path: root/scripts/show_delta
2010-02-02scripts: change scripts to use system python instead of envDon Zickus
Just a small change to a couple of scripts to go from #!/usr/bin/env python to #!/usr/bin/python This shouldn't effect anyone, unless they don't install python there. In preparation for python3, Fedora is doing a big push to change the scripts to use the system python. This allows developers to put the python3 in their path without fear of breaking existing scripts. Now I am pretty sure anyone using python3 for testing purposes will probably not run any of the scripts I changed, but Fedora has this automated tool that checks for this stuff so I thought I would try to push it upstream. Signed-off-by: Don Zickus <dzickus@redhat.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Acked-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2006-04-11kbuild: fix mode of checkstack.pl and other files.Paolo 'Blaisorblade' Giarrusso
Make it executable like it should be. Do the same for other files intended to be executed by the user - the ones called by the build process needn't be executable as they already work (as argument to their interpreter). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
