path: root/scripts
2013-01-03misc: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the last of the __dev* markings from the kernel from a variety of different, tiny, places. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-02UAPI: Strip _UAPI prefix on header install no matter the whitespaceDavid Howells
Commit 56c176c9cac9 ("UAPI: strip the _UAPI prefix from header guards during header installation") strips the _UAPI prefix from header guards, but only if there's a single space between the cpp directive and the label. Make it more flexible and able to handle tabs and multiple white space characters. Signed-off-by: David Howells <dhowell@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-20Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge the rest of Andrew's patches for -rc1: "A bunch of fixes and misc missed-out-on things. That'll do for -rc1. I still have a batch of IPC patches which still have a possible bug report which I'm chasing down." * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (25 commits) keys: use keyring_alloc() to create module signing keyring keys: fix unreachable code sendfile: allows bypassing of notifier events SGI-XP: handle non-fatal traps fat: fix incorrect function comment Documentation: ABI: remove testing/sysfs-devices-node proc: fix inconsistent lock state linux/kernel.h: fix DIV_ROUND_CLOSEST with unsigned divisors memcg: don't register hotcpu notifier from ->css_alloc() checkpatch: warn on uapi #includes that #include <uapi/... revert "rtc: recycle id when unloading a rtc driver" mm: clean up transparent hugepage sysfs error messages hfsplus: add error message for the case of failure of sync fs in delayed_sync_fs() method hfsplus: rework processing of hfs_btree_write() returned error hfsplus: rework processing errors in hfsplus_free_extents() hfsplus: avoid crash on failed block map free kcmp: include linux/ptrace.h drivers/rtc/rtc-imxdi.c: must include <linux/spinlock.h> mm: cma: WARN if freed memory is still in use exec: do not leave bprm->interp on stack ...
2012-12-20Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild misc changes from Michal Marek: "This is the non-critical part of kbuild - scripts/kernel-doc requires a "Return:" section for non-void functions - ARCH=arm SUBARCH=... support for make tags - COMPILED_SOURCE=1 support for make tags (only indexes .c files for which a .o exists) - New coccinelle check - Option parsing fix for scripts/config" * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: scripts/config: Fix wrong "shift" for --keep-case scripts/tags.sh: Support compiled source scripts/tags.sh: Support subarch for ARM scripts/coccinelle/misc/warn.cocci: use WARN scripts/kernel-doc: check that non-void fcts describe their return value Kernel-doc: Convention: Use a "Return" section to describe return values
2012-12-20checkpatch: warn on uapi #includes that #include <uapi/...Joe Perches
Avoid specifying internal uapi #include paths with uapi/... as userspace should not use and never see that. Neaten message line wrapping above. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-20Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild changes from Michal Marek: "The kbuild changes are minimal this time: - scripts/pnmlogo fix for some newer format - minor top-level Makefile cleanup - fix for a v3.5 regression with make clean M=<directory>" * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: Do not remove vmlinux when cleaning external module scripts/pnmtologo: fix for plain PBM kbuild: Remove reference to uninitialised variable
2012-12-19Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module update from Rusty Russell: "Nothing all that exciting; a new module-from-fd syscall for those who want to verify the source of the module (ChromeOS) and/or use standard IMA on it or other security hooks." * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: MODSIGN: Fix kbuild output when using default extra_certificates MODSIGN: Avoid using .incbin in C source modules: don't hand 0 to vmalloc. module: Remove a extra null character at the top of module->strtab. ASN.1: Use the ASN1_LONG_TAG and ASN1_INDEFINITE_LENGTH constants ASN.1: Define indefinite length marker constant moduleparam: use __UNIQUE_ID() __UNIQUE_ID() MODSIGN: Add modules_sign make target powerpc: add finit_module syscall. ima: support new kernel module syscall add finit_module syscall to asm-generic ARM: add finit_module syscall to ARM security: introduce kernel_module_from_file hook module: add flags arg to sys_finit_module() module: add syscall to load module from fd
2012-12-18Coccinelle: add api/d_find_alias.cocciCyril Roelandt
Ensure that calls to d_find_alias() have a corresponding dput(). Signed-off-by: Cyril Roelandt <tipecaml@gmail.com> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Gilles Muller <Gilles.Muller@lip6.fr> Cc: Nicolas Palix <nicolas.palix@imag.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17checkpatch: warn on CamelCase variable namesJoe Perches
Store the camelcase variables in a hash and only emit a warning on the first use of each new variable. Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17checkpatch: add support for floating point constantsJoe Perches
Even though the kernel doesn't support using floating point constants, add a regex for them. Support forms like: 0x123p1, 123e-1, 1.23, 1.5e23f Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17checkpatch: find hex constants as a single IDENTJoe Perches
