path: root/scripts/rt-tester
2010-02-02scripts: change scripts to use system python instead of envDon Zickus
Just a small change to a couple of scripts to go from #!/usr/bin/env python to #!/usr/bin/python This shouldn't effect anyone, unless they don't install python there. In preparation for python3, Fedora is doing a big push to change the scripts to use the system python. This allows developers to put the python3 in their path without fear of breaking existing scripts. Now I am pretty sure anyone using python3 for testing purposes will probably not run any of the scripts I changed, but Fedora has this automated tool that checks for this stuff so I thought I would try to push it upstream. Signed-off-by: Don Zickus <dzickus@redhat.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Acked-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2006-06-27[PATCH] rtmutex: Modify rtmutex-tester to test the setscheduler propagationThomas Gleixner
Make test suite setscheduler calls asynchronously. Remove the waits in the test cases and add a new testcase to verify the correctness of the setscheduler priority propagation. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] pi-futex: rt mutex testerThomas Gleixner
RT-mutex tester: scriptable tester for rt mutexes, which allows userspace scripting of mutex unit-tests (and dynamic tests as well), using the actual rt-mutex implementation of the kernel. [akpm@osdl.org: fixlet] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
