path: root/scripts/unifdef.c
2009-06-09kbuild: fix headers_exports with boolean expressionRussell King
When we had code like this in a header unifdef failed to deduct that the expression was always false - and we had code exported that was not intended for userspace. #if defined(__KERNEL__) && !defined(__ASSEMBLY__) int a; #endif This commit implment support in unidef which allows it to work out if an #if expression always evaluates true or false for symbols which are being undefined/always defined. The patch is slightly more complicated than I'd hoped because unifdef needs to see lines fully evaluated - doing otherwise causes it to mark the line as "dirty" and copy it over no matter what. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-03-07kbuild: fix C libary confusion in unifdef.c due to getline()Justin P. Mattock
This fixes an error when compiling the kernel. CHK include/linux/version.h HOSTCC scripts/unifdef scripts/unifdef.c:209: error: conflicting types for 'getline' /usr/include/stdio.h:651: note: previous declaration of 'getline' was here make[1]: *** [scripts/unifdef] Error 1 make: *** [__headers] Error 2 Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-25kbuild: replace use of strlcpy with a dedicated implmentation in unifdefSam Ravnborg
2006-09-25kbuild: add unifdefSam Ravnborg
This patch contains a raw copy of unifdef.c Next patch will modify it and add infrastructure to use it Adding unifdef to the kernel is acked by the author. The reason to add unifdef as part of the kernel source is that it is not yet a common utility on most distributions. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
