Do not update index on read only media.
Idea published by Christian Kujau <lists@nerdbynature.de>.
Cc: Nico Schottelius <nico@ikn.schottelius.org>
Cc: Christian Kujau <lists@nerdbynature.de>
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: (30 commits)
[S390] wire up sys_perf_counter_open
[S390] wire up sys_rt_tgsigqueueinfo
[S390] ftrace: add system call tracer support
[S390] ftrace: add function graph tracer support
[S390] ftrace: add function trace mcount test support
[S390] ftrace: add dynamic ftrace support
[S390] kprobes: use probe_kernel_write
[S390] maccess: arch specific probe_kernel_write() implementation
[S390] maccess: add weak attribute to probe_kernel_write
[S390] profile_tick called twice
[S390] dasd: forward internal errors to dasd_sleep_on caller
[S390] dasd: sync after async probe
[S390] dasd: check_characteristics cleanup
[S390] dasd: no High Performance FICON in 31-bit mode
[S390] dcssblk: revert devt conversion
[S390] qdio: fix access beyond ARRAY_SIZE of irq_ptr->{in,out}put_qs
[S390] vmalloc: add vmalloc kernel parameter support
[S390] uaccess: use might_fault() instead of might_sleep()
[S390] 3270: lock dependency fixes
[S390] 3270: do not register with tty_register_device
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic:
add generic lib/checksum.c
asm-generic: add a generic uaccess.h
asm-generic: add generic NOMMU versions of some headers
asm-generic: add generic atomic.h and io.h
asm-generic: add legacy I/O header files
asm-generic: add generic versions of common headers
asm-generic: make bitops.h usable
asm-generic: make pci.h usable directly
asm-generic: make get_rtc_time overridable
asm-generic: rename page.h and uaccess.h
asm-generic: rename atomic.h to atomic-long.h
asm-generic: add a generic unistd.h
asm-generic: add generic ABI headers
asm-generic: add generic sysv ipc headers
asm-generic: introduce asm/bitsperlong.h
asm-generic: rename termios.h, signal.h and mman.h
This patch allows a virtio driver to use VIRTIO_DEV_ANY_ID for the
device id. This will be used by a test module that can be bound to
any virtio device.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Fixes a merge conflict against the x86 tree caused by a fix to
atomic.h which I renamed to atomic_long.h.
Dynamic ftrace support for s390.
A new architecture should only define a minimal set of system
calls while still providing the full functionality. This version
of unistd.h has gone through intensive review to make sure that
by default it only enables syscalls that do not already have
a more featureful replacement.
It is modeled after the x86-64 version of unistd.h, which unifies
the syscall number definition and the actual system call table
in a single file, in order to keep them synchronized much more
easily.
This first version still keeps legacy system call definitions
around, guarded by various #ifdefs, and with numbers larger
than 1024. The idea behind this is to make it easier for
new architectures to transition from a full list to the reduced
set. In particular, the new microblaze architecture that should
migrate to using the generic ABI headers can at least use an
existing uClibc source tree without major rewrites during the
conversion.
* 'tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (244 commits)
Revert "x86, bts: reenable ptrace branch trace support"
tracing: do not translate event helper macros in print format
ftrace/documentation: fix typo in function grapher name
tracing/events: convert block trace points to TRACE_EVENT(), fix !CONFIG_BLOCK
tracing: add protection around module events unload
tracing: add trace_seq_vprint interface
tracing: fix the block trace points print size
ring-buffer: fix ret in rb_add_time_stamp
ring-buffer: pass in lockdep class key for reader_lock
tracing: add annotation to what type of stack trace is recorded
tracing: fix multiple use of __print_flags and __print_symbolic
tracing/events: fix output format of user stack
tracing/events: fix output format of kernel stack
tracing/trace_stack: fix the number of entries in the header
ring-buffer: discard timestamps that are at the start of the buffer
ring-buffer: try to discard unneeded timestamps
ring-buffer: fix bug in ring_buffer_discard_commit
ftrace: do not profile functions when disabled
tracing: make trace pipe recognize latency format flag
* 'x86-kbuild-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (46 commits)
x86, boot: add new generated files to the appropriate .gitignore files
x86, boot: correct the calculation of ZO_INIT_SIZE
x86-64: align __PHYSICAL_START, remove __KERNEL_ALIGN
x86, boot: correct sanity checks in boot/compressed/misc.c
x86: add extension fields for bootloader type and version
x86, defconfig: update kernel position parameters
x86, defconfig: update to current, no material changes
x86: make CONFIG_RELOCATABLE the default
x86: default CONFIG_PHYSICAL_START and CONFIG_PHYSICAL_ALIGN to 16 MB
x86: document new bzImage fields
x86, boot: make kernel_alignment adjustable; new bzImage fields
x86, boot: remove dead code from boot/compressed/head_*.S
x86, boot: use LOAD_PHYSICAL_ADDR on 64 bits
x86, boot: make symbols from the main vmlinux available
x86, boot: determine compressed code offset at compile time
x86, boot: use appropriate rep string for move and clear
x86, boot: zero EFLAGS on 32 bits
x86, boot: set up the decompression stack as early as possible
x86, boot: straighten out ranges to copy/zero in compressed/head*.S
x86, boot: stylistic cleanups for boot/compressed/head_64.S
Fixed trivial conflict in arch/x86/configs/x86_64_defconfig manually
Various cleanups of scripts/kernel-doc:
- don't use **/ as an ending kernel-doc block since it's not preferred;
- typos/spellos
- add whitespace around ==, after comma, & around . operator;
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
When we had code like this in a header unifdef failed to
deduct that the expression was always false - and we had code exported
that was not intended for userspace.
