path: root/scripts
2007-04-01[PATCH] kbuild: fix dependency generationJan Beulich
Commit 2e3646e51b2d6415549b310655df63e7e0d7a080 changed the way the split config tree is built, but failed to also adjust fixdep accordingly - if changing a config option from or to m, files referencing the respective CONFIG_..._MODULE (but not the corresponding CONFIG_...) didn't get rebuilt. The problem is that trisate symbol are represent with three different symbols: SYMBOL=n => no symbol defined SYMBOL=y => CONFIG_SYMBOL defined to '1' SYMBOL=m => CONFIG_SYMBOL_MODULE defined to '1' But conf_split_config do not distingush between the =y and =m case, so only the =y case is honoured. This is fixed in fixdep so when a CONFIG symbol with _MODULE is found we skip that part and only look for the CONFIG_SYMBOL version. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-01[PATCH] kernel-doc: allow space after __attribute__Randy Dunlap
Allow space(s) between "__attribute__" and "((blah))" so that kernel-doc does not complain like: Warning(/tester/linsrc/linux-2.6.20-git15//kernel/timer.c:939): No description found for parameter 'read_persistent_clock(void' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-26Merge master.kernel.org:/pub/scm/linux/kernel/git/kyle/parisc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/kyle/parisc-2.6: (78 commits) [PARISC] Use symbolic last syscall in __NR_Linux_syscalls [PARISC] Add missing statfs64 and fstatfs64 syscalls Revert "[PARISC] Optimize TLB flush on SMP systems" [PARISC] Compat signal fixes for 64-bit parisc [PARISC] Reorder syscalls to match unistd.h Revert "[PATCH] make kernel/signal.c:kill_proc_info() static" [PARISC] fix sys_rt_sigqueueinfo [PARISC] fix section mismatch warnings in harmony sound driver [PARISC] do not export get_register/set_register [PARISC] add ENTRY()/ENDPROC() and simplify assembly of HP/UX emulation code [PARISC] convert to use CONFIG_64BIT instead of __LP64__ [PARISC] use CONFIG_64BIT instead of __LP64__ [PARISC] add ASM_EXCEPTIONTABLE_ENTRY() macro [PARISC] more ENTRY(), ENDPROC(), END() conversions [PARISC] fix ENTRY() and ENDPROC() for 64bit-parisc [PARISC] Fixes /proc/cpuinfo cache output on B160L [PARISC] implement standard ENTRY(), END() and ENDPROC() [PARISC] kill ENTRY_SYS_CPUS [PARISC] clean up debugging printks in smp.c [PARISC] factor syscall_restart code out of do_signal ... Fix conflict in include/linux/sched.h due to kill_proc_info() being made publicly available to PARISC again.
2007-02-20[PATCH] remove modpost false warnings on ARMDavid Brownell
This patch stops "modpost" from issuing erroneous modpost warnings on ARM builds, which it's been doing since since maybe last summer. A canonical example would be driver method table entries: WARNING: <path> - Section mismatch: reference to .exit.text:<name>_remove from .data after '$d' (at offset 0x4) That "$d" symbol is generated by tools conformant with ARM ABI specs; in this case it's a symbol **in the middle of** a "<name>_driver" struct. The erroneous warnings appear to be issued because "modpost" whitelists references from "<name>_driver" data into init and exit sections ... but doesn't know should also include those "$d" mapping symbols, which are not otherwise associated with "<name>_driver" symbols. This patch prevents the modpost symbol lookup code from ever returning those mapping symbols, so it will return a whitelisted symbol instead. Then things work as expected. Now to revert various code-bloating "fixes" that got merged because of this modpost bug.... Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Roman Zippel <zippel@linux-m68k.org> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-20[PATCH] kernel-doc: include struct short description in title outputRandy Dunlap
Output of a function or struct in html mode needs to include the short description from the function/struct name line in the output title line. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-17[PARISC] rename *_ANY_ID to PA_*_ANY_ID in the exported headerKyle McMartin
Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-02-17[PARISC] generate modalias for parisc_device_id tablesKyle McMartin
2007-02-17Merge branch 'parisc' from /home/kyle/repos/parisc-2.6.gitKyle McMartin
Conflicts: arch/parisc/hpux/sys_hpux.c arch/parisc/mm/ioremap.c
2007-02-14Merge branch 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6Linus Torvalds
