path: root/scripts
2012-10-14Merge branch 'modules-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module signing support from Rusty Russell: "module signing is the highlight, but it's an all-over David Howells frenzy..." Hmm "Magrathea: Glacier signing key". Somebody has been reading too much HHGTTG. * 'modules-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (37 commits) X.509: Fix indefinite length element skip error handling X.509: Convert some printk calls to pr_devel asymmetric keys: fix printk format warning MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checking MODSIGN: Make mrproper should remove generated files. MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certs MODSIGN: Use the same digest for the autogen key sig as for the module sig MODSIGN: Sign modules during the build process MODSIGN: Provide a script for generating a key ID from an X.509 cert MODSIGN: Implement module signature checking MODSIGN: Provide module signing public keys to the kernel MODSIGN: Automatically generate module signing keys if missing MODSIGN: Provide Kconfig options MODSIGN: Provide gitignore and make clean rules for extra files MODSIGN: Add FIPS policy module: signature checking hook X.509: Add a crypto key parser for binary (DER) X.509 certificates MPILIB: Provide a function to read raw data into an MPI X.509: Add an ASN.1 decoder X.509: Add simple ASN.1 grammar compiler ...
2012-10-12Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild misc changes from Michal Marek: "In the non-critical part of kbuild, I have - Some make coccicheck improvements and two new tests - Support for a cleaner html output in scripts/kernel-doc, named html5 (no, it does not play videos, yet) BTW, Randy wants to route further kernel-doc patches through the kbuild tree." * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: Update SmPL/Coccinelle section of MAINTAINERS coccicheck: Add the rep+ctxt mode scripts/coccinelle/tests/odd_ptr_err.cocci: semantic patch for IS_ERR/PTR_ERR inconsistency scripts/tags.sh: Add magic for pci access functions scripts/coccinelle: ptr_ret: Add ternary operator version scripts/kernel-doc: drop maintainer scripts/kernel-doc: added support for html5
2012-10-12Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kconfig changes from Michal Marek: "kconfig in v3.7 is going to - initialize ncurses only once in menuconfig - be able to jump to a search result in menuconfig - change the misnomer oldnoconfig to a more meaningful name olddefconfig, keeping the old name as alias" * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kconfig: replace 'oldnoconfig' with 'olddefconfig', and keep the old name as an alias menuconfig: Assign jump keys per-page instead of globally menuconfig: Do not open code textbox scroll up/down menuconfig: Add jump keys to search results menuconfig: Extend dialog_textbox so that it can return to a scrolled position menuconfig: Extend dialog_textbox so that it can exit on arbitrary keypresses menuconfig: Remove superfluous conditionnal kconfig: document oldnoconfig to what it really does in conf.c kconfig/mconf.c: revision of curses initialization.
2012-10-12Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild changes from Michal Marek: "The main part of kbuild for v3.7 contains: - Fix for scripts/Makefile.modpost to not choke on a '.ko' substring in the build directory path - Two warning fixes (modpost and main Makefile) - __compiletime_error works also with gcc 4.3 - make tar{gz,bz2,xz}-pkg uses default compression settings instead of saving as many bytes as possible (this should actually be in the misc branch, I don't know why I applied it here)." * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: compiler-gcc4.h: correct verion check for __compiletime_error modpost: Permit .GCC.command.line sections Kbuild: use normal compression settings for tar*-pkg scripts/Makefile.modpost: error in finding modules from .mod files. kbuild: Remove useless warning while appending KCFLAGS
2012-10-11modpost: Permit .GCC.command.line sectionsJonathan Kliegman
Allow .GCC.command.line sections in modules to prevent modpost warnings: WARNING: sound/usb/snd-usbmidi-lib.o (.GCC.command.line): unexpected non-allocatable section. Did you forget to use "ax"/"aw" in a .S file? Note that for example <linux/init.h> contains section definitions for use in .S files. Signed-off-by: Jonathan Kliegman <kliegs@chromium.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-10-11coccicheck: Add the rep+ctxt modeNicolas Palix
This adds a 'rep+ctxt' mode which prints the warning message followed by the context. Signed-off-by: Nicolas Palix <nicolas.palix@imag.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-10-11scripts/coccinelle/tests/odd_ptr_err.cocci: semantic patch for ↵Julia Lawall
IS_ERR/PTR_ERR inconsistency Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-10-10MODSIGN: Sign modules during the build processDavid Howells
