path: root/scripts
2015-07-17checkpatch: fix long line messages about patch contextJoe Perches
Changes in ("checkpatch: categorize some long line length checks") now erroneously reports long line defects in patch context. Fix it. Signed-off-by: Joe Perches <joe@perches.com> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-08Merge tag 'pm+acpi-4.2-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management and ACPI updates from Rafael Wysocki: "These are fixes on top of the previous PM+ACPI pull requests (including one fix for a 4.1 regression) and two commits adding _CLS-based device enumeration support to the ACPI core and the ATA subsystem that waited for the latest ACPICA changes to be merged. Specifics: - Fix for an ACPI resources management regression introduced during the 4.1 cycle (that unfortunately went into -stable) effectively reverting the bad commit along with the recent fixups on top of it and using an alternative approach to address the underlying issue (Rafael J Wysocki). - Fix for a memory leak and an incorrect return value in an error code path in the ACPI LPSS (Low-Power Subsystem) driver (Rafael J Wysocki). - Fix for a leftover dangling pointer in an error code path in the new wakeup IRQ support code (Rafael J Wysocki). - Fix to prevent infinite loops (due to errors in other places) from happening in the core generic PM domains support code (Geert Uytterhoeven). - Hibernation documentation update/clarification (Uwe Geuder). - Support for _CLS-based device enumeration in the ACPI core and in the ATA subsystem (Suravee Suthikulpanit)" * tag 'pm+acpi-4.2-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: PM / wakeirq: Avoid setting power.wakeirq too hastily ata: ahci_platform: Add ACPI _CLS matching ACPI / scan: Add support for ACPI _CLS device matching PM / hibernate: clarify resume documentation PM / Domains: Avoid infinite loops in attach/detach code ACPI / LPSS: Fix up acpi_lpss_create_device() ACPI / PNP: Reserve ACPI resources at the fs_initcall_sync stage
2015-07-08modpost: work correctly with tile coldtext sectionsChris Metcalf
The tilegx and tilepro compilers use .coldtext for their unlikely executed text section name, so an __attribute__((cold)) function will (when compiled with higher optimization levels) land in the .coldtext section. Modify modpost to add .coldtext to the set of OTHER_TEXT_SECTIONS so we don't get warnings about referencing such a section in an __ex_table block, and then also modify arch/tile/lib/memcpy_user_64.c so that it uses plain ".coldtext" instead of ".coldtext.memcpy". The latter naming is a relic of an earlier use of -ffunction-sections, which we no longer use by default. Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au>
2015-07-07ACPI / scan: Add support for ACPI _CLS device matchingSuthikulpanit, Suravee
Device drivers typically use ACPI _HIDs/_CIDs listed in struct device_driver acpi_match_table to match devices. However, for generic drivers, we do not want to list _HID for all supported devices. Also, certain classes of devices do not have _CID (e.g. SATA, USB). Instead, we can leverage ACPI _CLS, which specifies PCI-defined class code (i.e. base-class, subclass and programming interface). This patch adds support for matching ACPI devices using the _CLS method. To support loadable module, current design uses _HID or _CID to match device's modalias. With the new way of matching with _CLS this would requires modification to the current ACPI modalias key to include _CLS. This patch appends PCI-defined class-code to the existing ACPI modalias as following. acpi:<HID>:<CID1>:<CID2>:..:<CIDn>:<bbsspp>: E.g: # cat /sys/devices/platform/AMDI0600:00/modalias acpi:AMDI0600:010601: where bb is th base-class code, ss is te sub-class code, and pp is the programming interface code Since there would not be _HID/_CID in the ACPI matching table of the driver, this patch adds a field to acpi_device_id to specify the matching _CLS. static const struct acpi_device_id ahci_acpi_match[] = { { ACPI_DEVICE_CLASS(PCI_CLASS_STORAGE_SATA_AHCI, 0xffffff) }, {}, }; In this case, the corresponded entry in modules.alias file would be: alias acpi*:010601:* ahci_platform Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org> Signed-off-by: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-02Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild updates from Michal Marek: "Just a few kbuild core commits this time: - kallsyms fix for CONFIG_XIP_KERNEL - bashisms in scripts/link-vmlinux.sh fixed - workaround to make DEBUG_INFO_REDUCED more useful yet still space efficient - clang is not wrongly detected when cross-compiling" * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: include core debug info when DEBUG_INFO_REDUCED scripts: link-vmlinux: Don't pass page offset to kallsyms if XIP Kernel scripts: fix link-vmlinux.sh bash-ism Makefile: Fix detection of clang when cross-compiling