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6: (94 commits) [PATCH] x86-64: Remove mk_pte_phys() [PATCH] i386: Fix broken CONFIG_COMPAT_VDSO on i386 [PATCH] i386: fix 32-bit ioctls on x64_32 [PATCH] x86: Unify pcspeaker platform device code between i386/x86-64 [PATCH] i386: Remove extern declaration from mm/discontig.c, put in header. [PATCH] i386: Rename cpu_gdt_descr and remove extern declaration from smpboot.c [PATCH] i386: Move mce_disabled to asm/mce.h [PATCH] i386: paravirt unhandled fallthrough [PATCH] x86_64: Wire up compat epoll_pwait [PATCH] x86: Don't require the vDSO for handling a.out signals [PATCH] i386: Fix Cyrix MediaGX detection [PATCH] i386: Fix warning in cpu initialization [PATCH] i386: Fix warning in microcode.c [PATCH] x86: Enable NMI watchdog for AMD Family 0x10 CPUs [PATCH] x86: Add new CPUID bits for AMD Family 10 CPUs in /proc/cpuinfo [PATCH] i386: Remove fastcall in paravirt.[ch] [PATCH] x86-64: Fix wrong gcc check in bitops.h [PATCH] x86-64: survive having no irq mapping for a vector [PATCH] i386: geode configuration fixes [PATCH] i386: add option to show more code in oops reports ...
2007-02-14[PATCH] qconf: hide empty list itemsCyrill V. Gorcunov
This patch fixes showing empty config list items if "Option/Show All Options" is turned on. For example empty items appears on list of 'Block Layer' menu. Signed-off-by: Cyrill V. Gorcunov <gorcunov@gmail.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Oleg Verych <olecom@flower.upol.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] qconf: Back button behaviour normalizationCyrill V. Gorcunov
Do "Back" button behaviour normalization so it is enabled starting from second-level menu only. Signed-off-by: Cyrill V. Gorcunov <gorcunov@gmail.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] qconf: fix showing help info on failed searchCyrill V. Gorcunov
qconf does not clear help text in search window if previous search has been failed. Signed-off-by: Cyrill V. Gorcunov <gorcunov@mail.ru> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] qconf: relocate Search CommandShlomi Fish
Relocate the qconf search command to the "Edit"->"Find" menu option. This is per the discussion on my qconf search dialog patch. Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] qconf: immediately update integer and string values in xconfig displayKarsten Wiese
In xconfig's display integer and string values are also shown as part of the config item's descriptive text. This patch updates the descriptive text, when the corresponding value has been changed. Fix for http://bugzilla.kernel.org/show_bug.cgi?id=7744 Take2 uses updateList() so config values dependending on the changed value see the change. Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] Make mkcompile_h use LANG=C and LC_ALL=C for $CC -vs situert
Fix a minor bug in mkcompile_h. As one can see, the current locale is used while getting the version of gcc. This produces problems when a locale other than C or en_US is used. As an example, my /proc/version contains Turkish characters in iso-8859-9 encoding. This patch fixes this issue by making sure that the C locale is used to get gcc's version. Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] search a little harder for mkimageMike Frysinger
Check to see if `${CROSS_COMPILE}mkimage` exists and if not, fall back to the standard `mkimage` The Blackfin toolchain includes mkimage, but we dont want to namespace collide with any of the user's system setup, so we prefix it with our toolchain name. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Oleg Verych <olecom@flower.upol.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-13[PATCH] i386: move startup_32() in text.head sectionVivek Goyal
o Entry startup_32 was in .text section but it was accessing some init data too and it prompts MODPOST to generate compilation warnings. WARNING: vmlinux - Section mismatch: reference to .init.data:boot_params from .text between '_text' (at offset 0xc0100029) and 'startup_32_smp' WARNING: vmlinux - Section mismatch: reference to .init.data:boot_params from .text between '_text' (at offset 0xc0100037) and 'startup_32_smp' WARNING: vmlinux - Section mismatch: reference to .init.data:init_pg_tables_end from .text between '_text' (at offset 0xc0100099) and 'startup_32_smp' o Can't move startup_32 to .init.text as this entry point has to be at the start of bzImage. Hence moved startup_32 to a new section .text.head and instructed MODPOST to not to generate warnings if init data is being accessed from .text.head section. This code has been audited. o SMP boot up code (startup_32_smp) can go into .init.text if CPU hotplug is not supported. Otherwise it generates more warnings WARNING: vmlinux - Section mismatch: reference to .init.data:new_cpu_data from .text between 'checkCPUtype' (at offset 0xc0100126) and 'is486' WARNING: vmlinux - Section mismatch: reference to .init.data:new_cpu_data from .text between 'checkCPUtype' (at offset 0xc0100130) and 'is486' Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Andi Kleen <ak@suse.de>
