Correct spelling in the kfree reports.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Signed-off-by: Andy Whitcroft <apw@shadowen.org>
usb_free_urb() can take a NULL, so let's check and warn about that.
Check to see if the block/statement which a condition or loop introduces
is indented correctly.
and for
Extend the trailing statement checks to report a trailing semi-colon ';'
as we really want it on the next line and indented so it is really really
obvious. Also extend the tests to include while and for.
Check on the spacing before square brackets. We should only allow spaces
there if this is part of a type definition or an initialialiser.
Report trailing statements on case and default lines.
searchability
Allow printk strings to break the 80 character width limits, thus keeping
them complete and searchable.
Fix end of statement location. Where the last line of the statement is
replaced we are miss reporting the newly added replacement an incorrectly
indented trailing statement for the negative context. We are also
incorrectly reporting negative statements generally.
We are incorrectly counting the lines in a block while accumulating
the trailing lines in a macro statement, leading to false positives.
Fix end of block handling and general counting for negative context lines.
When we see a goto we enter unary context. For example:
goto *h;
associated comments
When looking for an associated comment they may be suffixed by a macro
continuation. Ignore this.
We are false matching __asm__ as a type, and then tripping the external
function checks. Squash.
[apw@shadowen.org: generalise pattern and add tests]
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Some types such as typedefs may overlap real identifiers. Be more
targetted about when a type can really exist. Where it cannot let it be
an identifier. This prevents false reporting of the minus '-' in unary
context in the following:
foo[bar->bool - 1];
Casts require parentheses so it is possible to have something like this:
return (int)(*a);
This miss trips the complexity function. Ensure that the two separate
parenthesised sections are not coelesced.
Trying to compile the v850 port brings many compile errors, one of them exists
since at least kernel 2.6.19.
There also seems to be noone willing to bring this port back into a usable
state.
This patch therefore removes the v850 port.
If anyone ever decides to revive the v850 port the code will still be
available from older kernels, and it wouldn't be impossible for the port to
reenter the kernel if it would become actively maintained again.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Acked-by: Greg Ungerer <gerg@uclinux.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (79 commits)
arm: bus_id -> dev_name() and dev_set_name() conversions
sparc64: fix up bus_id changes in sparc core code
3c59x: handle pci_name() being const
MTD: handle pci_name() being const
HP iLO driver
sysdev: Convert the x86 mce tolerant sysdev attribute to generic attribute
sysdev: Add utility functions for simple int/ulong variable sysdev attributes
sysdev: Pass the attribute to the low level sysdev show/store function
driver core: Suppress sysfs warnings for device_rename().
kobject: Transmit return value of call_usermodehelper() to caller
sysfs-rules.txt: reword API stability statement
debugfs: Implement debugfs_remove_recursive()
HOWTO: change email addresses of James in HOWTO
always enable FW_LOADER unless EMBEDDED=y
uio-howto.tmpl: use unique output names
uio-howto.tmpl: use standard copyright/legal markings
sysfs: don't call notify_change
sysdev: fix debugging statements in registration code.
kobject: should use kobject_put() in kset-example
kobject: reorder kobject to save space on 64 bit builds
When a kernel was rebuilt, the previous Module.markers was not cleared.
It caused markers with different format strings to appear as duplicates
when a markers was changed. This problem is present since
scripts/mod/modpost.c started to generate Module.markers, commit
b2e3e658b344c6bcfb8fb694100ab2f2b5b2edb0
It therefore applies to 2.6.25, 2.6.26 and linux-next.
I merely merged the patches from Roland, Wenji and Takashi here.
Credits to
Roland McGrath <roland@redhat.com>
Wenji Huang <wenji.huang@oracle.com>
and
Takashi Nishiie <t-nishiie@np.css.fujitsu.com>
for providing the individual fixes.
- Changelog :
- Integrated Takashi's Makefile modification to clear Module.markers upon
make clean.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Cc: Roland McGrath <roland@redhat.com>
Cc: Wenji Huang <wenji.huang@oracle.com>
Cc: Takashi Nishiie <t-nishiie@np.css.fujitsu.com>
Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x]
Along with the non-modalias conformant "pnp:*" aliases, we add "acpi:*"
entries to PNP drivers, to allow module autoloading by ACPI PNP device
entries, which export proper modalias information, without any specific
userspace modprobe mangling.
Cc: Adam Belay <ambx1@neo.rr.com>
Cc: Thomas Renninger <trenn@suse.de>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Also fix unwanted rebuilds of the firmware/ihex2fw tool by including
the .ihex2fw.cmd file when present.