2015-07-02Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kconfig updates from Michal Marek: - kconfig conditions can use usual less/greater than comparisons - kconfig warns about stray characters in Kconfig files - bogus expression simplification removed - some minor fixes * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kconfig: re-generate *.c_shipped files after previous change kconfig: allow use of relations other than (in)equality kconfig: don't silently ignore unhandled characters kconfig: Wrap long "make help" text lines scripts/kconfig/Makefile: Cosmetic fixes scripts/kconfig/Makefile: Fix spelling of Qt Kconfig: Remove bad inference rules expr_eliminate_dups2()
2015-07-02Merge tag 'cpuinit-v4.1-rc8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull __cpuinit removal from Paul Gortmaker: "Remove __cpuinit macros and users. We removed the __cpuinit stuff in 3.11-rc1 with commit 22f0a2736774 ("init.h: remove __cpuinit sections from the kernel") but we left some no-op stubs as a courtesy to unmerged code. Here we get rid of the stubs as well, since (as can be seen in these changes) they are enabling use cases to sneak back in, primarily from older BSP code that has been living out of tree for some time prior to getting mainlined. So we get rid of these "new" users 1st and then get rid of the stubs. Obviously, getting rid of the stubs can't happen until all the users are gone, so I had to keep this together as a series, even though some of these commits since got picked up into maintainers trees as well. The nature of this change is such that it should have zero impact on the generated runtime. This is one of several independent cleanup branches aimed at enabling better organization in the init.h and module.h code. They have been getting coverage in the linux-next tree for the last month, in addition to my local testing, which also covers approximately a half dozen or more architectures" * tag 'cpuinit-v4.1-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: init: delete the __cpuinit related stubs kernel/cpu.c: remove new instance of __cpuinit that crept back in sched/core: remove __cpuinit section tag that crept back in. mips/mm/tlbex: remove new instance of __cpuinit that crept back in mips/c-r4k: remove legacy __cpuinit section that crept in mips/bcm77xx: remove legacy __cpuinit sections that crept in mips/ath25: remove legacy __cpuinit section that crept in arm/mach-hisi: remove legacy __CPUINIT section that crept in arm/mach-rockchip: remove legacy __cpuinit section that crept in arm/mach-mvebu: remove legacy __cpuinit sections that crept in arm/mach-keystone: remove legacy __cpuinit sections that crept in
2015-07-01Merge tag 'devicetree-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux Pull devicetree updates from Grant Likely: "A whole lot of bug fixes. Nothing stands out here except the ability to enable CONFIG_OF on every architecture, and an import of a newer version of dtc" * tag 'devicetree-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux: (22 commits) of/irq: Rename "intc_desc" to "of_intc_desc" to fix OF on sh of/irq: Fix pSeries boot failure Documentation: DT: Fix a typo in the filename "lantiq,<chip>-pinumx.txt" of: define of_find_node_by_phandle for !CONFIG_OF of/address: use atomic allocation in pci_register_io_range() of: Add vendor prefix for Zodiac Inflight Innovations dt/fdt: add empty versions of early_init_dt_*_memory_arch of: clean-up unnecessary libfdt include paths of: make unittest select OF_EARLY_FLATTREE instead of depend on it of: make CONFIG_OF user selectable MIPS: prepare for user enabling of CONFIG_OF of/fdt: fix argument name and add comments of unflatten_dt_node() of: return NUMA_NO_NODE from fallback of_node_to_nid() tps6507x.txt: Remove executable permission of/overlay: Grammar s/an negative/a negative/ of/fdt: Make fdt blob input parameters of unflatten functions const of: add helper function to retrive match data of: Grammar s/property exist/property exists/ of: Move OF flags to be visible even when !CONFIG_OF scripts/dtc: Update to upstream version 9d3649bd3be245c9 ...
2015-07-01Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge third patchbomb from Andrew Morton: - the rest of MM - scripts/gdb updates - ipc/ updates - lib/ updates - MAINTAINERS updates - various other misc things * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (67 commits) genalloc: rename of_get_named_gen_pool() to of_gen_pool_get() genalloc: rename dev_get_gen_pool() to gen_pool_get() x86: opt into HAVE_COPY_THREAD_TLS, for both 32-bit and 64-bit MAINTAINERS: add zpool MAINTAINERS: BCACHE: Kent Overstreet has changed email address MAINTAINERS: move Jens Osterkamp to CREDITS MAINTAINERS: remove unused nbd.h pattern MAINTAINERS: update brcm gpio filename pattern MAINTAINERS: update brcm dts pattern MAINTAINERS: update sound soc intel patterns MAINTAINERS: remove website for paride MAINTAINERS: update Emulex ocrdma email addresses bcache: use kvfree() in various places libcxgbi: use kvfree() in cxgbi_free_big_mem() target: use kvfree() in session alloc and free IB/ehca: use kvfree() in ipz_queue_{cd}tor() drm/nouveau/gem: use kvfree() in u_free() drm: use kvfree() in drm_free_large() cxgb4: use kvfree() in t4_free_mem() cxgb3: use kvfree() in cxgb_free_mem() ...