If CONFIG_MODULE_SIG is set, then this patch will cause all modules files to to have signatures added. The following steps will occur: (1) The module will be linked to foo.ko.unsigned instead of foo.ko (2) The module will be stripped using both "strip -x -g" and "eu-strip" to ensure minimal size for inclusion in an initramfs. (3) The signature will be generated on the stripped module. (4) The signature will be appended to the module, along with some information about the signature and a magic string that indicates the presence of the signature. Step (3) requires private and public keys to be available. By default these are expected to be found in files: signing_key.priv signing_key.x509 in the base directory of the build. The first is the private key in PEM form and the second is the X.509 certificate in DER form as can be generated from openssl: openssl req \ -new -x509 -outform PEM -out signing_key.x509 \ -keyout signing_key.priv -nodes \ -subj "/CN=H2G2/O=Magrathea/CN=Slartibartfast" If the secret key is not found then signing will be skipped and the unsigned module from (1) will just be copied to foo.ko. If signing occurs, lines like the following will be seen: LD [M] fs/foo/foo.ko.unsigned STRIP [M] fs/foo/foo.ko.stripped SIGN [M] fs/foo/foo.ko will appear in the build log. If the signature step will be skipped and the following will be seen: LD [M] fs/foo/foo.ko.unsigned STRIP [M] fs/foo/foo.ko.stripped NO SIGN [M] fs/foo/foo.ko NOTE! After the signature step, the signed module _must_not_ be passed through strip. The unstripped, unsigned module is still available at the name on the LD [M] line. This restriction may affect packaging tools (such as rpmbuild) and initramfs composition tools. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-10MODSIGN: Provide a script for generating a key ID from an X.509 certDavid Howells
Provide a script to parse an X.509 certificate and certain pieces of information from it in order to generate a key identifier to be included within a module signature. The script takes the Subject Name and extracts (if present) the organizationName (O), the commonName (CN) and the emailAddress and fabricates the signer's name from them: (1) If both O and CN exist, then the name will be "O: CN", unless: (a) CN is prefixed by O, in which case only CN is used. (b) CN and O share at least the first 7 characters, in which case only CN is used. (2) Otherwise, CN is used if present. (3) Otherwise, O is used if present. (4) Otherwise the emailAddress is used, if present. (5) Otherwise a blank name is used. The script emits a binary encoded identifier in the following form: - 2 BE bytes indicating the length of the signer's name. - 2 BE bytes indicating the length of the subject key identifier. - The characters of the signer's name. - The bytes of the subject key identifier. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-09Merge tag 'xtensa-next-20121008' of git://github.com/czankel/xtensa-linuxLinus Torvalds
Pull Xtensa patchset from Chris Zankel: "The Xtensa tree has been broken for some time now, and this patchset brings it back to life. It has been part of the linux-next tree for some time. Most changes are inside the xtensa subdirectory; the other changes mostly add another rule to already existing #ifdefs to exclude Xtensa, where required. The only 'common' change is to add two more sections ('.xt.prop' and '.xt.lit') to the white list in modpost." * tag 'xtensa-next-20121008' of git://github.com/czankel/xtensa-linux: (27 commits) xtensa: Setup CROSS_COMPILE at the top xtensa: drop CONFIG_EMBEDDED_RAMDISK xtensa: fix TIOCGSERIAL and TIOCSSERIAL definitions xtensa: provide dummy gcc intrinsics xtensa: add missing symbol exports parport: disable for xtensa arch xtensa: rename MISC SR definition to avoid name clashes hisax: disable build for big-endian xtensa xtensa: fix CODA build xtensa: fix parallel make xtensa: ISS: drop unused io.c xtensa: ISS: exit simulator in case of halt or poweroff xtensa: ISS: change keyboard polling rate xtensa: ISS: add platform_pcibios_init xtensa: ISS: add dummy serial.h for ISS platform xtensa: change default platform clock frequency to 10MHz xtensa: add ARCH_WANT_OPTIONAL_GPIOLIB to xtensa config xtensa: set NO_IOPORT to 'n' by default xtensa: adopt generic io routines xtensa: fix ioremap ...
2012-10-08X.509: Add simple ASN.1 grammar compilerDavid Howells
Add a simple ASN.1 grammar compiler. This produces a bytecode output that can be fed to a decoder to inform the decoder how to interpret the ASN.1 stream it is trying to parse. Action functions can be specified in the grammar by interpolating: ({ foo }) after a type, for example: SubjectPublicKeyInfo ::= SEQUENCE { algorithm AlgorithmIdentifier, subjectPublicKey BIT STRING ({ do_key_data }) } The decoder is expected to call these after matching this type and parsing the contents if it is a constructed type. The grammar compiler does not currently support the SET type (though it does support SET OF) as I can't see a good way of tracking which members have been encountered yet without using up extra stack space. Currently, the grammar compiler will fail if more than 256 bytes of bytecode would be produced or more than 256 actions have been specified as it uses 8-bit jump values and action indices to keep space usage down. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-08Merge branch 'rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild fixes from Michal Marek: "Here are two fixes I intended to send after v3.6-rc7, but failed to do so. So please pull them for v3.7-rc1 and they will be picked up by stable. The first one fixes gcc -x <language> syntax in various build-time tests, which icecream and possible other gcc wrappers did not understand (and yes, icecream is going to be fixed as well). The second one fixes make tar-pkg so that unpacking the tarball does not replace the /lib -> /usr/lib symlink on recent Fedora releases." * 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: Fix gcc -x syntax kbuild: Do not package /boot and /lib in make tar-pkg
