commit f8ce239dfc7ba9add41d9ecdc5e7810738f839fa upstream.
builddeb generates a control file that says the linux-headers package
can only be built for the build system primary architecture. This
breaks cross-building configurations. We should use $debarch for this
instead.
Since $debarch is not yet set when generating the control file, set
Architecture: any and use control file variables to fill in the
description.
Fixes: cd8d60a20a45 ('kbuild: create linux-headers package in deb-pkg')
Reported-and-tested-by: "Niew, Sh." <shniew@gmail.com>
Commit 6501320311664e11ad5489fedb17ea1f817c2617 dropped the rpm spec as a
prerequisite for the binrpm-pkg target but forgot to update $< usage,
which causes the rule to break.
This commit fixes that by replacing $< with the spec name.
Signed-off-by: Luiz Capitulino <lcapitulino@redhat.com>
The *pkg targets are always run, so it makes no sense to cache the
generated specfile. This also fixes build errors when the specfile
becomes out of date, without the Makefile noticing it:
$ make rpm
works
$ echo yadadada >localversion-test
$ make rpm
fails, because kernel.spec assumes the old kernel release string
Now that we only package explicitly listed files to the tarball, there
is no need to abuse the parent directory.
The source tree can contain lots of uninteresting data like tag or
cscope files, packaging which slows down make rpm needlessly. It can
also break the build, if the tree contains an unrelated file named
*.spec. The downside of this change is that new subdirectories have to
be added to the KBUILD_ALLDIRS variable in the top-level Makefile. The
upside is that the behavior is more predictable.
When dealing with multiple sub-arches (like 32- and 64-bit on x86, for
example) generating a bunch of kernel tar archives with the same name
but for different sub-arches could get confusing and error-prone. Also,
the build process could overwrite otherwise unrelated builds and you
probably don't want that. So, add the architecture to the archive name
for more clarity and less shoot-yourself-in-the-foot practices.
KBUILD_OUTPUT
KBUILD_OUTPUT is always empty here, so it is useless to test it. But
while use O=.., objtree and srctree will be different. I compare them
instead.
Signed-off-by: Bin Wang <wbin00@gmail.com>
'make rpm-pkg' and 'make binrpm-pkg' fail when the kernel source is
read-only. Specifically, when the RPM spec generated by
scripts/package/mkspec is run, KBUILD_SRC happens to be set to the
source location and thus the invocation of 'make headers_install'
fails when an internal call to 'filechk' tries to write a file into
the source tree.
The fix is to clear KBUILD_SRC for the 'make headers_install'
invocation in the spec file, as is already done for the 'make
modules_install' invocation.
Signed-off-by: David R. Bild <drbild@umich.edu>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kbuild changes from Michal Marek:
"The main part of kbuild for v3.7 contains:
- Fix for scripts/Makefile.modpost to not choke on a '.ko' substring
in the build directory path
- Two warning fixes (modpost and main Makefile)
- __compiletime_error works also with gcc 4.3
- make tar{gz,bz2,xz}-pkg uses default compression settings instead
of saving as many bytes as possible (this should actually be in the
misc branch, I don't know why I applied it here)."
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
compiler-gcc4.h: correct verion check for __compiletime_error
modpost: Permit .GCC.command.line sections
Kbuild: use normal compression settings for tar*-pkg
scripts/Makefile.modpost: error in finding modules from .mod files.
kbuild: Remove useless warning while appending KCFLAGS
For large kernel configurations (like a distribution kernel)
targz-pkg takes a quite long time to just do the compression.
I clocked it at 15+mins for a SUSE kernel like config on a fast
system. And tarxz and bzip2 are even slower.
The main reason is that the script that is doing the taring sets
the highest compression level (-9). When I change it to just
use the defaults the gzip time for the same kernel goes down
to ~3 mins. I haven't tested xz and bzip, but I expect those
to be much faster too.
I'm not willing to wait that long for a small compression
gain. So just change the script to use the defaults.
Reviewed-by: Fengguang Wu <fengguang.wu@intel.com>
There were reports of users destroying their Fedora installs by a kernel
tarball that replaces the /lib -> /usr/lib symlink. Let's remove the
toplevel directories from the tarball to prevent this from happening.
