commit a9ece53c4089ef23d4002d34c4c7148d94622a40 upstream.
Commit b478b782e110fdb4135caa3062b6d687e989d994 "kallsyms, tracing: output
more proper symbol name" introduces a "bugfix" that introduces a segfault
in kallsyms in my configurations.
The cause is the introduction of prefix_underscores_count() which attempts
to count underscores, even in symbols that do not have them. As a result,
it just uselessly runs past the end of the buffer until it crashes:
CC init/version.o
LD init/built-in.o
LD .tmp_vmlinux1
KSYM .tmp_kallsyms1.S
/bin/sh: line 1: 16934 Done sh-linux-gnu-nm -n .tmp_vmlinux1
16935 Segmentation fault | scripts/kallsyms > .tmp_kallsyms1.S
make: *** [.tmp_kallsyms1.S] Error 139
This simplifies the logic and just does a straightforward count.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Reviewed-by: Li Zefan <lizf@cn.fujitsu.com>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Paulo Marques <pmarques@grupopie.com>
Produce correct output for
- tagged commit (v2.6.30-rc6)
- past tagged commit (v2.6.30-rc5-299-g7c7327d)
- no tag
mips emit the following debug sections:
.mdebug* and .pdr
They were included in the check for non-allocatable section
and caused modpost to warn.
Manuel Lauss suggested to fix this by adding the relevant
sections to the list of sections we do not check.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Reported-by: Manuel Lauss <mano@roarinelk.homelinux.net>
Jean reported that he saw one warning for each module like the one below:
WARNING: arch/x86/kernel/cpu/cpufreq/acpi-cpufreq.o (.comment.SUSE.OPTs): unexpected non-allocatable section.
The warning appeared with the improved version of the
check of the flags in the sections.
That check already ignored sections named ".comment" - but SUSE store
additional info in the comment section and has named it in a SUSE
specific way. Therefore modpost failed to ignore the section.
The fix is to extend the pattern so we ignore all sections
that start with the name ".comment.".
Reported-by: Jean Delvare <khali@linux-fr.org>
Tested-by: Jean Delvare <khali@linux-fr.org>
The missing TO_NATIVE(sechdrs[i].sh_flags) was causing many
unexpected non-allocatable section warnings when cross-compiling
for an architecture with a different endianness.
Fix endianness of all the fields in the ELF header and
section headers, not just some of them so we are not
hit by this anohter time.
Signed-off-by: Anders Kaseorg <andersk@mit.edu>
Reported-by: Sean MacLennan <smaclennan@pikatech.com>
Tested-by: Sean MacLennan <smaclennan@pikatech.com>
The powerpc kernel always requires an Open Firmware like device tree
to supply device information. On systems without OF, this comes from
a flattened device tree blob. This blob is usually generated by dtc,
a tool which compiles a text description of the device tree into the
flattened format used by the kernel. Sometimes, the bootwrapper makes
small changes to the pre-compiled device tree blob (e.g. filling in
the size of RAM). To do this it uses the libfdt library.
Because these are only used on powerpc, the code for both these tools
is included under arch/powerpc/boot (these were imported and are
periodically updated from the upstream dtc tree).
However, the microblaze architecture, currently being prepared for
merging to mainline also uses dtc to produce device tree blobs. A few
other archs have also mentioned some interest in using dtc.
Therefore, this patch moves dtc and libfdt from arch/powerpc into
scripts, where it can be used by any architecture.
The vast bulk of this patch is a literal move, the rest is adjusting
the various Makefiles to use dtc and libfdt correctly from their new
locations.
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes
* 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes:
kbuild, modpost: Check the section flags, to catch missing "ax"/"aw"
kbuild: fix comment in modpost.c
kbuild: fix scripts/setlocalversion with git
kbuild: fix Module.markers permission error under cygwin
docs: also clean index.html
kbuild: remove a tag file before it is regenerated
kbuild: "make prepare" should be "make modules_prepare"
kbuild: clean Module.markers and modules.order for out-of-tree modules
avr32: drop unused CLEAN_FILES
scripts/kernel-doc can (incorrectly) delete struct members that are
surrounded by /* ... */ <struct members> /* ... */ if there is a /*
private: */ comment in there somewhere also.