2007-02-11[PATCH] fix fatal kernel-doc errorRandy Dunlap
Teach kernel-doc to handle functions that look like the new pcim_iomap_table(). Fixes this fatal error in scripts/kernel-doc: DOCPROC Documentation/DocBook/kernel-api.xml Error(/tester/linsrc/linux-2.6.20-git6//drivers/pci/pci.c:1351): cannot understand prototype: 'void __iomem * const * pcim_iomap_table(struct pci_dev *pdev) ' make[1]: *** [Documentation/DocBook/kernel-api.xml] Error 1 make: *** [htmldocs] Error 2 Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] kernel-doc: fix some odd spacing issuesRandy Dunlap
- in man and text mode output, if the function return type is empty (like it is for macros), don't print the return type and a following space; this fixes an output malalignment; - in the function short description, strip leading, trailing, and multiple embedded spaces (to one space); this makes function name/description output spacing consistent; - fix a comment typo; Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] kernel-doc: allow more whitespaceRandy Dunlap
Allow whitespace in pointer-to-function [accept "(* done)", not just "(*done)"]. Allow tabs (spaces are already allowed) between "#define" and a macro name. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] kernel-doc: allow a little whitespaceRandy Dunlap
In kernel-doc syntax, be a little flexible: allow whitespace between a function parameter name and the colon that must follow it, such as: @pdev : PCI device to unplug (This allows lots of megaraid kernel-doc to work without tons of editing.) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] DocBook/HTML: correction of recursive A tags in HTML outputPavel Pisa
The malformed HTML was generated after switch to XSLTPROC from SGML tools. The reference title <refentrytitle><phrase id="API-struct-x">struct x</phrase></refentrytitle> is converted into two recursive <a> tags <a href="re02.html"><span><a id="API-struct-x"></a>struct x</span></a> There is more possible solutions for this problem. One can be found at http://darkk.livejournal.com/ The proposed solution is based on suggestion provided by Jiri Kosek. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-09[PATCH] kbuild: more Makefile cleanupsRoman Zippel
This adds the remaining changes which should have been part of the review process. - the define command is inappropriate (it's primarily for rule definitions) - execute commands in the current dir as all other commands - .*.tmp (but not .*.null) files are also removed up by "make clean" - printf has other side effects, just use "echo -e" - proper quoting - proper indentation Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-08[PATCH] PA-RISC: Fix bogus warnings from modpostMatthew Wilcox
parisc and parisc64 seem to name sections a little differently from other targets. parisc64 gives spurious warnings like: WARNING: drivers/net/dummy.o - Section mismatch: reference to .init.text:dummy_setup from .data.rel.ro between '.LC1' (at offset 0x0) and '.LC6' and parisc gives spurious warnings like: WARNING: drivers/net/dummy.o - Section mismatch: reference to .init.text:dummy_setup from .rodata.cst4 between '.LC1' (at offset 0x0) and '.LC6' Given the other comments in modpost.c, it seems that the best solution is to move rodata down to the 'match at start of name' section and add .data.rel.ro to the 'match entire name' section. Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-02-08kbuild: fix space for good (take 103)Linus Torvalds
Michal Ostrowski points out what the real problem was: the spaces at the start of the definition of the 'checker-shell' make function. Cc: Michal Ostrowski <mostrows@watson.ibm.com> Acked-by: David Miller <davem@davemloft.net> Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: Oleg Verych <olecom@flower.upol.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-07kbuild: make $(checker-shell ) strip spaces around the resultLinus Torvalds
