path: root/scripts/ver_linux
2016-08-31ver_linux: rename ver_linux.awk to ver_linuxAlexander Kapshuk
ver_linux.awk renamed to ver_linux. Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-31ver_linux: shell implementation removedAlexander Kapshuk
The shell implementation removed. To be replaced with an all-awk implementation via consecutive patch. Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-07scripts: fix typo in ver_linuxMatthias Lange
Signed-off-by: Matthias Lange <matthias.lange@kernkonzept.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: proc/modules, limit text processing to 'sed'Alexander Kapshuk
This patch is more of a personal preference, rather than a fix for a problem. The current implementation used a combination of both 'cat' and 'sed' to generate an unsorted list of kernel modules separated by while space. The proposed implementation uses 'sort' and 'sed' to generate a sort list of kernel modules separated by while space. Tested on: Gentoo Linux Debian 6.0.10 Oracle Linux Server release 7.1 Arch Linux openSuSE 13.2 Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: wireless-tools, look for numerical input, not field numberAlexander Kapshuk
Rely on regex to find the version number, rather than rely on numerical input to be found in a particular input field. Tested on: Gentoo Linux Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: use 'udevadm', instead of 'udevinfo'Alexander Kapshuk
'udevinfo' no longer seems to be available across various distros. 'udevadm' seems to be the currently valid way to look up the 'udev' version. Tested on: Gentoo Linux Debian 6.0.10 Oracle Linux Server release 7.1 Rely on regex to find the version number, rather than rely on numerical input to be found in a particular input field. Proposed implementation also eliminates the necessity to invoke 'grep' + 'awk'. Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: sh-utils, look for numerical input, not field numberAlexander Kapshuk
Rely on regex to find the version number, rather than rely on numerical input to be found in a particular input field. Tested on: Gentoo Linux Debian 6.0.10 Oracle Linux Server release 7.1 Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: loadkeys, look for numerical input, not field numberAlexander Kapshuk
'loadkeys -h' no longer prints the version number across all distros, despite the claim to do so in the manpage, which I found to be the case on a Debian Linux system. The proposed implementation utilises the output of 'loadkeys -V' to acquire the version of both 'Kbd' and 'Console-tools'. Tested on: Gentoo Linux Debian 6.0.10 Oracle Linux Server release 7.1 Rely on regex to find the version number, rather than rely on numerical input to be found in a particular input field. Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: net-tools, look for numerical input, not field numberAlexander Kapshuk
2015-10-17ver_linux: procps, look for numerical input, not field numberAlexander Kapshuk
2015-10-17ver_linux: libcpp, fix missing outputAlexander Kapshuk
Neither 'libg++.so', nor 'libstdc++.so' were found where the current implementation expects them to be found in the distros below. Gentoo Linux Debian 6.0.10 Oracle Linux Server release 7.1 Which results in zero ouput generated. The proposed implementation relies on 'ldconfig' to locate the libraries in question. 'Sed' is used to do the text processing. Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: ldd, look for numerical input, not field numberAlexander Kapshuk
Rely on regex to find the version number, rather than rely on numerical input to be found in a particular input field. Proposed implementation also eliminates the necessity to invoke 'head' + 'awk'. The '-v' flag either seems to have been deprecated in some distros, e.g. Gentoo, or is an alias for '--version' in others. The proposed implementation uses the latter flag only. Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: libc, input redirection to sed fails in some distrosAlexander Kapshuk
The current implementation has been found not to work across all distros. The proposed implementation relies on 'sed' to both output the string 'Linux C Library' as well as to open '/proc/self/maps' without having to use output redirection. Tested on: Gentoo Linux Debian 6.0.10 Oracle Linux Server release 7.1 Arch Linux openSuSE 13.2 Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: ppp, look for numerical input, not field numberAlexander Kapshuk
Rely on regex to find the version number, rather than rely on numerical input to be found in a particular input field. Proposed implementation also eliminates the necessity to invoke 'grep' + 'awk'. Tested on: Oracle Linux Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: quota-tools, look for numerical input, not field numberAlexander Kapshuk
2015-10-17ver_linux: pcmciautils, look for numerical input, not field numberAlexander Kapshuk
2015-10-17ver_linux: xfsprogs, look for numerical input, not field numberAlexander Kapshuk
2015-10-17ver_linux: reiserfsprogs, look for numerical input, not field numberAlexander Kapshuk
2015-10-17ver_linux: jfsutils, look for numerical input, not field numberAlexander Kapshuk
Rely on regex to find the version number, rather than rely on numerical input to be found in a particular input field. Proposed implementation also eliminates the necessity to invoke 'grep' + 'sed' + 'awk'. Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: e2fsprogs, look for numerical input, not field numberAlexander Kapshuk
