done by the linker. Unfortunately modpost to generate Module.symvers file parses vmlinux.o (which is not linked yet) and all modules object files (which aren't linked yet). These aren't sanitized by the linker yet. That breaks modpost that can't detect license properly for modules. This patch makes modpost aware of the new exported symbols structure. [ This above is a slightly corrected version of the explanation of the problem, copied from commit 62a2635610db ("modpost: Fix modpost's license checking V3"). That commit fixed the problem for module object files, but not for vmlinux.o. This patch fixes modpost for vmlinux.o. ] Signed-off-by: Frank Rowand <frank.rowand@am.sony.com> Signed-off-by: Alessio Igor Bogani <abogani@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-30Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild changes from Michal Marek: - Unification of cmd_uimage among archs that use it - make headers_check tries harder before reporting a missing <linux/types.h> include - kbuild portability fix for shells that do not support echo -e - make clean descends into samples/ - setlocalversion grep fix - modpost typo fix - dtc warnings fix * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: setlocalversion: Use "grep -q" instead of piping output to "read dummy" modpost: fix ALL_INIT_DATA_SECTIONS Kbuild: centralize MKIMAGE and cmd_uimage definitions headers_check: recursively search for linux/types.h inclusion scripts/Kbuild.include: Fix portability problem of "echo -e" scripts: dtc: fix compile warnings kbuild: clean up samples directory kbuild: disable -Wmissing-field-initializers for W=1
2012-03-26modpost: fix ALL_INIT_DATA_SECTIONSJan Beulich
This was lacking a comma between two supposed to be separate strings. Signed-off-by: Jan Beulich <jbeulich@suse.com> Cc: <stable@vger.kernel.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-03-09Merge 3.3-rc6 into driver-core-nextGreg Kroah-Hartman
This was done to resolve a conflict in the drivers/base/cpu.c file. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
