path: root/scripts/tags.sh
2012-04-02Subject: [PATCH] tags.sh: Add missing quotesStephen Boyd
When $remove_structs is empty a test for empty string will turn into test -n with no arguments meaning true. Add quotes so an empty string is tested and so that make cscope works again. Reported-and-tested-by: Jike Song <albcamus@gmail.com> Reported-by: Prarit Bhargava <prarit@redhat.com> Acked-by: Yang Bai <hamo.by@gmail.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-03-26scripts: refactor remove structure forward declarationsYang Bai
Since now it has some problems when generate TAGS, refactor this code. Now it will not show the error message and will remove declarations using emacs etags. Signed-off-by: Yang Bai <hamo.by@gmail.com> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-03-26kbuild: incremental tags update for GNU GlobalJianbin Kang
GNU gtags support '-i' for updating tag files incrementally. It runs more quickly than generating new tags after kernel source update. Signed-off-by: Jianbin Kang <kjbmail@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-12-18ctags: remove struct forward declarationsAlexey Dobriyan
They're quite pointless and obscure location of real structure definition. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-11-14scripts/tags.sh: Add Page flag function magicStephen Boyd
It takes a while to find the macro-magically defined Page*() functions defined in include/linux/page-flags.h if you're new to the kernel. Add some magic to the tags script to transform these macros into the actual functions they are, so that tag jumping in the mm code is a bit easier. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-08-31tags, powerpc: Update tags.sh to support _GLOBAL symbolsIan Munsie
On PowerPC we use _GLOBAL throughout the assembly to define symbols, but currently these symbols are missing from the tags generated with ARCH=powerpc make tags. This patch modifies the tags.sh script to recognise _GLOBAL(.*) so that these symbols will be in the tags. This is almost (but not quite) PowerPC specific and this change should not affect anyone else: $ git grep -E '^_GLOBAL\(([^)]*)\).*' |sed 's/^\([^/]*\/[^/]*\)\/.*$/\1/'|uniq -c 627 arch/powerpc 2 arch/um Signed-off-by: Ian Munsie <imunsie@au1.ibm.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-25scripts/tags.sh: Add magic for trace-events for etags tooSteven Rostedt
Seems that Peter Zijlstra treats us emacs users as second class citizens and the commit: commit 15664125f7cadcb6d725cb2d9b90f9715397848d Author: Peter Zijlstra <peterz@infradead.org> scripts/tags.sh: Add magic for trace-events only updated ctags (for vim) and did not do the work to let us lowly emacs users benefit from such a change. Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-25scripts/tags.sh: Fix ctags for DEFINE_EVENT()Steven Rostedt
The regex to handle DEFINE_EVENT() should not be the same as the TRACE_EVENT() as the first parameter in DEFINE_EVENT is the template name, not the event name. We need the second parameter as that is what the trace_... will use. Tested-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-03-20Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: scripts/extract-ikconfig: add xz compression support kbuild: add GNU GLOBAL tags generation setlocalversion: update mercurial tag parsing
2011-01-15kbuild: add GNU GLOBAL tags generationJianbin Kang
GNU GLOBAL (http://www.gnu.org/software/global/) is a source code tagging system It is really cheap to support it in kbuild system. Signed-off-by: Jianbin Kang <kjbmail@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-01-10Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: Documentation/kbuild: add info that 'choice' can have a symbol name kbuild: add numeric --set-val option to scripts/config headers_check: Fix warning text headers_check: better search for functions in headers scripts/coccinelle: update for compatability with Coccinelle 0.2.4 tags: put function prototypes back! Kconfig: fix single letter command in scripts/config gitignore: add scripts/recordmcount
2010-12-02scripts/tags.sh: Add magic for trace-eventsPeter Zijlstra
Make tags find the trace-event definitions Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1290591835.2072.438.camel@laptop> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-12-02tags: put function prototypes back!Uwe Kleine-König
Commit 7db86dc (ctags: usability fix) removed function prototypes from tags file claiming "It makes no real sense to include function prototypes". But it is useful for quickly determining which header file developer needs to include to fix compilation. Now if someone wants to remove forward declarations (which I agree are baggage), write a postprocessing script. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-03-08Revert "kbuild: specify absolute paths for cscope"Michal Marek
This reverts commit eb8f844c0a41c4529a7d06b7801296eca9ae67aa. Ian Campbell writes: > I keep my kernel source tree on a more powerful build box where I run my > builds etc (including "make cscope") but run my editor from my > workstation with an NFS mount to the source. This worked fine for me > using relative paths for cscope. Using absolute paths in cscope breaks > this previously working setup because the root path is not the same on > both systems. I guess this is similar to moving the source tree around. > > Without wanting to start a flamewar it really sounds to me like we are > working around a vim (or cscope) bug here, emacs with cscope bindings > works fine in this configuration. Given that absolute paths can be forced by make O=. cscope, change the default back to relative paths. Ian Campbell <ijc@hellion.org.uk> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-03-03tags: Add the ability to make tags for all archs using "all"John Kacur