It looks like GNU make version 3.80 (but apparently not 3.81) adds leading whitespace to the result of the checker-shell execution. This strips them off explicitly. Also, don't bother symlinking the output file to /dev/null. It's likely as expensive as just writing the temp-file, and we need to remove it anyway afterwards. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-07[PATCH] kbuild, Kbuild.include: avoid using spaces in call argumentsOleg Verych
Do not use whitespace in arguments of functions in makefiles, as they propagate further without notice. Thus we get + echo ' y' instead of + echo y Fix misleading comments. Signed-off-by: Oleg Verych <olecom@flower.upol.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-06[PATCH] kbuild: improve option checking, Kbuild.include cleanupOleg Verych
GNU binutils, root users, tmpfiles, external modules ro builds must be fixed to do the right thing now. Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Horst Schirmeier <horst@schirmeier.com> Cc: Jan Beulich <jbeulich@novell.com> Cc: Daniel Drake <dsd@gentoo.org> Cc: Andi Kleen <ak@suse.de> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Oleg Verych <olecom@flower.upol.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-06[PATCH] kbuild scripts: replace gawk, head, bc with shell, updateOleg Verych
Replacing overhead of using some (external) programs instead of good old `sh'. Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: William Stearns <wstearns@pobox.com> Cc: Martin Schlemmer <azarah@nosferatu.za.org> Signed-off-by: Oleg Verych <olecom@flower.upol.cz> Acked-by: Mark Lord <lkml@rtr.ca> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30[PATCH] translate dashes in filenames for headers installMike Frysinger
The current filename->define translation does not scrub dashes so when creating stub defines for like asm-x86_64/ptrace-abi.h, we get: #define __ASM_STUB_PTRACE-ABI_H gcc just hates that sort of thing :) trivial attached patch adds - to the tr list to scrub it to _ Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-11[PATCH] qconf: (re)fix SIGSEGV on empty menu itemsRoman Zippel
Back out the recent fix for this bug, fix it by correctly initialising ConfigInfoView.sym. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: "Cyrill V. Gorcunov" <gorcunov@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2007-01-11[PATCH] x86-64: Modpost whitelist reference to more symbols (pattern 3)Vivek Goyal
o MODPOST generates warning on i386 if kernel is compiled with CONFIG_RELOCATABLE=y. WARNING: vmlinux - Section mismatch: reference to .init.text:__init_begin from .text between 'free_initmem' (at offset 0xc0114fd3) and 'do_test_wp_bit' WARNING: vmlinux - Section mismatch: reference to .init.text:_sinittext from .text between 'core_kernel_text' (at offset 0xc012aeae) and 'kernel_text_address' WARNING: vmlinux - Section mismatch: reference to .init.text:_einittext from .text between 'core_kernel_text' (at offset 0xc012aeb7) and 'kernel_text_address' WARNING: vmlinux - Section mismatch: reference to .init.text:_sinittext from .text between 'get_symbol_pos' (at offset 0xc0135776) and 'reset_iter' WARNING: vmlinux - Section mismatch: reference to .init.text:_einittext from .text between 'get_symbol_pos' (at offset 0xc013577d) and 'reset_iter' o These symbols (__init_begin, _sinittext, _einittext) belong to init section and generally represent a section boundary. These are special symbols in the sense that their size is zero and no memory is allocated for them in init section. Their addr and value are same. So even if we free the init section, it is ok to reference them. o Whitelist access to such select symbols in MODPOST. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org>
2007-01-11[PATCH] x86-64: modpost add more symbols to whitelist pattern2Vivek Goyal
o MODPOST generates warning for i386 if compiled with CONFIG_RELOCATABLE=y and serial console support is enabled. o Serial console setup function, serial8250_console_setup(), is a non __init function and it calls functions which are of type __init(). (uart_parse_options() and uart_set_options()). Assuming, setup will be called during init time, changing serial8250_console_setup() to __init. o Adding one more pattern to modpost whitelist. Console drivers might have *_console structures containing references to setup functions which can be of __init type. Don't generate warnings for those. WARNING: vmlinux - Section mismatch: reference to .init.text: from .data between 'serial8250_console' (at offset 0xc05a33d8) and 'serial8250_reg' Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org>
