commit 6520fe5564acf07ade7b18a1272db1184835c487 upstream.
A new option is added to the relocs tool called '--realmode'.
This option causes the generation of 16-bit segment relocations
and 32-bit linear relocations for the real-mode code. When
the real-mode code is moved to the low-memory during kernel
initialization, these relocation entries can be used to
relocate the code properly.
In the assembly code 16-bit segment relocations must be relative
to the 'real_mode_seg' absolute symbol. Linear relocations must be
relative to a symbol prefixed with 'pa_'.
16-bit segment relocation is used to load cs:ip in 16-bit code.
Linear relocations are used in the 32-bit code for relocatable
data references. They are declared in the linker script of the
real-mode code.
The relocs tool is moved to arch/x86/tools/relocs.c, and added new
target archscripts that can be used to build scripts needed building
an architecture. be compiled before building the arch/x86 tree.
[ hpa: accelerating this because it detects invalid absolute
relocations, a serious bug in binutils 2.22.52.0.x which currently
produces bad kernels. ]
Link: http://lkml.kernel.org/r/1336501366-28617-2-git-send-email-jarkko.sakkinen@intel.com
Signed-off-by: Jarkko Sakkinen <jarkko.sakkinen@intel.com>
Cc: <stable@vger.kernel.org>
[bwh: Backported to 3.2:
- Adjust context (no archheaders; no insn_sanity)
- Expand put_unaligned_le32()]
commit e88aa7bbbe3046a125ea1936b16bb921cc9c6349 upstream.
The symbol table on x86-64 starts to have entries that have names
like:
_GLOBAL__sub_I_65535_0___mod_x86cpu_device_table
They are of type STT_FUNCTION and this one had a length of 18. This
matched the device ID validation logic and it barfed because the
length did not meet the device type's criteria.
FATAL: arch/x86/crypto/aesni-intel: sizeof(struct x86cpu_device_id)=16 is not a modulo of the size of section __mod_x86cpu_device_table=18.
Fix definition of struct x86cpu_device_id in mod_devicetable.h
These are some kind of compiler tool internal stuff being emitted and
not something we want to inspect in modpost's device ID table
validation code.
So skip the symbol if it is not of type STT_OBJECT.
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Signed-off-by: Jonathan Nieder <jrnieder@gmail.com>
commit 258f742635360175564e9470eb060ff4d4b984e7 upstream.
Commit f02e8a6596b7 ("module: Sort exported symbols") sorts symbols
placing each of them in its own elf section. This sorting and merging
into the canonical sections are done by the linker.
Unfortunately modpost to generate Module.symvers file parses vmlinux.o
(which is not linked yet) and all modules object files (which aren't
linked yet). These aren't sanitized by the linker yet. That breaks
modpost that can't detect license properly for modules.
This patch makes modpost aware of the new exported symbols structure.
[ This above is a slightly corrected version of the explanation of the
problem, copied from commit 62a2635610db ("modpost: Fix modpost's
license checking V3"). That commit fixed the problem for module
object files, but not for vmlinux.o. This patch fixes modpost for
vmlinux.o. ]
Signed-off-by: Frank Rowand <frank.rowand@am.sony.com>
Signed-off-by: Alessio Igor Bogani <abogani@kernel.org>
commit 9aaf440f8fabcebf9ea79a62ccf4c212e6544b49 upstream.
This was lacking a comma between two supposed to be separate strings.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
commit 6c635224602d760c1208ada337562f40d8ae93a5 upstream.
The current use of /tmp for file lists is insecure. Put them under
$objtree/debian instead.
Acked-by: maximilian attems <max@stro.at>
commit 2e885057b7f75035f0b85e02f737891482815a81 upstream.
In ELF64, the sh_flags field is 64-bits wide. recordmcount was
erroneously treating it as a 32-bit wide field. For little endian
objects this works because the flags of interest (SHF_EXECINSTR)
reside in the lower 32 bits of the word, and you get the same result
with either a 32-bit or 64-bit read. Big endian objects on the
other hand do not work at all with this error.
The fix: Correctly treat sh_flags as 64-bits wide in elf64 objects.
The symptom I observed was that my
__start_mcount_loc..__stop_mcount_loc was empty even though ftrace
function tracing was enabled.
Link: http://lkml.kernel.org/r/1324345362-12230-1-git-send-email-ddaney.cavm@gmail.com
Signed-off-by: David Daney <david.daney@cavium.com>
commit 364212fddaaa60c5a64f67a0f5624ad996ecc8a0 upstream.
Thomas Lange reported that when he did a 'make localmodconfig', his
config was missing the brcmsmac driver, even though he had the module
loaded.