2015-07-01Merge tag 'for-linus-4.2-rc0-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull xen updates from David Vrabel: "Xen features and cleanups for 4.2-rc0: - add "make xenconfig" to assist in generating configs for Xen guests - preparatory cleanups necessary for supporting 64 KiB pages in ARM guests - automatically use hvc0 as the default console in ARM guests" * tag 'for-linus-4.2-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: block/xen-blkback: s/nr_pages/nr_segs/ block/xen-blkfront: Remove invalid comment block/xen-blkfront: Remove unused macro MAXIMUM_OUTSTANDING_BLOCK_REQS arm/xen: Drop duplicate define mfn_to_virt xen/grant-table: Remove unused macro SPP xen/xenbus: client: Fix call of virt_to_mfn in xenbus_grant_ring xen: Include xen/page.h rather than asm/xen/page.h kconfig: add xenconfig defconfig helper kconfig: clarify kvmconfig is for kvm xen/pcifront: Remove usage of struct timeval xen/tmem: use BUILD_BUG_ON() in favor of BUG_ON() hvc_xen: avoid uninitialized variable warning xenbus: avoid uninitialized variable warning xen/arm: allow console=hvc0 to be omitted for guests arm,arm64/xen: move Xen initialization earlier arm/xen: Correctly check if the event channel interrupt is present
2015-07-01Merge tag 'arc-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc Pull ARC architecture updates from Vineet Gupta: - support for HS38 cores based on ARCv2 ISA ARCv2 is the next generation ISA from Synopsys and basis for the HS3{4,6,8} families of processors which retain the traditional ARC mantra of low power and configurability and are now more performant and feature rich. HS38x is a 10 stage pipeline core which supports MMU (with huge pages) and SMP (upto 4 cores) among other features. + www.synopsys.com/dw/ipdir.php?ds=arc-hs38-processor + http://news.synopsys.com/2014-10-14-New-DesignWare-ARC-HS38-Processor-Doubles-Performance-for-Embedded-Linux-Applications + http://www.embedded.com/electronics-news/4435975/Synopsys-ARC-HS38-core-gives-2X-boost-to-Linux-based-apps - support for ARC SDP (Software Development platform): Main Board + CPU Cards = AXS101: CPU Card with ARC700 in silicon @ 700 MHz = AXS103: CPU Card with HS38x in FPGA - refactoring of ARCompact port to accomodate new ARCv2 ISA - misc updates/cleanups * tag 'arc-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc: (72 commits) ARC: Fix build failures for ARCompact in linux-next after ARCv2 support ARCv2: Allow older gcc to cope with new regime of ARCv2/ARCompact support ARCv2: [vdk] dts files and defconfig for HS38 VDK ARCv2: [axs103] Support ARC SDP FPGA platform for HS38x cores ARC: [axs101] Prepare for AXS103 ARCv2: [nsim*hs*] Support simulation platforms for HS38x cores ARCv2: All bits in place, allow ARCv2 builds ARCv2: SLC: Handle explcit flush for DMA ops (w/o IO-coherency) ARCv2: STAR 9000837815 workaround hardware exclusive transactions livelock ARC: Reduce bitops lines of code using macros ARCv2: barriers arch: conditionally define smp_{mb,rmb,wmb} ARC: add smp barriers around atomics per Documentation/atomic_ops.txt ARC: add compiler barrier to LLSC based cmpxchg ARCv2: SMP: intc: IDU 2nd level intc for dynamic IRQ distribution ARCv2: SMP: clocksource: Enable Global Real Time counter ARCv2: SMP: ARConnect debug/robustness ARCv2: SMP: Support ARConnect (MCIP) for Inter-Core-Interrupts et al ARC: make plat_smp_ops weak to allow over-rides ARCv2: clocksource: Introduce 64bit local RTC counter ...