Hexadecimal values are current found in 2 parts. A hex constant like 0x123456abcdef is found as 0 and then x123456abcdef and later coalesced. Instead, reverse the order of the 2 searches in $Constant to find 0x first, then 0 so that the entire hex constant is found all at once. Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17checkpatch: add --strict test for switch/default missing breakJoe Perches
switch default case is sometimes written as "default:;". This can cause new cases added below the default to be defective. Suggest adding a break; after empty default cases to avoid fallthrough defects. Fixed indentation in the other semicolon test above it. Suggested-by: Peter Senna Tschudin <peter.senna@gmail.com> Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17checkpatch: warn when declaring "struct spinlock foo;"Joe Perches
spinlock_t should always be used. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: "Luis R. Rodriguez" <mcgrof@do-not-panic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17checkpatch: Add --strict messages for blank lines around bracesJoe Perches
Blank lines around braces are not unnecessary. Emit a message on the use of these blank lines only when using --strict. int foo(int bar) { something or other.... } is generally written in the kernel as: int foo(int bar) { something or other... } Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17checkpatch: extend line continuation testJoe Perches
Preprocessor directives and asm statements should be allowed to have a line continuation. Signed-off-by: Joe Perches <joe@perches.com> Tested-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17checkpatch: allow control over line length warning, default remains 80Joe Perches
Some projects might want a longer line length so allow a command line --max-line-length=n control over the long line warnings. The default line length is 80. Signed-off-by: Joe Perches <joe@perches.com> Cc: Constantine Shulyupin <const@makelinux.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17checkpatch: consolidate if (foo) bar(foo) checks and add debugfs_removeAndy Whitcroft
Consolidate the if (foo) bar(foo) detectors into a single check. Add debugfs_remove and family. Based on a patch by Constantine Shulyupin. Signed-off-by: Andy Whitcroft <apw@canonical.com> Cc: Constantine Shulyupin <const@MakeLinux.com>. Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17checkpatch: remove reference to feature-removal-schedule.txtTao Ma
In commit 9c0ece069b32 ("Get rid of Documentation/feature-removal.txt"), Linus removes feature-removal-schedule.txt from Documentation, but there is still some reference to this file. So remove them. Signed-off-by: Tao Ma <boyu.mt@taobao.com> Acked-by: Andy Whitcroft <apw@canonical.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17checkpatch: warn about using CONFIG_EXPERIMENTALKees Cook
This config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, it is being removed. This will discourage future addition of CONFIG_EXPERIMENTAL while it is being phased out. Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Andy Whitcroft <apw@canonical.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17checkpatch: warn on unnecessary line continuationsJoe Perches
When the previous line is not a line continuation and the current line has a line continuation but is not a #define, emit a warning. Signed-off-by: Joe Perches <joe@perches.com> Cc: Peter Hurley <peter@hurleysoftware.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-14scripts/config: Fix wrong "shift" for --keep-caseHiroshi Doyu
Remove wrong "shift" for --keep-case. There is always "shift" at beginning of while-loop. No need "shift" at --keep-case just before "continue" to process next argument. Now the following works as expected: ./scripts/config -e aAa -k -e bBb -e cCc && tail -3 .config CONFIG_AAA=y CONFIG_bBb=y CONFIG_cCc=y Signed-off-by: Hiroshi Doyu <hdoyu@nvidia.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-12-14MODSIGN: Add modules_sign make targetJosh Boyer
If CONFIG_MODULE_SIG is set, and 'make modules_sign' is called then this patch will cause the modules to get a signature appended. The make target is intended to be run after 'make modules_install', and will modify the modules in-place in the installed location. It can be used to produce signed modules after they have been processed by distribution build scripts. Signed-off-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (minor typo fix)
2012-12-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial branch from Jiri Kosina: "Usual stuff -- comment/printk typo fixes, documentation updates, dead code elimination." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) HOWTO: fix double words typo x86 mtrr: fix comment typo in mtrr_bp_init propagate name change to comments in kernel source doc: Update the name of profiling based on sysfs treewide: Fix typos in various drivers treewide: Fix typos in various Kconfig wireless: mwifiex: Fix typo in wireless/mwifiex driver messages: i2o: Fix typo in messages/i2o scripts/kernel-doc: check that non-void fcts describe their return value Kernel-doc: Convention: Use a "Return" section to describe return values radeon: Fix typo and copy/paste error in comments doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c various: Fix spelling of "asynchronous" in comments. Fix misspellings of "whether" in comments. eisa: Fix spelling of "asynchronous". various: Fix spelling of "registered" in comments. doc: fix quite a few typos within Documentation target: iscsi: fix comment typos in target/iscsi drivers treewide: fix typo of "suport" in various comments and Kconfig treewide: fix typo of "suppport" in various comments ...