Looking into this, I found the file:
drivers/net/wireless/brcm80211/brcmsmac/Makefile
had the following in the Makefile:
MODULEPFX := brcmsmac
obj-$(CONFIG_BRCMSMAC) += $(MODULEPFX).o
The way streamline-config.pl works, is parsing all the
obj-$(CONFIG_FOO) += foo.o
lines to find that CONFIG_FOO belongs to the module foo.ko.
But in this case, the brcmsmac.o was not used, but a variable in its place.
By changing streamline-config.pl to remember defined variables in Makefiles
and substituting them when they are used in the obj-X lines, allows
Thomas (and others) to have their brcmsmac module stay configured
when it is loaded and running "make localmodconfig".
Reported-by: Thomas Lange <thomas-lange2@gmx.de>
Tested-by: Thomas Lange <thomas-lange2@gmx.de>
Cc: Arend van Spriel <arend@broadcom.com>
commit d060d963e88f3e990cec2fe5214de49de9a49eca upstream.
Simplify the way lines ending with backslashes (continuation) in Makefiles
is parsed. This is needed to implement a necessary fix.
Commit 5c48b108 ("um: take arch/um/sys-x86 to arch/x86/um") broke the
make target update-po-config, as its symlink trick (again) fails.
(Previous breakage was fixed with commit bdc69ca4 ("kconfig: change
update-po-config to reflect new layout of arch/um").)
The new UML layout allows to drop the symlick trick entirely. And if,
one day, another architecture supports UML too, that should now work
without again breaking this make target.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
* 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
script/checkpatch.pl: warn about deprecated use of EXTRA_{A,C,CPP,LD}FLAGS
tags, powerpc: Update tags.sh to support _GLOBAL symbols
scripts: add extract-vmlinux
* 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
scripts/kconfig/nconf: add KEY_HOME / KEY_END for dialog_inputbox
scripts/kconfig/nconf: fix editing long strings
scripts/kconfig/nconf: dynamically alloc dialog_input_result
scripts/kconfig/nconf: fix memmove's length arg
scripts/kconfig/nconf: fix typo: unknow => unknown
kconfig: fix set but not used variables
kconfig: handle SIGINT in menuconfig
kconfig: fix __enabled_ macros definition for invisible and un-selected symbols
kconfig: factor code in menu_get_ext_help()
kbuild: Fix help text not displayed in choice option.
kconfig/nconf: nuke unreferenced `nohelp_text'
kconfig/streamline_config.pl: merge local{mod,yes}config
kconfig/streamline_config.pl: use options to determine operating mode
kconfig/streamline_config.pl: directly access LSMOD from the environment
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
Kbuild: append missing-syscalls to the default target list
genksyms: Regenerate lexer and parser
genksyms: Do not expand internal types
genksyms: Minor parser cleanup
Makefile: remove a duplicated line
fixdep: fix extraneous dependencies
scripts/Makefile.build: do not reference EXTRA_CFLAGS as CFLAGS replacement
kbuild: prevent make from deleting _shipped files
kbuild: Do not delete empty files in make distclean
Use of the GPL or a compatible licence doesn't necessarily make the code
any good. We already consider staging modules to be suspect, and this
should also be true for out-of-tree modules which may receive very
little review.
Reviewed-by: Dave Jones <davej@redhat.com>
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (patched oops-tracing.txt)
Some find using utf-8 in commit logs inappropriate.
Some patch commit logs contain unintended utf-8 characters when doing
things like copy/pasting compilation output.
Look for the start of any commit log by skipping initial lines that look
like email headers and "From: " lines.
Stop looking for utf-8 at the first signature line.
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Andy Whitcroft <apw@shadowen.org>
Mark obsolete/deprecated strict_strto<foo> and simple_strto<foo> functions
and macros as obsolete.
Update checkpatch to warn about their use.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
* 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1519 commits)
staging: et131x: Remove redundant check and return statement
staging: et131x: Mainly whitespace changes to appease checkpatch
staging: et131x: Remove last of the forward declarations
staging: et131x: Remove even more forward declarations
staging: et131x: Remove yet more forward declarations
staging: et131x: Remove more forward declarations
staging: et131x: Remove forward declaration of et131x_adapter_setup
staging: et131x: Remove some forward declarations
staging: et131x: Remove unused rx_ring.recv_packet_pool
staging: et131x: Remove call to find pci pm capability
staging: et131x: Remove redundant et131x_reset_recv() call
staging: et131x: Remove unused rx_ring.recv_buffer_pool
Staging: bcm: Fix three initialization errors in InterfaceDld.c
Staging: bcm: Fix coding style issues in InterfaceDld.c
staging:iio:dac: Add AD5360 driver
staging:iio:trigger:bfin-timer: Fix compile error
Staging: vt6655: add some range checks before memcpy()
Staging: vt6655: whitespace fixes to iotcl.c
Staging: vt6656: add some range checks before memcpy()
Staging: vt6656: whitespace cleanups in ioctl.c
Fix up conflicts in:
- drivers/{Kconfig,Makefile}, drivers/staging/{Kconfig,Makefile}:
vg driver movement
- drivers/staging/brcm80211/brcmfmac/{dhd_linux.c,mac80211_if.c}:
driver removal vs now stale changes
- drivers/staging/rtl8192e/r8192E_core.c:
- drivers/staging/et131x/et131*:
driver consolidation into one file, tried to do fixups
Consider structures, unions and enums defined in the source file as
internal and do not expand them. This way, changes to e.g. struct
serial_private in drivers/tty/serial/8250_pci.c will not affect the
checksum of the pciserial_* exports.
