path: root/scripts
2007-07-06x86_64: fix headers_installDavid Woodhouse
A bug in headers_install for ARCH=x86_64 yields an asm/ directory full of files all of which are using the same #ifdef guard, "__ASM_STUB_" with no postfix. So the second and later asm files #included in the same C file (often through standard headers like ioctl.h) yields no symbols. Strangeness with the Ubuntu 'tell me if I support something that's not explcitly mentioned in POSIX, and I'll strip it out' shell, I believe. We don't need the 'export' but we do need a semicolon at the end of the FNAME line: Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Rob Landley <rob@landley.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-28Introduce fixed sys_sync_file_range2() syscall, implement on PowerPC and ARMDavid Woodhouse
Not all the world is an i386. Many architectures need 64-bit arguments to be aligned in suitable pairs of registers, and the original sys_sync_file_range(int, loff_t, loff_t, int) was therefore wasting an argument register for padding after the first integer. Since we don't normally have more than 6 arguments for system calls, that left no room for the final argument on some architectures. Fix this by introducing sys_sync_file_range2(int, int, loff_t, loff_t) which all fits nicely. In fact, ARM already had that, but called it sys_arm_sync_file_range. Move it to fs/sync.c and rename it, then implement the needed compatibility routine. And stop the missing syscall check from bitching about the absence of sys_sync_file_range() if we've implemented sys_sync_file_range2() instead. Tested on PPC32 and with 32-bit and 64-bit userspace on PPC64. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-24update checkpatch.pl to version 0.06Andy Whitcroft
Update to checkpatch.pl v0.06. Of note: - do { and else handled correctly as control structures for { matching - trailing whitespace correctly tripped when line otherwise empty - support for const, including const foo * const bar - multiline macros defining values correctly reported This version of checkpatch.pl can be found at the following URL: http://www.kernel.org/pub/linux/kernel/people/apw/checkpatch/checkpatch.pl-0.06 Full Changelog: Andy Whitcroft (14): Version: 0.06 cleanup the Type regular expression declarations fix up block counting end of line counts as a space for ++ and -- do { needs the same checks as if, for et al handle "const foo * const a" as a valid type add spacing checks following ; complete whitespace lines should trip trailing whitespace check else is also a block control structure badly formatted else can trip function declaration detect and report trailing statements after else types need to be terminated by a boundary multiline macros defining values should be surrounded by parentheses soften the wording of the Signed-off-by: warnings Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-24update checkpatch.pl to version 0.05Andy Whitcroft
This version brings a some new tests, and a host of changes to fix false positives, of particular note: - detect 'var ++;' and 'var --;' as a bad combination - multistatement #defines are now checked based on statement count - multistatement #defines with initialisation correctly reported - checks the location of the inline keywords - EXPORT_SYMBOL for variables are now understood - typedefs are loosened to handle sparse etc This version of checkpatch.pl can be found at the following URL: http://www.shadowen.org/~apw/public/checkpatch/checkpatch.pl-0.05 Full Changelog: Andy Whitcroft (18): Version: 0.05 macro definition checks should be for a single statement avoid assignements only in if conditionals declarations of function pointers need no space multiline macros which are purely initialisation cannot be wrapped EXPORT_SYMBOL can also directly follow a variable definition check on the location of the inline keyword EXPORT_SYMBOL needs to allow for attributes ensure we do not find C99 // in strings handle malformed #include lines accept the {0,} form typedefs are sensible for defining function pointer parameters ensure { handling correctly handles nested switch() statements trailing whitespace checks are not anchored typedefs for sparse bitwise annotations make sense update the type matcher to include sparse annotations clean up indent and spacing Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-11kbuild: fix sh64 section mismatch problemsSam Ravnborg