#if defined(__KERNEL__) && !defined(__ASSEMBLY__)
int a;
#endif
This commit implment support in unidef which allows it to work out if
an #if expression always evaluates true or false for symbols which
are being undefined/always defined.
The patch is slightly more complicated than I'd hoped because unifdef
needs to see lines fully evaluated - doing otherwise causes it to
mark the line as "dirty" and copy it over no matter what.
'extern' checking information is not clear, refine it.
Plus, fix a comment.
Signed-off-by: WANG Cong <amwang@redhat.com>
[sam: redid the extern error message]
I'm trying to install kernel headers to build a cross-toolchain, but got
the following:
make ARCH=arm
INSTALL_HDR_PATH=/work/psl/eldk-builds/arm-2009-04-21/work/var/tmp/crosstool-0.43-3-root/usr/crosstool/gcc-4.2.2-glibc-20070515T2025-eldk/
+arm-linux-gnueabi/arm-linux-gnueabi/
headers_check
CHECK include/linux/raid (2 files)
CHECK include/linux/spi (1 files)
CHECK include/linux/sunrpc (1 files)
CHECK include/linux/tc_act (6 files)
CHECK include/linux/tc_ematch (4 files)
CHECK include/linux/usb (8 files)
make[2]: execvp: /bin/sh: Argument list too long
make[2]: ***
[/work/psl/eldk-builds/arm-2009-04-21/work/var/tmp/crosstool-0.43-3-root/usr/crosstool/gcc-4.2.2-glibc-20070515T2025-eldk/arm-linux-gnueab
+i/arm-linux-gnueabi//include/linux/.check]
Error 127
make[1]: *** [linux] Error 2
make: *** [headers_check] Error 2
Introduce use of xargs to fix this.
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
The '-e' option to echo and brace expansion are not guaranteed to be supported
by a POSIX-compliant /bin/sh (e.g. dash)
Signed-off-by: dann frazier <dannf@debian.org>
As requested by Guennadi Liakhovetski
Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Correct the regular expression in scripts/headers_check.pl to include '_'
as a valid character in the class; otherwise, the check will report a
"leaked" symbol of CONFIG_A_B_C as merely CONFIG_A.
This patch will make no difference whatsoever in the current kernel tree
as the call to the perl routine that does that check is currently
commented out:
&check_include();
&check_asm_types();
&check_sizetypes();
&check_prototypes();
# Dropped for now. Too much noise &check_config();
However, I noticed that problem when I was building the yum downloadable
kernel source rpm for fedora 11 (beta), which *does* run that check, and
that's where the problem became obvious.
Regardless of KCONFIG_AUTOCONFIG, the filename written as a Make target
into "include/config/auto.conf.cmd" was always the default one.
Of course this doesn't make it work for the Kernel kbuild system, since
there the filename is hardcoded at several places in the Makefiles.
Signed-off-by: Markus Heidelberg <markus.heidelberg@web.de>
Rather than hardcoding ".config" use conf_get_configname(), which also
respects the environment variable KCONFIG_CONFIG.
This fixes "make silentoldconfig" when KCONFIG_CONFIG is used and also
suggests the given filename for "Load" and "Save as" in qconf.
QApplication::desktop() returns a pointer to QDesktopWidget, not to
QWidget.
Fixes the following compiler error after a quick conversion with 'qt3to4',
which occured with g++ 3.4.6 and 4.1.2, but not anymore with 4.3.2.
scripts/kconfig/qconf.cc: In constructor 'ConfigMainWindow::ConfigMainWindow()':
scripts/kconfig/qconf.cc:1289: error: cannot convert 'QDesktopWidget*' to 'QWidget*' in initialization
They are defined in the 'Qt' namespace.
