path: root/scripts
2013-10-01kernel-doc: bugfix - multi-line macrosDaniel Santos
commit 654784284430bf2739985914b65e09c7c35a7273 upstream. Prior to this patch the following code breaks: /** * multiline_example - this breaks kernel-doc */ #define multiline_example( \ myparam) Producing this error: Error(somefile.h:983): cannot understand prototype: 'multiline_example( \ ' This patch fixes the issue by appending all lines ending in a blackslash (optionally followed by whitespace), removing the backslash and any whitespace after it prior to appending (just like the C pre-processor would). This fixes a break in kerel-doc introduced by the additions to rbtree.h. Signed-off-by: Daniel Santos <daniel.santos@pobox.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-26kbuild: Fix gcc -x syntaxJean Delvare
commit b1e0d8b70fa31821ebca3965f2ef8619d7c5e316 upstream. The correct syntax for gcc -x is "gcc -x assembler", not "gcc -xassembler". Even though the latter happens to work, the former is what is documented in the manual page and thus what gcc wrappers such as icecream do expect. This isn't a cosmetic change. The missing space prevents icecream from recognizing compilation tasks it can't handle, leading to silent kernel miscompilations. Besides me, credits go to Michael Matz and Dirk Mueller for investigating the miscompilation issue and tracking it down to this incorrect -x parameter syntax. Signed-off-by: Jean Delvare <jdelvare@suse.de> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Bernhard Walle <bernhard@bwalle.de> Cc: Michal Marek <mmarek@suse.cz> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13kbuild: make: fix if_changed when command contains backslashesSascha Hauer
commit c353acba28fb3fa1fd05fd6b85a9fc7938330f9c upstream. The call if_changed mechanism does not work when the command contains backslashes. This basically is an issue with lzo and bzip2 compressed kernels. The compressed binaries do not contain the uncompressed image size, so these use size_append to append the size. This results in backslashes in the executed command. With this if_changed always detects a change in the command and rebuilds the compressed image even if nothing has changed. Fix this by escaping backslashes in make-cmd Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Jan Luebbe <jlu@pengutronix.de> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Bernhard Walle <bernhard@bwalle.de> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-07Fix modpost failures in fedora 17David Miller
commit e88aa7bbbe3046a125ea1936b16bb921cc9c6349 upstream. The symbol table on x86-64 starts to have entries that have names like: _GLOBAL__sub_I_65535_0___mod_x86cpu_device_table They are of type STT_FUNCTION and this one had a length of 18. This matched the device ID validation logic and it barfed because the length did not meet the device type's criteria. -------------------- FATAL: arch/x86/crypto/aesni-intel: sizeof(struct x86cpu_device_id)=16 is not a modulo of the size of section __mod_x86cpu_device_table=18. Fix definition of struct x86cpu_device_id in mod_devicetable.h -------------------- These are some kind of compiler tool internal stuff being emitted and not something we want to inspect in modpost's device ID table validation code. So skip the symbol if it is not of type STT_OBJECT. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Jonathan Nieder <jrnieder@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13modpost: Fix modpost license checking of vmlinux.oFrank Rowand
commit 258f742635360175564e9470eb060ff4d4b984e7 upstream. Commit f02e8a6596b7 ("module: Sort exported symbols") sorts symbols placing each of them in its own elf section. This sorting and merging into the canonical sections are done by the linker. Unfortunately modpost to generate Module.symvers file parses vmlinux.o (which is not linked yet) and all modules object files (which aren't linked yet). These aren't sanitized by the linker yet. That breaks modpost that can't detect license properly for modules. This patch makes modpost aware of the new exported symbols structure. [ This above is a slightly corrected version of the explanation of the problem, copied from commit 62a2635610db ("modpost: Fix modpost's license checking V3"). That commit fixed the problem for module object files, but not for vmlinux.o. This patch fixes modpost for vmlinux.o. ] Signed-off-by: Frank Rowand <frank.rowand@am.sony.com> Signed-off-by: Alessio Igor Bogani <abogani@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13modpost: Fix modpost's license checking V3Alessio Igor Bogani