There's a special .cranges section that is almost always generated, with data being moved to the appropriate section by the linker at a later stage. To give a bit of background, sh64 has both a native SHmedia instruction set (32-bit instructions) and SHcompact (which is compatability with normal SH -- 16-bit, a massively reduced register set, etc.). code ranges are emitted when we're using the 32-bit ABI, but not the 64-bit one. It is a special staging section used solely by binutils where code with different flags get placed (more specifically differing flags for input and output sections), before being lazily merged by the linker. The closest I've been able to find to documentation is: http://sources.redhat.com/cgi-bin/cvsweb.cgi/src/ld/emultempl/sh64elf.em?rev=1.10&content-type=text/x-cvsweb-markup&cvsroot=src It's an array of 8-byte Elf32_CRange structure given in http://sources.redhat.com/cgi-bin/cvsweb.cgi/src/bfd/elf32-sh64.h?rev=1.4&content-type=text/x-cvsweb-markup&cvsroot=src that describes for which ISA a range is used. Silence the warnings by allowing references from .init.text to .cranges. The following warnings are fixed: WARNING: init/built-in.o(.cranges+0x0): Section mismatch: reference to .init.text: WARNING: init/built-in.o(.cranges+0xa): Section mismatch: reference to .init.text: WARNING: init/built-in.o(.cranges+0x14): Section mismatch: reference to .init.text: WARNING: init/built-in.o(.cranges+0x1e): Section mismatch: reference to .init.text: WARNING: init/built-in.o(.cranges+0x28): Section mismatch: reference to .init.text: WARNING: init/built-in.o(.cranges+0x32): Section mismatch: reference to .init.text: WARNING: kernel/built-in.o(.cranges+0x50): Section mismatch: reference to .init.text: WARNING: kernel/built-in.o(.cranges+0x5a): Section mismatch: reference to .init.text: WARNING: kernel/built-in.o(.cranges+0x64): Section mismatch: reference to .init.text: WARNING: kernel/built-in.o(.cranges+0xfa): Section mismatch: reference to .init.text: WARNING: kernel/built-in.o(.cranges+0x104): Section mismatch: reference to .init.text: WARNING: kernel/built-in.o(.cranges+0x10e): Section mismatch: reference to .init.text: WARNING: kernel/built-in.o(.cranges+0x14a): Section mismatch: reference to .init.text: WARNING: kernel/built-in.o(.cranges+0x154): Section mismatch: reference to .init.text: WARNING: kernel/built-in.o(.cranges+0x15e): Section mismatch: reference to .init.text: WARNING: mm/built-in.o(.cranges+0x6e): Section mismatch: reference to .init.text: WARNING: mm/built-in.o(.cranges+0x78): Section mismatch: reference to .init.text: WARNING: mm/built-in.o(.cranges+0x82): Section mismatch: reference to .init.text: WARNING: mm/built-in.o(.cranges+0xaa): Section mismatch: reference to .init.text: WARNING: fs/built-in.o(.cranges+0x136): Section mismatch: reference to .init.text: WARNING: fs/built-in.o(.cranges+0x140): Section mismatch: reference to .init.text: WARNING: fs/built-in.o(.cranges+0x14a): Section mismatch: reference to .init.text: WARNING: fs/built-in.o(.cranges+0x168): Section mismatch: reference to .init.text: WARNING: fs/built-in.o(.cranges+0x1f4): Section mismatch: reference to .init.text: WARNING: fs/built-in.o(.cranges+0x1fe): Section mismatch: reference to .init.text: WARNING: net/built-in.o(.cranges+0x302): Section mismatch: reference to .init.text: WARNING: net/built-in.o(.cranges+0x30c): Section mismatch: reference to .init.text: WARNING: net/built-in.o(.cranges+0x316): Section mismatch: reference to .init.text: WARNING: net/built-in.o(.cranges+0x3a2): Section mismatch: reference to .init.text: WARNING: net/built-in.o(.cranges+0x3ac): Section mismatch: reference to .init.text: WARNING: net/built-in.o(.cranges+0x4ce): Section mismatch: reference to .init.text: WARNING: net/built-in.o(.cranges+0x4d8): Section mismatch: reference to .init.text: Signed-off-by: Paul Mundt <lethal@linux-sh.org> Cc: Kaz Kojima <kkojima@rr.iij4u.or.jp> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-06-08update checkpatch.pl to version 0.04Andy Whitcroft