Reported-by: Andi Kleen <andi@firstfloor.org>
Suggested-by: Ben Hutchings <ben@decadent.org.uk>
Cc: <stable@kernel.org>
I discovered that make deb-pkg does not add Makefile_32.cpu from
arch/x86 directory when doing i386 kernel build and package build.
Fix it by greedily adding all Makefiles.
Reported-by: Witold Baryluk <baryluk@smp.if.uj.edu.pl>
Signed-off-by: maximilian attems <max@stro.at>
That way they don't file conflict with official firmware package:
trying to overwrite '/lib/firmware/qlogic/1040.bin', which is
also in package firmware-qlogic 0.35
Reported-by: Michael Prokop <mika@debian.org>
After 303395ac3bf3e2cb488435537d416bc840438fcb, some headers are
autogenerated. Include these autogenerated headers (mainly
unistd_32_ia32.h) in out-of-tree builds to allow DKMS modules to be
built succesfully.
Signed-off-by: Peter Lekensteyn <lekensteyn@gmail.com>
The out-of-tree build is broken in 'make deb-pkg'. The
header checks and the header install works on the source and
not on the object tree.
While fixing this also replace the direct 'make' invocations
with the $MAKE variable to be consistent within the script.
Cc: maximilian attems <max@stro.at>
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: debian-kernel@lists.debian.org
Cc: linux-kbuild@vger.kernel.org
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
For user-mode Linux the other packages are not required. So
only build the package with the linux-image in it.
Tested-by: Ben Hutchings <ben@decadent.org.uk>
The Link to the kernel header files in the debian packages
point to the original build directory. This is a bad choice
if the packages were installed on a different machine. Fix
this in by manually re-creating the link in the builddeb
script.
Reviewed-by: Ben Hutchings <ben@decadent.org.uk>
The current use of /tmp for file lists is insecure. Put them under
$objtree/debian instead.
Cc: stable@vger.kernel.org # 2.6.39+
Acked-by: maximilian attems <max@stro.at>
Signed-off-by: Paul Menzel <paulepanter@users.sourceforge.net>
Specify --git-dir when building perf targets to allow out-of-tree
builds using O=<build-dir>.
The shell command in `git archive' had to be modified to allow proper
file name expansion of the files listed in MANIFEST.
Signed-off-by: matt mooney <mfm@muteddisk.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6
* 'packaging' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6:
kbuild: Create a kernel-headers RPM
rpm-pkg: Fix when current directory is a symlink
Replace '-' in kernel version with '_'
To compile binaries which depend on new kernel interfaces, we need a
kernel-headers RPM
Signed-off-by: Arun Sharma <asharma@fb.com>
The better fix would be to stop using the parent directory (principle of
least surprise), but as long as we use it, use it consistently.
Removing the '-' results in hard to read filenames such as:
kernel-2.6.35.2000042g76e4caf-28.x86_64.rpm
kernel-2.6.35.2_000042_g76e4caf-28.x86_64.rpm is easier to
read.
Signed-off-by: Zdenek Kaspar <zkaspar82@gmail.com>
When building linux-headers package using deb-pkg, builddeb erroneously assume
current directory is the source tree. This is not true if building in another
directory, using make O=... deb-pkg.
This patch fix this problem.
Signed-off-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr>
Tested-by: Nikolai Kondrashov <spbnick@gmail.com>
Fix x86 centric path to allow building kernel-header packages for
other architecture.
deb-pkg: s/hdr/kernel_headers_/ && s/header/libc_headers_/
deb-pkg: Make deb-pkg generate a seperate linux-libc-dev deb
kbuild, deb-pkg: support overriding userland architecture
kbuild, deb-pkg: select userland architecture based on UTS_MACHINE
kbuild, deb-pkg: Fix build with paranoid umask
hdrpackage and headerpackage are not intuitive names,
use proposed alternatives by Michel Marek.
While touching them move the mkdir of the kernel_headers dir up
and fix it for paranoid umask.