2012-10-06kernel-doc: don't mangle whitespace in Example sectionDaniel Santos
A section with the name "Example" (case-insensitive) has a special meaning to kernel-doc. These sections are output using mono-type fonts. However, leading whitespace is stripped, thus robbing a lot of meaning from this, as indented code examples will be mangled. This patch preserves the leading whitespace for "Example" sections. More accurately, it preserves it for all sections, but removes it later if the section isn't an "Example" section. Signed-off-by: Daniel Santos <daniel.santos@pobox.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06kernel-doc: bugfix - empty line in Example sectionDaniel Santos
If you have a section named "Example" that contains an empty line, attempting to generate htmldocs give you the error: /path/Documentation/DocBook/kernel-api.xml:3455: parser error : Opening and ending tag mismatch: programlisting line 3449 and para </para><para> ^ /path/Documentation/DocBook/kernel-api.xml:3473: parser error : Opening and ending tag mismatch: para line 3467 and programlisting </programlisting></informalexample> ^ /path/Documentation/DocBook/kernel-api.xml:3678: parser error : Opening and ending tag mismatch: programlisting line 3672 and para </para><para> ^ /path/Documentation/DocBook/kernel-api.xml:3701: parser error : Opening and ending tag mismatch: para line 3690 and programlisting </programlisting></informalexample> ^ unable to parse /path/Documentation/DocBook/kernel-api.xml Essentially, the script attempts to close a <programlisting> with a closing tag for a <para> block. This patch corrects the problem by simply not outputting anything extra when we're dumping pre-formatted text, since the empty line will be rendered correctly anyway. Signed-off-by: Daniel Santos <daniel.santos@pobox.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06kernel-doc: bugfix - multi-line macrosDaniel Santos
Prior to this patch the following code breaks: /** * multiline_example - this breaks kernel-doc */ #define multiline_example( \ myparam) Producing this error: Error(somefile.h:983): cannot understand prototype: 'multiline_example( \ ' This patch fixes the issue by appending all lines ending in a blackslash (optionally followed by whitespace), removing the backslash and any whitespace after it prior to appending (just like the C pre-processor would). This fixes a break in kerel-doc introduced by the additions to rbtree.h. Signed-off-by: Daniel Santos <daniel.santos@pobox.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06checkpatch: fix name of "MODULE_PARM_DESC"Kees Cook
Fix macro name in checkpatch: s/PARAM/PARM/. Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06checkpatch: check networking specific block comment styleJoe Perches
In an effort to get fewer checkpatch reviewer corrections, add a networking specific style test for the preferred networking comment style. /* The preferred style for block comments in * drivers/net/... and net/... is like this */ These tests are only used in net/ and drivers/net/ Tested with: $ cat drivers/net/t.c /* foo */ /* * foo */ /* foo */ /* foo * bar */ $ ./scripts/checkpatch.pl -f drivers/net/t.c WARNING: networking block comments don't use an empty /* line, use /* Comment... #4: FILE: net/t.c:4: + +/* WARNING: networking block comments put the trailing */ on a separate line #12: FILE: net/t.c:12: + * bar */ total: 0 errors, 2 warnings, 12 lines checked Signed-off-by: Joe Perches <joe@perches.com> Cc: "Allan, Bruce W" <bruce.w.allan@intel.com> Cc: Andy Whitcroft <apw@canonical.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06checkpatch: update suggested printk conversionsJoe Perches
Direct conversion of printk(KERN_<LEVEL>... to pr_<level> isn't the preferred conversion when a struct net_device or struct device is available. Hint that using netdev_<level> or dev_<level> is preferred to using pr_<level>. Add netdev_dbg and dev_dbg variants too. Miscellaneous whitespace neatening of a misplaced close brace. Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@canonical.com> Cc: Greg KH <gregkh@linuxfoundation.org> Cc: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06checkpatch: check utf-8 content from a commit log when it's missing from charsetPasi Savanainen
Check that a commit log doesn't contain UTF-8 when a mail header explicitly defines a different charset, like 'Content-Type: text/plain; charset="us-ascii"' Signed-off-by: Pasi Savanainen <pasi.savanainen@nixu.com> Cc: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06kbuild: make: fix if_changed when command contains backslashesSascha Hauer
