path: root/scripts
2011-06-09kconfig: migrate parser to implicit rulesArnaud Lacombe
Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
2011-06-09kconfig/zconf.l: do not ask to generate backupArnaud Lacombe
This avoids the creation of a top-level `lex.backup' when the lexer gets re-generated. Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
2011-06-09kconfig: kill no longer needed reference to YYDEBUGArnaud Lacombe
2011-06-09kconfig: constify `kconf_id_lookup'Arnaud Lacombe
2011-06-09genksym: regen parserArnaud Lacombe
2011-06-09genksyms: migrate parser to implicit rulesArnaud Lacombe
2011-06-09genksyms: drop -Wno-uninitialized from HOSTCFLAGS_parse.tab.oArnaud Lacombe
2011-06-09genksyms: pass hash and lookup functions name and target language though the ↵Arnaud Lacombe
input file Renaming hash and lookup functions on the command line would reduces its genericity. Use the .gperf file to pass this information. Do the same for the target language. Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
2011-06-09kbuild: simplify the %_shipped ruleArnaud Lacombe
This is needed to have make(1) correctly link the implicit rules which generate the _shipped file from the lexer/parser to the final file. Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
2011-06-09kbuild: add implicit rules for parser generationArnaud Lacombe
Cc: David Gibson <david@gibson.dropbear.id.au> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
2011-06-09kbuild: add `baseprereq'Arnaud Lacombe
On the same model as `basetarget', it represents the filename of first prerequisite with directory and extension stripped. Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
2011-06-09kbuild: silence Nothing to be done for 'all' messagePeter Foley
This patch silences a Makefile.asm-generic message by defining a dummy rule for all. make -f /usr/src/git/scripts/Makefile.asm-generic \ obj=arch/x86/include/generated/asm make[1]: Nothing to be done for `all'. Signed-off-by: Peter Foley <pefoley2@verizon.net> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-06-08Merge branch 'kconfig-trivial' of git://github.com/lacombar/linux-2.6 into ↵Michal Marek
kbuild/kconfig
2011-06-08Merge commit 'v3.0-rc1' into kbuild/kconfigMichal Marek
2011-06-07Merge commit 'v3.0-rc1' into kbuild/kbuildMichal Marek
2011-06-06kconfig/gconf: silent missing prototype warningsArnaud Lacombe
As the `gconf' frontend is un-maintained, go the easy way by silencing the "warning: no previous prototype for '<fn>'" warnings. Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
2011-06-06kconfig/gconf: kill deadcodeArnaud Lacombe
The only call site of renderer_toggled() has been commented out since Apr. 2003, as per Linus' Linux history repository: commit e7f67eb3c0570aa50c1cc0707b478a6d93bdc255 Author: Roman Zippel <zippel@linux-m68k.org> Date: Fri Apr 4 04:18:05 2003 -0800 [PATCH] gconf update A gconf update by Romain Li<C3><A9>vin <roms@tilp.info> - fixed bug when double-clicking for changing value. - expand row when enabling a row with a submenu. - various bug fixes As this result in a warning: scripts/kconfig/gconf.c:891:13: warning: 'renderer_toggled' defined but not used just nuke that code. Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
2011-06-06kconfig: nuke LKC_DIRECT_LINK cruftArnaud Lacombe
This interface is not (and has never been ?) used by any frontend, just get rid of it. Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
2011-06-06kconfig: nuke reference to SWIGArnaud Lacombe
SWIG is not used (yet?) to create kconfig binding, so there is no point referencing it. Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
2011-06-06kconfig: add missing <stdlib.h> inclusionArnaud Lacombe
This header is needed when using {m,re}alloc(3) and free(3) function family. Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
2011-06-06kconfig: add missing <ctype.h> inclusionArnaud Lacombe
This header is needed when using isspace(3) function family. Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
2011-06-06kconfig: add missing <stdarg.h> inclusionArnaud Lacombe
This header is needed when using va_{start,end,copy}(3) functions family. Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
2011-06-06kconfig: fix return code for invalid boolean symbol in conf_set_sym_val()Arnaud Lacombe
Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
2011-06-06kconfig: annotate non-trivial fall-troughArnaud Lacombe
2011-05-28Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (25 commits) perf: Fix SIGIO handling perf top: Don't stop if no kernel symtab is found perf top: Handle kptr_restrict perf top: Remove unused macro perf events: initialize fd array to -1 instead of 0 perf tools: Make sure kptr_restrict warnings fit 80 col terms perf tools: Fix build on older systems perf symbols: Handle /proc/sys/kernel/kptr_restrict perf: Remove duplicate headers ftrace: Add internal recursive checks tracing: Update btrfs's tracepoints to use u64 interface tracing: Add __print_symbolic_u64 to avoid warnings on 32bit machine ftrace: Set ops->flag to enabled even on static function tracing tracing: Have event with function tracer check error return ftrace: Have ftrace_startup() return failure code jump_label: Check entries limit in __jump_label_update ftrace/recordmcount: Avoid STT_FUNC symbols as base on ARM scripts/tags.sh: Add magic for trace-events for etags too scripts/tags.sh: Fix ctags for DEFINE_EVENT() x86/ftrace: Fix compiler warning in ftrace.c ...