2012-12-12Merge branch 'for-linus' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: "Here's the updates for ARM for this merge window, which cover quite a variety of areas. There's a bunch of patch series from Will tackling various bugs like the PROT_NONE handling, ASID allocation, cluster boot protocol and ASID TLB tagging updates. We move to a build-time sorted exception table rather than doing the sorting at run-time, add support for the secure computing filter, and some updates to the perf code. We also have sorted out the placement of some headers, fixed some build warnings, fixed some hotplug problems with the per-cpu TWD code." * 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (73 commits) ARM: 7594/1: Add .smp entry for REALVIEW_EB ARM: 7599/1: head: Remove boot-time HYP mode check for v5 and below ARM: 7598/1: net: bpf_jit_32: fix sp-relative load/stores offsets. ARM: 7595/1: syscall: rework ordering in syscall_trace_exit ARM: 7596/1: mmci: replace readsl/writesl with ioread32_rep/iowrite32_rep ARM: 7597/1: net: bpf_jit_32: fix kzalloc gfp/size mismatch. ARM: 7593/1: nommu: do not enable DCACHE_WORD_ACCESS when !CONFIG_MMU ARM: 7592/1: nommu: prevent generation of kernel unaligned memory accesses ARM: 7591/1: nommu: Enable the strict alignment (CR_A) bit only if ARCH < v6 ARM: 7590/1: /proc/interrupts: limit the display of IPIs to online CPUs only ARM: 7587/1: implement optimized percpu variable access ARM: 7589/1: integrator: pass the lm resource to amba ARM: 7588/1: amba: create a resource parent registrator ARM: 7582/2: rename kvm_seq to vmalloc_seq so to avoid confusion with KVM ARM: 7585/1: kernel: fix nr_cpu_ids check in DT logical map init ARM: 7584/1: perf: fix link error when CONFIG_HW_PERF_EVENTS is not selected ARM: gic: use a private mapping for CPU target interfaces ARM: kernel: add logical mappings look-up ARM: kernel: add cpu logical map DT init in setup_arch ARM: kernel: add device tree init map function ...
2012-12-11Merge tag 'driver-core-3.8-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg Kroah-Hartman: "Here's the large driver core updates for 3.8-rc1. The biggest thing here is the various __dev* marking removals. This is going to be a pain for the merge with different subsystem trees, I know, but all of the patches included here have been ACKed by their various subsystem maintainers, as they wanted them to go through here. If this is too much of a pain, I can pull all of them out of this tree and just send you one with the other fixes/updates and then, after 3.8-rc1 is out, do the rest of the removals to ensure we catch them all, it's up to you. The merges should all be trivial, and Stephen has been doing them all in linux-next for a few weeks now quite easily. Other than the __dev* marking removals, there's nothing major here, some firmware loading updates and other minor things in the driver core. All of these have (much to Stephen's annoyance), been in linux-next for a while. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fixed up trivial conflicts in drivers/gpio/gpio-{em,stmpe}.c due to gpio update. * tag 'driver-core-3.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (93 commits) modpost.c: Stop checking __dev* section mismatches init.h: Remove __dev* sections from the kernel acpi: remove use of __devinit PCI: Remove __dev* markings PCI: Always build setup-bus when PCI is enabled PCI: Move pci_uevent into pci-driver.c PCI: Remove CONFIG_HOTPLUG ifdefs unicore32/PCI: Remove CONFIG_HOTPLUG ifdefs sh/PCI: Remove CONFIG_HOTPLUG ifdefs powerpc/PCI: Remove CONFIG_HOTPLUG ifdefs mips/PCI: Remove CONFIG_HOTPLUG ifdefs microblaze/PCI: Remove CONFIG_HOTPLUG ifdefs dma: remove use of __devinit dma: remove use of __devexit_p firewire: remove use of __devinitdata firewire: remove use of __devinit leds: remove use of __devexit leds: remove use of __devinit leds: remove use of __devexit_p mmc: remove use of __devexit ...