2007-01-05[PATCH] qconf: fix SIGSEGV on empty menu itemsCyrill V. Gorcunov
qconf may cause SIGSEGV by trying to show debug information on empty menu items Signed-off-by: Cyrill V. Gorcunov <gorcunov@gmail.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-22[PATCH] kernel-doc: allow unnamed structs/unionsRandy Dunlap
Make kernel-doc support unnamed (anonymous) structs and unions. There is one (union) in include/linux/skbuff.h (inside struct sk_buff) that is currently generating a kernel-doc warning, so this fixes that warning. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] kconfig: set gconf's save-widget's sensitivity according to ↵Karsten Wiese
.config's changed state Clean up a little. Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] kconfig: add "void conf_set_changed_callback(void (*fn)(void))", use ↵Karsten Wiese
it in qconf.cc Added function sets "void (*conf_changed_callback)(void)". Call it, if .config's changed state changes. Use above in qconf.cc to set gui's save-widget's sensitvity. Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] kconfig: make sym_change_count static, let it be altered by 2 ↵Karsten Wiese
functions only Those two functions are void sym_set_change_count(int count) and void sym_add_change_count(int count) All write accesses to sym_change_count are replaced by calls to above functions. Variable and changer-functions are moved to confdata.c. IMO thats ok, as sym_change_count is an attribute of the .config's change state. Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] kconfig: new function "bool conf_get_changed(void)"Karsten Wiese
Run "make xconfig" on a freshly untarred kernel-tree. Look at the floppy disk icon of the qt application, that has just started: Its in a normal, active state. Mouse click on it: .config is being saved. This patch series changes things so taht after the mouse click on the floppy disk icon, the icon is greyed out. If you mouse click on it now, nothing happens. If you change some CONFIG_*, the floppy disk icon returns to "active state", that is, if you mouse click it now, .config is written. This patch: Returns sym_change_count to reflect the .config's change state. All read only accesses of sym_change_count are replaced by calls to conf_get_changed() . mconfig.c is manipulated to ask for saving only when conf_get_changed() returned true. Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] Fix section mismatch in parainstructionsRandy Dunlap
Section .parainstructions should not warn about section mismatches. WARNING: drivers/net/hamradio/scc.o - Section mismatch: reference to .exit.text: from .parainstructions after '' (at offset 0x0) WARNING: drivers/net/hamradio/scc.o - Section mismatch: reference to .exit.text: from .parainstructions after '' (at offset 0x8) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Andi Kleen <ak@suse.de> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-10[PATCH] kbuild: don't put temp files in sourceRoman Zippel
The as-instr/ld-option need to create temporary files, but create them in the output directory, when compiling external modules. Reformat them a bit and use $(CC) instead of $(AS) as the former is used by kbuild to assemble files. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Andi Kleen <ak@suse.de> Cc: Jan Beulich <jbeulich@novell.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: <jpdenheijer@gmail.com> Cc: Horst Schirmeier <horst@schirmeier.com> Cc: Daniel Drake <dsd@gentoo.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] move kallsyms data to .rodataJan Beulich
Kallsyms data is never written to, so it can as well benefit from CONFIG_DEBUG_RODATA. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07Merge branch 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6Linus Torvalds