CC: Theodore Ts'o <tytso@mit.edu>
userland dev likes latest incarnation of that userland API.
make it easy to also build it on make deb-pkg invocation:
dpkg-deb: building package `linux-libc-dev' in `../linux-libc-dev_2.6.32-rc6-4_amd64.deb'.
Last year patch rebased on top of latest deb-pkg changes.
Create a linux-headers-$KVER.deb package which can be used to build
external modules without having the source tree around.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Usefull if building for sparc64 userland, because the
sparc and sparc64 userlands use the same 64-bit kernel,
making it impossible to always select the correct userland
architecture for the resulting debian package.
Might also be usefull, if you want a i386 userland with a amd64 kernel.
Example usage:
make KBUILD_DEBARCH=i386 deb-pkg
LKML-reference: <alpine.DEB.2.02.1011051437500.13287@aurora.sdinet.de>
Signed-off-by: Asbjoern Sloth Toennesen <asbjorn@asbjorn.biz>
Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com>
Instead of creating the debian package for the compiling userland,
create it for a userland matching the kernel thats being compiled.
This patch supports all Lenny release architectures,
and Linux-based architecture candidates for Squeeze.
If it can't find a proper Debian userspace it displays a warning,
and fallback to let deb-gencontrol use the host's userspace arch.
Eg. with this patch the following make command:
make ARCH=i386 deb-pkg
will output an i386 Debian package instead of an amd64 one,
when run on an amd64 machine.
umask 077
make deb-pkg
<snipp ..>
dpkg-deb: building package `linux-image-2.6.36+' in `../linux-image-2.6.36+_2.6.36+-4_amd64.deb'.
dpkg-deb: control directory has bad permissions 700 (must be >=0755 and <=0775)
make[1]: *** [deb-pkg] Error 2
Reported-by: Bastian Blank <waldi@debian.org>
scripts/package: don't break if %{_smp_mflags} isn't set
kbuild, deb-pkg: Check if KBUILD_IMAGE exists before copying it
Same fix as in 13797b77d419fc1b16eebf2993bf7b5cea65f0bf is needed for the "new"
line invoking _smp_mflags for modules_install. Without the fix, `make
binrpm-pkg` fails with:
+ make '%{_smp_mflags}' KBUILD_SRC= modules_install
make[2]: warning: jobserver unavailable: using -j1. Add `+' to parent make rule.
make[2]: *** No rule to make target `%{_smp_mflags}'. Stop.
error: Bad exit status from /var/tmp/rpm-tmp.8S9B9e (%install)
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com>
Avoid an error when doing cp over the image when it does not contain
the full path to the file.
Signed-off-by: Guillem Jover <guillem@hadrons.org>
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (162 commits)
tracing/kprobes: unregister_trace_probe needs to be called under mutex
perf: expose event__process function
perf events: Fix mmap offset determination
perf, powerpc: fsl_emb: Restore setting perf_sample_data.period
perf, powerpc: Convert the FSL driver to use local64_t
perf tools: Don't keep unreferenced maps when unmaps are detected
perf session: Invalidate last_match when removing threads from rb_tree
perf session: Free the ref_reloc_sym memory at the right place
x86,mmiotrace: Add support for tracing STOS instruction
perf, sched migration: Librarize task states and event headers helpers
perf, sched migration: Librarize the GUI class
perf, sched migration: Make the GUI class client agnostic
perf, sched migration: Make it vertically scrollable
perf, sched migration: Parameterize cpu height and spacing
perf, sched migration: Fix key bindings
perf, sched migration: Ignore unhandled task states
perf, sched migration: Handle ignored migrate out events
perf: New migration tool overview
tracing: Drop cpparg() macro
perf: Use tracepoint_synchronize_unregister() to flush any pending tracepoint call
Fix up trivial conflicts in Makefile and drivers/cpufreq/cpufreq.c
kbuild: Change section of generated debian packages to kernel
kbuild: Mark that the packages generated conform to Standards-Version 3.8.4
kbuild: Add homepage field to debian/control file
tools/perf/Makefile
tools/perf/util/hist.c
Merge reason: Resolve the conflicts and update to latest upstream.
