path: root/scripts
2007-10-13i2c: Kill struct i2c_device_idJean Delvare
I2C devices do not have any form of ID as PCI or USB devices have. No driver uses "MODULE_DEVICE_TABLE(i2c, ...)" because it doesn't make sense. So we can get rid of struct i2c_device_id and the associated support code. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Greg KH <greg@kroah.com>
2007-10-11Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (867 commits) [SKY2]: status polling loop (post merge) [NET]: Fix NAPI completion handling in some drivers. [TCP]: Limit processing lost_retrans loop to work-to-do cases [TCP]: Fix lost_retrans loop vs fastpath problems [TCP]: No need to re-count fackets_out/sacked_out at RTO [TCP]: Extract tcp_match_queue_to_sack from sacktag code [TCP]: Kill almost unused variable pcount from sacktag [TCP]: Fix mark_head_lost to ignore R-bit when trying to mark L [TCP]: Add bytes_acked (ABC) clearing to FRTO too [IPv6]: Update setsockopt(IPV6_MULTICAST_IF) to support RFC 3493, try2 [NETFILTER]: x_tables: add missing ip6t_modulename aliases [NETFILTER]: nf_conntrack_tcp: fix connection reopening [QETH]: fix qeth_main.c [NETLINK]: fib_frontend build fixes [IPv6]: Export userland ND options through netlink (RDNSS support) [9P]: build fix with !CONFIG_SYSCTL [NET]: Fix dev_put() and dev_hold() comments [NET]: make netlink user -> kernel interface synchronious [NET]: unify netlink kernel socket recognition [NET]: cleanup 3rd argument in netlink_sendskb ... Fix up conflicts manually in Documentation/feature-removal-schedule.txt and my new least favourite crap, the "mod_devicetable" support in the files include/linux/mod_devicetable.h and scripts/mod/file2alias.c. (The latter files seem to be explicitly _designed_ to get conflicts when different subsystems work with them - that have an absolutely horrid lack of subsystem separation!) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/hskinnemoen/avr32-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/hskinnemoen/avr32-2.6: [AVR32] Fix random segfault with preemption [AVR32] Don't use __builtin_xchg() [AVR32] ngw100 i2c-gpio tweaks [AVR32] Ignore a few irrelevant syscalls [AVR32] SMC configuration in clock cycles [AVR32] Drop support for redundant "keepinitrd" boot-time parm. [AVR32] Make dma_sync_*_for_cpu no-ops [AVR32] Remove unneeded 8K alignment of .text section [AVR32] Kill a few hardcoded constants in vmlinux.lds [AVR32] rename vmlinux.lds [AVR32] fix command line parsing in early_parse_fbmem [AVR32] checkstack support [AVR32] Wire up USBA device [AVR32] add multidrive support for pio driver [AVR32] /sys/kernel/debug/at32ap_clk [AVR32] Move AT32_PM_BASE definition into pm.h
git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc: (67 commits) mmc: don't use weight32() pxamci: support arbitrary block size sdio: make the IRQ thread more resilient in the presence of bad states sdio: fix IRQ diagnostic message sdhci: remove old dma module params sdhci: add SDHCI_QUIRK_BROKEN_DMA quirk sdhci: remove DMA capability check from controller's PCI Class reg sdhci: fix a typo mmc: Disabler for Ricoh MMC controller sdio: adaptive interrupt polling mmc: pxamci: add SDIO card interrupt reporting capability mmc: pxamci: set proper buswidth capabilities according to PXA flavor mmc: pxamci: set proper block capabilities according to PXA flavor mmc: pxamci: better pending IRQ determination arm: i.MX/MX1 SDHC implements SD cards read-only switch read-back mmc: add led trigger mmc_spi host driver MMC core learns about SPI MMC/SD card driver learns SPI MMC headers learn about SPI ...