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6: (156 commits) [PATCH] x86-64: Export smp_call_function_single [PATCH] i386: Clean up smp_tune_scheduling() [PATCH] unwinder: move .eh_frame to RODATA [PATCH] unwinder: fully support linker generated .eh_frame_hdr section [PATCH] x86-64: don't use set_irq_regs() [PATCH] x86-64: check vector in setup_ioapic_dest to verify if need setup_IO_APIC_irq [PATCH] x86-64: Make ix86 default to HIGHMEM4G instead of NOHIGHMEM [PATCH] i386: replace kmalloc+memset with kzalloc [PATCH] x86-64: remove remaining pc98 code [PATCH] x86-64: remove unused variable [PATCH] x86-64: Fix constraints in atomic_add_return() [PATCH] x86-64: fix asm constraints in i386 atomic_add_return [PATCH] x86-64: Correct documentation for bzImage protocol v2.05 [PATCH] x86-64: replace kmalloc+memset with kzalloc in MTRR code [PATCH] x86-64: Fix numaq build error [PATCH] x86-64: include/asm-x86_64/cpufeature.h isn't a userspace header [PATCH] unwinder: Add debugging output to the Dwarf2 unwinder [PATCH] x86-64: Clarify error message in GART code [PATCH] x86-64: Fix interrupt race in idle callback (3rd try) [PATCH] x86-64: Remove unwind stack pointer alignment forcing again ... Fixed conflict in include/linux/uaccess.h manually Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] kernel-doc: stricter function pointer recognitionRandy Dunlap
Be more careful about function pointer args: look for "(...*" instead of just "(". This line in include/linux/input.h fools the current kernel-doc script into deciding that this is a function pointer: unsigned long ffbit[NBITS(FF_MAX)]; Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] ver_linux additionsValdis Kletnieks
scripts/ver_linux needed some minor clean-ups, as follows: 1) Add reporting of actual oprofile release 2) Add reporting of actual wireless-tools release 3) Add reporting of actual pcmciautils release Signed-off-by: Valdis Kletnieks <valdis.kletnieks@vt.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] qconf: support old QTakpm@osdl.org
Might make qconf compilable with qt-3.1 as well as qt-3.3 Cc: greg chesson <xtp@google.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] relocatable kernel: Fix kallsyms on avr32 after relocatable kernel ↵Vivek Goyal
changes o On some platforms like avr32, section init comes before .text and not necessarily a symbol's relative position w.r.t _text is positive. In such cases assembler detects the overflow and emits warning. This patch fixes it. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Andi Kleen <ak@suse.de> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-12-07[PATCH] paravirt: Patch inline replacements for paravirt interceptsRusty Russell
It turns out that the most called ops, by several orders of magnitude, are the interrupt manipulation ops. These are obvious candidates for patching, so mark them up and create infrastructure for it. The method used is that the ops structure has a patch function, which is called for each place which needs to be patched: this returns a number of instructions (the rest are NOP-padded). Usually we can spare a register (%eax) for the binary patched code to use, but in a couple of critical places in entry.S we can't: we make the clobbers explicit at the call site, and manually clobber the allowed registers in debug mode as an extra check. And: Don't abuse CONFIG_DEBUG_KERNEL, add CONFIG_DEBUG_PARAVIRT. And: AK: Fix warnings in x86-64 alternative.c build And: AK: Fix compilation with defconfig And: ^From: Andrew Morton <akpm@osdl.org> Some binutlises still like to emit references to __stop_parainstructions and __start_parainstructions. And: AK: Fix warnings about unused variables when PARAVIRT is disabled. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Zachary Amsden <zach@vmware.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-12-07[PATCH] relocatable kernel: Kallsyms generate relocatable symbolsEric W. Biederman
Print the addresses of non-absolute symbols relative to _text so that ld will generate relocations. Allowing a relocatable kernel to relocate them. We can't actually use the symbol names because kallsyms includes static symbols that are not exported from their object files. Add the _text symbol definitions to the architectures which don't define it otherwise linker will fail. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de>
2006-11-25[PATCH] fix menuconfig colours with TERM=vt100Roman Zippel
On Mon, 13 Nov 2006, Phil Oester wrote: > In commit 350b5b76384e77bcc58217f00455fdbec5cac594, the default menuconfig > color scheme was changed to bluetitle. This breaks the highlighting > of the selected item for me with TERM=vt100. The only way I can see > which item is selected is via: > > make MENUCONFIG_COLOR=mono menuconfig > > Which restores the pre-2.6.19 white on black highlighting. Fix. Cc: Phil Oester <kernel@linuxace.com> Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