The call if_changed mechanism does not work when the command contains backslashes. This basically is an issue with lzo and bzip2 compressed kernels. The compressed binaries do not contain the uncompressed image size, so these use size_append to append the size. This results in backslashes in the executed command. With this if_changed always detects a change in the command and rebuilds the compressed image even if nothing has changed. Fix this by escaping backslashes in make-cmd Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Jan Luebbe <jlu@pengutronix.de> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Bernhard Walle <bernhard@bwalle.de> Cc: Michal Marek <mmarek@suse.cz> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-03modpost: fix modpost warnings for xtensaMax Filippov
Suppress warnings for two informational sections (.xt.lit and .xt.prop) used by the Xtensa architecture. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net>
2012-10-03Merge tag 'uapi-prep-20121002' of ↵Linus Torvalds
git://git.infradead.org/users/dhowells/linux-headers Pull preparatory patches for user API disintegration from David Howells: "The patches herein prepare for the extraction of the Userspace API bits from the various header files named in the Kbuild files. New subdirectories are created under either include/uapi/ or arch/x/include/uapi/ that correspond to the subdirectory containing that file under include/ or arch/x/include/. The new subdirs under the uapi/ directory are populated with Kbuild files that mostly do nothing at this time. Further patches will disintegrate the headers in each original directory and fill in the Kbuild files as they do it. These patches also: (1) fix up #inclusions of "foo.h" rather than <foo.h>. (2) Remove some redundant #includes from the DRM code. (3) Make the kernel build infrastructure handle Kbuild files both in the old places and the new UAPI place that both specify headers to be exported. (4) Fix some kernel tools that #include kernel headers during their build. I have compile tested this with allyesconfig against x86_64, allmodconfig against i386 and a scattering of additional defconfigs of other arches. Prepared for main script Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com> Acked-by: H. Peter Anvin <hpa@zytor.com>" * tag 'uapi-prep-20121002' of git://git.infradead.org/users/dhowells/linux-headers: UAPI: Plumb the UAPI Kbuilds into the user header installation and checking UAPI: x86: Differentiate the generated UAPI and internal headers UAPI: Remove the objhdr-y export list UAPI: Move linux/version.h UAPI: Set up uapi/asm/Kbuild.asm UAPI: x86: Fix insn_sanity build failure after UAPI split UAPI: x86: Fix the test_get_len tool UAPI: (Scripted) Set up UAPI Kbuild files UAPI: Partition the header include path sets and add uapi/ header directories UAPI: (Scripted) Convert #include "..." to #include <path/...> in kernel system headers UAPI: (Scripted) Convert #include "..." to #include <path/...> in drivers/gpu/ UAPI: (Scripted) Remove redundant DRM UAPI header #inclusions from drivers/gpu/. UAPI: Refer to the DRM UAPI headers with <...> and from certain headers only
2012-10-03Merge tag 'dt-for-3.7' of git://sources.calxeda.com/kernel/linuxLinus Torvalds
Pull devicetree updates from Rob Herring: - Import of latest upstream device tree compiler (dtc) - New function of_get_child_by_name - Support for #size-cells of 0 and #addr-cells of >2 - Couple of DT binding documentation updates Fix up trivial conflicts due to of_get_child_by_name() having been added next to the new of_get_next_available_child(). * tag 'dt-for-3.7' of git://sources.calxeda.com/kernel/linux: MAINTAINERS: add scripts/dtc under Devicetree maintainers dtc: import latest upstream dtc dt: Document general interrupt controller bindings dt/s3c64xx/spi: Use of_get_child_by_name to get a named child dt: introduce of_get_child_by_name to get child node by name of: i2c: add support for wakeup-source property of/address: Handle #address-cells > 2 specially DT: export of_irq_to_resource_table() devicetree: serial: Add documentation for imx serial devicetree: pwm: mxs-pwm.txt: Fix reg field annotation of: Allow busses with #size-cells=0
2012-10-03kbuild: Fix gcc -x syntaxJean Delvare
The correct syntax for gcc -x is "gcc -x assembler", not "gcc -xassembler". Even though the latter happens to work, the former is what is documented in the manual page and thus what gcc wrappers such as icecream do expect. This isn't a cosmetic change. The missing space prevents icecream from recognizing compilation tasks it can't handle, leading to silent kernel miscompilations. Besides me, credits go to Michael Matz and Dirk Mueller for investigating the miscompilation issue and tracking it down to this incorrect -x parameter syntax. Signed-off-by: Jean Delvare <jdelvare@suse.de> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: stable@vger.kernel.org Cc: Bernhard Walle <bernhard@bwalle.de> Cc: Michal Marek <mmarek@suse.cz> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-10-02UAPI: Plumb the UAPI Kbuilds into the user header installation and checkingDavid Howells