2007-10-11x86: fixup the x86 namespace change in scripts/namespace.plThomas Gleixner
Let namespace.pl look at the correct files. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-11[AVR32] checkstack supportHaavard Skinnemoen
Add regexes to recognize stack frame adjustments in AVR32 code. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-10-11i386/x86_64: move headers to include/asm-x86Thomas Gleixner
Move the headers to include/asm-x86 and fixup the header install make rules Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-10[NETNS]: Move some code into __init section when CONFIG_NET_NS=nPavel Emelyanov
With the net namespaces many code leaved the __init section, thus making the kernel occupy more memory than it did before. Since we have a config option that prohibits the namespace creation, the functions that initialize/finalize some netns stuff are simply not needed and can be freed after the boot. Currently, this is almost not noticeable, since few calls are no longer in __init, but when the namespaces will be merged it will be possible to free more code. I propose to use the __net_init, __net_exit and __net_initdata "attributes" for functions/variables that are not used if the CONFIG_NET_NS is not set to save more space in memory. The exiting functions cannot just reside in the __exit section, as noticed by David, since the init section will have references on it and the compilation will fail due to modpost checks. These references can exist, since the init namespace never dies and the exit callbacks are never called. So I introduce the __exit_refok attribute just like it is already done with the __init_refok. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[SSB]: add Sonics Silicon Backplane bus supportMichael Buesch
SSB is an SoC bus used in a number of embedded devices. The most well-known of these devices is probably the Linksys WRT54G, but there are others as well. The bus is also used internally on the BCM43xx and BCM44xx devices from Broadcom. This patch also includes support for SSB ID tables in modules, so that SSB drivers can be loaded automatically. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-23sdio: add modalias supportPierre Ossman
Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-09-01kconfig: oldconfig shall not set symbols if it does not need toRoman Zippel
Avoid setting the value if the symbol doesn't need to be changed or can't be changed. Later choices may change the dependencies and thus the possible input range. make oldconfig from a 2.6.22 .config with CONFIG_HOTPLUG_CPU not set was in some configurations setting CONFIG_HOTPLUG_CPU=y without asking, even when there was no actual requirement for CONFIG_HOTPLUG_CPU. This was triggered by SUSPEND_SMP that does a select HOTPLUG_CPU. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Tested-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-08-11update checkpatch.pl to version 0.09Andy Whitcroft
This version brings a number of new checks, and a number of bug fixes. Of note: - checks for spacing on round and square bracket combinations - loosening of the single statement brace checks, to allow them when they contain comments or where other blocks in a compound statement have them. - parks the multple declaration support - allows architecture defines in architecture specific headers Andy Whitcroft (21): Version: 0.09 loosen single statement brace checks fix up multiple declaration to avoid function arguments add some function space parenthesis check exceptions handle EXPORT_'s with parentheses in their names clean up some warnings in multi-line macro bracketing support park the multiple declaration checks make block brace checks count comments as a statement __volatile__ and __extension__ are not functions allow architecture specific defined within architecture includes check spacing on square brackets check spacing on parentheses ensure we apply checks to the part before start comment check #ifdef conditional spacing handle __init_refok and __must_check add noinline to inline checks prevent email addresses from tripping spacing checks handle typed initialiser spacing handle line contination as end of line add bool to the type matcher refine EXPORT_SYMBOL checks to handle pointers Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31kbuild: whitelist references from __dbe_table to .initRalf Baechle
This is needed on MIPS where the same mechanism as get_user() is used to intercept bus error exceptions for some hardware probes. Without this patch modpost will throw spurious warnings: LD vmlinux SYSMAP System.map SYSMAP .tmp_System.map MODPOST vmlinux WARNING: arch/mips/sgi-ip22/built-in.o(__dbe_table+0x0): Section mismatch: reference to .init.text: Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-25kbuild: fix modpost warnings for xtensaSam Ravnborg