2015-06-30scripts/gdb: remove useless global instructionThiébaud Weksteen
Signed-off-by: Thiébaud Weksteen <thiebaud@weksteen.fr> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30scripts/gdb: add ps commandThiébaud Weksteen
2015-06-30scripts/gdb: fix PEP8 complianceThiébaud Weksteen
2015-06-30scripts/gdb: fix typo in exception nameThiébaud Weksteen
2015-06-30scripts/gdb: enable completion for lx-list-check parameterJan Kiszka
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Cc: Thiébaud Weksteen <thiebaud@weksteen.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30scripts/gdb: also allow list_head pointer as lx-list-check paramterJan Kiszka
This makes the usage more flexible. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Cc: Thiébaud Weksteen <thiebaud@weksteen.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30scripts/gdb: add command to check list consistencyThiébaud Weksteen
Add a gdb script to verify the consistency of lists. Signed-off-by: Thiébaud Weksteen <thiebaud@weksteen.fr> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-26Merge tag 'usb-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB updates from Greg KH: "Here's the big USB patchset for 4.2-rc1. As is normal these days, the majority of changes are in the gadget drivers, with a bunch of other small driver changes. All of these have been in linux-next with no reported issues" * tag 'usb-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (175 commits) usb: dwc3: Use ASCII space in Kconfig usb: chipidea: add work-around for Marvell HSIC PHY startup usb: chipidea: allow multiple instances to use default ci_default_pdata dt-bindings: Consolidate ChipIdea USB ci13xxx bindings phy: add Marvell HSIC 28nm PHY phy: Add Marvell USB 2.0 OTG 28nm PHY dt-bindings: Add Marvell PXA1928 USB and HSIC PHY bindings USB: ssb: use devm_kzalloc USB: ssb: fix error handling in ssb_hcd_create_pdev() usb: isp1760: check for null return from kzalloc cdc-acm: Add support of ATOL FPrint fiscal printers usb: chipidea: usbmisc_imx: Remove unneeded semicolon USB: usbtmc: add device quirk for Rigol DS6104 USB: serial: mos7840: Use setup_timer phy: twl4030-usb: add ABI documentation phy: twl4030-usb: remove incorrect pm_runtime_get_sync() in probe function. phy: twl4030-usb: remove pointless 'suspended' test in 'suspend' callback. phy: twl4030-usb: make runtime pm more reliable. drivers:usb:fsl: Fix compilation error for fsl ehci drv usb: renesas_usbhs: Don't disable the pipe if Control write status stage ...
2015-06-26Merge tag 'char-misc-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver updates from Greg KH: "Here's the big char/misc driver pull request for 4.2-rc1. Lots of mei, extcon, coresight, uio, mic, and other driver updates in here. Full details in the shortlog. All of these have been in linux-next for some time with no reported problems" * tag 'char-misc-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (176 commits) mei: me: wait for power gating exit confirmation mei: reset flow control on the last client disconnection MAINTAINERS: mei: add mei_cl_bus.h to maintained file list misc: sram: sort and clean up included headers misc: sram: move reserved block logic out of probe function misc: sram: add private struct device and virt_base members misc: sram: report correct SRAM pool size misc: sram: bump error message level on unclean driver unbinding misc: sram: fix device node reference leak on error misc: sram: fix enabled clock leak on error path misc: mic: Fix reported static checker warning misc: mic: Fix randconfig build error by including errno.h uio: pruss: Drop depends on ARCH_DAVINCI_DA850 from config uio: pruss: Add CONFIG_HAS_IOMEM dependence uio: pruss: Include <linux/sizes.h> extcon: Redefine the unique id of supported external connectors without 'enum extcon' type char:xilinx_hwicap:buffer_icap - change 1/0 to true/false for bool type variable in function buffer_icap_set_configuration(). Drivers: hv: vmbus: Allocate ring buffer memory in NUMA aware fashion parport: check exclusive access before register w1: use correct lock on error in w1_seq_show() ...
2015-06-26Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge second patchbomb from Andrew Morton: - most of the rest of MM - lots of misc things - procfs updates - printk feature work - updates to get_maintainer, MAINTAINERS, checkpatch - lib/ updates * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (96 commits) exit,stats: /* obey this comment */ coredump: add __printf attribute to cn_*printf functions coredump: use from_kuid/kgid when formatting corename fs/reiserfs: remove unneeded cast NILFS2: support NFSv2 export fs/befs/btree.c: remove unneeded initializations fs/minix: remove unneeded cast init/do_mounts.c: add create_dev() failure log kasan: remove duplicate definition of the macro KASAN_FREE_PAGE fs/efs: femove unneeded cast checkpatch: emit "NOTE: <types>" message only once after multiple files checkpatch: emit an error when there's a diff in a changelog checkpatch: validate MODULE_LICENSE content checkpatch: add multi-line handling for PREFER_ETHER_ADDR_COPY checkpatch: suggest using eth_zero_addr() and eth_broadcast_addr() checkpatch: fix processing of MEMSET issues checkpatch: suggest using ether_addr_equal*() checkpatch: avoid NOT_UNIFIED_DIFF errors on cover-letter.patch files checkpatch: remove local from codespell path checkpatch: add --showfile to allow input via pipe to show filenames ...
