path: root/scripts
2006-03-20[PATCH] add EXPORT_SYMBOL_GPL_FUTURE()Greg Kroah-Hartman
This patch adds the ability to mark symbols that will be changed in the future, so that kernel modules that don't include MODULE_LICENSE("GPL") and use the symbols, will be flagged and printed out to the system log. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-17[PATCH] kbuild: fix buffer overflow in modpostSam Ravnborg
Jiri Benc <jbenc@suse.cz> reported that modpost would stop with SIGABRT if used with long filepaths. The error looked like: > Building modules, stage 2. > MODPOST > *** glibc detected *** scripts/mod/modpost: realloc(): invalid next size: +0x0809f588 *** > [...] Fix this by allocating at least the required memory + SZ bytes each time. Before we sometimes ended up allocating too little memory resuting in the glibc detected bug above. Based on patch originally submitted by: Jiri Benc <jbenc@suse.cz> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-06[PATCH] s390: fix match in ccw modaliasBastian Blank
Fix matching of devmodel in modaliases. It breaks automatic loading of any dasd module. Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-09Revert "[PATCH] kconfig: detect if -lintl is needed when linking conf,mconf"Linus Torvalds
This reverts commit 5e375bc7d586e0df971734a5a5f1f080ffd89b68. Kyle McMartin steps on his soap-box: "Sigh. Can everyone please stop assuming gcc can output to /dev/null? On several platforms, ld tries to lseek in the output file, and fails if it can't." Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-bugfixLinus Torvalds
2006-02-05[PATCH] kconfig: detect if -lintl is needed when linking conf,mconfRobb, Sam
On a system where libintl.h is present, but the NLS functionality is supplied by a separate library instead of the system C library, an attempt to "make config" or "make menuconfig" will fail with link errors, ex: scripts/kconfig/mconf.o:mconf.c:(.text+0xf63): undefined reference to `_libintl_gettext' This patch attempts to correct the problem by detecting whether or not NLS support requires linking with libintl. Signed-off-by: Samuel J Robb <sam.robb@timesys.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] kernel-doc: clean up the script (whitespace)Randy Dunlap
Remove lots of trailing whitespace. Nothing else. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] Doc/kernel-doc: add more usage infoRandy Dunlap
- Add info that structs, unions, enums, and typedefs are supported. - Add doc about "private:" and "public:" tags for struct fields. - Fix some typos. - Remove some trailing whitespace. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] DocBook: allow even longer return typesMartin Waitz
kernel-doc errored out because it could not understand the new __copy_to_user definition. Now we allow return types with four words. Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-21kconfig: fix /dev/null breakageSam Ravnborg
While running "make menuconfig" and "make mrproper" some people experienced that /dev/null suddenly changed permissions or suddenly became a regular file. The main reason was that /dev/null was used as output to gcc in the check-lxdialog.sh script and gcc did some strange things with the output file; in this case /dev/null when it errorred out. Following patch implements a suggestion from Bryan O'Sullivan <bos@serpentine.com> to use gcc -print-file-name=libxxx.so. Also the Makefile is adjusted to not resolve value of HOST_EXTRACFLAGS and HOST_LOADLIBES until they are actually used. This prevents us from calling gcc when running make *clean/mrproper Thanks to Eyal Lebedinsky <eyal@eyal.emu.id.au> and Jean Delvare <khali@linux-fr.org> for the first error reports. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> ---
2006-01-16kbuild: create .kernelrelease at *config stepSam Ravnborg
To enable 'make kernelrelease' earlier now create .kernelrelease when one of the *config targets are used. Also introduce KERNELVERSION - only user is kconfig. KERNELVERSION was needed to display kernel version in menuconfig - KERNELRELEASE is not valid until configuration has completed. kconfig files modified to use KERNELVERSION. Bug reported by: Rene Rebe <rene@exactcode.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-01-15kconfig: get rid of stray a.o, support ncurseswSam Ravnborg
scripts/kconfig/lxdialog/check-lxdialog.sh uses gcc to check for what libraries are present. Redirect output to /dev/null so we do not generate an a.out. Also included support for ncursesw - so if present prefer that instead of ncurses. The order is now (first is preferred): 1) ncursesw 2) ncurses 3) curses The latter is to support SunOS. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-01-10Merge ssh://master.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
Fix up some trivial conflicts in {i386|ia64}/Makefile
2006-01-10[PATCH] DocBook: warn for missing macro parametersMartin Waitz