commit 62a2635610dbc83c5e8d724e00941eee4d18c186 upstream. The commit f02e8a6 sorts symbols placing each of them in its own elf section. The sorting and merging into the canonical sections are done by the linker. Unfortunately modpost to generate Module.symvers file parses vmlinux (already linked) and all modules object files (which aren't linked yet). These aren't sanitized by the linker yet. That breaks modpost that can't detect license properly for modules. This patch makes modpost aware of the new exported symbols structure. Thanks to Arnaud Lacombe <lacombar@gmail.com> and Anders Kaseorg <andersk@ksplice.com> for providing useful suggestions about code. This work was supported by a hardware donation from the CE Linux Forum. Reported-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Alessio Igor Bogani <abogani@kernel.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13modpost: fix ALL_INIT_DATA_SECTIONSJan Beulich
commit 9aaf440f8fabcebf9ea79a62ccf4c212e6544b49 upstream. This was lacking a comma between two supposed to be separate strings. Signed-off-by: Jan Beulich <jbeulich@suse.com> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29builddeb: Don't create files in /tmp with predictable namesBen Hutchings
commit 6c635224602d760c1208ada337562f40d8ae93a5 upstream. The current use of /tmp for file lists is insecure. Put them under $objtree/debian instead. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: maximilian attems <max@stro.at> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-25recordmcount: Fix handling of elf64 big-endian objects.David Daney
commit 2e885057b7f75035f0b85e02f737891482815a81 upstream. In ELF64, the sh_flags field is 64-bits wide. recordmcount was erroneously treating it as a 32-bit wide field. For little endian objects this works because the flags of interest (SHF_EXECINSTR) reside in the lower 32 bits of the word, and you get the same result with either a 32-bit or 64-bit read. Big endian objects on the other hand do not work at all with this error. The fix: Correctly treat sh_flags as 64-bits wide in elf64 objects. The symptom I observed was that my __start_mcount_loc..__stop_mcount_loc was empty even though ftrace function tracing was enabled. Link: http://lkml.kernel.org/r/1324345362-12230-1-git-send-email-ddaney.cavm@gmail.com Signed-off-by: David Daney <david.daney@cavium.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25kconfig/streamline-config.pl: Fix parsing Makefile with variablesSteven Rostedt
commit 364212fddaaa60c5a64f67a0f5624ad996ecc8a0 upstream. Thomas Lange reported that when he did a 'make localmodconfig', his config was missing the brcmsmac driver, even though he had the module loaded. Looking into this, I found the file: drivers/net/wireless/brcm80211/brcmsmac/Makefile had the following in the Makefile: MODULEPFX := brcmsmac obj-$(CONFIG_BRCMSMAC) += $(MODULEPFX).o The way streamline-config.pl works, is parsing all the obj-$(CONFIG_FOO) += foo.o lines to find that CONFIG_FOO belongs to the module foo.ko. But in this case, the brcmsmac.o was not used, but a variable in its place. By changing streamline-config.pl to remember defined variables in Makefiles and substituting them when they are used in the obj-X lines, allows Thomas (and others) to have their brcmsmac module stay configured when it is loaded and running "make localmodconfig". Reported-by: Thomas Lange <thomas-lange2@gmx.de> Tested-by: Thomas Lange <thomas-lange2@gmx.de> Cc: Arend van Spriel <arend@broadcom.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25kconfig/streamline-config.pl: Simplify backslash line concatinationSteven Rostedt
commit d060d963e88f3e990cec2fe5214de49de9a49eca upstream. Simplify the way lines ending with backslashes (continuation) in Makefiles is parsed. This is needed to implement a necessary fix. Tested-by: Thomas Lange <thomas-lange2@gmx.de> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11kbuild: Fix help text not displayed in choice option.Srinivas Kandagatla