2015-06-25checkpatch: emit "NOTE: <types>" message only once after multiple filesJoe Perches
Make this message similar to the "false positives" message and emit it only once when scanning multiple files instead of after each file scanned. Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25checkpatch: emit an error when there's a diff in a changelogJoe Perches
People often put diff snippets in changelogs. This causes problems when one tries to apply a file containing both the changelog and the diff because patch(1) tries to apply the diff which it found in the changelog. Warn once when what seems to be a diff snippet in the changelog exists. Signed-off-by: Joe Perches <joe@perches.com> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25checkpatch: validate MODULE_LICENSE contentBjorn Andersson
There is a well defined list of expected values for MODULE_LICENSE so warn the user upon usage of unknown values. Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25checkpatch: add multi-line handling for PREFER_ETHER_ADDR_COPYMateusz Kulikowski
Handle multi-line memcpy() properly. Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Acked-by: Joe Perches <joe@perches.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25checkpatch: suggest using eth_zero_addr() and eth_broadcast_addr()Mateusz Kulikowski
Suggest using eth_zero_addr() or eth_broadcast_addr() instead of memset(). Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Acked-by: Joe Perches <joe@perches.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25checkpatch: fix processing of MEMSET issuesMateusz Kulikowski
Remove 's' modifier to avoid reporting the same warning several times. Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Acked-by: Joe Perches <joe@perches.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25checkpatch: suggest using ether_addr_equal*()Mateusz Kulikowski
Check if memcmp() is used to compare ethernet addresses and suggest using ether_addr_equal() or ether_addr_equal_unaligned() Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Acked-by: Joe Perches <joe@perches.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25checkpatch: avoid NOT_UNIFIED_DIFF errors on cover-letter.patch filesJoe Perches
Make an exception for the "Does not appear to be a unified-diff" error when scanning what appears to be git generated cover letters. Signed-off-by: Joe Perches <joe@perches.com> Suggested-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25checkpatch: remove local from codespell pathMaxim Uvarov
local is typically used for manually installed apps. For apps installed from distro the right path is /usr/share. Signed-off-by: Maxim Uvarov <maxim.uvarov@linaro.org> Acked-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25checkpatch: add --showfile to allow input via pipe to show filenamesJoe Perches
Using "git diff | ./scripts/checkpatch -" does not have an easy mechanism to see the files and lines actually modified. Add --showfile to see the file and line specified in the diff. When --showfile is used without --terse, the second line of each message output is redundant, so it is removed. Signed-off-by: Joe Perches <joe@perches.com> Cc: Petr Mladek <pmladek@suse.cz> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25checkpatch: colorize output to terminalJoe Perches
Add optional colors to make seeing message types a bit easier. Add --color command line switch, default:on Error is RED, warning is YELLOW, check is GREEN. The message type, if shown, is BLUE. Signed-off-by: Joe Perches <joe@perches.com> Tested-by: Petr Mladek <pmladek@suse.cz> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25checkpatch: improve output with multiple command-line filesJoe Perches
If there are multiple patches/files on the command line, use a prefix before the patch/file message output like: -------------- patch/filename -------------- to make the identifying which messages go with which file/patch a bit easier to parse. Move the perl version and false positive messages after all the files have been scanned so that they are emitted only once. Standardize the NOTE: <...> form to always emit a blank line before the NOTE and always use print << "EOM" style. Signed-off-by: Joe Perches <joe@perches.com> Suggested-by: Petr Mladek <pmladek@suse.cz> Tested-by: Petr Mladek <pmladek@suse.cz> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25checkpatch: categorize some long line length checksJoe Perches
Many lines of code extend beyond the maximum line length. Some of these are possibly justified by use type. For instance: structure definitions where comments are added per member like: struct foo { type member; /* some long description */ And lines that don't fit the typical logging message style where a string constant is used like: SOME_MACRO(args, "Some long string"); Categorize these long line types so that checkpatch can use a command-line --ignore=<type> option to avoid emitting some long line warnings. One of the existing checkpatch exclusions allowed kernel-doc argument documentation to exceed 80 columns because old versions of kernel-doc required single line documentation. The requirement was removed in 2009 so remove that exclusion. Add documentation to make the test a bit clearer. Signed-off-by: Joe Perches <joe@perches.com> Cc: Julia Lawall <julia.lawall@lip6.fr> Cc: Michael Shuey <shuey@purdue.edu> Cc: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25checkpatch: use $String consistentlyJoe Perches