Fixes the following compiler errors after a quick conversion with 'qt3to4',
scripts/kconfig/qconf.cc: In member function 'virtual void ConfigLineEdit::keyPressEvent(QKeyEvent*)':
scripts/kconfig/qconf.cc:311: error: 'Key_Escape' was not declared in this scope
scripts/kconfig/qconf.cc:313: error: 'Key_Return' was not declared in this scope
scripts/kconfig/qconf.cc:314: error: 'Key_Enter' was not declared in this scope
scripts/kconfig/qconf.cc: In member function 'virtual void ConfigList::keyPressEvent(QKeyEvent*)':
scripts/kconfig/qconf.cc:653: error: 'Key_Escape' was not declared in this scope
scripts/kconfig/qconf.cc:666: error: 'Key_Return' was not declared in this scope
scripts/kconfig/qconf.cc:667: error: 'Key_Enter' was not declared in this scope
scripts/kconfig/qconf.cc:681: error: 'Key_Space' was not declared in this scope
scripts/kconfig/qconf.cc:684: error: 'Key_N' was not declared in this scope
scripts/kconfig/qconf.cc:687: error: 'Key_M' was not declared in this scope
scripts/kconfig/qconf.cc:690: error: 'Key_Y' was not declared in this scope
scripts/kconfig/qconf.cc:1329: error: 'CTRL' was not declared in this scope
scripts/kconfig/qconf.cc:1329: error: 'Key_Q' was not declared in this scope
scripts/kconfig/qconf.cc:1331: error: 'Key_L' was not declared in this scope
scripts/kconfig/qconf.cc:1333: error: 'Key_S' was not declared in this scope
scripts/kconfig/qconf.cc:1340: error: 'Key_F' was not declared in this scope
They were used as QSplitter::Horizontal resp. QSplitter::Vertical, but
scripts/kconfig/qconf.cc: In constructor 'ConfigSearchWindow::ConfigSearchWindow(ConfigMainWindow*, const char*)':
scripts/kconfig/qconf.cc:1213: error: 'Vertical' is not a member of 'QSplitter'
scripts/kconfig/qconf.cc:1304: error: 'Horizontal' is not a member of 'QSplitter'
scripts/kconfig/qconf.cc:1311: error: 'Vertical' is not a member of 'QSplitter'
These compiler warnings occure when adding -Wall to HOSTCXXFLAGS in
/Makefile
scripts/kconfig/qconf.h: In constructor ‘ConfigInfoView::ConfigInfoView(QWidget*, const char*)’:
scripts/kconfig/qconf.h:274: warning: ‘ConfigInfoView::menu’ will be initialized after
scripts/kconfig/qconf.h:273: warning: ‘symbol* ConfigInfoView::sym’
scripts/kconfig/qconf.cc:922: warning: when initialized here
scripts/kconfig/qconf.cc: In member function ‘void ConfigMainWindow::setMenuLink(menu*)’:
scripts/kconfig/qconf.cc:1498: warning: enumeration value ‘menuMode’ not handled in switch
scripts/kconfig/qconf.cc:1498: warning: enumeration value ‘listMode’ not handled in switch
scripts/kconfig/qconf.cc: In member function ‘void ConfigMainWindow::saveSettings()’:
scripts/kconfig/qconf.cc:1664: warning: enumeration value ‘menuMode’ not handled in switch
scripts/kconfig/qconf.cc:1664: warning: enumeration value ‘listMode’ not handled in switch
- getcwd returns path without a slash at the end, add the slash
- add KBUILD_SRC env support, so that we can specify path for
kernel (to know where scripts/kernel-doc resides) and SRCTREE
(for searching files referenced in .tmpl) separately
[v2]
- use KBUILD_SRC instead of a newly introduced environment variable
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
'drop' variable is unused.
'ppc' and 'sparc64' directories don't exist in arch/,
and I think their headers can be well exported now, so
just remove them.
- add .init.rodata to INIT_DATA, and group all initconst flavors
together
- move strings generated from __setup_param() into .init.rodata
- add .*init.rodata to modpost's sets of init sections
- make modpost warn about references between meminit and cpuinit
as well as memexit and cpuexit sections (as CPU and memory
hotplug are independently selectable features)
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Latest Debian policy is 3.8.1.
Even if we are not yet compliant to it strive for the latest.
Signed-off-by: maximilian attems <max@stro.at>
Signed-off-by: Frans Pop <elendil@planet.nl>
Acked-by: Andres Salomon <dilinger@debian.org>
Section "base" has been removed, the base is defined by Priority field.
For Squeeze the section should be "kernel", but as that's not yet
supported for Sarge and Etch we stay with admin for now.