The Xtensa architecture places literal pools in sections separate from the instructions. The corresponsing text sections, therefore, reference the .literal section, and we have to suppress those warnings. The naming convention defines the name for a literal section as .SECTION.literal, unless .SECTION is .text. In that case the name is only .literal. Using strncmp() instead of strcmp() to compare the from-section with .SECTION.init.refok in pattern 0 should not cause any regressions for other architectures. We also need to suppress warnings for two informational sections (.xt.lit and .xt.prop) used by the Xtensa architecture. Signed-off-by: Chris Zankel <chris@zankel.net> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-25kbuild: be more foregiving on init section namingSam Ravnborg
In the whitelist function of modpost now use the same check to identify init_section as in other places of modpost. This has the effect that we now recognize sections named .init.text.19 as init sections and we no longer warn when we see these. At the same time make surrounding code readable by dropping use of temporary flags. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-25kbuild: rearrange a few function in modpostSam Ravnborg
This is a preparational patch that just move two functions and add one (for now unused) function. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-25kbuild: use LDFLAGS_MODULE only for .ko linksRoland McGrath
Sam Ravnborg pointed out that Documentation/kbuild/makefiles.txt already says this is what it's for. This patch makes the reality live up to the documentation. This fixes the problem of LDFLAGS_BUILD_ID getting into too many places. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-25kconfig: remove unused members from struct symbolSam Ravnborg
dep and dep2 in struct symbol was unused - remove them. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2007-07-25kconfig: attach help text to menusSam Ravnborg
Roman Zippel wrote: > A simple example would be > help texts, right now they are per symbol, but they should really be per > menu, so archs can provide different help texts for something. This patch does this and at the same time introduce a few API funtions used to access the help text. The relevant api functions are introduced in the various frontends. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2007-07-25kbuild: fix up printing of Linux C Library version in scripts/ver_linuxJesper Juhl
I noticed, when running scripts/ver_linux on both a Gentoo system and a Slackware system, that the line printing the C library version looked a little odd. So I fixed it up to be in line with all the rest. Old output: Linux C Library > libc.2.5 New output: Linux C Library 2.5 Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-25kbuild: do not do section mismatch checks on vmlinux in 2nd passSam Ravnborg
We already check and warn about section mismatches from vmlinux (build as vmlinux.o) during first pass so skip the checks during the 2nd pass where we process modules. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-23ACPI: autoload modules - Create ACPI alias interfaceThomas Renninger
Modify modpost (file2alias.c) to add acpi*:XYZ0001: alias in modules.alias like: grep acpi /lib/modules/2.6.22-rc4-default/modules.alias alias acpi*:SNY5001:* sony_laptop alias acpi*:SNY6001:* sony_laptop for e.g. the sony_laptop module. This module matches against all ACPI devices with a HID or CID of SNY5001 or SNY6001 Export an uevent and modalias sysfs file containing the string: [MODALIAS=]acpi:PNP0C0C: additional CIDs are concatenated at the end. Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-20Fix Lindent to not indent preprocessor comments so farMatthew Wilcox
I recently ran Lindent over the AdvanSys driver and it moved the comments on #else and #endif lines way over to the right: #else /* ADVANSYS_DEBUG */ This doesn't match what I expect from kernel style, but it is documented. We just need another flag to indent to make this look like: #else /* ADVANSYS_DEBUG */ Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-20m68k: teach modpost about .m68_fixupAl Viro
2007-07-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: (33 commits) xtensa: use DATA_DATA in xtensa powerpc: add missing DATA_DATA to powerpc cris: use DATA_DATA in cris kallsyms: remove usage of memmem and _GNU_SOURCE from scripts/kallsyms.c kbuild: use -fno-optimize-sibling-calls unconditionally kconfig: reset generated values only if Kconfig and .config agree. kbuild: fix the warning when running make tags kconfig: strip 'CONFIG_' automatically in kernel configuration search kbuild: use POSIX BRE in headers install target Whitelist references from __dbe_table to .init modpost white list pattern adjustment kbuild: do section mismatch check on full vmlinux kbuild: whitelist references from variables named _timer to .init.text kbuild: remove hardcoded _logo names from modpost kbuild: remove hardcoded apic_es7000 from modpost kbuild: warn about references from .init.text to .exit.text kbuild: consolidate section checks kbuild: refactor code in modpost to improve maintainability kbuild: ignore section mismatch warnings originating from .note section kbuild: .paravirtprobe section is obsolete, so modpost doesn't need to handle it ...