2012-12-11Merge tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull device tree changes from Grant Likely: "Here are the DT changes I've got queued up for v3.8. As described below, there are a lot of bug fixes here and documentation updates but nothing major: Bug fixes, little cleanups, and documentation changes. The most invasive thing here touches a bunch of the arch directories to use a common build rule for .dtb files. There are no major changes to functionality here other than a few new helper functions." * tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux-2.6: (34 commits) arm64: Fix the dtbs target building mtd: nand: davinci: fix the binding documentation rtc: rtc-mv: Add the device tree binding documentation devicetree/bindings: Move gpio-leds binding into leds directory of/vendor-prefixes: add Imagination Technologies microblaze: use new common dtc rule c6x: use new common dtc rule openrisc: use new common dtc rule arm64: Add dtbs target for building all the enabled dtb files arm64: use new common dtc rule ARM: dt: change .dtb build rules to build in dts directory kbuild: centralize .dts->.dtb rule Fix build when CONFIG_W1_MASTER_GPIO=m b exporting "allnodes" of/spi: Honour "status=disabled" property of device of_mdio: Honour "status=disabled" property of device of_i2c: Honour "status=disabled" property of device powerpc: Fix fallout from device_node->name constification of: add 'const' for of_parse_phandle parameter *np Documentation: correct of_platform_populate() argument list script: dtc: clean generated files ...
2012-12-11scripts/tags.sh: Support compiled sourceJoonsoo Kim
We usually have interst in compiled files only, because they are strongly related to individual's work. Current tags.sh can't select compiled files, so support it. We can use this functionality like below. "make cscope O=. SRCARCH=xxxx COMPILED_SOURCE=compiled" It must be executed after building the kernel. Signed-off-by: Joonsoo Kim <js1304@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-12-11scripts/tags.sh: Support subarch for ARMJoonsoo Kim
Current tags.sh doesn't handle subarch for ARM. There are too many subarch on ARM, it is hard that we locate some functions which are defined in every subarch with tags util family. Therefore support subarch for removing this unconvenience. We can use ARM subarch functionality like below. "make cscope O=. SRCARCH=arm SUBARCH=xxx" Signed-off-by: Joonsoo Kim <js1304@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-12-11Merge branches 'cache-l2x0', 'fixes', 'hdrs', 'misc', 'mmci', 'vic' and ↵Russell King
'warnings' into for-next
2012-12-09scripts/coccinelle/misc/warn.cocci: use WARNJulia Lawall
Use WARN(1,...) rather than printk followed by WARN(1). Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-12-06scripts/kernel-doc: check that non-void fcts describe their return valueYacine Belkadi
If a function has a return value, but its kernel-doc comment doesn't contain a "Return" section, then emit the following warning: Warning(file.h:129): No description found for return value of 'fct' Note: This check emits a lot of warnings at the moment, because many functions don't have a 'Return' doc section. So until the number of warnings goes sufficiently down, the check is only performed in verbose mode. Signed-off-by: Yacine Belkadi <yacine.belkadi.1@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-11-30modpost.c: Stop checking __dev* section mismatchesGreg Kroah-Hartman
Now that the __dev* sections are not being generated, we don't need to check for them in modpost.c. Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-30kbuild: centralize .dts->.dtb ruleStephen Warren