Previously kernel-doc silently ignored missing parameter descriptions for preprocessor macros. Now that all such omissions are fixed up we can warn about them in kernel-doc to be able to keep it that way. Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10spelling: s/retreive/retrieve/Adrian Bunk
2006-01-08[PATCH] tiny: Add bloat-o-meter to scriptsMatt Mackall
This is a rewrite of Andi Kleen's bloat-o-meter with sorting and reporting of gainers/decliners. Sample output: add/remove: 0/8 grow/shrink: 2/0 up/down: 88/-4424 (-4336) function old new delta __copy_to_user_ll 59 103 +44 __copy_from_user_ll 59 103 +44 fill_note 32 - -32 maydump 58 - -58 dump_seek 67 - -67 writenote 180 - -180 elf_dump_thread_status 274 - -274 fill_psinfo 308 - -308 fill_prstatus 466 - -466 elf_core_dump 3039 - -3039 The summary line says: no functions added, 8 removed two functions grew, none shrunk we gained 88 bytes and lost 4424 (or -4336 net) This work was sponsored in part by CE Linux Forum Signed-off-by: Matt Mackall <mpm@selenic.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] kconf: Check for eof from input stream.Ben Collins
Signed-off-by: Ben Collins <bcollins@ubuntu.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] fix gcc4.1 build failure on xconfigDave Jones
scripts/kconfig/qconf.h:25: error: extra qualification ‘ConfigSettings::’ on member ‘readSizes’ scripts/kconfig/qconf.h:26: error: extra qualification ‘ConfigSettings::’ on member ‘writeSizes’ scripts/kconfig/qconf.h:127: error: extra qualification ‘ConfigList::’ on member ‘updateMenuList’ Signed-off-by: Dave Jones <davej@redhat.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08kbuild: reference_discarded additionDave Jones
Error: ./fs/quota_v2.o .opd refers to 0000000000000020 R_PPC64_ADDR64 .exit.text Been carrying this for some time in Red Hat trees. Keith Ownes <kaos@sgi.com> commented: For our future {in}sanity, add a comment that this is the ppc .opd section, not the ia64 .opd section. ia64 .opd should not point to discarded sections. Any idea why ppc .opd points to discarded sections when ia64 does not? AFAICT no ia64 object has a useful .opd section, they are all empty or (sometimes) a dummy entry which is 1 byte long. ia64 .opd data is built at link time, not compile time. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-01-08kbuild: In setlocalversion change -git_dirty to just -dirtyRyan Anderson
When building Debian packages directly from the git tree, the appended "git_dirty" is a problem due to the underscore. In order to cause the least problems, change that just to "dirty". Signed-off-by: Ryan Anderson <ryan@michonline.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-01-08modpost/file2alias: Fix typoBrian Gerst
SND_MAX should be FF_MAX Signed-off-by: Brian Gerst <bgerst@didntduck.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-01-08kconfig: factor out ncurses check in a shell scriptSam Ravnborg
Cleaning up the lxdialog Makefile by factoring out the ncurses compatibility checks. This made the checks much more obvious and easier to extend. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-01-06kbuild: introduce escsq to escapre single quotesSam Ravnborg
This makes things a little bit more reader friendly and gvim is less confused. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-01-06kconfig: fix gconfig with POSIXLY_CORRECT=1Adrian Bunk
This patch fixed "make gconfig" with POSIXLY_CORRECT=1 set. This issue was reported by Jens Elkner <elkner@linofee.org> in kernel Bugzilla #2919. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-01-06kbuild: Use git in scripts/setlocalversionRene Scharfe
Currently scripts/setlocalversion is a Perl script that tries to figure out the current git commit ID of a repo without using git. It also imports Digest::MD5 without using it and generally is too big for the small task it does. :] And it always reports a git ID, even when the HEAD is tagged -- this is a bug. This patch replaces it with a Bourne Shell script that uses git commands to do the same. I can't come up with a scenario where someone would use a git repo and refuse to install git core at the same time, so I think it's reasonable to assume git is available. The new script also reports uncommitted changes by adding -git_dirty to the version string. Obviously you can't see from that _what_ has been changed from the last commit, so it's more of a reminder that you forgot to commit something. The script is easily extensible: simply add a check for Mercurial (or whatever) below the git check. Note: the script doesn't print a newline char anymore. That's only because it was easier to implement it that way, not a feature (or bug). 'make kernelrelease' doesn't care. Signed-off-by: Rene Scharfe <rene.scharfe@lsrfire.ath.cx> Acked-by: Ryan Anderson <ryan@michonline.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-01-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
Trivial manual merge fixup for usb_find_interface clashes.