commit 3f198dfee49d2e9c30583c62b0c79286c78c7b44 upstream. Help text under choice menu is never displayed because it does not have symbol name associated with it, however many kconfigs have help text under choice, assuming that it will be displayed when user selects help. for example in Kconfig if we have: choice prompt "Choice" ---help--- HELP TEXT ... config A bool "A" config B bool "B" endchoice Without this patch "HELP TEXT" is not displayed when user selects help option when "Choice" is highlighted from menuconfig or xconfig or gconfig. This patch changes the logic in menu_get_ext_help to display help for cases which dont have symbol names like choice. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com> Reviewed-by: Stuart Menefy <stuart.menefy@st.com> Reviewed-by: Arnaud Lacombe <lacombar@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-13Merge branch 'rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: kbuild: Do not write to builddir in modules_install
2011-07-12kbuild: Do not write to builddir in modules_installMichal Marek
Let depmod.sh create a temporary directory in /tmp instead of writing to the build directory as root. The mktemp utility should be available on any recent system (and there is already scripts/gen_initramfs_list.sh relying on it). Reported-by: Christian Kujau <lists@nerdbynature.de> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-06-15checkpatch: add warning for uses of printk_ratelimitJoe Perches
Warn about uses of printk_ratelimit() because it uses a global state and can hide subsequent useful messages. Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@canonical.com> Cc: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-09kbuild: Hack for depmod not handling X.Y versionsMichal Marek
depmod from module-init-tools < 3.13 and the busybox depmod check if the kernel release starts with <num>.<num>.<num>. To support these versions, we create a symlink with two numbers prepended. Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-06-09kbuild: Move depmod call to a separate scriptMichal Marek
Do not bloat the Makefile with multiline shell statements. No user-visible change intended. Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-06-09kbuild: silence Nothing to be done for 'all' messagePeter Foley
This patch silences a Makefile.asm-generic message by defining a dummy rule for all. make -f /usr/src/git/scripts/Makefile.asm-generic \ obj=arch/x86/include/generated/asm make[1]: Nothing to be done for `all'. Signed-off-by: Peter Foley <pefoley2@verizon.net> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-28Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (25 commits) perf: Fix SIGIO handling perf top: Don't stop if no kernel symtab is found perf top: Handle kptr_restrict perf top: Remove unused macro perf events: initialize fd array to -1 instead of 0 perf tools: Make sure kptr_restrict warnings fit 80 col terms perf tools: Fix build on older systems perf symbols: Handle /proc/sys/kernel/kptr_restrict perf: Remove duplicate headers ftrace: Add internal recursive checks tracing: Update btrfs's tracepoints to use u64 interface tracing: Add __print_symbolic_u64 to avoid warnings on 32bit machine ftrace: Set ops->flag to enabled even on static function tracing tracing: Have event with function tracer check error return ftrace: Have ftrace_startup() return failure code jump_label: Check entries limit in __jump_label_update ftrace/recordmcount: Avoid STT_FUNC symbols as base on ARM scripts/tags.sh: Add magic for trace-events for etags too scripts/tags.sh: Fix ctags for DEFINE_EVENT() x86/ftrace: Fix compiler warning in ftrace.c ...
2011-05-27Merge branch 'docs-move' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs * 'docs-move' of git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs: Create Documentation/security/, move LSM-, credentials-, and keys-related files from Documentation/ to Documentation/security/, add Documentation/security/00-INDEX, and update all occurrences of Documentation/<moved_file> to Documentation/security/<moved_file>.