Plumb the UAPI Kbuilds into the user header installation and checking system. As the headers are split the entries will be transferred across from the old Kbuild files to the UAPI Kbuild files. The changes made in this commit are: (1) Exported generated files (of which there are currently four) are moved to uapi/ directories under the appropriate generated/ directory, thus we get: include/generated/uapi/linux/version.h arch/x86/include/generated/uapi/asm/unistd_32.h arch/x86/include/generated/uapi/asm/unistd_64.h arch/x86/include/generated/uapi/asm/unistd_x32.h These paths were added to the build as -I flags in a previous patch. (2) scripts/Makefile.headersinst is now given the UAPI path to install from rather than the old path. It then determines the old path from that and includes that Kbuild also if it exists, thus permitting the headers to exist in either directory during the changeover. I also renamed the "install" variable to "installdir" as it refers to a directory not the install program. (3) scripts/headers_install.pl is altered to take a list of source file paths instead of just their names so that the makefile can tell it exactly where to find each file. For the moment, files can be obtained from one of four places for each output directory: .../include/uapi/foo/ .../include/generated/uapi/foo/ .../include/foo/ .../include/generated/foo/ The non-UAPI paths will be dropped later. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-10-02UAPI: Remove the objhdr-y export listDavid Howells
Remove the objhdr-y export list as it is no longer used. genhdr-y should be used instead. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-10-01Merge tag 'staging-3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging tree update from Greg Kroah-Hartman: "Here is the big staging tree update for the 3.7-rc1 merge window. There are a few patches in here that are outside of the staging area, namely HID and IIO patches, but all of them have been acked by the relevant subsystem maintainers. The IIO stuff is still coming in through this tree as it hasn't entirely moved out of the staging tree, but is almost there. Other than that, there wa a ton of work on the comedi drivers to make them more readable and the correct style. Doing that removed a lot of code, but we added a new driver to the staging tree, so we didn't end up with a net reduction this time around: 662 files changed, 51649 insertions(+), 26582 deletions(-) All of these patches have been in the linux-next tree already. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'staging-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1094 commits) staging: comedi: jr3_pci: fix iomem dereference staging: comedi: drivers: use comedi_fc.h cmdtest helpers Staging: winbond: usb_free_urb(NULL) is safe Staging: winbond: checkpatch cleanup Staging: winbond: Removed undesired spaces, lines and tabs Staging: winbond: Typo corrections in comments Staging: winbond: Changed c99 comments to c89 comments staging: r8712u: Do not queue cloned skb staging: comedi: ni_mio_common: always lock in ni_ai_poll() staging: comedi: s626: add FIXME comment staging: comedi: s626: don't dereference insn->data staging: comedi: s526: fix if() check in s526_gpct_winsn() staging: comedi: s626: cleanup comments in s626_initialize() staging: comedi: s626: remove clear of kzalloc'ed data staging: comedi: s626: remove 'WDInterval' from private data staging: comedi: s626: remove 'ChargeEnabled' from private data staging: comedi: s626: remove 'IsBoardRevA' comment staging: comedi: s626: #if 0 out the "SAA7146 BUG WORKAROUND" staging: comedi: s626: remove 'allocatedBuf' from private data staging: comedi: s626: add final attach message ...
2012-10-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 updates from Martin Schwidefsky: "The main new feature is machine support for System zEC12 including transactional memory, runtime instrumentation, support for scm block devices via eadm subchannels, and support for CEX4 crypto cards. In addition there are some nice improvements: bpf jit compiler, arch backend for cmpxchg_double, relative exception table entries, dasd partition detection independent from the dasd driver ioctls, and cpu cache information in /proc/cpuinfo and /sys/device/cpu. And last but not least a series of cleanup patches from Heiko." Fix up trivial add-add conflict in arch/s390/Kconfig due to commit b952741c8079 ("cputime: Generalize CONFIG_VIRT_CPU_ACCOUNTING") * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (76 commits) s390: update defconfig s390/jump label,nss: let shared kernel support depend on !JUMP_LABEL s390/disassembler: fix decoding of risblg instruction s390/bpf,jit: add support for BPF_S_ANC_ALU_XOR_X instruction s390/traps: move call to print_modules() out of show_regs() s390/mm: mark free_initrd_mem() as __init s390/dasd: check count address during online setting drivers/s390/char/monreader.c: fix error return code s390/cmpxchg,percpu: implement cmpxchg_double() s390/percpu: implement this_cpu_add_return() s390/percpu: implement this_cpu_xchg() s390/kexec: remove CONFIG_KEXEC s390/irq: use designated initializers for irq class array s390: add uninitialized_var() to suppress false positive compiler warnings s390/crashdump: move fill_cpu_elf_notes() prototype to header file s390/process: add missing header include s390/ptrace: add missing ifdef s390/ipl,decrompressor: disable branch profiling s390/perf_events: compile only for CONFIG_64BIT s390/tape: remove even more tape block leftovers ...