2006-01-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
2006-01-04[PATCH] Input: add modalias supportRusty Russell
Here's the patch for modalias support for input classes. It uses comma-separated numbers, and doesn't describe all the potential keys (no module currently cares, and that would make the strings huge). The changes to input.h are to move the definitions needed by file2alias outside __KERNEL__. I chose not to move those definitions to mod_devicetable.h, because there are so many that it might break compile of something else in the kernel. The rest is fairly straightforward. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> CC: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-03Merge branch 'master'Sam Ravnborg
2006-01-03update the email address of Randy DunlapAdrian Bunk
This patch removes all references to the bouncing address rddunlap@osdl.org and one dead web page from the kernel. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Randy Dunlap <rdunlap@xenotime.net>
2006-01-03s/retreiv/retriev/gMatt Mackall
As everyone knows, the rule is: "i before e.. um.. always." Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-03gitignore: ignore more generated files
2006-01-01kconfig: Remove support for lxdialog --checklistPetr Baudis
Remove support for lxdialog --checklist The checklist lxdialog functionality is not used by menuconfig (only the radiolist variant is used) and supporting it would significantly complicate the forthcoming liblxdialog API. Signed-off-by: Petr Baudis <pasky@suse.cz> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-01-01gitignore: misc filesBrian Gerst
Ignore all files generated from *_shipped files, plus a few others. Signed-off-by: Brian Gerst <bgerst@didntduck.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-01-01kbuild: tar-pkg with out-out-tree buildingJan-Benedict Glaw
Fix out-of-tree builds for the tar-pkg targets When I wrote the buildtar script, I didn't even think about out-of-tree builds because I didn't use these back then. This patch throughoutly uses ${objtree} instead of `pwd`. Also, the kernel version is no longer manually built. Instead, it will properly use $KERNELRELEASE . Installing modules is only done if CONFIG_MODULES is set. Signed-off-by: Jan-Benedict Glaw <jbglaw@lug-owl.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-12-26kbuild: always run 'make silentoldconfig' when tree is cleanedSam Ravnborg
If the file .kconfig.d is missing then make sure to run 'make silentoldconfig', since we have no way to detect if a Kconfig file has been updated. -kconfig.d is created by kconfig and is removed as part of 'make clean' so the situation is likely to occur in reality. Jan Beulich <JBeulich@novell.com> reported this bug. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-12-26kbuild: Create _shipped files for genksymsSam Ravnborg
Generate _shipped files so the genksyms change in previous commit is enabled. The files are generated with latest versions of the tools: bison (GNU Bison) 2.0 flex version 2.5.4 GNU gperf 3.0.1 Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-12-26kbuild: Fix genksyms handling of DEFINE_PER_CPU(struct foo_s *, bar);Robin Holt
This is a one-line change to parse.y. To take advantage of this the scripts/genksyms/*_shipped files needs to be rebuild - this is the next patch. When a .c file contains: DEFINE_PER_CPU(struct foo_s *, bar); the .cpp output looks like: __attribute__((__section__(".data.percpu"))) __typeof__(struct foo_s *) per_cpu__bar; With the existing parse.y, the value inside the paranthesis of __typeof__() does not evaluate as a type_specifier and therefore per_cpu__bar does not get assigned a type for genksyms which results in the EXPORT_PER_CPU_SYMBOL() not generating a CRC value. I have compared the Modules.symvers with and without this patch and for ia64's defconfig, the only change is: Before 0x00000000 per_cpu____sn_nodepda vmlinux After 0x9d3f3faa per_cpu____sn_nodepda vmlinux per_cpu____sn_nodepda was the original source of my problems. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-12-26kbuild: set correct KBUILD_MODNAME when using well known kernel symbols as ↵Ustyugov Roman