make ALLSOURCE_ARCHS=all tags - Document this in kbuild.txt Without this change you have to type each arch separately. Signed-off-by: John Kacur <jkacur@redhat.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-03-03tags: Fix spelling error in comment (is->if)John Kacur
2010-02-22tags: Use $SRCARCHMichal Marek
$ make mrproper $ make tags GEN tags find: `arch/x86_64/': No such file or directory Caused by commit f81b1be (tags: include headers before source files) Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-02-17tags: include headers before source filesGuennadi Liakhovetski
Currently looking up a structure definition in TAGS / tags takes one to one of multiple "static struct X" definitions in arch sources, which makes it for many structs practically impossible to get to the required header. This patch changes the order of sources being tagged to first scan architecture includes, then the top-level include/ directory, and only then the rest. It also takes into account, that many architectures have more than one include directory, i.e., not only arch/$ARCH/include, but also arch/$ARCH/mach-X/include etc. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> [mmarek@suse.cz: fix 'var+=text' bashism] Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-12kbuild: specify absolute paths for cscopeDaniel Vetter
Cscope doesn't hadle relative paths when cscope.out is not in $PWD. Use absolute paths when generating cscope.files, which seems to be the recommended way to generate cscope.out, anyway (at least according to cscope.sf.net). The speed and size differences are minimal, the only drawback is that the database needs to be regenerated if the source directory is moved. [mmarek: fixed for O= builds, modified changelog] Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-09-20ctags: usability fixStefani Seibold
The tag file generated by the tags.sh script has some issue. First: The identifier-list miss the DEFINE_TRACE,EXPORT_TRACEPOINT_SYMBOL,EXPORT_TRACEPOINT_SYMBOL_GPL special handling, which can result in a wrong tag, not to jump to the right variable definition or function implementation. Second: It makes no real sense to include function prototypes and external and forward variable declarations, because jumping to a tag will sometimes go to this and not to the real definition and implementation. The information about the declaration is still there at the definition and implementation place. So this patch make it lot easier to navigate through the kernel source tree using vi. Signed-off-by: Stefani Seibold <stefani@seibold.net> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-05-01kbuild: remove a tag file before it is regeneratedMatt Kraai
If a tag file is not removed before it is regenerated, the newly generated data is appended to the old, which preserves stale data and makes the tag file grow over time. Signed-off-by: Matt Kraai <kraai@ftbfs.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-02-15kbuild: add sys_* entries for syscalls in tagsRabin Vincent
Currently, it is no longer possible to use the tags file to jump to system call function definitions with sys_foo, because the definitions are obscured by use of the SYSCALL_DEFINE* macros. This patch adds the appropriate option to ctags to make it see through the macro. Also, it adds the ENTRY() work already done for Exuberant to Emacs too. Signed-off-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-02-15kbuild: fix tags generation of config symbolsAlexey Dobriyan
commit 4f628248a578585472e19e4cba2c604643af8c6c aka "kbuild: reintroduce ALLSOURCE_ARCHS support for tags/cscope" breaks tags generation for Kconfig symbols. Steps to reproduce: make tags vi -t PROC_FS It should jump to 'config PROC_FS' line. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Tested-by: Pete Wyckoff <pw@padd.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-01-07kbuild: reintroduce ALLSOURCE_ARCHS support for tags/cscopeJike Song
This patch reintroduce the ALLSOURCE_ARCHS support for tags/TAGS/ cscope targets. The Kbuild previously has this feature, but after moving the targets into scripts/tags.sh, ALLSOURCE_ARCHS disappears. It's something like this: $ make ALLSOURCE_ARCHS="x86 mips arm" tags cscope Signed-off-by: Jike Song <albcamus@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-01-02kbuild: drop debugging leftover in tags.shSam Ravnborg
Noticed by Jike. Reported-by: "Jike Song" <albcamus@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-12-14kbuild: fix string equality testing in tags.shJiri Slaby
Test of string equality in shells is =, not C-like ==. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-12-14kbuild: fix make tags/cscopeJiri Slaby
- fix combining O=... and tags - don't allow * expansion during sh function calls Signed-off-by: Jiri Slaby <jirislaby@gmail.com> [sam: use KBUILD_SRC to check if we use O=...] Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-12-03tags and cscope support really belongs in a shell scriptSam Ravnborg
as they do not benefit from the make functionality. Moving the support to a shell script has several benefits: - The readability of the code has increased a lot - More people is able to extend the tags support - We see less changes to the top-level Makefile The shell script version includes improvements from: Alexey Dobriyan <adobriyan@gmail.com> (jump to kconfig symbols) Alexey Dobriyan <adobriyan@gmail.com> (drop ./ in paths) Ian Campbell <ijc@hellion.org.uk> (simplified find algorithms) This version has a few caveats: => It does not support ALLSOURCE_ARCHS - it is easy to add if it is really used => It assumes all archs have moved to arch/$ARCH/include - until that happens we have a few additional hits in the archs Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Tested-by: Ian Campbell <ijc@hellion.org.uk>