2011-05-27Merge branch 'docs-move' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs * 'docs-move' of git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs: Create Documentation/security/, move LSM-, credentials-, and keys-related files from Documentation/ to Documentation/security/, add Documentation/security/00-INDEX, and update all occurrences of Documentation/<moved_file> to Documentation/security/<moved_file>.
2011-05-27Merge branch 'tip/perf/urgent' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/urgent
2011-05-25ftrace/recordmcount: Avoid STT_FUNC symbols as base on ARMRabin Vincent
While find_secsym_ndx often finds the unamed local STT_SECTION, if a section has only one function in it, the ARM toolchain generates the STT_FUNC symbol before the STT_SECTION, and recordmcount finds this instead. This is problematic on ARM because in ARM ELFs, "if a [STT_FUNC] symbol addresses a Thumb instruction, its value is the address of the instruction with bit zero set (in a relocatable object, the section offset with bit zero set)". This leads to incorrect mcount addresses being recorded. Fix this by not using STT_FUNC symbols as the base on ARM. Signed-off-by: Rabin Vincent <rabin@rab.in> Link: http://lkml.kernel.org/r/1305134631-31617-1-git-send-email-rabin@rab.in Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-25scripts/tags.sh: Add magic for trace-events for etags tooSteven Rostedt
Seems that Peter Zijlstra treats us emacs users as second class citizens and the commit: commit 15664125f7cadcb6d725cb2d9b90f9715397848d Author: Peter Zijlstra <peterz@infradead.org> scripts/tags.sh: Add magic for trace-events only updated ctags (for vim) and did not do the work to let us lowly emacs users benefit from such a change. Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-25scripts/tags.sh: Fix ctags for DEFINE_EVENT()Steven Rostedt
The regex to handle DEFINE_EVENT() should not be the same as the TRACE_EVENT() as the first parameter in DEFINE_EVENT is the template name, not the event name. We need the second parameter as that is what the trace_... will use. Tested-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-25Merge branch 'kconfig-for-40' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kconfig-for-40' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: xconfig: merge code path to conf_write() kconfig: do not record timestamp in .config gconfig: Hide unused left treeview when start up the interface gconfig: enable rules hint for main treeviews MAINTAINERS: Update KCONFIG entry kconfig-language: add to hints kconfig: Document the new "visible if" syntax kconfig: quiet commands when V=0 kconfig: change update-po-config to reflect new layout of arch/um kconfig: make update-po-config work in KBUILD_OUTPUT kconfig: rearrange clean-files kconfig: change gconf to modify hostprogs-y like nconf and mconf kconfig: change qconf to modify hostprogs-y like nconf and mconf kconfig: only build kxgettext when needed nconfig: Silence unused return values from wattrset kconfig: Do not record timestamp in auto.conf and autoconf.h kconfig: get rid of unused flags kconfig: allow multiple inclusion of the same file kconfig: Avoid buffer underrun in choice input
2011-05-25Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: export_report: use warn() to issue WARNING, so they go to stderr export_report: sort SECTION 2 output export_report: do collectcfiles work in perl itself kbuild: make versioncheck work in KBUILD_OUTDIR kbuild: make includecheck work in KBUILD_OUTDIR kbuild: make headerdep work in KBUILD_OUTDIR kbuild: add targets to PHONY kbuild: don't warn about include/linux/version.h not including itself eradicate bashisms in scripts/patch-kernel
2011-05-25Merge branch 'packaging' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'packaging' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: kbuild: Create a kernel-headers RPM rpm-pkg: Fix when current directory is a symlink Replace '-' in kernel version with '_'
2011-05-25checkpatch: fix defect in printk(KERN_<LEVEL> 80 column exceptionsJoe Perches
Currently, printk lines with a only KERN_PREFIX and a quoted string without a comma or close paren that exceed 80 columns are flagged with a warning. ie: printk(KERN_WARNING "some long string that extends beond 80 cols..." "and is continued on another line\n"); Allow this form instead of emitting a warning. Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25checkpatch: add <foo>_<level> and MODULE_<BAR> to 80 column exceptionsJoe Perches
Many module or file local logging functions use specific prefixes other than pr|dev|netdev. Allow all forms like foo_printk and foo_err to be longer than 80 columns. Also allow MODULE_<BAR> declarations to be longer than 80 columns. Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25checkpatch: add check for line continuations in quoted stringsJoe Perches
Add a warning for unterminated quoted strings with line continuations as these frequently add unwanted whitespace. Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25Merge branch 'kbuild/kconfig-for-40' into kbuild/kconfigMichal Marek