This version brings a some new tests, and a host of changes to fix false positives, of particular note: - check for and report #if 0 - extend checking of line lengths and spacing for .pl, .sh etc - extends the pointer type checks to multiple levels - updates printk handling to track newlines - adds a wrapped patch detector - drops the leading component of the filenames - extends switch indent handling to switch statmentes rooted in the context - adds foo * bar single pointer checks This version of checkpatch.pl can be found at the following URL: http://www.shadowen.org/~apw/public/checkpatch/checkpatch.pl-0.04 Full Changelog: Andy Whitcroft (16): allow checking line lengths and spacing on other source files clean up that whitespace sanitise the input line standardising the content of quotes clean up pointer type * and space checks fix up the sanitiser so it maintains the line length apply the printk facility checks only to the first printk in a set switch/case indent checks may anchor in the context add a wrapped patch detector put the #ifdef in C file checks on ice asm volatile is acceptable check for and report #if 0 drop the leading component of the filename as patches are -p1 use the original line when reporting operator errors correct spelling of Joel's name Version: 0.04 add support for struct foo * bar checks Geert Uytterhoeven (1): Fix checkpatch.pl name in usage template Randy Dunlap (1): checkpatch: produce fewer lines of output Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Joel Schopp <jschopp@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-08checkpatch: produce fewer lines of outputRandy Dunlap
Produce one less line of output per flagged incident. Change this: use tabs not spaces PATCH: /home/rddunlap/arcmsr1200014.patch4:756: FILE: b/drivers/scsi/arcmsr/arcmsr_hba.c:1843: + return PCI_ERS_RESULT_NEED_RESET;$ to this: use tabs not spaces #756: FILE: b/drivers/scsi/arcmsr/arcmsr_hba.c:1843: + return PCI_ERS_RESULT_NEED_RESET;$ Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-08update checkpatch.pl to version 0.03Andy Whitcroft
This version brings a host of changes to cure false positives and bugs detected on patches submitted to lkml and -mm. It also brings a number of new tests in response to reviews, of particular note: - catch use of volatile - allow deprecated functions to be listed in feature-removal-schedule.txt - warn about #ifdef's in c files - check that spinlock_t and struct mutex use is commented - report on architecture specific defines being used - report memory barriers without an associated comment Full changelog: catch use of volatile convert other quoted string checks to common routine alloc deprecated functions to be listed in feature-removal-schedule.txt split out the line length and indent for each line improve switch block handling handle GNU diff context lines with no leading space warn about #ifdef's in c files tidy up tests for signed-off-by using raw mode check that spinlock_t and struct mutex use is commented syntax checks for open brace placement may drop off the bottom of hunk report memory barriers without an associated comment when a sign off is present but ugly do not report it missing do not mistake bitfield definitions for indented labels report on architecture specific defines being used major update to the operator checks prevent switch/if/while etc matching foo_switch generify assignement in condition error message introduce an operator context marker Version: 0.03 Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-07checkpatch.pl: should be executableAndy Whitcroft
scripts/checkpatch.pl should be executable, make it so. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Acked-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Joel Schopp <jschopp@austin.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-01add a trivial patch style checkerAndy Whitcroft
We are seeing increasing levels of minor patch style violations in submissions to the mailing lists as well as making it into the tree. These detract from the quality of the submission and cause unnessary work for reviewers. As a first step package up the current state of the patch style checker and include it in the kernel tree. Add instructions suggesting running it on submissions. This adds version v0.01 of the checkpatch.pl script. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Joel Schopp <jschopp@austin.ibm.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-21Make 'headerscheck' stop immediately on an errorDavid Woodhouse
