[ Upstream commit 82fdd12b95727640c9a8233c09d602e4518e71f7 ]
The namespace.pl script does not work properly if objtree is not set to
an absolute path. The do_nm function is run from within the find
function, which changes directories.
Because of this, appending objtree, $File::Find::dir, and $source, will
return a path which is not valid from the current directory.
This used to work when objtree was set to an absolute path when using
"make namespacecheck". It appears to have not worked when calling
./scripts/namespace.pl directly.
This behavior was changed in 7e1c04779efd ("kbuild: Use relative path
for $(objtree)", 2014-05-14)
Rather than fixing the Makefile to set objtree to an absolute path, just
fix namespace.pl to work when srctree and objtree are relative. Also fix
the script to use an absolute path for these by default.
Use the File::Spec module for this purpose. It's been part of perl
5 since 5.005.
The curdir() function is used to get the current directory when the
objtree and srctree aren't set in the environment.
rel2abs() is used to convert possibly relative objtree and srctree
environment variables to absolute paths.
Finally, the catfile() function is used instead of string appending
paths together, since this is more robust when joining paths together.
Signed-off-by: Jacob Keller <jacob.e.keller@intel.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
Tested-by: Randy Dunlap <rdunlap@infradead.org>
The default NetBSD package manager is pkgsrc and it installs Perl
along other third party programs under custom and configurable prefix.
The default prefix for binary prebuilt packages is /usr/pkg, and the
Perl executable lands in /usr/pkg/bin/perl.
This change switches "/usr/bin/perl" to "/usr/bin/env perl" as it's
the most portable solution that should work for almost everybody.
Perl's executable is detected automatically.
This change switches -w option passed to the executable with more
modern "use warnings;" approach. There is no functional change to the
default behavior.
While there, drop "require 5" from scripts/namespace.pl (Perl from 1994?).
Signed-off-by: Kamil Rytarowski <n54@gmx.com>
Similar to how relative extables are implemented, it is possible to emit
the kallsyms table in such a way that it contains offsets relative to
some anchor point in the kernel image rather than absolute addresses.
On 64-bit architectures, it cuts the size of the kallsyms address table
in half, since offsets between kernel symbols can typically be expressed
in 32 bits. This saves several hundreds of kilobytes of permanent
.rodata on average. In addition, the kallsyms address table is no
longer subject to dynamic relocation when CONFIG_RELOCATABLE is in
effect, so the relocation work done after decompression now doesn't have
to do relocation updates for all these values. This saves up to 24
bytes (i.e., the size of a ELF64 RELA relocation table entry) per value,
which easily adds up to a couple of megabytes of uncompressed __init
data on ppc64 or arm64. Even if these relocation entries typically
compress well, the combined size reduction of 2.8 MB uncompressed for a
ppc64_defconfig build (of which 2.4 MB is __init data) results in a ~500
KB space saving in the compressed image.
Since it is useful for some architectures (like x86) to retain the
ability to emit absolute values as well, this patch also adds support
for capturing both absolute and relative values when
KALLSYMS_ABSOLUTE_PERCPU is in effect, by emitting absolute per-cpu
addresses as positive 32-bit values, and addresses relative to the
lowest encountered relative symbol as negative values, which are
subtracted from the runtime address of this base symbol to produce the
actual address.
Support for the above is enabled by default for all architectures except
IA-64 and Tile-GX, whose symbols are too far apart to capture in this
manner.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Tested-by: Guenter Roeck <linux@roeck-us.net>
Tested-by: Kees Cook <keescook@chromium.org>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Michal Marek <mmarek@suse.cz>
This reverts commit 24a54f7974a616385b96cd939e004592e2cea484.
Stephen Hemminger <shemminger@vyatta.com> writes:
> That patch should not be included. It causes more problems than it
> solves, since then there are duplicate file locations which causes
> false duplicate symbol reports.
Reported-by: Stephen Hemminger <shemminger@vyatta.com>
Teach namespace checker about some special case files where the
source is in unusual location. This fixes many of the source file
not found errors (more can be added), and also prevents false positives
for functions not being used.
Exclude more symbols from arch/x86/vdso/ and arch/x86/boot/; add some more
linker-defined symbols into exception list; add other cond_syscalls
besides "sys_*".
Signed-off-by: Amerigo Wang <amwang@redhat.com>
Cc: Stephen Hemminger <shemminger@vyatta.com>
1. Teach namespace.pl to understand "V" and "v"
2. cond_syscalls are moved into kernel/sys_ni.c
File::Find will do chdir automatically, so we need to get the absolute
patch with $File::Find::dir.
Use local file handle not global.
Make loop and other variables local in scope.
Cc: Hui Zhu <teawater@gmail.com>
Cc: Cong Wang <amwang@redhat.com>
Let namespace.pl look at the correct files.
Make it executable like it should be. Do the same for other files intended to be
executed by the user - the ones called by the build process needn't be
executable as they already work (as argument to their interpreter).
Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Using the fixed path to /usr/bin/{nm,objdump} does not allow
CROSS_COMPILE environments to use namespace.pl. This patch causes
namespace.pl to use $NM and $OBJDUMP if defined or fall back to the nm
and objdump found in the path.
Signed-off-by: Aaron Brooks <aaron.brooks@sicortex.com>
infrastructure for it.
Let it rip!