2007-07-19update checkpatch.pl to version 0.08Andy Whitcroft
This version brings a number of new checks, and a number of bug fixes. Of note: - warnings for multiple assignments per line - warnings for multiple declarations per line - checks for single statement blocks with braces This patch includes an update for feature-removal-schedule.txt to better target checks. Andy Whitcroft (12): Version: 0.08 only apply printk checks where there is a string literal allow suppression of errors for when no patch is found warn about multiple assignments warn on declaration of multiple variables check for kfree() with needless null check check for single statement braced blocks check for aggregate initialisation on the next line handle the => operator check for spaces between function name and open parenthesis move to explicit Check: entries in feature-removal-schedule.txt handle pointer attributes Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19kernel-doc: fix leading dot in man-mode outputRandy Dunlap
If a parameter description begins with a '.', this indicates a "request" for "man" mode output (*roff), so it needs special handling. Problem case is in include/asm-i386/atomic.h for function atomic_add_unless(): * @u: ...unless v is equal to u. This parameter description is currently not printed in man mode output. [akpm@linux-foundation.org: cleanup] Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19kernel-doc: strip C99 commentsRandy Dunlap
Strip C99-style comments from the input stream. /*...*/ comments are already stripped. C99 comments confuse the kernel-doc script. Also update some comments. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19kernel-doc: fix unnamed struct/union warningRandy Dunlap
Fix kernel-doc warning: Warning(linux-2.6.22-rc2-git2/include/linux/skbuff.h:316): No description found for parameter '}' which is caused by nested anonymous structs/unions ending with: }; }; Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17kallsyms: make KSYM_NAME_LEN include space for trailing '\0'Tejun Heo
KSYM_NAME_LEN is peculiar in that it does not include the space for the trailing '\0', forcing all users to use KSYM_NAME_LEN + 1 when allocating buffer. This is nonsense and error-prone. Moreover, when the caller forgets that it's very likely to subtly bite back by corrupting the stack because the last position of the buffer is always cleared to zero. This patch increments KSYM_NAME_LEN by one and updates code accordingly. * off-by-one bug in asm-powerpc/kprobes.h::kprobe_lookup_name() macro is fixed. * Where MODULE_NAME_LEN and KSYM_NAME_LEN were used together, MODULE_NAME_LEN was treated as if it didn't include space for the trailing '\0'. Fix it. Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Paulo Marques <pmarques@grupopie.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17kallsyms: remove usage of memmem and _GNU_SOURCE from scripts/kallsyms.cPaulo Marques
The only in-kernel user of "memmem" is scripts/kallsyms.c and it only uses it to find tokens that are 2 bytes in size. It is trivial to replace it with a simple function that finds 2-byte tokens. This should help users from systems that don't have the memmem GNU extension available. Signed-off-by: Paulo Marques <pmarques@grupopie.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-17kconfig: reset generated values only if Kconfig and .config agree.Roman Zippel
Normally generated values (Kconfig entries without a prompt) are cleared as they are regenerated anyway and so they appear as new should they become visible and defaults work as expected (once a value is set defaults aren't used anymore). The detection whether a value is generated or not is only based on its visibility status, which can quickly change for a lot of symbols by just removing a single line from .config or adding a dependency to Kconfig as you noticed. The patch now suppresses this logic when .config and Kconfig aren't in sync and .config needs to be updated, so that you can remove now a random value from .config and oldconfig won't reask for many other values. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-17kconfig: strip 'CONFIG_' automatically in kernel configuration searchBernhard Walle
Modify the ncurses configuration tool ('make menuconfig') in a way that the user can enter the search string (/) both with or without the leading 'CONFIG_'. This simplifies using copy & paste from .config files because you can select the whole word. Signed-off-by: Bernhard Walle <bwalle@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-17kbuild: use POSIX BRE in headers install targetMike Frysinger
The sed expression used at the moment in scripts/Makefile.headersinst relies on the (handy) GNU extension where you can escape ERE's in an otherwise BRE without using the GNU -r option. The following patch replaces this "\+" usage with a functionally equivalent POSIX BRE compliant "\{1,\}". Tested with `make headers_install` against blackfin/x86_64/i386 targets. Stupid whiny OS X users and their crappy sed ;) Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-17Whitelist references from __dbe_table to .initRalf Baechle
This is needed on MIPS where the same mechanism as get_user() is used to intercept bus error exceptions for some hardware probes. Without this patch modpost will throw spurious warnings: LD vmlinux SYSMAP System.map SYSMAP .tmp_System.map MODPOST vmlinux WARNING: arch/mips/sgi-ip22/built-in.o(__dbe_table+0x0): Section mismatch: reference to .init.text: Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-17modpost white list pattern adjustmentJan Beulich