Fix that by making the "/* private:" only allow whitespace between /* and
"private:", not anything/everything in the world.
This fixes some erroneous kernel-doc warnings that popped up while
processing include/linux/usb/composite.h.
When you put
.section ".foo"
in an assembly file instead of
.section "foo", "ax"
, one of the possible symptoms is that modpost will see an
ld-generated section name ".foo.1" in section_rel() or section_rela().
But this heuristic has two problems: it will miss a bad section that
has no relocations, and it will incorrectly flag many gcc-generated
sections as bad when compiling with -ffunction-sections
-fdata-sections.
On mips it fixes a lot of bogus warnings with gcc 4.4.0 lije this one:
WARNING: crypto/cryptd.o (.text.T.349): unexpected section name.
So instead of checking whether the section name matches a particular
pattern, we directly check for a missing SHF_ALLOC in the section
flags.
Tested-by: Ralf Baechle <ralf@linux-mips.org>
There is some confusion on naming of the head section.
Correct naming is .head.text.
Fix comment so we use correct naming.
When using trees like wireless-testing, which have untagged tags,
scripts/setlocalversion does not display any git indication for
localversion.
This patch fixes it: If git is available, but no usable tag is found,
it uses -g${head}. It skips the detection of unanottated tags via
git name-rev.
Signed-off-by: Nico Schottelius <nico@ikn.schottelius.org>
While building the kernel, we end-up calling modpost with -K and -M
options for the same file (Modules.markers). This is resulting in
modpost's main function calling read_markers() and then write_markers() on
the same file.
We then have read_markers() mmap'ing the file, and writer_markers()
opening that same file for writing.
The issue is that read_markers() exits without munmap'ing the file and is
as a matter holding a reference on Modules.markers. When write_markers()
is opening that very same file for writing, we still have a reference on
it and cygwin (Windows?) is then making fopen() fail with EPERM.
Calling release_file() before exiting read_markers() clears that reference
(and memory leak) and fopen() then succeeds.
Tested on both cygwin (1.3.22) and Linux. Also ran modpost within
valgrind on Linux to make sure that the munmap'ed file was not accessed
after read_markers()
Signed-off-by: Cedric Hombourger <chombourger@gmail.com>
Cc: <stable@kernel.org>
If a tag file is not removed before it is regenerated, the newly
generated data is appended to the old, which preserves stale data and
makes the tag file grow over time.
Signed-off-by: Matt Kraai <kraai@ftbfs.org>
The old refok sections
.text.init.refok
.data.init.refok
.exit.text.refok
have been deprecated since commit
312b1485fb509c9bc32eda28ad29537896658cb8. After the other patches in
this patch series nothing is put in these sections, so clean things up
by eliminating all the remaining references to them.
Signed-off-by: Tim Abbott <tabbott@mit.edu>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Following patch introduce support for setting options
to gcc that has effect for current directory and all
subdirectories.
The typical use case are an architecture or a subsystem that
decide to cover all files with -Werror.
Today alpha, mips and sparc uses -Werror in almost all their
Makefile- with subdir-ccflag-y it is now simpler to do so
as only the top-level directories needs to be covered.
Likewise if we decide to cover a full subsystem such
as net/ with -Werror this is done by adding a single
line to net/Makefile.