2012-10-01Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf update from Ingo Molnar: "Lots of changes in this cycle as well, with hundreds of commits from over 30 contributors. Most of the activity was on the tooling side. Higher level changes: - New 'perf kvm' analysis tool, from Xiao Guangrong. - New 'perf trace' system-wide tracing tool - uprobes fixes + cleanups from Oleg Nesterov. - Lots of patches to make perf build on Android out of box, from Irina Tirdea - Extend ftrace function tracing utility to be more dynamic for its users. It allows for data passing to the callback functions, as well as reading regs as if a breakpoint were to trigger at function entry. The main goal of this patch series was to allow kprobes to use ftrace as an optimized probe point when a probe is placed on an ftrace nop. With lots of help from Masami Hiramatsu, and going through lots of iterations, we finally came up with a good solution. - Add cpumask for uncore pmu, use it in 'stat', from Yan, Zheng. - Various tracing updates from Steve Rostedt - Clean up and improve 'perf sched' performance by elliminating lots of needless calls to libtraceevent. - Event group parsing support, from Jiri Olsa - UI/gtk refactorings and improvements from Namhyung Kim - Add support for non-tracepoint events in perf script python, from Feng Tang - Add --symbols to 'script', similar to the one in 'report', from Feng Tang. Infrastructure enhancements and fixes: - Convert the trace builtins to use the growing evsel/evlist tracepoint infrastructure, removing several open coded constructs like switch like series of strcmp to dispatch events, etc. Basically what had already been showcased in 'perf sched'. - Add evsel constructor for tracepoints, that uses libtraceevent just to parse the /format events file, use it in a new 'perf test' to make sure the libtraceevent format parsing regressions can be more readily caught. - Some strange errors were happening in some builds, but not on the next, reported by several people, problem was some parser related files, generated during the build, didn't had proper make deps, fix from Eric Sandeen. - Introduce struct and cache information about the environment where a perf.data file was captured, from Namhyung Kim. - Fix handling of unresolved samples when --symbols is used in 'report', from Feng Tang. - Add union member access support to 'probe', from Hyeoncheol Lee. - Fixups to die() removal, from Namhyung Kim. - Render fixes for the TUI, from Namhyung Kim. - Don't enable annotation in non symbolic view, from Namhyung Kim. - Fix pipe mode in 'report', from Namhyung Kim. - Move related stats code from stat to util/, will be used by the 'stat' kvm tool, from Xiao Guangrong. - Remove die()/exit() calls from several tools. - Resolve vdso callchains, from Jiri Olsa - Don't pass const char pointers to basename, so that we can unconditionally use libgen.h and thus avoid ifdef BIONIC lines, from David Ahern - Refactor hist formatting so that it can be reused with the GTK browser, From Namhyung Kim - Fix build for another rbtree.c change, from Adrian Hunter. - Make 'perf diff' command work with evsel hists, from Jiri Olsa. - Use the only field_sep var that is set up: symbol_conf.field_sep, fix from Jiri Olsa. - .gitignore compiled python binaries, from Namhyung Kim. - Get rid of die() in more libtraceevent places, from Namhyung Kim. - Rename libtraceevent 'private' struct member to 'priv' so that it works in C++, from Steven Rostedt - Remove lots of exit()/die() calls from tools so that the main perf exit routine can take place, from David Ahern - Fix x86 build on x86-64, from David Ahern. - {int,str,rb}list fixes from Suzuki K Poulose - perf.data header fixes from Namhyung Kim - Allow user to indicate objdump path, needed in cross environments, from Maciek Borzecki - Fix hardware cache event name generation, fix from Jiri Olsa - Add round trip test for sw, hw and cache event names, catching the problem Jiri fixed, after Jiri's patch, the test passes successfully. - Clean target should do clean for lib/traceevent too, fix from David Ahern - Check the right variable for allocation failure, fix from Namhyung Kim - Set up evsel->tp_format regardless of evsel->name being set already, fix from Namhyung Kim - Oprofile fixes from Robert Richter. - Remove perf_event_attr needless version inflation, from Jiri Olsa - Introduce libtraceevent strerror like error reporting facility, from Namhyung Kim - Add pmu mappings to perf.data header and use event names from cmd line, from Robert Richter - Fix include order for bison/flex-generated C files, from Ben Hutchings - Build fixes and documentation corrections from David Ahern - Assorted cleanups from Robert Richter - Let O= makes handle relative paths, from Steven Rostedt - perf script python fixes, from Feng Tang. - Initial bash completion support, from Frederic Weisbecker - Allow building without libelf, from Namhyung Kim. - Support DWARF CFI based unwind to have callchains when %bp based unwinding is not possible, from Jiri Olsa. - Symbol resolution fixes, while fixing support PPC64 files with an .opt ELF section was the end goal, several fixes for code that handles all architectures and cleanups are included, from Cody Schafer. - Assorted fixes for Documentation and build in 32 bit, from Robert Richter - Cache the libtraceevent event_format associated to each evsel early, so that we avoid relookups, i.e. calling pevent_find_event repeatedly when processing tracepoint events. [ This is to reduce the surface contact with libtraceevents and make clear what is that the perf tools needs from that lib: so far parsing the common and per event fields. ] - Don't stop the build if the audit libraries are not installed, fix from Namhyung Kim. - Fix bfd.h/libbfd detection with recent binutils, from Markus Trippelsdorf. - Improve warning message when libunwind devel packages not present, from Jiri Olsa" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (282 commits) perf trace: Add aliases for some syscalls perf probe: Print an enum type variable in "enum variable-name" format when showing accessible variables perf tools: Check libaudit availability for perf-trace builtin perf hists: Add missing period_* fields when collapsing a hist entry perf trace: New tool perf evsel: Export the event_format constructor perf evsel: Introduce rawptr() method perf tools: Use perf_evsel__newtp in the event parser perf evsel: The tracepoint constructor should store sys:name perf evlist: Introduce set_filter() method perf evlist: Renane set_filters method to apply_filters perf test: Add test to check we correctly parse and match syscall open parms perf evsel: Handle endianity in intval method perf evsel: Know if byte swap is needed perf tools: Allow handling a NULL cpu_map as meaning "all cpus" perf evsel: Improve tracepoint constructor setup tools lib traceevent: Fix error path on pevent_parse_event perf test: Fix build failure trace: Move trace event enable from fs_initcall to core_initcall tracing: Add an option for disabling markers ...