String detection where a source line with a string constant is converted can either have an X or a space. Some of the string detection regexes do not allow the space character, but there is a handy $String variable that does. Convert the remaining uses of string detection regexes to use the $String variable to reduce possible false negatives. Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25checkpatch: make types found in a source file/patch localAlex Dowad
checkpatch uses various cues in its input patches and files to discover the names of user-defined types and modifiers. It then uses that information when processing expressions to discover potential style issues. Unfortunately, in rare cases, this means that checkpatch may give different results if you run it on several input files in one execution, or one by one! The reason is that it may identify a type (or something that looks like a type) in one file, and then carry this information over when processing a different file. For example, drivers/staging/media/bcm2048/radio-bcm2048.c contains this line (in a macro): size value; and drivers/staging/media/davinci_vpfe/vpfe_video.c has this line: while (size * *nbuffers > vpfe_dev->video_limit) If checkpatch processes these 2 files in a single command like: ./scripts/checkpatch.pl -f $file1 $file2 the (spurious) "size" type detected in the first file will cause it to flag the second file for improper use of the pointer dereference operator. To fix this, store types and modifiers found in a file in separate arrays from built-in ones, and reset the arrays of types and modifiers found in files at the beginning of each new source file. Signed-off-by: Alex Dowad <alexinbeijing@gmail.com> Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25checkpatch: add --strict warning for c99 fixed size typedefs : int<size>_tJoe Perches
Using declarations like u_int16_t in kernel code is not preferred. Suggest the kernel sized types instead of the c99 types when not in the uapi directory. Add a $typeC99Typedefs variable for the types to check and neaten the other typedef variables. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25checkpatch: check for uncommented waitqueue_active()Joe Perches
Linus sayeth: : Pretty much every single time people use this "if : (waitqueue_active())" model, it tends to be a bug, because it means : that there is zero serialization with people who are just about to go : to sleep. It's fundamentally racy against all the "wait_event()" loops : that carefully do memory barriers between testing conditions and going : to sleep, because the memory barriers now don't exist on the waking : side. : : So I'm making a new rule: if you use waitqueue_active(), I want an : explanation for why it's not racy with the waiter. A big comment about : the memory ordering, or about higher-level locks that are held by the : caller, or something. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25get_maintainer: fix perl 5.22/5.24 deprecated/incompatible "\C" useJoe Perches
Perl 5.22 emits a deprecated message when "\C" is used in a regex. Perl 5.24 will disallow it altogether. Fix it by using [A-Z] instead of \C. Signed-off-by: Joe Perches <joe@perches.com> Reported-by: Valdis Kletnieks <Valdis.Kletnieks@vt.edu> Tested-by: Valdis Kletnieks <Valdis.Kletnieks@vt.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25get_maintainer: emit longer section headersJoe Perches
Section headers can be quite long and some are very long and duplicated for many initial characters. The current maximum length emitted for a section header is 20 bytes (or 17 bytes then ... when the section header length is > 20). Change that length to 50 so more of the section is shown. Example new output: $ ./scripts/get_maintainer.pl -f drivers/net/ethernet/broadcom/bnx2x/ Ariel Elior <ariel.elior@qlogic.com> (supporter:BROADCOM BNX2X 10 GIGABIT ETHERNET DRIVER) netdev@vger.kernel.org (open list:BROADCOM BNX2X 10 GIGABIT ETHERNET DRIVER) linux-kernel@vger.kernel.org (open list) Old: $ ./scripts/get_maintainer.pl -f drivers/net/ethernet/broadcom/bnx2x/ Ariel Elior <ariel.elior@qlogic.com> (supporter:BROADCOM BNX2X 10...) netdev@vger.kernel.org (open list:BROADCOM BNX2X 10...) linux-kernel@vger.kernel.org (open list) Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25get_maintainer.pl: add .get_maintainer.ignore file capabilityJoe Perches
Some people prefer not to be cc'd on patches. Add an ability to have a file (.get_maintainer.ignore) with names and email addresses that are excluded from being listed except when specifically listed as a maintainer in a section. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25Merge tag 'for-4.2' of git://git.sourceforge.jp/gitroot/uclinux-h8/linuxLinus Torvalds
Pull Renesas H8/300 architecture re-introduction from Yoshinori Sato. We dropped arch/h8300 two years ago as stale and old, this is a new and more modern rewritten arch support for the same architecture. * tag 'for-4.2' of git://git.sourceforge.jp/gitroot/uclinux-h8/linux: (27 commits) h8300: fix typo. h8300: Always build dtb h8300: Remove ARCH_WANT_IPC_PARSE_VERSION sh-sci: Get register size from platform device clk: h8300: fix error handling in h8s2678_pll_clk_setup() h8300: Symbol name fix h8300: devicetree source h8300: configs h8300: IRQ chip driver h8300: clocksource h8300: clock driver h8300: Build scripts h8300: library functions h8300: Memory management h8300: miscellaneous functions h8300: process helpers h8300: compressed image support h8300: Low level entry h8300: kernel startup h8300: Interrupt and exceptions ...
