commit e390f9a9689a42f477a6073e2e7df530a4c1b740 upstream.
The '__unreachable' and '__func_stack_frame_non_standard' sections are
only used at compile time. They're discarded for vmlinux but they
should also be discarded for modules.
Since this is a recurring pattern, prefix the section names with
".discard.". It's a nice convention and vmlinux.lds.h already discards
such sections.
Also remove the 'a' (allocatable) flag from the __unreachable section
since it doesn't make sense for a discarded section.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Jessica Yu <jeyu@redhat.com>
Fixes: d1091c7fa3d5 ("objtool: Improve detection of BUG() and other dead ends")
Link: http://lkml.kernel.org/r/20170301180444.lhd53c5tibc4ns77@treble
[dwmw2: Remove the unreachable part in backporting since it's not here yet]
Signed-off-by: David Woodhouse <dwmw@amazon.co.ku>
[ Upstream commit ab42632156becd35d3884ee5c14da2bedbf3149a ]
For powerpc the __jump_table section in modules is not aligned, this
causes a WARN_ON() splat when loading a module containing a __jump_table.
Strict alignment became necessary with commit 3821fd35b58d
("jump_label: Reduce the size of struct static_key"), currently in
linux-next, which uses the two least significant bits of pointers to
__jump_table elements.
Fix by forcing __jump_table to 8, which is the same alignment used for
this section in the kernel proper.
Link: http://lkml.kernel.org/r/20170301220453.4756-1-david.daney@cavium.com
Reviewed-by: Jason Baron <jbaron@akamai.com>
Acked-by: Jessica Yu <jeyu@redhat.com>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Tested-by: Sachin Sant <sachinp@linux.vnet.ibm.com>
Signed-off-by: David Daney <david.daney@cavium.com>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
KASan uses constructors for initializing redzones for global variables.
Globals instrumentation in GCC 4.9.2 produces constructors with priority
(.init_array.00099)
Currently kernel ignores such constructors. Only constructors with
default priority supported (.init_array)
This patch adds support for constructors with priorities. For kernel
image we put pointers to constructors between __ctors_start/__ctors_end
and do_ctors() will call them on start up. For modules we merge
.init_array.* sections into resulting .init_array. Module code properly
handles constructors in .init_array section.
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Konstantin Serebryany <kcc@google.com>
Cc: Dmitry Chernenkov <dmitryc@google.com>
Signed-off-by: Andrey Konovalov <adech.fo@gmail.com>
Cc: Yuri Gribov <tetra2005@gmail.com>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Pekka Enberg <penberg@kernel.org>
These __ksymtab*/__kcrctab* sections currently have non-zero addresses.
Non-zero section addresses in a relocatable ELF confuse GDB and it ends
up not relocating all symbols when add-symbol-file is used on modules
which have exports. The kernel's module loader does not care about
these addresses, so let's just set them to zero.
Before:
$ readelf -S lib/notifier-error-inject.ko | grep 'Name\| __ksymtab_gpl'
[Nr] Name Type Addr Off Size ES Flg Lk Inf Al
[ 8] __ksymtab_gpl PROGBITS 0000000c 0001b4 000010 00 A 0 0 4
(gdb) add-symbol-file lib/notifier-error-inject.ko 0x500000 -s .bss 0x700000
add symbol table from file "lib/notifier-error-inject.ko" at
.text_addr = 0x500000
.bss_addr = 0x700000
(gdb) p ¬ifier_err_inject_dir
$3 = (struct dentry **) 0x0
After:
[ 8] __ksymtab_gpl PROGBITS 00000000 0001b4 000010 00 A 0 0 4
$3 = (struct dentry **) 0x700000
Signed-off-by: Rabin Vincent <rabin.vincent@axis.com>
This patch places every exported symbol in its own section
(i.e. "___ksymtab+printk"). Thus the linker will use its SORT() directive
to sort and finally merge all symbol in the right and final section
(i.e. "__ksymtab").
The symbol prefixed archs use an underscore as prefix for symbols.
To avoid collision we use a different character to create the temporary
section names.
This work was supported by a hardware donation from the CE Linux Forum.
Signed-off-by: Alessio Igor Bogani <abogani@kernel.org>
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (folded in '+' fixup)
Tested-by: Dirk Behme <dirk.behme@googlemail.com>
x86 throws away .discard section but no other archs do. Also,
.discard is not thrown away while linking modules. Make every arch
and module linking throw it away. This will be used to define dummy
variables for percpu declarations and definitions.
This patch is based on Ivan Kokshaysky's alpha percpu patch.
[ Impact: always throw away everything in .discard ]
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Cc: Bryan Wu <cooloney@kernel.org>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Chris Zankel <chris@zankel.net>