gcc puts data into .data.rel or .data.rel.* on some architectures (e.g. ia64) or under certain conditions, so whatever is legal relative to .data should also be legal for those other sections. Fixes a few modpost warnings on ia64. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-17kbuild: do section mismatch check on full vmlinuxSam Ravnborg
Previously we did do the check on the .o files used to link vmlinux but that failed to find questionable references across the .o files. Create a dedicated vmlinux.o file used only for section mismatch checks that uses the defualt linker script so section does not get renamed. The vmlinux.o may later be used as part of the the final link of vmlinux but for now it is used fo section mismatch only. For a defconfig build this is instant but for an allyesconfig this add two minutes to a full build (that anyways takes ~2 hours). Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-16kbuild: whitelist references from variables named _timer to .init.textSam Ravnborg
arm uses a lot of ops structures named *_timer that has legitimite references to .init.text. So let's add this variable to the list of variables that may reference .init.text without causing any warning. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-16kbuild: remove hardcoded _logo names from modpostSam Ravnborg
Replaced this with a __init_refok marker in front of fb_find_logo(). I think that the __initdata marker for the logo's are wrong but I have not justified this so I did not remove it. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-16kbuild: remove hardcoded apic_es7000 from modpostSam Ravnborg
Replace the hardcoded variable name apic_es7000 in modpost with a __initdata_refok marker. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-16kbuild: warn about references from .init.text to .exit.textSam Ravnborg
The .exit.text section may be discarded either at build or at runtime. So let modpost warn if this situation is detected. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-16kbuild: consolidate section checksSam Ravnborg
Move more checks from whitelist to the section check functions. Remove the redundent pci_fixup check. Renumber the patterns. No functional changes. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-16kbuild: refactor code in modpost to improve maintainabilitySam Ravnborg
There were a great deal of overlap between the two functions that check which sections may reference .init.text and .exit.text. Factor out common check to a separate function and sort entries in the original functions. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-16kbuild: ignore section mismatch warnings originating from .note sectionSam Ravnborg
.note* sections are ELF notes, which are typically used by external tools to examine the kernel image. Since this is removed from any runtime consideration, it's OK to reference any section from a .note* section. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-16kbuild: .paravirtprobe section is obsolete, so modpost doesn't need to handle itJeremy Fitzhardinge
The .paravirtprobe section is obsolete, so modpost doesn't need to handle it. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-16kbuild: suppress modpost warnings for references from the .toc section as ↵Stephen Rothwell
used by powerpc We should do better here by effetively "dereferencing" references to the .toc (or the .got2) section, but that is much harder. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-16kbuild: make better section mismatch reports on armSam Ravnborg
With this change we can find more symbols hereby improving the readability of the warnings. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-16kbuild: make better section mismatch reports on i386 and mipsAtsushi Nemoto
On i386 and MIPS, warn_sec_mismatch() sometimes fails to show usefull symbol name. This is because empty 'refsym' due to 0 r_addend value. This patch is to adjust r_addend value, consulting with apply_relocate() routine in kernel code. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-16kconfig: fix update-po-configSam Ravnborg
Massimo Maiurana <maiurana@gmail.com> reported that update-po-config was broken: 1) spelling errors in Makefile so arch/um failed 2) UTF-8 was not supported The following patch address the above problems. kxgettext now append the output to the .pot file generated by xgettext - so we have a header. In all places UFT-8 is specifed so we now flawlessly support UTF-8. The Kconfig files had an empty string in a few cases - these are now supressed in kxgettext. With this the translators can now pick up where they left and get it all translated. There are ~11000 strings to be translated... Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Massimo Maiurana <maiurana@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
2007-07-16kbuild: add support for squashing uid/gid in gen_initramfs_list.shMike Frysinger
Sometimes it is useful to squash all uid's/gid's to 0:0 regardless of current owner. For example, in build systems that get run as arbitrary users (uClinux-dist). This adds a special "squash" keyword so you can do '-g squash -u squash' and have ownership squashed to root. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