Move the identical logic for recording a struct/union/enum definition to
a function.
Fast-forward merge with Linus to be able to merge patches
based on more recent version of the tree.
This is a resend from the original, changing the title from PATCH to
RFC(since this is a review for commit, and I should have put that the first go around).
and also removing some of the commit's with ia64 and bash since it is significant.
let me know if I might have missed anything etc..
to make it easier to locate begin/end when editing long strings;
Signed-off-by: Cheng Renquan <crquan@gmail.com>
Acked By: Nir Tzachar <nir.tzachar@gmail.com>
The original dialog_inputbox doesn't work with longer than prompt_width
strings, here fixed it in this way:
1) add variable cursor_form_win to record cursor of form_win,
keep its value always between [0, prompt_width-1];
reuse the original cursor_position as cursor of the string result,
use (cursor_position-cursor_form_win) as begin offset to show part of
the string in form_win;
Cc: Arnaud Lacombe <lacombar@gmail.com>
Cc: Nir Tzachar <nir.tzachar@gmail.com>
To support unlimited length string config items;
No check for realloc return value keeps code simple, and to be
consistent with other existing unchecked malloc in kconfig.
Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
In case KEY_BACKSPACE / KEY_DC to delete a char, it memmove only
(len-cursor_position+1) bytes;
the default case is to insert a char, it should also memmove exactly
the original use of (len+1) is wrong and may access following memory
that doesn't belong to result, may cause SegFault in theory;
case KEY_BACKSPACE:
if (cursor_position > 0) {
memmove(&result[cursor_position-1],
&result[cursor_position],
len-cursor_position+1);
cursor_position--;
break;
case KEY_DC:
if (cursor_position >= 0 && cursor_position < len) {
memmove(&result[cursor_position],
&result[cursor_position+1],
break;
default:
if ((isgraph(res) || isspace(res)) &&
len-2 < result_len) {
/* insert the char at the proper position */
memmove(&result[cursor_position+1],
result[cursor_position] = res;
cursor_position++;
Acked-by: Nir Tzachar <nir.tzachar@gmail.com>
Acked-by: Arnaud Lacombe <lacombar@gmail.com>
The introduction of include/linux/kconfig.h created 3 extraneous
dependencies:
include/config/.h
include/config/h.h
include/config/foo.h
Fix this by excluding kconfig.h from fixdep calculations.
Signed-off-by: Peter Foley <pefoley2@verizon.net>
Usage of these flags has been deprecated for nearly 4 years by:
commit f77bf01425b11947eeb3b5b54685212c302741b8
Author: Sam Ravnborg <sam@neptun.(none)>
Date: Mon Oct 15 22:25:06 2007 +0200
kbuild: introduce ccflags-y, asflags-y and ldflags-y
Moreover, these flags (at least EXTRA_CFLAGS) have been documented for command
line use. By default, gmake(1) do not override command line setting, so this is
likely to result in build failure or unexpected behavior.
Warn about their introduction in Makefile or Kbuild files.
Cc: Andy Whitcroft <apw@canonical.com>
command line use. By default, gmake(1) do not override command line
setting, so this is likely to result in build failure or unexpected
behavior.
Do not advertise for its usage.
Cc: linux-kbuild@vger.kernel.org
commit 7373f4f (kbuild: add implicit rules for parser generation)
created a implicit rule chain (%.c: %.c_shipped: %.y).
Make considers the _shipped files to be intermediate files which
causes them to be deleted if they didn't exist before make was run.
Mark the _shipped files PRECIOUS to prevent make from deleting them.
On PowerPC we use _GLOBAL throughout the assembly to define symbols, but
currently these symbols are missing from the tags generated with
ARCH=powerpc make tags. This patch modifies the tags.sh script to
recognise _GLOBAL(.*) so that these symbols will be in the tags.
This is almost (but not quite) PowerPC specific and this change should
not affect anyone else:
$ git grep -E '^_GLOBAL\(([^)]*)\).*' |sed 's/^\([^/]*\/[^/]*\)\/.*$/\1/'|uniq -c
627 arch/powerpc
2 arch/um
Signed-off-by: Ian Munsie <imunsie@au1.ibm.com>
This script can be used to extract vmlinux from a compressed
kernel image (bzImage, etc..). It's inspired from (a subset of)
extract-ikconfig.