Reported-and-tested-by: Wang Chen <wangchen@cn.fujitsu.com>
* 'for-2.6.27' of git://git.infradead.org/users/dwmw2/firmware-2.6: (64 commits)
firmware: convert sb16_csp driver to use firmware loader exclusively
dsp56k: use request_firmware
edgeport-ti: use request_firmware()
edgeport: use request_firmware()
vicam: use request_firmware()
dabusb: use request_firmware()
cpia2: use request_firmware()
ip2: use request_firmware()
firmware: convert Ambassador ATM driver to request_firmware()
whiteheat: use request_firmware()
ti_usb_3410_5052: use request_firmware()
emi62: use request_firmware()
emi26: use request_firmware()
keyspan_pda: use request_firmware()
keyspan: use request_firmware()
ttusb-budget: use request_firmware()
kaweth: use request_firmware()
smctr: use request_firmware()
firmware: convert ymfpci driver to use firmware loader exclusively
firmware: convert maestro3 driver to use firmware loader exclusively
Fix up trivial conflicts with BKL removal in drivers/char/dsp56k.c and
drivers/char/ip2/ip2main.c manually.
sound/pci/Kconfig
* 'tracing/for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (228 commits)
ftrace: build fix for ftraced_suspend
ftrace: separate out the function enabled variable
ftrace: add ftrace_kill_atomic
ftrace: use current CPU for function startup
ftrace: start wakeup tracing after setting function tracer
ftrace: check proper config for preempt type
ftrace: trace schedule
ftrace: define function trace nop
ftrace: move sched_switch enable after markers
ftrace: prevent ftrace modifications while being kprobe'd, v2
fix "ftrace: store mcount address in rec->ip"
mmiotrace broken in linux-next (8-bit writes only)
ftrace: avoid modifying kprobe'd records
ftrace: freeze kprobe'd records
kprobes: enable clean usage of get_kprobe
ftrace: build fix with gcc 4.3
namespacecheck: fixes
ftrace: fix "notrace" filtering priority
ftrace: fix printout
Add modalias and subchannel type attributes for all subchannels.
I/O subchannel specific attributes are now created in
io_subchannel_probe(). modalias and subchannel type are also
added to the uevent for the css bus. Also make the css modalias
known.
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Not the straight conversion to binary which objcopy can do for us, but
actually representing each record with its original {addr, length},
because some drivers need that information preserved.
Fix up 'firmware_install' to be able to build $(hostprogs-y) too.
For 'make modules_install', install any firmware required by
the modules which are being installed.
Also add a 'make firmware_install' target which doesn't depend on the
configuration, but installs _all_ available in-kernel-tree firmware into
$(INSTALL_FW_PATH), which defaults to /lib/firmware. This is intended
for distributors to make arch-independent (and config-independent)
packages containing firmware.
Kumar Gala <galak@kernel.crashing.org> wrote:
We have a case in powerpc in which we want to link some library
routines with all module objects. The routines are intended for
handling out-of-line function call register save/restore so having
them as EXPORT_SYMBOL() is counter productive (we do also need to
link the same "library" code into the kernel).
Without this patch a powerpc build would error out and fail
to build modules with the added register save/restore module.
There were two obvious solutions:
1) To link the .o file before the modpost stage
2) To ignore the symbols in modpost
Option 1) was ruled out because we do not have any separate
linking stage for single file modules.
This patch implements option 2 - and do so only for powerpc.
The symbols we ignore are all undefined symbols named:
_restgpr_*, _savegpr_*, _rest32gpr_*, _save32gpr_*
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Cc: Kumar Gala <galak@kernel.crashing.org>
This version is a bit of a whopper. This version brings a few new checks,
improvements to a number of checks mostly through modifications to the
way types are parsed, several fixes to quote/comment handling, as well as
the usual slew of fixes for false positives.
Of note:
- return is not a function and is now reported,
- preprocessor directive detection is loosened to match C99 standard,
- we now intuit new type modifiers, and
- comment handling is much improved
Andy Whitcroft (18):
Version: 0.19
fix up a couple of missing newlines in reports
colon to parenthesis spacing varies on asm
values: #include is a preprocessor statement
quotes: fix single character quotes at line end
add typedef exception for the non-pointer "function types"
kerneldoc parameters must be on one line, relax line length
types: word boundary is not always required
improved #define bracketing reports
uninitialized_var is an annotation not a function name
possible types: add possible modifier handling
possible types: fastcall is a type modifier
types: unsigned is not a modifier on all types
static/external initialisation to zero should allow modifiers
checkpatch: fix recognition of preprocessor directives -- part 2
comments: fix inter-hunk comment tracking
do not report include/asm/foo.h use in include/linux/foo.h
return is not a function -- tighten test
[jengelh@computergmbh.de: fix recognition of preprocessor directives]
Cc: Jan Engelhardt <jengelh@computergmbh.de>
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes:
kbuild: fix $(src) assignmnet with external modules
When we introduced support for KBUILD_EXTRA_SYMBOLS
we started to include the externam module's kbuild
file when doing the final modpost step.