2011-05-27Merge branch 'tip/perf/urgent' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/urgent
2011-05-25ftrace/recordmcount: Avoid STT_FUNC symbols as base on ARMRabin Vincent
While find_secsym_ndx often finds the unamed local STT_SECTION, if a section has only one function in it, the ARM toolchain generates the STT_FUNC symbol before the STT_SECTION, and recordmcount finds this instead. This is problematic on ARM because in ARM ELFs, "if a [STT_FUNC] symbol addresses a Thumb instruction, its value is the address of the instruction with bit zero set (in a relocatable object, the section offset with bit zero set)". This leads to incorrect mcount addresses being recorded. Fix this by not using STT_FUNC symbols as the base on ARM. Signed-off-by: Rabin Vincent <rabin@rab.in> Link: http://lkml.kernel.org/r/1305134631-31617-1-git-send-email-rabin@rab.in Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-25scripts/tags.sh: Add magic for trace-events for etags tooSteven Rostedt
Seems that Peter Zijlstra treats us emacs users as second class citizens and the commit: commit 15664125f7cadcb6d725cb2d9b90f9715397848d Author: Peter Zijlstra <peterz@infradead.org> scripts/tags.sh: Add magic for trace-events only updated ctags (for vim) and did not do the work to let us lowly emacs users benefit from such a change. Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-25scripts/tags.sh: Fix ctags for DEFINE_EVENT()Steven Rostedt
The regex to handle DEFINE_EVENT() should not be the same as the TRACE_EVENT() as the first parameter in DEFINE_EVENT is the template name, not the event name. We need the second parameter as that is what the trace_... will use. Tested-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-25Merge branch 'kconfig-for-40' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kconfig-for-40' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: xconfig: merge code path to conf_write() kconfig: do not record timestamp in .config gconfig: Hide unused left treeview when start up the interface gconfig: enable rules hint for main treeviews MAINTAINERS: Update KCONFIG entry kconfig-language: add to hints kconfig: Document the new "visible if" syntax kconfig: quiet commands when V=0 kconfig: change update-po-config to reflect new layout of arch/um kconfig: make update-po-config work in KBUILD_OUTPUT kconfig: rearrange clean-files kconfig: change gconf to modify hostprogs-y like nconf and mconf kconfig: change qconf to modify hostprogs-y like nconf and mconf kconfig: only build kxgettext when needed nconfig: Silence unused return values from wattrset kconfig: Do not record timestamp in auto.conf and autoconf.h kconfig: get rid of unused flags kconfig: allow multiple inclusion of the same file kconfig: Avoid buffer underrun in choice input
2011-05-25Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: export_report: use warn() to issue WARNING, so they go to stderr export_report: sort SECTION 2 output export_report: do collectcfiles work in perl itself kbuild: make versioncheck work in KBUILD_OUTDIR kbuild: make includecheck work in KBUILD_OUTDIR kbuild: make headerdep work in KBUILD_OUTDIR kbuild: add targets to PHONY kbuild: don't warn about include/linux/version.h not including itself eradicate bashisms in scripts/patch-kernel
2011-05-25Merge branch 'packaging' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'packaging' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: kbuild: Create a kernel-headers RPM rpm-pkg: Fix when current directory is a symlink Replace '-' in kernel version with '_'
2011-05-25checkpatch: fix defect in printk(KERN_<LEVEL> 80 column exceptionsJoe Perches
Currently, printk lines with a only KERN_PREFIX and a quoted string without a comma or close paren that exceed 80 columns are flagged with a warning. ie: printk(KERN_WARNING "some long string that extends beond 80 cols..." "and is continued on another line\n"); Allow this form instead of emitting a warning. Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25checkpatch: add <foo>_<level> and MODULE_<BAR> to 80 column exceptionsJoe Perches
Many module or file local logging functions use specific prefixes other than pr|dev|netdev. Allow all forms like foo_printk and foo_err to be longer than 80 columns. Also allow MODULE_<BAR> declarations to be longer than 80 columns. Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25checkpatch: add check for line continuations in quoted stringsJoe Perches
Add a warning for unterminated quoted strings with line continuations as these frequently add unwanted whitespace. Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25xconfig: merge code path to conf_write()Arnaud Lacombe