2012-10-01Merge tag 'localmodconfig-v3.7-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-kconfig Pull localmodconfig fixes from Steven Rostedt: "Bill Pemberton added some changes to make streamline-config.pl work again as a stand-alone tool (outside of make localmodconfig). Also, he added a couple of updates to make the code be more "Perl proper". Added last minute fix to localyesconfig, that was the same as localmodconfig since v3.2, due to a change in the makefiles." * tag 'localmodconfig-v3.7-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-kconfig: localmodconfig: Fix localyesconfig to set to 'y' not 'm' localmodconfig: Use my variable for loop in streamline_config.pl localmodconfig: Use 3 parameter open in streamline_config.pl localmodconfig: Rework find_config in streamline_config.pl localmodconfig: Set default value for ksource in streamline_config.pl
2012-10-01localmodconfig: Fix localyesconfig to set to 'y' not 'm'Yuta Ando
The kbuild target 'localyesconfig' has been same as 'localmodconfig' since the commit 50bce3e "kconfig/streamline_config.pl: merge local{mod,yes}config". The commit expects this script generates different configure depending on target, but it was not yet implemented. So I added code that sets to 'yes' when target is 'localyesconfig'. Link: http://lkml.kernel.org/r/1349101470-12243-1-git-send-email-yuta.and@gmail.com Cc: stable@vger.kernel.org # v3.2 Cc: linux-kbuild@vger.kernel.org Signed-off-by: Yuta Ando <yuta.and@gmail.com> Signed-off-by: Steven Rostedt <rostedt@rostedt.homelinux.com>
2012-10-01dtc: import latest upstream dtcStephen Warren
This updates scripts/dtc to commit 317a5d9 "dtc: zero out new label objects" from git://git.jdl.com/software/dtc.git. This adds features such as: * /bits/ syntax for cell data. * Math expressions within cell data. * The ability to delete properties or nodes. * Support for #line directives in the input file, which allows the use of cpp on *.dts. * -i command-line option (/include/ path) * -W/-E command-line options for error/warning control. * Removal of spew to STDOUT containing the filename being compiled. * Many additions to the libfdt API. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Jon Loeliger <jdl@jdl.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull the trivial tree from Jiri Kosina: "Tiny usual fixes all over the place" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) doc: fix old config name of kprobetrace fs/fs-writeback.c: cleanup riteback_sb_inodes kerneldoc btrfs: fix the commment for the action flags in delayed-ref.h btrfs: fix trivial typo for the comment of BTRFS_FREE_INO_OBJECTID vfs: fix kerneldoc for generic_fh_to_parent() treewide: fix comment/printk/variable typos ipr: fix small coding style issues doc: fix broken utf8 encoding nfs: comment fix platform/x86: fix asus_laptop.wled_type module parameter mfd: printk/comment fixes doc: getdelays.c: remember to close() socket on error in create_nl_socket() doc: aliasing-test: close fd on write error mmc: fix comment typos dma: fix comments spi: fix comment/printk typos in spi Coccinelle: fix typo in memdup_user.cocci tmiofb: missing NULL pointer checks tools: perf: Fix typo in tools/perf tools/testing: fix comment / output typos ...
2012-09-27kconfig: replace 'oldnoconfig' with 'olddefconfig', and keep the old name as ↵Adam Lee
an alias As 67d34a6a391369269a2e5dba8a5f42cc4cd50231 said, 'oldnoconfig' doesn't set new symbols to 'n', but instead sets it to their default values. So, this patch replaces 'oldnoconfig' with 'olddefconfig', stop making people confused, and keep the old name 'oldnoconfig' as an alias, because people already are dependent on its behavior with the counter-intuitive name. Signed-off-by: Adam Lee <adam8157@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-09-27menuconfig: Assign jump keys per-page instead of globallyBenjamin Poirier
At the moment, keys 1-9 are assigned to the first 9 search results. This patch makes them assigned to the first 9 results per-page instead. We are much less likely to run out of keys that way. Signed-off-by: Benjamin Poirier <bpoirier@suse.de> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-09-27menuconfig: Do not open code textbox scroll up/downBenjamin Poirier
We don't need to explicitely use ncurses' scroll(). ncurses performs vertical-motion optimization at wrefresh() time. Using strace I confirmed that with the following patch curses still sends only the new line of text to the terminal when scrolling up/down one line at a time. Signed-off-by: Benjamin Poirier <bpoirier@suse.de> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-09-27menuconfig: Add jump keys to search resultsBenjamin Poirier
makes it possible to jump directly to the menu for a configuration entry after having searched for it with '/'. If this menu is not currently accessible we jump to the nearest accessible parent instead. After exiting this menu, the user is returned to the search results where he may jump further in or elsewhere. Signed-off-by: Benjamin Poirier <bpoirier@suse.de> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-09-27menuconfig: Extend dialog_textbox so that it can return to a scrolled positionBenjamin Poirier
We can now display other UI elements (menus) "on top" of a textbox and then seemingly come back to it in the same state it was left. Signed-off-by: Benjamin Poirier <bpoirier@suse.de> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-09-27menuconfig: Extend dialog_textbox so that it can exit on arbitrary keypressesBenjamin Poirier
The caller will be able to perform actions based on hotkeys in the displayed text. Signed-off-by: Benjamin Poirier <bpoirier@suse.de> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-09-27menuconfig: Remove superfluous conditionnalBenjamin Poirier