module names This patch fixes a problem when we use well known kernel symbols as module names. For example, if module source name is current.c, idle_stack.c or etc., we have a bad KBUILD_MODNAME value. For example, KBUILD_MODNAME will be "get_current()" instead of "current", or "(init_thread_union.stack)" instead of "idle_task". The trick is to define a stringify macro on the commandline - named KBUILD_STR for namespace reasons - and then to stringify the module name. There are a few uses of KBUILD_MODNAME throughout the tree but the usage is for debug and will not be harmed by this change so left untouched for now. While at it KBUILD_BASENAME was changed too. Any spinlock usage in the unix module would have created wrong section names without it. Usage in spinlock.h fixed so it no longer stringify KBUILD_BASENAME. Original patch from Ustyogov Roman - all bugs introduced by me. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-12-25kbuild: escape '#' in .target.cmd filesSam Ravnborg
Commandlines are contained in the .<target>.cmd files and in case they contain a '#' char make see this as start of comment. Teach fixdep to escape the '#' char so make will assing the full commandline. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-12-25kbuild: Fix crc-error warning on modulesLuke Yang
This is the patch for the following issue: In include/linux/module.h, "__crc_" and "__ksymtab_" are hard coded to be the prefix for some kinds of symbols (CRC symbol and ksymtab section). But in script /mod/modpost.c, MODULE_SYMBOL_PREFIX##"__crc_" is used as the prefix to search CRC symbols. So if an architecture (such as h8300 or Blackfin) defines MODULE_SYMBOL_PREFIX as not NULL ("_"), modpost will always warn about "no invalid crc". And it is the same with KSYMTAB_PFX. Signed-off-by: Luke Yang <luke.adi@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-12-16kconfig: move lxdialog to scripts/kconfig/lxdialogSam Ravnborg
The only lxdialog user i kconfig - for menuconfig. So move it to reflect this. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-11-22[PATCH] prefer pkg-config for the QT checkRoman Zippel
This makes pkg-config now the prefered way to configure QT and properly fixes the recent Fedora breakage and leaves the old QT detection as fallback mechanism. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-21kconfig: truncate too long menu lines in menuconfigSam Ravnborg
menu lines wrapped over too lines when too long - truncate them. Also fixed a coding style issue Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-11-20kconfig: make lxdialog/menubox.c more readableSam Ravnborg
Utilising a small macro for print_item made wonders for readability for this file. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-11-20kconfig: Fix indention when using menuconfig in text-onle consolesSam Ravnborg
When using menuconfig in a text-only console (no X started) the indention was often two spaces wrong. This proved to be a ncurses issue which are worked around by calling wrefresh more often. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-11-20kconfig: Left aling menu items in menuconfigSam Ravnborg
Keeping menu lines on a fixed position creates less visual noise when navigating the menus. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-11-19kconfig: Add print_title helper in lxdialogSam Ravnborg
Simplify check for long title and use a helper function in util.c Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-11-19kconfig: lxdialog is now sparse cleanSam Ravnborg
Replacing a gcc idiom with malloc and deleting an unused global variable made lxdialog sparse clean. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-11-19kconfig: fixup after LindentSam Ravnborg
Readability are more important then the 80 coloumn limit, so fold several lines to greatly improve readability. Also keep return type on same line as function definition. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