This should make it stop immediately after printing the _helpful_ error message, rather than continuing to spit out many pages more of 'CHECK include/linux/foo.h' before eventually coming to a halt with something less obvious. Now I get this... CHECK include/linux/smb_fs.h /shiny/git/linux-2.6/usr/include/linux/smb_fs.h requires linux/jiffies.h, which does not exist in exported headers make[2]: *** [/shiny/git/linux-2.6/usr/include/linux/.check.smb_fs.h] Error 1 make[1]: *** [linux] Error 2 make: *** [headers_check] Error 2 Signed-off-by-if-Sam-says-so: David Woodhouse <dwmw2@infradead.org> [ Sam had better say so! This made me waste way too much time. - Linus] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-21Revert "kbuild: make better section mismatch reports on i386, arm and mips"Linus Torvalds
This reverts commit f892b7d480eec809a5dfbd6e65742b3f3155e50e, which totally broke the build on x86 with CONFIG_RELOCATABLE (which, as far as I can tell, is the only case where it should even matter!) due to a SIGSEGV in modpost. Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fix: mm/slab: fix section mismatch warning mm: fix section mismatch warnings init/main: use __init_refok to fix section mismatch kbuild: introduce __init_refok/__initdata_refok to supress section mismatch warnings all-archs: consolidate .data section definition in asm-generic all-archs: consolidate .text section definition in asm-generic kbuild: add "Section mismatch" warning whitelist for powerpc kbuild: make better section mismatch reports on i386, arm and mips kbuild: make modpost section warnings clearer kconfig: search harder for curses library in check-lxdialog.sh kbuild: include limits.h in sumversion.c for PATH_MAX powerpc: Fix the MODALIAS generation in modpost for of devices
2007-05-21x86_64: Support x86_64 in make buildtarAndi Kleen
Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-19mm: fix section mismatch warningsSam Ravnborg
modpost had two cases hardcoded for mm/ Shift over to __init_refok and kill the hardcoded function names in modpost. This has the drawback that the functions will always be kept no matter configuration. With previous code the function were placed in init section if configuration allowed it. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-19init/main: use __init_refok to fix section mismatchSam Ravnborg
Kill a special case in modpost by introducing the __init_refok marker. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-19kbuild: introduce __init_refok/__initdata_refok to supress section mismatch ↵Sam Ravnborg
warnings Throughout the kernel there are a few legitimite references to init or exit sections. Most of these are covered by the patterns included in modpost but a few nees special attention. To avoid hardcoding a lot of function names in modpost introduce a marker so relevant function/data can be marked. When modpost see a reference to a init/exit function from a function/data marked no warning will be issued. Idea from: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Andrew Morton <akpm@linux-foundation.org>
2007-05-19kbuild: add "Section mismatch" warning whitelist for powerpcLi Yang
This patch fixes the following class of "Section mismatch" warnings when building powerpc platforms. WARNING: arch/powerpc/kernel/built-in.o - Section mismatch: reference to .init.data:.got2 from prom_entry (offset 0x0) WARNING: arch/powerpc/platforms/built-in.o - Section mismatch: reference to .init.text:mpc8313_rdb_probe from .machine.desc after 'mach_mpc8313_rdb' (at offset 0x4) .... Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-19kbuild: make better section mismatch reports on i386, arm and mipsAtsushi Nemoto
On i386, ARM and MIPS, warn_sec_mismatch() sometimes fails to show usefull symbol name. This is because empty 'refsym' due to 0 r_addend value. This patch is to adjust r_addend value, consulting with apply_relocate() routine in kernel code. Without this patch: MODPOST vmlinux WARNING: init/built-in.o - Section mismatch: reference to .init.text: from .text between 'rest_init' (at offset 0xf4) and 'try_name' WARNING: mm/built-in.o - Section mismatch: reference to .init.text: from .text between 'kmem_cache_create' (at offset 0x18a39) and 'cache_reap' WARNING: mm/built-in.o - Section mismatch: reference to .init.text: from .text between 'kmem_cache_create' (at offset 0x18a6b) and 'cache_reap' With this patch: MODPOST vmlinux WARNING: mm/built-in.o - Section mismatch: reference to .init.text:set_up_list3s from .text between 'kmem_cache_create' (at offset 0x18a39) and 'cache_reap' WARNING: mm/built-in.o - Section mismatch: reference to .init.text:set_up_list3s from .text between 'kmem_cache_create' (at offset 0x18a6b) and 'cache_reap' Now modpost can detect "kernel_init" name (and whitelist it) and show "set_up_list3s" name. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-19kbuild: make modpost section warnings clearerRussell King