Avoid to have multiple path saving the config. This fixes an error check miss when the window is being closed and the user requested the config to be written. Reported-by: Hiromu Yakura <hiromu1996@gmail.com> Pointed-out-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-24Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: kbuild: make KBUILD_NOCMDDEP=1 handle empty built-in.o scripts/kallsyms.c: fix potential segfault scripts/gen_initramfs_list.sh: Convert to a /bin/sh script kbuild: Fix GNU make v3.80 compatibility kbuild: Fix passing -Wno-* options to gcc 4.4+ kbuild: move scripts/basic/docproc.c to scripts/docproc.c kbuild: Fix Makefile.asm-generic for um kbuild: Allow to combine multiple W= levels kbuild: Disable -Wunused-but-set-variable for gcc 4.6.0 Fix handling of backlash character in LINUX_COMPILE_BY name kbuild: asm-generic support kbuild: implement several W= levels kbuild: Fix build with binutils <= 2.19 initramfs: Use KBUILD_BUILD_TIMESTAMP for generated entries kbuild: Allow to override LINUX_COMPILE_BY and LINUX_COMPILE_HOST macros kbuild: Drop unused LINUX_COMPILE_TIME and LINUX_COMPILE_DOMAIN macros kbuild: Use the deterministic mode of ar kbuild: Call gzip with -n kbuild: move KALLSYMS_EXTRA_PASS from Kconfig to Makefile Kconfig: improve KALLSYMS_ALL documentation Fix up trivial conflict in Makefile
2011-05-24kbuild: Create a kernel-headers RPMArun Sharma
To compile binaries which depend on new kernel interfaces, we need a kernel-headers RPM Signed-off-by: Arun Sharma <asharma@fb.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-24rpm-pkg: Fix when current directory is a symlinkMichal Marek
The better fix would be to stop using the parent directory (principle of least surprise), but as long as we use it, use it consistently. Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-24kconfig: do not record timestamp in .configArnaud Lacombe
Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-24export_report: use warn() to issue WARNING, so they go to stderrJim Cromie
Also count CONFIG_MODVERSIONS warnings, and print a NOTE at start of SECTION 2 if any were issued. Section 2 will be empty if the build is lacking this CONFIG_ item, and user may have missed the warnings, as they're off screen. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-24export_report: sort SECTION 2 outputJim Cromie
Sort SECTION 2 modules by name. Within those module listings, sort the symbol providers by name, and remove the count, as it is misleading; its the kernel-wide count of uses of that symbol, not the count pertaining to the module being outlined. (this can be seen by grepping the output for a single symbol). The count is still used to sort the symbols. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-24export_report: do collectcfiles work in perl itselfJim Cromie
Avoid spawning a shell pipeline doing cat, grep, sed, and do it all inside perl. The <*.c> globbing construct works at least as far back as 5.8.9 Note that this is not just an optimization; the sed command in the pipeline was unterminated, due to lack of escape on the end-of-line (\$) in the regex, resulting in this: $ perl ../linux-2.6/scripts/export_report.pl > /dev/null sed: -e expression #1, char 5: unterminated `s' command sh: .mod.c/: not found Comments on an earlier patch sought an all-perl implementation. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> cc: Michal Marek <mmarek@suse.cz>, cc: linux-kbuild@vger.kernel.org cc: Arnaud Lacombe lacombar@gmail.com cc: Stephen Hemminger shemminger@vyatta.com Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-24gconfig: Hide unused left treeview when start up the interfaceEduardo Silva
When the gconfig program starts in full mode view, it shows the left treeview which belongs to the 'split mode view'. The patch fix this visual issue. Signed-off-by: Eduardo Silva <edsiper@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-24gconfig: enable rules hint for main treeviewsEduardo Silva
Due to the large amount of rows in the treeviews, is difficult to match columns with rows, setting the rules hint to 'true' allows the treeview to alternate background colors in the rows making the data more readable. Signed-off-by: Eduardo Silva <edsiper@gmail.com> Tested-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
2011-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits) macvlan: fix panic if lowerdev in a bond tg3: Add braces around 5906 workaround. tg3: Fix NETIF_F_LOOPBACK error macvlan: remove one synchronize_rcu() call networking: NET_CLS_ROUTE4 depends on INET irda: Fix error propagation in ircomm_lmp_connect_response() irda: Kill set but unused variable 'bytes' in irlan_check_command_param() irda: Kill set but unused variable 'clen' in ircomm_connect_indication() rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport() be2net: Kill set but unused variable 'req' in lancer_fw_download() irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication() atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined. rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer(). rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler() rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection() rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window() pkt_sched: Kill set but unused variable 'protocol' in tc_classify() isdn: capi: Use pr_debug() instead of ifdefs. tg3: Update version to 3.119 tg3: Apply rx_discards fix to 5719/5720 ... Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c as per Davem.