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes:
docbook: make cleandocs
kbuild: fix spurious initramfs rebuild
Documentation: explain the difference between __bitwise and __bitwise__
kbuild: make it possible for the linker to discard local symbols from vmlinux
kbuild: remove pointless strdup() on arguments passed to new_module() in modpost
kbuild: fix a few typos in top-level Makefile
kbuild: introduce destination-y for exported headers
kbuild: use git svn instead of git-svn in setlocalversion
kconfig: fix update-po-config to accect backslash in input
kbuild: fix option processing for -I in headerdep
* 'gm_20090410' of git://repo.or.cz/linux-2.6/trivial-mods:
MAINTAINERS - Update MN10300 patterns
MAINTAINERS - Update frv arch patterns
scripts/get_maintainer.pl - Allow multiple files on command line
MAINTAINERS - Update Freescale sound patterns
MAINTAINERS - Add additional patterns
MAINTAINERS - Add missing "/" to some pattern directories
MAINTAINERS - Update DRIVER CORE patterns
MAINTAINERS - Update M68K patterns
MAINTAINERS - Coalesce sections "DVB" and "Video for Linux"
MAINTAINERS - Remove cyblafb frame buffer no longer in tree
MAINTAINERS - Remove x86/Voyager no longer in tree
MAINTAINERS - Update FPU Emulator contact address and web page
MAINTAINERS - i2c_tiny_usb T: should be W:
MAINTAINERS - Add Linus Torvalds' git
MAINTAINERS - standardize "T: git urls"
MAINTAINERS - Remove HP Fibre Channel HBA no longer in tree
MAINTAINERS - Standardize style
MAINTAINERS - Add file patterns
Add scripts/get_maintainer.pl
Acked-by: Pavel Machek <pavel@ucw.cz>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
When gen_initramfs_list is used to generate make dependencies, it
includes symbolic links, for which make tracks the link target. Any
change to that target will cause an initramfs rebuild, even if the
symlink points to something outside of the initramfs directory.
If the target happens to be /tmp, the rebuild occurs for each kernel
build, since gen_initramfs_list uses mktemp...
Proposed way to fix it is to omit symbolic links from generated
dependencies, but this has a small drawback: changing perm/owner on a
symlink will go unnoticed.
Signed-off-by: Maxime Bizon <mbizon@freebox.fr>
new_module() itself already calls strdup() on its modname parameter.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
xtensa and arm have asked for a possibility to export headers
and locate them in a specific directory when exported.
Introduce destiantion-y to support this.
This patch in additiona adds some limited
documentation for the variables used for exported headers.
Cc: Oskar Schirmer <os@emlix.com>
Cc: Mikael Starvik <mikael.starvik@axis.com>
Use the correct git <subcmd> syntax instead of the deprecated git-<subcmd>.
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
Massimo Maiurana reported (slightly edited):
In latest 2.6.29 "make update-po-config" fails at msguniq invocation
with an "invalid control sequence" error.
The offending string is the following, and it's located in
drivers/staging/panel/Kconfig:72:
"'\e[L' which are specific to the LCD, and a few ANSI codes. The"
looks to me like gettext expects strings in printf format, so in
this case it thinks "\e" is a control sequence but doesn't recognise
it as a valid one.
A valid solution would be to tell kxgettext to automatically
escape this kind of strings in the */config.pot he produces, so that
msguniq would not complain.
This patch implements the suggested escaping.
Reported-by: Massimo Maiurana <maiurana@gmail.com>
Tested-by: Massimo Maiurana <maiurana@gmail.com>
-I takes an argument. Without this change only a 1 is added to
@opt_include which is not helpful.
Acked-by: Vegard Nossum <vegard.nossum@gmail.com>
Improve handling of "by:" signoffs
Sorting and frequency checks are done by name/email, not
by "by:" tag.
A script to parse file pattern information in MAINTAINERS
and return selected information about a file or patch
usage: scripts/get_maintainer.pl [options] patchfile
scripts/get_maintainer.pl [options] -f file
version: 0.14
MAINTAINERS field selection options:
--email => print email address(es) if any
--git => include git "*-by:" signers in commit count order
--git-chief-penguins => include (Linus Torvalds)
--git-min-signatures => number of signatures required (default: 1)
--git-max-maintainers => maximum maintainers to add (default: 5)
--git-since => git history to use (default: 1-year-ago)
--m => include maintainer(s) if any
--n => include name 'Full Name <addr@domain.tld>'
--l => include list(s) if any
--s => include subscriber only list(s) if any
--scm => print SCM tree(s) if any
--status => print status if any
--subsystem => print subsystem name if any
--web => print website(s) if any
Output type options:
--separator [, ] => separator for multiple entries on 1 line
--multiline => print 1 entry per line
Default options:
[--email --git --m --n --l --multiline]
Other options:
--version => show version
--help => show this help information
* git://git.infradead.org/~dwmw2/firmware-2.6:
qla1280: Fix off-by-some error in firmware loading.