Change modpost section mismatch warnings to be less confusing; model them on the binutils linker warnings which we all know how to interpret. Also, fix the wrong ordering of arguments for the final case - fromsec and refsymname were reversed. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-19kconfig: search harder for curses library in check-lxdialog.shMike Frysinger
The check-lxdialog.sh script searches for "libFOO.so" which fails on OS X, due to their special naming of libraries like "libfoo.dylib". This patch turns the curses lib search into extensible loops and adds dylib as a valid extension. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-19kbuild: include limits.h in sumversion.c for PATH_MAXMike Frysinger
POSIX says limits.h defines PATH_MAX so we should include it (which fixes compiling on some systems like OS X). Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-19powerpc: Fix the MODALIAS generation in modpost for of devicesSylvain Munaut
Since the devices may have multiple (or none) compatible properties, the uevent generated internally by the kernel may have multiple "C..." entries. So the MODALIAS stored in the module must have wilcard before and after the compatible entry. Also, if the 'compatible' field is not used for matching, there will be no 'C' and that must handled as well. The previous code handled all those case incorrectly and it "mostly" worked ... but not always. Signed-off-by: Sylvain Munaut <tnt@246tNt.com> Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (25 commits) sound: convert "sound" subdirectory to UTF-8 MAINTAINERS: Add cxacru website/mailing list include files: convert "include" subdirectory to UTF-8 general: convert "kernel" subdirectory to UTF-8 documentation: convert the Documentation directory to UTF-8 Convert the toplevel files CREDITS and MAINTAINERS to UTF-8. remove broken URLs from net drivers' output Magic number prefix consistency change to Documentation/magic-number.txt trivial: s/i_sem /i_mutex/ fix file specification in comments drivers/base/platform.c: fix small typo in doc misc doc and kconfig typos Remove obsolete fat_cvf help text Fix occurrences of "the the " Fix minor typoes in kernel/module.c Kconfig: Remove reference to external mqueue library Kconfig: A couple of grammatical fixes in arch/i386/Kconfig Correct comments in genrtc.c to refer to correct /proc file. Fix more "deprecated" spellos. Fix "deprecated" typoes. ... Fix trivial comment conflict in kernel/relay.c.
2007-05-09Allow arch to initialize arch field of the module structureRoman Zippel
This will later allow an arch to add module specific information via linker generated tables instead of poking directly in the module object structure. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09kernel-doc: small kernel-doc optimizationBorislav Petkov
Get the kernel version string only once from the environment, thus slightly speeding up kernel-doc. Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Fix occurrences of "the the "Michael Opdenacker
Signed-off-by: Michael Opdenacker <michael@free-electrons.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-08kill warnings when building mandocsBorislav Petkov
This patch shuts warnings of the sort: make -C /mnt/samsung_200/sam/kernel/trees/21-rc6/build \ KBUILD_SRC=/mnt/samsung_200/sam/kernel/trees/21-rc6 \ KBUILD_EXTMOD="" -f /mnt/samsung_200/sam/kernel/trees/21-rc6/Makefile mandocs make -f /mnt/samsung_200/sam/kernel/trees/21-rc6/scripts/Makefile.build obj=scripts/basic make -f /mnt/samsung_200/sam/kernel/trees/21-rc6/scripts/Makefile.build obj=Documentation/DocBook mandocs SRCTREE=/mnt/samsung_200/sam/kernel/trees/21-rc6/ /mnt/samsung_200/sam/kernel/trees/21-rc6/build/scripts/basic/docproc doc /mnt/samsung_200/sam/kernel/trees/21-rc6/Documentation/DocBook/wanbook.tmpl >Documentation/DocBook/wanbook.xml if grep -q refentry Documentation/DocBook/wanbook.xml; then xmlto man -m /mnt/samsung_200/sam/kernel/trees/21-rc6/Documentation/DocBook/stylesheet.xsl -o