As external modules often do:
ccflags-y := -I$(src)
We had problems because $(src) was unassinged and
gcc then used the next parameter for -I resulting in
strange build failures.
Fix is to assign $(src) and $(obj) when building
external modules.
This fixes: http://bugzilla.kernel.org/show_bug.cgi?id=10798
Cc: Tvrtko <tvrtko.ursulin@sophos.com>
Cc: Andrea Arcangeli <andrea@qumranet.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
.. because it is.
These magic greps and hacks in ver_linux to get the gcc version always break after some gcc releases.
Since now gcc >4.3 allows compiling with '--with-pkgversion' ( which can be everything 'My Cool Gcc' or something )
ver_linux will report random junk for these.
Simply use 'gcc -dumpversion' to get the gcc version which should always work.
Signed-off-by: Gabriel C <nix.or.die@googlemail.com>
We currently have a way to add special CFLAGS to code, but we do not have a
way to remove them if needed.
With the case of ftrace, some files should simply not be profiled. Adding
the -pg flag to these files is simply a waste, and adding "notrace" to each
and every function is ugly.
Currently we put in "Makefile turd" [1] to stop the compiler from adding -pg
to certain files. This was clumsy and awkward.
This patch now adds the revese of CFLAGS_(basename).o with
CFLAGS_REMOVE_(basename).o. This allows developers to prevent certain
CFLAGS from being used to compile files. For example, we can now do
CFLAGS_REMOVE_string.o = -pg
to remove the -pg option from the string.o file in the lib directory.
Note: a space delimited list of options may be added to the REMOVE macro.
[1] - what David Miller called the workaronud to remove -pg
Signed-off-by: Steven Rostedt <srostedt@redhat.com>
1) The field 'len' of the 'gstr' structure seems to track the size of the memory
already allocated for the "growable string". So the value of this field should be
the same as the 'malloc()' just above, shouldn't it ?
Signed-off-by: Christophe Jaillet <christophe.jaillet@wanadoo.fr>
Allow for unnamed bit-fields and skip them instead of printing an
erroneous warning message for them, such as:
Warning(include/asm-s390/cio.h:103): No description found for parameter 'u32'
which contains:
struct tm_scsw {
u32 :1;
Andi Kleen <andi@firstfloor.org>
reported that he saw a lot of symbols like this:
0000000000000b24 N DW.aio.h.903a6d92.2
0000000000000bce N DW.task_io_accounting.h.8d8de327.0
0000000000000bec N DW.hrtimer.h.c23659c6.0
in his System.map / kallsyms output.
Simple solution is to skip all debugging
symbols (they are marked 'N').
Cc: Paulo Marques <pmarques@grupopie.com>
Disable modpost warnings for linkonce sections
My build gives lots of warnings like
WARNING: sound/core/snd.o (.gnu.linkonce.wi.mpspec_def.h.30779716): unexpected section name.
The (.[number]+) following section name are ld generated and not expected.
Did you forget to use "ax"/"aw" in a .S file?
Note that for example <linux/init.h> contains
section definitions for use in .S files.
But for .linkonce. duplicated sections are actually ok and expected.
So just disable the warning for this case.
Acked-by: Timur Tabi <timur@freescale.com>
Not all device types need a wildcard at the end of their module
aliases. In particular, for i2c module aliases, the trailing wildcard
is not only unneeded, it could also cause the wrong driver to be
loaded.
As I2C devices have no IDs, i2c module aliases are simple, arbitrary
device names. For example:
$ /sbin/modinfo lm90
filename: /lib/modules/2.6.25-git18/kernel/drivers/hwmon/lm90.ko
author: Jean Delvare <khali@linux-fr.org>
description: LM90/ADM1032 driver
license: GPL
vermagic: 2.6.25-git18 mod_unload
depends: hwmon
alias: i2c:lm90*
alias: i2c:adm1032*
alias: i2c:lm99*
alias: i2c:lm86*
alias: i2c:max6657*
alias: i2c:adt7461*
alias: i2c:max6680*
This would cause trouble if one I2C chip name matches the beginning of
another I2C chip name and both chips are supported by different
drivers. For example, an i2c device named lm9042 would cause the lm90
driver to be loaded, while it doesn't support that device. This case
has yet to be seen in practice, but still, I'd like to fix it now. The
cleanest fix is to remove the trailing wildcard from i2c module aliases.