Cc: Andres Salomon <dilinger@debian.org>
kernel-image naming has been dropped for the Lenny release
and was only transitional for Etch.
As it builds modules it provides linux-modules-$version.
The binary package that make deb-pkg creates is a linux-image.
To be fixed may also be the addition of $DEB_ARCH.
The Source: field is defined as the source package in the package
archive from which a binary packages are built. As deb-pkg does not
generate a source package, we should avoid to use any existing source
packages here.
Acked-by: maximilian attems <max@stro.at>
Try harder to find email and maintainer name.
Debian's own devscripts all use DEBEMAIL or DEBFULLNAME prior to an
eventual EMAIL or NAME environment variable. Match their logic.
"Anonymous" sounds nicer then "Kernel Compiler" if no name is found.
On Thursday 23 April 2009, Frans Pop wrote:
Add a basic debian/copyright to the binary packages.
Based on an earlier patch from Maximilian Attems.
Hook scripts in the default directory /etc/kernel are also executed by
official Debian kernel packages as well as kernel packages created using
make-kpkg. Allow to specify an alternative hook scripts directory by
exporting the environment variable KDEB_HOOKDIR.
Allow to specify a custom revision for the generated .deb by
exporting the environment variable KDEB_PKGVERSION.
scripts
The Debian packaging scripts created by the deb-pkg target do not pass
on the standard Debian maintainer script parameters to hook scripts,
which means that those scripts cannot tell whether they are being called
during e.g. install vs. upgrade, or removal vs. purge of the package.
As there are several variantions in how hook scripts are called from
kernel packages, we pass the parameters in the environment variable
DEB_MAINT_PARAMS rather than as extra arguments.
Bump version of builddep script to 1.3.
Not all architectures prepend the $(boot) path in $(KBUILD_IMAGE).
Allow for that fact in the builddeb script. Example is arm.
Factor out code to build package into separate function and
only write "source" section for the debian/control file once.
Minor coding style improvements and typo fix in leading comment.
Implement support for comment entries within choice groups. Comment entries
are displayed visually distinct from normal configs, and selecting them is
a no-op.
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
Cc: Roman Zippel <zippel@linux-m68k.org>
Produce correct output for
- tagged commit (v2.6.30-rc6)
- past tagged commit (v2.6.30-rc5-299-g7c7327d)
- no tag
Allow the compression commands in Kbuild (i.e. gzip, bzip2, lzma) to
take multiple input files and emit the concatenated compressed
output. This avoids an intermediate step when a kernel image is built
from multiple components, such as the relocatable x86-32 kernel.
Sam Ravnborg integrated the bin_size script into the Makefile.
[ Impact: new build feature, not yet used ]
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Merge reason: tracing/core was on a .30-rc1 base and was missing out on
on a handful of tracing fixes present in .30-rc5-almost.
The only references in the kernel to the .text.sched section are in
recordmcount.pl. Since the code it has is intended to be example code
it should refer to real kernel sections. So change it to .sched.text
instead.
[ Impact: consistency in comments ]
Signed-off-by: Tim Abbott <tabbott@mit.edu>
LKML-Reference: <1241136371-10768-1-git-send-email-tabbott@mit.edu>
mips emit the following debug sections:
.mdebug* and .pdr
They were included in the check for non-allocatable section
and caused modpost to warn.
Manuel Lauss suggested to fix this by adding the relevant
sections to the list of sections we do not check.
Reported-by: Manuel Lauss <mano@roarinelk.homelinux.net>
Jean reported that he saw one warning for each module like the one below:
WARNING: arch/x86/kernel/cpu/cpufreq/acpi-cpufreq.o (.comment.SUSE.OPTs): unexpected non-allocatable section.
The warning appeared with the improved version of the
check of the flags in the sections.
That check already ignored sections named ".comment" - but SUSE store
additional info in the comment section and has named it in a SUSE
specific way. Therefore modpost failed to ignore the section.
The fix is to extend the pattern so we ignore all sections
that start with the name ".comment.".
Reported-by: Jean Delvare <khali@linux-fr.org>
Tested-by: Jean Delvare <khali@linux-fr.org>
The missing TO_NATIVE(sechdrs[i].sh_flags) was causing many
unexpected non-allocatable section warnings when cross-compiling
for an architecture with a different endianness.
Fix endianness of all the fields in the ELF header and
section headers, not just some of them so we are not
hit by this anohter time.
Signed-off-by: Anders Kaseorg <andersk@mit.edu>
Reported-by: Sean MacLennan <smaclennan@pikatech.com>
Tested-by: Sean MacLennan <smaclennan@pikatech.com>