Documentation/DocBook/man Documentation/DocBook/wanbook.xml ; gzip -f Documentation/DocBook/man/*.9; fi Note: meta version: No productnumber or alternative sppp_close Note: meta version: No refmiscinfo@class=version sppp_close Note: Writing sppp_close.9 Note: meta version: No productnumber or alternative sppp_open Note: meta version: No refmiscinfo@class=version sppp_open by adding a RefMiscInfo xml tag in the form of the current kernel version to the function, struct and enum definitions in files included by kernel-doc when building 'mandocs'. However, the version string appears truncated on the manpage due to some constraints in the xml DTD for the man header, I believe, for the troff output is truncated too. Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08kernel-doc: html mode struct highlightsRandy Dunlap
Johannes Berg reported that struct names are not highlighted (bold, italic, etc.) in html kernel-doc output. (Also not in text-mode output, but I don't see that changing.) This patch adds the following: - highlight struct names in html output mode - highlight environment var. names in html output mode - indent struct fields in the original struct layout Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08kernel-doc: handle arrays with arithmetic expressions as initializersBorislav Petkov
In a different approach here's a patch that handles the special case of composite arithmetic expressions in array size initializers. With it, prior to pushing the split strings on the @first_arg array, I split the keywords before the array name as before and then keep the array name along with the subscript expression as a single whole element which gets pushed last. In this manner, kernel-doc produces correct output without removing whitespaces which makes the array subscripts unreadable in the docs. Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08scripts: kernel-doc whitespace cleanupRandy Dunlap
Whitespace cleanup only: convert some series of spaces to tabs. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Add white list into modpost.c for memory hotplug code and ia64's machvec sectionYasunori Goto
This patch is add white list into modpost.c for some functions and ia64's section to fix section mismatchs. sparse_index_alloc() and zone_wait_table_init() calls bootmem allocator at boot time, and kmalloc/vmalloc at hotplug time. If config memory hotplug is on, there are references of bootmem allocater(init text) from them (normal text). This is cause of section mismatch. Bootmem is called by many functions and it must be used only at boot time. I think __init of them should keep for section mismatch check. So, I would like to register sparse_index_alloc() and zone_wait_table_init() into white list. In addition, ia64's .machvec section is function table of some platform dependent code. It is mixture of .init.text and normal text. These reference of __init functions are valid too. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07blackfin architectureBryan Wu
This adds support for the Analog Devices Blackfin processor architecture, and currently supports the BF533, BF532, BF531, BF537, BF536, BF534, and BF561 (Dual Core) devices, with a variety of development platforms including those avaliable from Analog Devices (BF533-EZKit, BF533-STAMP, BF537-STAMP, BF561-EZKIT), and Bluetechnix! Tinyboards. The Blackfin architecture was jointly developed by Intel and Analog Devices Inc. (ADI) as the Micro Signal Architecture (MSA) core and introduced it in December of 2000. Since then ADI has put this core into its Blackfin processor family of devices. The Blackfin core has the advantages of a clean, orthogonal,RISC-like microprocessor instruction set. It combines a dual-MAC (Multiply/Accumulate), state-of-the-art signal processing engine and single-instruction, multiple-data (SIMD) multimedia capabilities into a single instruction-set architecture. The Blackfin architecture, including the instruction set, is described by the ADSP-BF53x/BF56x Blackfin Processor Programming Reference http://blackfin.uclinux.org/gf/download/frsrelease/29/2549/Blackfin_PRM.pdf The Blackfin processor is already supported by major releases of gcc, and there are binary and source rpms/tarballs for many architectures at: http://blackfin.uclinux.org/gf/project/toolchain/frs There is complete documentation, including "getting started" guides available at: http://docs.blackfin.uclinux.org/ which provides links to the sources and patches you will need in order to set up a cross-compiling environment for bfin-linux-uclibc This patch, as well as the other patches (toolchain, distribution, uClibc) are actively supported by Analog Devices Inc, at: http://blackfin.uclinux.org/ We have tested this on LTP, and our test plan (including pass/fails) can be found at: http://docs.blackfin.uclinux.org/doku.php?id=testing_the_linux_kernel [m.kozlowski@tuxland.pl: balance parenthesis in blackfin header files] Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Aubrey Li <aubrey.li@analog.com> Signed-off-by: Jie Zhang <jie.zhang@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: (38 commits) kconfig: fix mconf segmentation fault kbuild: enable use of code from a different dir kconfig: error out if recursive dependencies are found kbuild: scripts/basic/fixdep segfault on pathological string-o-death kconfig: correct minor typo in Kconfig warning message. kconfig: fix path to modules.txt in Kconfig help usr/Kconfig: fix typo kernel-doc: alphabetically-sorted entries in index.html of 'htmldocs' kbuild: be more explicit on missing .config file kbuild: clarify the creation of the LOCALVERSION_AUTO string. kbuild: propagate errors from find in scripts/gen_initramfs_list.sh kconfig: refer to qt3 if we cannot find qt libraries kbuild: handle compressed cpio initramfs-es kbuild: ignore section mismatch warning for references from .paravirtprobe to .init.text kbuild: remove stale comment in modpost.c kbuild/mkuboot.sh: allow spaces in CROSS_COMPILE kbuild: fix make mrproper for Documentation/DocBook/man kbuild: remove kconfig binaries during make mrproper kconfig/menuconfig: do not hardcode '.config' kbuild: override build timestamp & version ...
2007-05-06kconfig: fix mconf segmentation faultMarcin Garski
I have found small bug in mconf, when you run it without any argument it will sigsegv. Without patch: $ scripts/kconfig/mconf Segmentation fault With patch: $ scripts/kconfig/mconf can't find file (null) Signed-off-by: Marcin Garski <mgarski@post.pl> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-06kbuild: enable use of code from a different dirSam Ravnborg
To introduce support for source in one directory but output files in another directory during a non O= build prefix all paths with $(src) repsectively $(obj). Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-06kconfig: error out if recursive dependencies are foundSam Ravnborg
Sample: config FOO bool "This is foo" depends on BAR config BAR bool "This is bar" depends on FOO This will result in following error message: error: found recursive dependency: FOO -> BAR -> FOO And will then exit with exit code equal 1 so make will stop. Inspired by patch from: Adrian Bunk <bunk@stusta.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Adrian Bunk <bunk@stusta.de> Cc: Roman Zippel <zippel@linux-m68k.org>
2007-05-02kbuild: scripts/basic/fixdep segfault on pathological string-o-deathAndy Green
build scripts: fixdep blows segfault on string CONFIG_MODULE seen The string "CONFIG_MODULE" appearing anywhere in a source file causes fixdep to segfault. This string appeared in the wild in the current mISDN sources (I think they meant CONFIG_MODULES). But it shouldn't segfault (esp as CONFIG_MODULE appeared in a quoted string). Signed-off-by: Andy Green <andy@warmcat.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-02kconfig: correct minor typo in Kconfig warning message.Robert P. J. Day
Correct a minor spelling mistake in a Kconfig warning message. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-02kbuild: be more explicit on missing .config fileRandy Dunlap
Somewhat in reponse to kernel bugzilla #8197, be more explicit about why 'make all' fails when there is no .config file. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-02kbuild: propagate errors from find in scripts/gen_initramfs_list.shMichael Ellerman