Because end_reached is set to 0 before the loop, the test "!end_reached" is always true and can be removed. This structure was perhaps copied from the similar one in back_lines(). Signed-off-by: Benjamin Poirier <bpoirier@suse.de> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-09-27Kbuild: use normal compression settings for tar*-pkgAndi Kleen
For large kernel configurations (like a distribution kernel) targz-pkg takes a quite long time to just do the compression. I clocked it at 15+mins for a SUSE kernel like config on a fast system. And tarxz and bzip2 are even slower. The main reason is that the script that is doing the taring sets the highest compression level (-9). When I change it to just use the defaults the gzip time for the same kernel goes down to ~3 mins. I haven't tested xz and bzip, but I expect those to be much faster too. I'm not willing to wait that long for a small compression gain. So just change the script to use the defaults. Signed-off-by: Andi Kleen <ak@linux.intel.com> Reviewed-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-09-27kbuild: Do not package /boot and /lib in make tar-pkgMichal Marek
There were reports of users destroying their Fedora installs by a kernel tarball that replaces the /lib -> /usr/lib symlink. Let's remove the toplevel directories from the tarball to prevent this from happening. Reported-by: Andi Kleen <andi@firstfloor.org> Suggested-by: Ben Hutchings <ben@decadent.org.uk> Cc: <stable@kernel.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-09-26s390/exceptions: switch to relative exception table entriesHeiko Carstens
This is the s390 port of 70627654 "x86, extable: Switch to relative exception table entries". Reduces the size of our exception tables by 50% on 64 bit builds. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-09-25Merge branch 'akpm' (sundry from Andrew)Linus Torvalds
Merge misc fixes from Andrew Morton: "One maintainer change and three bugfixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (4 commits) c/r: prctl: fix build error for no-MMU case lib/flex_proportions.c: fix corruption of denominator in flexible proportions checksyscalls: fix "here document" handling pwm-backlight: take over maintenance
2012-09-25checksyscalls: fix "here document" handlingHeiko Carstens
"echo" doesn't read from stdin, therefore the checksyscalls script didn't warn about not implemented system calls anymore since 29dc54c6 ("checksyscalls: Use arch/x86/syscalls/syscall_32.tbl as source"). Use "cat" instead of "echo" which handles this correctly. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Michal Marek <mmarek@suse.cz> Cc: H. Peter Anvin <hpa@linux.intel.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-09-23Merge branch 'rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild fixes from Michal Marek: "There are two more kbuild fixes for 3.6. One fixes a race between x86's archscripts target and the rule (re)building scripts/basic/fixdep. The second is a fix for the previous attempt at fixing make firmware_install with make 3.82. This new solution should work with any version of GNU make" * 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: x86/kbuild: archscripts depends on scripts_basic firmware: fix directory creation rule matching with make 3.80
2012-09-21firmware: fix directory creation rule matching with make 3.80Mark Asselstine
Since make 3.80 doesn't support secondary expansion it uses a fallback rule to create firmware directories which is matched after primary expansion of the $(installed-fw) rule's prerequisite. Commit 6c7080a61fc7 [firmware: fix directory creation rule matching with make 3.82] changed the expression generated after primary expansion such that the fallback was not matched. Updating the fallback rule to match the new look primary expansion is not an option for various reasons. The trailing slash added here to $(INSTALL_FW_PATH)/. while defining installed-fw-dirs fixes builds with make 3.82 since this will provide a matching rule for $(INSTALL_FW_PATH)/$$(dir %) when % is in the base firmware directory (ie. $(dir %) gives './'). Versions of make prior to 3.82 will strip this trailing slash along with the one generated by $(dir %) when % is in the base firmware directory and as such continue to function as before. Signed-off-by: Mark Asselstine <mark.asselstine@windriver.com> Tested-by: Jan Beulich <jbeulich@suse.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-09-16Merge 3.6-rc6 into staging-nextGreg Kroah-Hartman
This pulls in the staging tree fixes in 3.6-rc6 into our branch to resolve the merge issues. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-13Merge branch 'core/rcu' into perf/coreIngo Molnar
Steve Rostedt asked for the merge of a single commit, into both the RCU and the perf/tracing tree: | Josh made a change to the tracing code that affects both the | work Paul McKenney and I are currently doing. At the last | Kernel Summit back in August, Linus said when such a case | exists, it is best to make a separate branch based off of his | tree and place the change there. This way, the repositories | that need to share the change can both pull them in and the | SHA1 will match for both. Whichever branch is pulled in first | by Linus will also pull in the necessary change for the other | branch as well. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-09-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lliubbo/blackfin Pull blackfin updates from Bob Liu: "One kbuild and a smp build fix." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lliubbo/blackfin: kbuild: add symbol prefix arg to kallsyms blackfin: smp: adapt to generic smp helpers