All architectures that use cmd_dtc do so in almost the same way. Create a central build rule to avoid duplication. The one difference is that most current uses of dtc build $(obj)/%.dtb from $(src)/dts/%.dts rather than building the .dtb in the same directory as the .dts file. This difference will be eliminated arch-by-arch in future patches. MIPS is the exception here; it already uses the exact same rule as the new common rule, so the duplicate is removed in this patch to avoid any conflict. arch/mips changes courtesy of Ralf Baechle. Update Documentation/kbuild to remove the explicit call to cmd_dtc from the example, now that the rule exists in a centralized location. Cc: Arnd Bergmann <arnd@arndb.de> Cc: linux-arm-kernel@lists.infradead.org Cc: Olof Johansson <olof@lixom.net> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: linux@lists.openrisc.net Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: linux-c6x-dev@linux-c6x.org Cc: Mark Salter <msalter@redhat.com> Cc: Michal Simek <monstr@monstr.eu> Cc: microblaze-uclinux@itee.uq.edu.au Cc: Chris Zankel <chris@zankel.net> Cc: linux-xtensa@linux-xtensa.org Cc: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-11-27scripts/kernel-doc: check that non-void fcts describe their return valueYacine Belkadi
If a function has a return value, but its kernel-doc comment doesn't contain a "Return" section, then emit the following warning: Warning(file.h:129): No description found for return value of 'fct' Note: This check emits a lot of warnings at the moment, because many functions don't have a 'Return' doc section. So until the number of warnings goes sufficiently down, the check is only performed in verbose mode. Signed-off-by: Yacine Belkadi <yacine.belkadi.1@gmail.com> Signed-off-by: Rob Landley <rob@landley.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-11-26UAPI: strip the _UAPI prefix from header guards during header installationDavid Howells
Strip the _UAPI prefix from header guards during header installation so that any userspace dependencies aren't affected. glibc, for example, checks for linux/types.h, linux/kernel.h, linux/compiler.h and linux/list.h by their guards - though the last two aren't actually exported. libtool: compile: gcc -std=gnu99 -DHAVE_CONFIG_H -I. -Wall -Werror -Wformat -Wformat-security -D_FORTIFY_SOURCE=2 -fno-delete-null-pointer-checks -fstack-protector -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m32 -march=i686 -mtune=atom -fasynchronous-unwind-tables -c child.c -fPIC -DPIC -o .libs/child.o In file included from cli.c:20:0: common.h:152:8: error: redefinition of 'struct sysinfo' In file included from /usr/include/linux/kernel.h:4:0, from /usr/include/linux/sysctl.h:25, from /usr/include/sys/sysctl.h:43, from common.h:50, from cli.c:20: /usr/include/linux/sysinfo.h:7:8: note: originally defined here Reported-by: Tomasz Torcz <tomek@pipebreaker.pl> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-21sign-file: fix the perl warning message when extracting ASN.1Chun-Yi Lee
There have the following warning message when running modules install for sign ko files: # make modules_install ... INSTALL drivers/input/touchscreen/pcap_ts.ko Found = in conditional, should be == at scripts/sign-file line 164. Found = in conditional, should be == at scripts/sign-file line 161. Found = in conditional, should be == at scripts/sign-file line 159. This patch change replace '=' by '==' in elsif conditions for avoid the above warning messages. Signed-off-by: Chun-Yi Lee <jlee@suse.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-21script: dtc: clean generated filesMagnus Damm
Fix "make distclean" to clean up generated dtc files. Without this patch the following files are left around: - dtc-lexer.lex.c - dtc-parser.tab.c - dtc-parser.tab.h Signed-off-by: Magnus Damm <damm@opensource.se> Reviewed-by: Simon Horman <horms@verge.net.au> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-11-20scripts/pnmtologo: fix for plain PBMAndreas Bießmann
PBM generated with current tools do not have a whitespace between the digits. Therefore the pnmtologo tool fails to gernerate the required C-Array for these images. This patch fixes that behaviour and can handle both 'old style' and 'new style' PBM files. Signed-off-by: Andreas Bießmann <andreas@biessmann.de> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-11-12Merge branch 'rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull menuconfig portability fix from Michal Marek: "Here is a fix for v3.7 that makes menuconfig compile again on systems whose C library is lacking CIRCLEQ_* macros. I thought I sent it earlier, but apparently I did not." * 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: menuconfig: Replace CIRCLEQ by list_head-style lists.