make rpm was broken by commit 0915512:
make clean
set -e; cd ..; ln -sf /usr/src/iwlwifi-2.6 kernel-2.6.35rc4wl
/bin/sh /usr/src/iwlwifi-2.6/scripts/setlocalversion --scm-only >
/usr/src/iwlwifi-2.6/.scmversion
cat: .scmversion: input file is output file
make[1]: *** [rpm] Error 1
Reported-and-tested-by: "Zheng, Jiajia" <jiajia.zheng@intel.com>
Merge reason: Pick up the latest perf fixes
Makefile
Now that we run scripts/setlocalversion during every build, it makes
sense to move all the localversion logic there. This cleans up the
toplevel Makefile and also makes sure that the script is called only
once in 'make prepare' (previously, it would be called every time due to
a variable expansion in an ifneq statement). No user-visible change is
intended, unless one runs the setlocalversion script directly.
Reported-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Nico Schottelius <nico-linuxsetlocalversion@schottelius.org>
Merge reason: Go from -rc1 base to -rc3 base, merge in fixes.
Useful for when people want to try some version of the perf tools and don't
wants to download the kernel tarball.
Here is a session using this new target:
[root@emilia linux-2.6-tip]# make help | grep -i perf
perf-tar-src-pkg - Build perf-2.6.35-rc1.tar source tarball
perf-targz-src-pkg - Build perf-2.6.35-rc1.tar.gz source tarball
perf-tarbz2-src-pkg - Build perf-2.6.35-rc1.tar.bz2 source tarball
[root@emilia linux-2.6-tip]# make perf-tarbz2-src-pkg
TAR
[root@emilia linux-2.6-tip]# ls -la perf-2.6.35-rc1.tar.bz2
-rw-r--r-- 1 root root 295731 May 31 11:18 perf-2.6.35-rc1.tar.bz2
[root@emilia linux-2.6-tip]# tar xf perf-2.6.35-rc1.tar.bz2
[root@emilia linux-2.6-tip]# cd perf-2.6.35-rc1
[root@emilia perf-2.6.35-rc1]# ls
arch HEAD include lib tools
[root@emilia perf-2.6.35-rc1]# cd tools/perf
[root@emilia perf]# make -j9 2>&1 | tail
CC arch/x86/util/dwarf-regs.o
CC util/probe-finder.o
CC util/newt.o
CC util/scripting-engines/trace-event-perl.o
CC scripts/perl/Perf-Trace-Util/Context.o
CC perf.o
CC builtin-help.o
AR libperf.a
LINK perf
rm .perf.dev.null
[root@emilia perf]# ./perf record -a sleep 1
[ perf record: Woken up 1 times to write data ]
[ perf record: Captured and wrote 0.262 MB perf.data (~11457 samples) ]
[root@emilia perf]# ./perf report | head -12
# Events: 6K cycles
# Overhead Command Shared Object Symbol
4.73% perf [kernel.kallsyms] [k] format_decode
4.49% perf libc-2.12.so [.] _IO_file_underflow_internal
4.38% init [kernel.kallsyms] [k] mwait_idle
3.29% perf [kernel.kallsyms] [k] vsnprintf
2.38% init [kernel.kallsyms] [k] sched_clock_local
2.35% init [kernel.kallsyms] [k] apic_timer_interrupt
1.86% sirq-timer/5 [kernel.kallsyms] [k] find_busiest_group
[root@emilia perf]#
Acked-by: Michal Marek <mmarek@suse.cz>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Cc: Frédéric Weisbecker <fweisbec@gmail.com>
Cc: Michal Marek <mmarek@suse.cz>
Cc: Stephane Eranian <eranian@google.com>
Cc: Tom Zanussi <tzanussi@gmail.com>
LKML-Reference: <20100528185357.GA28009@ghostprotocols.net>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
To follow the way that Official Debian kernel packages are made, put the
generated packages in the right section, the kernel section. This also
avoids polluting the admin section.
Signed-off-by: Rogério Brito <rbrito@ime.usp.br>