It's something a lot of people have been looking for (mainly
people with xen < 4 that doesn't support bzImages at all).
Signed-off-by: Corentin Chary <corentincj@iksaif.net>
kbuild/kconfig
Some variables were being set but never used, which was triggering
warnings in GCC >= 4.6.
I recently got bitten in the ass when pressing Ctrl-C and lost all my current
configuration changes. This patch captures SIGINT and allows the user to save
any changes.
Some code refactoring was made in order to handle the exit behavior.
Signed-off-by: Davidlohr Bueso <dave@gnu.org>
__enabled_<sym-name> are only generated on visible or selected entries, do not
reflect the purpose of its introduction.
Fix this by always generating these entries for named symbol.
Reported-by: Rabin Vincent <rabin@rab.in>
This resolves a conflict with:
drivers/staging/brcm80211/brcmsmac/types.h
The test for bad usage of min_t() and max_t() is missing the --ignore
type. Add it.
Signed-off-by: Hui Zhu <teawater@gmail.com>
Change to new git tree -
(git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git).
Signed-off-by: Ralf Thielow <ralf.thielow@googlemail.com>
Cc: Joe Perches <joe@perches.com>
When I added the driver_data field to hv_vmbus_device_id, I forgot to
take into the account how the alias was created, so it would append the
kernel pointer to the end of the alias, which is not correct.
This changes how the hv_vmbus_device_id alias is created to proper
account for the driver_data field. As no module yet uses this alias, it
is safe to fix this up at this point in the commit stream.
Cc: K. Y. Srinivasan <kys@microsoft.com>
Cc: Haiyang Zhang <haiyangz@microsoft.com>
Add code to parse struct hv_vmbus_device_id table.
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com>
git://github.com/lacombar/linux-2.6 into kbuild/kconfig
Cc: Srinivas Kandagatla <srinivas.kandagatla@st.com>
Help text under choice menu is never displayed because it does not have
symbol name associated with it, however many kconfigs have help text
under choice, assuming that it will be displayed when user selects help.
for example in Kconfig if we have:
choice
prompt "Choice"
---help---
HELP TEXT ...
config A
bool "A"
config B
bool "B"
endchoice
Without this patch "HELP TEXT" is not displayed when user selects help
option when "Choice" is highlighted from menuconfig or xconfig or
gconfig.
This patch changes the logic in menu_get_ext_help to display help for
cases which dont have symbol names like choice.
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com>
Reviewed-by: Stuart Menefy <stuart.menefy@st.com>
Reviewed-by: Arnaud Lacombe <lacombar@gmail.com>
Cc: stable@kernel.org
After commit 5416857867c9cc94aba641898c567d9707de30f1, nohelp_text' is no
longer referenced, nuke it.
The two targets `localmodconfig' and `localyesconfig' only differs from the
sed(1) ran on the result of `streamline_config.pl' to convert symbols set to
`modules' to `yes'. This conversion can be made directly from the perl script,
and thus avoid duplicating the command to generate the configuration.
The options introduced are --localmodconfig (default) and --localyesconfig.
They match the Makefile target behavior.
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6
* 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (25 commits)
kconfig: Introduce IS_ENABLED(), IS_BUILTIN() and IS_MODULE()
xconfig: Abort close if configuration cannot be saved
kconfig: fix missing "0x" prefix from S_HEX symbol in autoconf.h
kconfig/nconf: remove useless conditionnal
kconfig/nconf: prevent segfault on empty menu
kconfig/nconf: use the generic menu_get_ext_help()
nconfig: Avoid Wunused-but-set warning
kconfig/conf: mark xfgets() private
kconfig: remove pending prototypes for kconfig_load()
kconfig/conf: add command line options' description
kconfig/conf: reduce the scope of `defconfig_file'
kconfig: use calloc() for expr allocation
kconfig: introduce specialized printer
kconfig: do not overwrite symbol direct dependency in assignment
kconfig/gconf: silent missing prototype warnings
kconfig/gconf: kill deadcode
kconfig: nuke LKC_DIRECT_LINK cruft
kconfig: nuke reference to SWIG
kconfig: add missing <stdlib.h> inclusion
kconfig: add missing <ctype.h> inclusion
Fix up conflicts in scripts/kconfig/Makefile
Replace the config_is_*() macros with a variant that allows for grepping
for usage of CONFIG_* options in the code. Usage:
if (IS_ENABLED(CONFIG_NUMA))
or
#if IS_ENABLED(CONFIG_NUMA)
The IS_ENABLED() macro evaluates to 1 if the argument is set (to either 'y'
or 'm'), IS_BUILTIN() tests if the option is 'y' and IS_MODULE() test if
the option is 'm'. Only boolean and tristate options are supported.
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