2015-06-23mksysmap: Add h8300 local symbol patternYoshinori Sato
h8300's nm output have a lot of local symbols. ex) 00000000 N .Lframe0 00000013 N .LLST1 00000026 N .LLST2 00000039 N .LLST3 0000004c N .LLST4 Added new pattern " .L" to filter rule. Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp>
2015-06-22Merge branch 'x86-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 core updates from Ingo Molnar: "There were so many changes in the x86/asm, x86/apic and x86/mm topics in this cycle that the topical separation of -tip broke down somewhat - so the result is a more traditional architecture pull request, collected into the 'x86/core' topic. The topics were still maintained separately as far as possible, so bisectability and conceptual separation should still be pretty good - but there were a handful of merge points to avoid excessive dependencies (and conflicts) that would have been poorly tested in the end. The next cycle will hopefully be much more quiet (or at least will have fewer dependencies). The main changes in this cycle were: * x86/apic changes, with related IRQ core changes: (Jiang Liu, Thomas Gleixner) - This is the second and most intrusive part of changes to the x86 interrupt handling - full conversion to hierarchical interrupt domains: [IOAPIC domain] ----- | [MSI domain] --------[Remapping domain] ----- [ Vector domain ] | (optional) | [HPET MSI domain] ----- | | [DMAR domain] ----------------------------- | [Legacy domain] ----------------------------- This now reflects the actual hardware and allowed us to distangle the domain specific code from the underlying parent domain, which can be optional in the case of interrupt remapping. It's a clear separation of functionality and removes quite some duct tape constructs which plugged the remap code between ioapic/msi/hpet and the vector management. - Intel IOMMU IRQ remapping enhancements, to allow direct interrupt injection into guests (Feng Wu) * x86/asm changes: - Tons of cleanups and small speedups, micro-optimizations. This is in preparation to move a good chunk of the low level entry code from assembly to C code (Denys Vlasenko, Andy Lutomirski, Brian Gerst) - Moved all system entry related code to a new home under arch/x86/entry/ (Ingo Molnar) - Removal of the fragile and ugly CFI dwarf debuginfo annotations. Conversion to C will reintroduce many of them - but meanwhile they are only getting in the way, and the upstream kernel does not rely on them (Ingo Molnar) - NOP handling refinements. (Borislav Petkov) * x86/mm changes: - Big PAT and MTRR rework: making the code more robust and preparing to phase out exposing direct MTRR interfaces to drivers - in favor of using PAT driven interfaces (Toshi Kani, Luis R Rodriguez, Borislav Petkov) - New ioremap_wt()/set_memory_wt() interfaces to support Write-Through cached memory mappings. This is especially important for good performance on NVDIMM hardware (Toshi Kani) * x86/ras changes: - Add support for deferred errors on AMD (Aravind Gopalakrishnan) This is an important RAS feature which adds hardware support for poisoned data. That means roughly that the hardware marks data which it has detected as corrupted but wasn't able to correct, as poisoned data and raises an APIC interrupt to signal that in the form of a deferred error. It is the OS's responsibility then to take proper recovery action and thus prolonge system lifetime as far as possible. - Add support for Intel "Local MCE"s: upcoming CPUs will support CPU-local MCE interrupts, as opposed to the traditional system- wide broadcasted MCE interrupts (Ashok Raj) - Misc cleanups (Borislav Petkov) * x86/platform changes: - Intel Atom SoC updates ... and lots of other cleanups, fixlets and other changes - see the shortlog and the Git log for details" * 'x86-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (222 commits) x86/hpet: Use proper hpet device number for MSI allocation x86/hpet: Check for irq==0 when allocating hpet MSI interrupts x86/mm/pat, drivers/infiniband/ipath: Use arch_phys_wc_add() and require PAT disabled x86/mm/pat, drivers/media/ivtv: Use arch_phys_wc_add() and require PAT disabled x86/platform/intel/baytrail: Add comments about why we disabled HPET on Baytrail genirq: Prevent crash in irq_move_irq() genirq: Enhance irq_data_to_desc() to support hierarchy irqdomain iommu, x86: Properly handle posted interrupts for IOMMU hotplug iommu, x86: Provide irq_remapping_cap() interface iommu, x86: Setup Posted-Interrupts capability for Intel iommu iommu, x86: Add cap_pi_support() to detect VT-d PI capability iommu, x86: Avoid migrating VT-d posted interrupts iommu, x86: Save the mode (posted or remapped) of an IRTE iommu, x86: Implement irq_set_vcpu_affinity for intel_ir_chip iommu: dmar: Provide helper to copy shared irte fields iommu: dmar: Extend struct irte for VT-d Posted-Interrupts iommu: Add new member capability to struct irq_remap_ops x86/asm/entry/64: Disentangle error_entry/exit gsbase/ebx/usermode code x86/asm/entry/32: Shorten __audit_syscall_entry() args preparation x86/asm/entry/32: Explain reloading of registers after __audit_syscall_entry() ...
