path: root/scripts/show_delta
2014-06-10kbuild: trivial - remove trailing empty linesMasahiro Yamada
2013-10-23show_delta: Update script to support python versions 2.5 through 3.3Mike Pagano
Support past and active versions of python while maintaining backward compatibility. Script has been tested on python versions from 2.5.x up to and including 3.3.x. Signed-off-by: Mike Pagano <mpagano@gentoo.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-02-02scripts: change scripts to use system python instead of envDon Zickus
Just a small change to a couple of scripts to go from #!/usr/bin/env python to #!/usr/bin/python This shouldn't effect anyone, unless they don't install python there. In preparation for python3, Fedora is doing a big push to change the scripts to use the system python. This allows developers to put the python3 in their path without fear of breaking existing scripts. Now I am pretty sure anyone using python3 for testing purposes will probably not run any of the scripts I changed, but Fedora has this automated tool that checks for this stuff so I thought I would try to push it upstream. Signed-off-by: Don Zickus <dzickus@redhat.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Acked-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2006-04-11kbuild: fix mode of checkstack.pl and other files.Paolo 'Blaisorblade' Giarrusso
Make it executable like it should be. Do the same for other files intended to be executed by the user - the ones called by the build process needn't be executable as they already work (as argument to their interpreter). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