Rely on regex to find the version number, rather than rely on numerical input to be found in a particular input field. Proposed implementation also eliminates the necessity to invoke 'grep' + 'sed' + 'awk'. Tested on: Gentoo Linux Debian 6.0.10 Oracle Linux Server release 7.1 Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: module-init-tools, look for numerical input, not field numberAlexander Kapshuk
2015-10-17ver_linux: util-linux, 'fdformat' not ubiquitous any longerAlexander Kapshuk
The current implementation relies on 'fdformat' to output the version of 'util-linux'. This does not seem to be reliable any longer, as 'fdformat' does not seem to come preinstalled in all ditros these days. The proposed implementation uses 'mount' to output both the version of 'util-linux' and 'mount' proper, as 'mount' is also a part of the 'util-linux' package. Tested on: Gentoo Linux Debian 6.0.10 Oracle Linux Server release 7.1 Rely on regex to find the version number, rather than a field number. Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: binutils, fix inaccurate outputAlexander Kapshuk
Current implementation output on Gentoo Linux: binutils 2.25.1 1.1 2.25.1 Proposed implementation: Binutils 2.25.1 Tested on: Gentoo Linux Debian 6.0.10 Oracle Linux Server release 7.1 Rely on regex to find the version number. Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: make --version, use regex to find version numberAlexander Kapshuk
Rely on regex to find the version number, rather than a field number. Reduce the number of 'awk' invocations from two to one. Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: gcc -dumpversion, use regex to find version numberAlexander Kapshuk
2009-06-09Remove bashisms from scriptsdann frazier
The '-e' option to echo and brace expansion are not guaranteed to be supported by a POSIX-compliant /bin/sh (e.g. dash) Signed-off-by: dann frazier <dannf@debian.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-31kbuild: scripts/ver_linux: don't set PATHAdrian Bunk
It would have saved both a bug submitter and me a few hours if scripts/ver_linux had picked the same gcc as the build. Since I can't see any reason why it fiddles with PATH at all this patch therefore removes the PATH setting. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-05-25scripts/ver_linux use 'gcc -dumpversion'Gabriel C
These magic greps and hacks in ver_linux to get the gcc version always break after some gcc releases. Since now gcc >4.3 allows compiling with '--with-pkgversion' ( which can be everything 'My Cool Gcc' or something ) ver_linux will report random junk for these. Simply use 'gcc -dumpversion' to get the gcc version which should always work. Signed-off-by: Gabriel C <nix.or.die@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: scripts/ver_linux : correct printing of binutils versionJesper Juhl
Currently scripts/ver_linux prints "Binutils" or other random information for the version number in the "binutils" output line on some distributions. This patch corrects that. When I initially submitted a patch to correct that, I was not aware that the output from "ld -v" could differ as much as it turned out it can, so my original fix turned out to not cover all bases. This patch works correctly with all the different "ld -v" output that people posted in replys to my first patch, so it should be a clear win over what we have currently. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: ver_linux fix glibc version printJesper Juhl
Fix ver_linux glibc version printing (for real this time) Alexey Dobriyan reported that commit 4a645d5ea65baaa5736bcb566673bf4a351b2ad8 broke ver_linux when glibc has a 3 digit version number, and proposed a patch. Al Viro then suggested a simpler way to solve the problem which I've then simply put into patch form. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Al Viro <viro@ftp.linux.org.uk> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-25kbuild: fix up printing of Linux C Library version in scripts/ver_linuxJesper Juhl
I noticed, when running scripts/ver_linux on both a Gentoo system and a Slackware system, that the line printing the C library version looked a little odd. So I fixed it up to be in line with all the rest. Old output: Linux C Library > libc.2.5 New output: Linux C Library 2.5 Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-12-07[PATCH] ver_linux additionsValdis Kletnieks
scripts/ver_linux needed some minor clean-ups, as follows: 1) Add reporting of actual oprofile release 2) Add reporting of actual wireless-tools release 3) Add reporting of actual pcmciautils release Signed-off-by: Valdis Kletnieks <valdis.kletnieks@vt.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-05ver_linux: don't print reiser4progs version if none foundAlexey Dobriyan
Sam: did the same for reiserprogs Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-09-07[PATCH] Adapt scripts/ver_linux to new util-linux version stringsAlexey Dobriyan
Tested with 2.12i and 2.13-pre2. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-18[PATCH] 2.6.12-rc1-mm3 Fix ver_linux script for no udev utils.Steven Cole
Without the attached patch, the ver_linux script gives the following if udev utils are not present. ./scripts/ver_linux: line 90: udevinfo: command not found The patch causes ver_linux to be silent in the case of no udevinfo command. Signed-off-by: Steven Cole <elenstev@mesatop.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