2015-06-22ARCv2: extable: Enable sorting at build timeVineet Gupta
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
2015-06-16init: delete the __cpuinit related stubsPaul Gortmaker
The __cpuinit support was removed several releases ago in 3.11-rc1 with commit 22f0a27367742f65130c0fb25ef00f7297e032c1 ("init.h: remove __cpuinit sections from the kernel") People have had a chance to update their out of tree code, so now we remove the no-op stubs to ensure no more new use cases can creep back in. Also delete the mention of __cpuinitdata from the tag script. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2015-06-16kconfig: add xenconfig defconfig helperLuis R. Rodriguez
This lets you build a kernel which can support xen dom0 or xen guests on i386, x86-64 and arm64 by just using: make xenconfig You can start from an allnoconfig and then switch to xenconfig. This also splits out the options which are available currently to be built with x86 and 'make ARCH=arm64' under a shared config. Technically xen supports a dom0 kernel and also a guest kernel configuration but upon review with the xen team since we don't have many dom0 options its best to just combine these two into one. A few generic notes: we enable both of these: CONFIG_INET=y CONFIG_BINFMT_ELF=y although technically not required given you likely will end up with a pretty useless system otherwise. A few architectural differences worth noting: $ make allnoconfig; make xenconfig > /dev/null ; \ grep XEN .config > 64-bit-config $ make ARCH=i386 allnoconfig; make ARCH=i386 xenconfig > /dev/null; \ grep XEN .config > 32-bit-config $ make ARCH=arm64 allnoconfig; make ARCH=arm64 xenconfig > /dev/null; \ grep XEN .config > arm64-config Since the options are already split up with a generic config and architecture specific configs you anything on the x86 configs are known to only work right now on x86. For instance arm64 doesn't support MEMORY_HOTPLUG yet as such although we try to enabe it generically arm64 doesn't have it yet, so we leave the xen specific kconfig option XEN_BALLOON_MEMORY_HOTPLUG on x86's config file to set expecations correctly. Then on x86 we have differences between i386 and x86-64. The difference between 64-bit-config and 32-bit-config is you don't get XEN_MCE_LOG as this is only supported on 64-bit. You also do not get on i386 XEN_BALLOON_MEMORY_HOTPLUG, there does not seem to be any technical reasons to not allow this but I gave up after a few attempts. Cc: Josh Triplett <josh@joshtriplett.org> Cc: Borislav Petkov <bp@suse.de> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Michal Marek <mmarek@suse.cz> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: penberg@kernel.org Cc: levinsasha928@gmail.com Cc: mtosatti@redhat.com Cc: fengguang.wu@intel.com Cc: David Vrabel <david.vrabel@citrix.com> Cc: Ian Campbell <Ian.Campbell@citrix.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: xen-devel@lists.xenproject.org Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Acked-by: Julien Grall <julien.grall@linaro.org> Acked-by: Michal Marek <mmarek@suse.cz> Acked-by: David Rientjes <rientjes@google.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com> Signed-off-by: David Vrabel <david.vrabel@citrix.com>
2015-06-16kconfig: clarify kvmconfig is for kvmLuis R. Rodriguez
We'll be adding options for xen as well. Cc: Josh Triplett <josh@joshtriplett.org> Cc: Borislav Petkov <bp@suse.de> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Michal Marek <mmarek@suse.cz> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: penberg@kernel.org Cc: levinsasha928@gmail.com Cc: mtosatti@redhat.com Cc: fengguang.wu@intel.com Cc: David Vrabel <david.vrabel@citrix.com> Cc: Ian Campbell <Ian.Campbell@citrix.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: xen-devel@lists.xenproject.org Reviewed-by: Josh Triplett <josh@joshtriplett.org> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Borislav Petkov <bp@suse.de> Acked-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com> Signed-off-by: David Vrabel <david.vrabel@citrix.com>
2015-06-15kconfig: re-generate *.c_shipped files after previous changeJan Beulich
Signed-off-by: Jan Beulich <jbeulich@suse.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2015-06-15kconfig: allow use of relations other than (in)equalityJan Beulich
Over the years I found it desirable to be able to use all sorts of relations, not just (in)equality. And apparently I'm not the only one, as there's at least one example in the tree where the programmer assumed this would work (see DEBUG_UART_8250_WORD in arch/arm/Kconfig.debug). Another possible use would e.g. be to fold the two SMP/NR_CPUS prompts into one: SMP could be promptless, simply depending on NR_CPUS > 1. A (desirable) side effect of this change - resulting from numeric values now necessarily being compared as numbers rather than as strings - is that comparing hex values now works as expected: Other than int ones (which aren't allowed to have leading zeroes), zeroes following the 0x prefix made them compare unequal even if their values were equal. Signed-off-by: Jan Beulich <jbeulich@suse.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