2012-11-09Merge branch 'akpm' (Fixes from Andrew)Linus Torvalds
Merge misc fixes from Andrew Morton: "Five fixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (5 patches) h8300: add missing L1_CACHE_SHIFT mm: bugfix: set current->reclaim_state to NULL while returning from kswapd() fanotify: fix missing break revert "epoll: support for disabling items, and a self-test app" checkpatch: improve network block comment style checking
2012-11-09checkpatch: improve network block comment style checkingJoe Perches
Some comment styles in net and drivers/net are flagged inappropriately. Avoid proclaiming inline comments like: int a = b; /* some comment */ and block comments like: /********************* * some comment ********************/ are defective. Tested with $ cat drivers/net/t.c /* foo */ /* * foo */ /* foo */ /* foo * bar */ /**************************** * some long block comment ***************************/ struct foo { int bar; /* another test */ }; $ Signed-off-by: Joe Perches <joe@perches.com> Reported-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: David Miller <davem@davemloft.net> Cc: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-06modules: don't break modules_install on external modules with no key.Rusty Russell
The script still spits out an error ("Can't read private key") but we don't break modules_install. Reported-by: Bruno Wolff III <bruno@wolff.to> Original-patch-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-11-04ARM: 7568/1: Sort exception table at compile timeStephen Boyd
Add the ARM machine identifier to sortextable and select the config option so that we can sort the exception table at compile time. sortextable relies on a section named __ex_table existing in the vmlinux, but ARM's linker script places the exception table in the data section. Give the exception table its own section so that sortextable can find it. This allows us to skip the sorting step during boot. Cc: David Daney <david.daney@cavium.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Tested-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-10-25menuconfig: Replace CIRCLEQ by list_head-style lists.Benjamin Poirier
sys/queue.h and CIRCLEQ in particular have proven to cause portability problems (reported on Debian Sarge, Cygwin and FreeBSD) Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Tested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Tested-by: Yaakov Selkowitz <yselkowitz@users.sourceforge.net> Signed-off-by: Benjamin Poirier <bpoirier@suse.de> Signed-off-by: "Yann E. MORIN" <yann.morin.1998@free.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-10-19MODSIGN: Move the magic string to the end of a module and eliminate the searchDavid Howells
Emit the magic string that indicates a module has a signature after the signature data instead of before it. This allows module_sig_check() to be made simpler and faster by the elimination of the search for the magic string. Instead we just need to do a single memcmp(). This works because at the end of the signature data there is the fixed-length signature information block. This block then falls immediately prior to the magic number. From the contents of the information block, it is trivial to calculate the size of the signature data and thus the size of the actual module data. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-19MODSIGN: perlify sign-file and merge in x509keyidDavid Howells
Turn sign-file into perl and merge in x509keyid. The latter doesn't need to be a separate script as it doesn't actually need to work out the SHA1 sum of the X.509 certificate itself, since it can get that from the X.509 certificate. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-19kbuild: Fix module signature generationLinus Torvalds
Rusty had clearly not actually tested his module signing changes that I (trustingly) applied as commit e2a666d52b48 ("kbuild: sign the modules at install time"). That commit had multiple bugs: - using "${#VARIABLE}" to get the number of characters in a shell variable may look clever, but it's locale-dependent: it returns the number of *characters*, not bytes. And we do need bytes. So don't use "${#..}" expansion, do the stupid "wc -c" thing instead (where "c" stands for "bytes", not "characters", despite the letter. - Rusty had confused "siglen" and "signerlen", and his conversion didn't set "signerlen" at all, and incorrectly set "siglen" to the size of the signer, not the size of the signature. End result: the modified sign-file script did create something that superficially *looked* like a signature, but didn't actually work at all, and would fail the signature check. Oops. Tssk, tssk, Rusty. But Rusty was definitely right that this whole thing should be rewritten in perl by somebody who has the perl-fu to do so. That is not me, though - I'm just doing an emergency fix for the shell script. Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-19kbuild: sign the modules at install timeRusty Russell
Linus deleted the old code and put signing on the install command, I fixed it to extract the keyid and signer-name within sign-file and cleaned up that script now it always signs in-place. Some enthusiast should convert sign-key to perl and pull x509keyid into it. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-18Merge tag 'dt-fixes-for-3.7' of git://sources.calxeda.com/kernel/linuxLinus Torvalds
Pull DeviceTree fixes from Rob Herring: "A handful of fixes: - a fix for dtc from upstream - sparse fixes in DeviceTree code - stub of_get_child_by_name for !OF builds" * tag 'dt-fixes-for-3.7' of git://sources.calxeda.com/kernel/linux: dtc: fix for_each_*() to skip first object if deleted of/platform: sparse fix of/irq: sparse fixes of/address: sparse fixes of: add stub of_get_child_by_name for non-OF builds
2012-10-17dtc: fix for_each_*() to skip first object if deletedStephen Warren
The previous definition of for_each_*() would always include the very first object within the list, irrespective of whether it was marked deleted, since the deleted flag was not checked on the first object, but only on any "next" object. Fix for_each_*() to check the deleted flag in the loop body every iteration to correct this. (upstream dtc commit 1762ab42ef77db7ab2776d0d6cba3515150f518a) Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