If the find(1) in scripts/gen_initramfs_list.sh generates any errors, it will cause gen_initramfs_list.sh to fail (because of "set -e"), however the errors from find are not printed to the user. This is rather confusing: ~/src/powerpc$ make O=~/build/powerpc-cell32/ make[2]: *** [usr/initramfs_data.cpio.gz] Error 1 make[1]: *** [usr] Error 2 make[1]: *** Waiting for unfinished jobs.... make[1]: *** wait: No child processes. Stop. make: *** [_all] Error 2 It is much easier to work out what the problem is if we let the errors from find hit the console, eg: ~/src/powerpc$ make O=~/build/powerpc-cell32/ find: /home/michael/initramfs-source/home: Permission denied find: /home/michael/initramfs-source/lost+found: Permission denied find: /home/michael/initramfs-source/opt: Permission denied find: /home/michael/initramfs-source/root: Permission denied make[2]: *** [usr/initramfs_data.cpio.gz] Error 1 make[1]: *** [usr] Error 2 make[1]: *** Waiting for unfinished jobs.... make[1]: *** wait: No child processes. Stop. make: *** [_all] Error 2 Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-02kconfig: refer to qt3 if we cannot find qt librariesSam Ravnborg
We do not support qt4 (yet) so the simple fix was to warn that qt3 are missing. The better fix would have been to implment qt4 support but that has failed so far. This solves http://bugzilla.kernel.org/show_bug.cgi?id=8277 Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-02kbuild: handle compressed cpio initramfs-esAlex Landau
Make kbuild handle compressed cpio initramfs-es. An already compressed cpio is copied directly to usr/, while a non-compressed cpio is filtered through gzip (no changes here) on its way to usr/. If the user has created a compressed cpio by other means, this saves him from uncompressing it, just to be compressed again by kbuild. Signed-off-by: Alex Landau <landau.alex@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-02kbuild: ignore section mismatch warning for references from .paravirtprobe ↵Sam Ravnborg
to .init.text Added on request from: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Rusty Russell <rusty@rustcorp.com.au>
2007-05-02kbuild: remove stale comment in modpost.cSam Ravnborg
2007-05-02kbuild/mkuboot.sh: allow spaces in CROSS_COMPILEUwe kleine-König
I'm currently using CROSS_COMPILE="ccache arm-linux-". With that the bash builtin command "type" searches for ccache and arm-linux-mkimage and so sets MKIMAGE="/path/to/ccache" as I don't have arm-linux-mkimage. Then the script dies with an error, that ccache doesn't support the argument -A. This patch adds some quoting such that it works again for me. Please note that this patch doesn't help you if you use ${CROSSCOMPILE}-mkimage and ccache as mkuboot.sh now searches for the command "ccache arm-linux-mkimage". Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-02kbuild: remove kconfig binaries during make mrproperSam Ravnborg
Nigel Cunningham <nigel@nigel.suspend2.net> noticed that 'make mrproper' did not remove mconf. Fixed so we now remove all relevant binaries. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Nigel Cunningham <nigel@nigel.suspend2.net>
2007-05-02kconfig/menuconfig: do not hardcode '.config'Sam Ravnborg
Export and use the function conf_get_configname() to retreive the default configuration filename. Suggested by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-02kbuild: override build timestamp & versionSam Ravnborg
Introduce KBUILD_BUILD_VERSION to make it possible to override kernel build version during build time. Introduce KBUILD_BUILD_TIMESTAMP to make it possible to override kernel build timestamp during build time. But variables are useful mainly by distros that want to pass info from an SCM when building the kernel. Timestamp could be last checkin date for a file etc. The idea came from Olaf Hering <olaf@aepfle.de> Cc: Olaf Hering <olaf@aepfle.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-02kbuild: complain about missing system callsSam Ravnborg
Most system calls seems to get added to i386 first. This patch automatically generates a warning for any new system call which is implemented on i386 but not the architecture currently being compiled. On PowerPC at the moment, for example, it results in these warnings: init/missing_syscalls.h:935:3: warning: #warning syscall sync_file_range not implemented init/missing_syscalls.h:947:3: warning: #warning syscall getcpu not implemented init/missing_syscalls.h:950:3: warning: #warning syscall epoll_pwait not implemented The file scripts/checksyscalls.sh list a number of legacy system calls that are ignored because they only makes sense on i386 systems. Other contributors to this patch are Russell King <rmk+lkml@arm.linux.org.uk> and Stéphane Jourdois <kwisatz@rubis.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