Here's a patch doing this.
Not all device type aliases need a trailing wildcard, in particular
the i2c aliases don't. Don't add a wildcard by default in do_table(),
instead let each device type handler add it if needed.
I have tested types acpi, dmi, eisa, i2c, ide, ieee1394, input, pci,
pcmcia, platform, pnp, scsi, serio, ssb and usb. Other types (ccw, of,
vio, parisc, sdio and virtio) are untested.
Acked-by: Jochen Friedrich <jochen@scram.de>
OS-X shell did not like 'echo -e' so implement
suggestion from Al Viro to use a more portable construct.
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Acked-By: Timur Tabi <timur@freescale.com>
Pointed out by Paulo:
"When I wrote this initially, it was a mistake to add a Changelog in
the first place, but I didn't know better at the time.
If you're going to make changes to this file, please remove all the
Changelog, instead of adding more entries to it. The 'Changelog'
should be kept by the version control system, and not the source code
itself."
Signed-off-by: Bryan Wu <cooloney@kernel.org>
Acked-by: Paulo Marques <pmarques@grupopie.com>
Based on earlier work by Jon Smirl and Jochen Friedrich.
This patch allows new-style i2c chip drivers to have alias names using
the official kernel aliasing system and MODULE_DEVICE_TABLE(). At this
point, the old i2c driver binding scheme (driver_name/type) is still
supported.
Cc: Jochen Friedrich <jochen@scram.de>
Cc: Jon Smirl <jonsmirl@gmail.com>
Cc: Kay Sievers <kay.sievers@vrfy.org>
This version brings a few fixes for the extern checks, and a couple of
new checks.
Of note:
- false is now recognised as a 0 assignment in static/external
assignments,
- printf format strings including %L are reported,
- a number of fixes for the extern in .c file detector which had
temporarily lost its ability to detect variables; undetected due to
the loss of its test.
Andy Whitcroft (8):
Version: 0.18
false should trip 0 assignment checks
tests: reinstate missing tests
tests: allow specification of the file extension for a test
fix extern checks for variables
check for and report %Lu, %Ld, and %Li
ensure we only start a statement on lines with some content
extern spacing
This version brings improvements to external declaration detection, fixes to
quote tracking, fixes to unary tracking, some clarification of wording, and
Of note:
- much better unary tracking across preprocessor directives
- UTF8 checks highlight the character at fault
- widening of mutex detection
Andy Whitcroft (17):
Version: 0.17
values: __attribute__ carries through the previous type
quotes: should only follow "positive" lines
clarify the indent tabs over spaces wording
loosen NR_CPUS check for array range initialisers
detect external function declarations without an extern prefix
function declaration arguments should be with the identifier
DEFINE_MUTEX should report in line with struct mutex
NR_CPUS is valid in preprocessor statements
comment detection should not start on the @@ line
types: add support for #undef
tighten mutex/completion reports to usage
allow export of function pointers
values: preprocessor #define is out of line maintain values
values: #define does not always have parentheses
unary '*' may be const
utf8 checks should report location of the invalid character
Wolfram Sang (1):
make checkpatch.pl really skip <asm/irq.h>
The new version of indent supports positioning labels in column 1
using "-il0"
http://www.nabble.com/Release-2.2.10-of-GNU-Indent-td15990700.html
Add "-il0" if indent version >= 2.2.10
Acked-by: Alan Cox <alan@redhat.com>
As choice dependency are now fully checked, it's quite easy to add support
for named choices. This lifts the restriction that a choice value can only
appear once, although it still has to be within the same group,
but multiple choices can be joined by giving them a name.
While at it I cleaned up a little the choice type logic to simplify it a
bit.
Signed-off-by: Roman Zippel <zippel@linux-m68k.org>
Properly check the dependency of choices as a group.
Also fix that sym_check_deps() correctly terminates the dependency loop
error check (otherwise it would continue printing the dependency chain).
On a Mac OS X machine the output of ls -l is different from a standard
Linux machine. Use readlink instead of parsing a hardcoded field number
from the ls output.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