2011-05-25kconfig: Only generate config_is_xxx for bool and tristate optionsMichal Marek
For strings and integers, the config_is_xxx macros are useless and sometimes misleading: #define CONFIG_INITRAMFS_SOURCE "" #define config_is_initramfs_source() 1 Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-25xconfig: merge code path to conf_write()Arnaud Lacombe
Avoid to have multiple path saving the config. This fixes an error check miss when the window is being closed and the user requested the config to be written. Reported-by: Hiromu Yakura <hiromu1996@gmail.com> Pointed-out-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-25kbuild: Fix reference to vermagic.hGeert Uytterhoeven
It's "include/linux/vermagic.h", not "include/vermagic.h" Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-24Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: kbuild: make KBUILD_NOCMDDEP=1 handle empty built-in.o scripts/kallsyms.c: fix potential segfault scripts/gen_initramfs_list.sh: Convert to a /bin/sh script kbuild: Fix GNU make v3.80 compatibility kbuild: Fix passing -Wno-* options to gcc 4.4+ kbuild: move scripts/basic/docproc.c to scripts/docproc.c kbuild: Fix Makefile.asm-generic for um kbuild: Allow to combine multiple W= levels kbuild: Disable -Wunused-but-set-variable for gcc 4.6.0 Fix handling of backlash character in LINUX_COMPILE_BY name kbuild: asm-generic support kbuild: implement several W= levels kbuild: Fix build with binutils <= 2.19 initramfs: Use KBUILD_BUILD_TIMESTAMP for generated entries kbuild: Allow to override LINUX_COMPILE_BY and LINUX_COMPILE_HOST macros kbuild: Drop unused LINUX_COMPILE_TIME and LINUX_COMPILE_DOMAIN macros kbuild: Use the deterministic mode of ar kbuild: Call gzip with -n kbuild: move KALLSYMS_EXTRA_PASS from Kconfig to Makefile Kconfig: improve KALLSYMS_ALL documentation Fix up trivial conflict in Makefile
2011-05-24kbuild: Create a kernel-headers RPMArun Sharma
To compile binaries which depend on new kernel interfaces, we need a kernel-headers RPM Signed-off-by: Arun Sharma <asharma@fb.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-24rpm-pkg: Fix when current directory is a symlinkMichal Marek
The better fix would be to stop using the parent directory (principle of least surprise), but as long as we use it, use it consistently. Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-24Merge branch 'kbuild/kconfig-for-40' into kbuild/kconfigMichal Marek
2011-05-24kconfig: do not record timestamp in .configArnaud Lacombe
Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-24export_report: use warn() to issue WARNING, so they go to stderrJim Cromie
Also count CONFIG_MODVERSIONS warnings, and print a NOTE at start of SECTION 2 if any were issued. Section 2 will be empty if the build is lacking this CONFIG_ item, and user may have missed the warnings, as they're off screen. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-24export_report: sort SECTION 2 outputJim Cromie
Sort SECTION 2 modules by name. Within those module listings, sort the symbol providers by name, and remove the count, as it is misleading; its the kernel-wide count of uses of that symbol, not the count pertaining to the module being outlined. (this can be seen by grepping the output for a single symbol). The count is still used to sort the symbols. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-24export_report: do collectcfiles work in perl itselfJim Cromie
Avoid spawning a shell pipeline doing cat, grep, sed, and do it all inside perl. The <*.c> globbing construct works at least as far back as 5.8.9 Note that this is not just an optimization; the sed command in the pipeline was unterminated, due to lack of escape on the end-of-line (\$) in the regex, resulting in this: $ perl ../linux-2.6/scripts/export_report.pl > /dev/null sed: -e expression #1, char 5: unterminated `s' command sh: .mod.c/: not found Comments on an earlier patch sought an all-perl implementation. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> cc: Michal Marek <mmarek@suse.cz>, cc: linux-kbuild@vger.kernel.org cc: Arnaud Lacombe lacombar@gmail.com cc: Stephen Hemminger shemminger@vyatta.com Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-24gconfig: Hide unused left treeview when start up the interfaceEduardo Silva
When the gconfig program starts in full mode view, it shows the left treeview which belongs to the 'split mode view'. The patch fix this visual issue. Signed-off-by: Eduardo Silva <edsiper@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-24gconfig: enable rules hint for main treeviewsEduardo Silva
Due to the large amount of rows in the treeviews, is difficult to match columns with rows, setting the rules hint to 'true' allows the treeview to alternate background colors in the rows making the data more readable. Signed-off-by: Eduardo Silva <edsiper@gmail.com> Tested-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