2011-05-19Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (107 commits) perf stat: Add more cache-miss percentage printouts perf stat: Add -d -d and -d -d -d options to show more CPU events ftrace/kbuild: Add recordmcount files to force full build ftrace: Add self-tests for multiple function trace users ftrace: Modify ftrace_set_filter/notrace to take ops ftrace: Allow dynamically allocated function tracers ftrace: Implement separate user function filtering ftrace: Free hash with call_rcu_sched() ftrace: Have global_ops store the functions that are to be traced ftrace: Add ops parameter to ftrace_startup/shutdown functions ftrace: Add enabled_functions file ftrace: Use counters to enable functions to trace ftrace: Separate hash allocation and assignment ftrace: Create a global_ops to hold the filter and notrace hashes ftrace: Use hash instead for FTRACE_FL_FILTER ftrace: Replace FTRACE_FL_NOTRACE flag with a hash of ignored functions perf bench, x86: Add alternatives-asm.h wrapper x86, 64-bit: Fix copy_[to/from]_user() checks for the userspace address limit x86, mem: memset_64.S: Optimize memset by enhanced REP MOVSB/STOSB x86, mem: memmove_64.S: Optimize memmove by enhanced REP MOVSB/STOSB ...
2011-05-19Create Documentation/security/,Randy Dunlap
2011-05-19ftrace/kbuild: Add recordmcount files to force full buildMichal Marek
Modifications to recordmcount must be performed on all object files to stay consistent with what the kernel code may expect. Add the recordmcount files to the main dependencies to make sure any change to them causes a full recompile. Signed-off-by: Michal Marek <mmarek@suse.cz> Link: http://lkml.kernel.org/r/20110517133646.GP13293@sepie.suse.cz Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-19modpost: Update 64k section support for binutils 2.18.50Anders Kaseorg
Binutils 2.18.50 made a backwards-incompatible change in the way it writes ELF objects with over 65280 sections, to improve conformance with the ELF specification and interoperability with other ELF tools. Specifically, it no longer adds 256 to section indices SHN_LORESERVE and higher to skip over the reserved range SHN_LORESERVE through SHN_HIRESERVE; those values are only considered special in the st_shndx field, and not in other places where section indices are stored. See: http://sourceware.org/bugzilla/show_bug.cgi?id=5900 http://groups.google.com/group/generic-abi/browse_thread/thread/e8bb63714b072e67/6c63738f12cc8a17 Signed-off-by: Anders Kaseorg <andersk@ksplice.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-05-19module: Sort exported symbolsAlessio Igor Bogani
This patch places every exported symbol in its own section (i.e. "___ksymtab+printk"). Thus the linker will use its SORT() directive to sort and finally merge all symbol in the right and final section (i.e. "__ksymtab"). The symbol prefixed archs use an underscore as prefix for symbols. To avoid collision we use a different character to create the temporary section names. This work was supported by a hardware donation from the CE Linux Forum. Signed-off-by: Alessio Igor Bogani <abogani@kernel.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (folded in '+' fixup) Tested-by: Dirk Behme <dirk.behme@googlemail.com>
2011-05-18Haavard Skinnemoen has left AtmelJean Delvare
Haavard's e-mail address at Atmel is no longer valid. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Havard Skinnemoen <hskinnemoen@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-16Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: drivers/net/wireless/iwlwifi/iwl-agn-tx.c net/mac80211/sta_info.h
2011-05-16ftrace/s390: mcount offset calculationMartin Schwidefsky
Do the mcount offset adjustment in the recordmcount.pl/recordmcount.[ch] at compile time and not in ftrace_call_adjust at run time. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