Add README.AddingFirmware file. Basically telling people not to.
firmware: Remove newly-added slicoss and sxg firmware images
firmware/WHENCE: Add missing origin information for Ambassador atmsar11.fw
ALSA: wavefront - Always use request_firmware()
Remove fdump tool for av7110 firmware
firmware: convert av7110 driver to request_firmware()
Partially revert "V4L/DVB (9533): cx88: Add support for TurboSight TBS8910 DVB-S PCI card"
Revert "fix modules_install via NFS"
Add-add conflicts in firmware/WHENCE fixed manually
* 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
branch tracer, intel-iommu: fix build with CONFIG_BRANCH_TRACER=y
branch tracer: Fix for enabling branch profiling makes sparse unusable
ftrace: Correct a text align for event format output
Update /debug/tracing/README
tracing/ftrace: alloc the started cpumask for the trace file
tracing, x86: remove duplicated #include
ftrace: Add check of sched_stopped for probe_sched_wakeup
function-graph: add proper initialization for init task
tracing/ftrace: fix missing include string.h
tracing: fix incorrect return type of ns2usecs()
tracing: remove CALLER_ADDR2 from wakeup tracer
blktrace: fix pdu_len when tracing packet command requests
blktrace: small cleanup in blk_msg_write()
blktrace: NUL-terminate user space messages
tracing: move scripts/trace/power.pl to scripts/tracing/power.pl
This reverts commit 8b249b6856f16f09b0e5b79ce5f4d435e439b9d6.
This 'fix' is not necessary; we just need to undo the damage caused
accidentally by Igor/Mauro in 4b29631db33292d416dc395c56122ea865e7635c
("V4L/DVB (9533): cx88: Add support for TurboSight TBS8910 DVB-S PCI card")
* 'tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (413 commits)
tracing, net: fix net tree and tracing tree merge interaction
tracing, powerpc: fix powerpc tree and tracing tree interaction
ring-buffer: do not remove reader page from list on ring buffer free
function-graph: allow unregistering twice
trace: make argument 'mem' of trace_seq_putmem() const
tracing: add missing 'extern' keywords to trace_output.h
tracing: provide trace_seq_reserve()
blktrace: print out BLK_TN_MESSAGE properly
blktrace: extract duplidate code
blktrace: fix memory leak when freeing struct blk_io_trace
blktrace: fix blk_probes_ref chaos
blktrace: make classic output more classic
blktrace: fix off-by-one bug
blktrace: fix the original blktrace
blktrace: fix a race when creating blk_tree_root in debugfs
blktrace: fix timestamp in binary output
tracing, Text Edit Lock: cleanup
tracing: filter fix for TRACE_EVENT_FORMAT events
ftrace: Using FTRACE_WARN_ON() to check "freed record" in ftrace_release()
x86: kretprobe-booster interrupt emulation code fix
Fix up trivial conflicts in
arch/parisc/include/asm/ftrace.h
include/linux/memory.h
kernel/extable.c
kernel/module.c
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-module-and-param
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-module-and-param:
module: use strstarts()
strstarts: helper function for !strncmp(str, prefix, strlen(prefix))
arm: allow usage of string functions in linux/string.h
module: don't use stop_machine on module load
module: create a request_module_nowait()
module: include other structures in module version check
module: remove the SHF_ALLOC flag on the __versions section.
module: clarify the force-loading taint message.
module: Export symbols needed for Ksplice
Ksplice: Add functions for walking kallsyms symbols
module: remove module_text_address()
module: __module_address
module: Make find_symbol return a struct kernel_symbol
kernel/module.c: fix an unused goto label
param: fix charp parameters set via sysfs
Fix trivial conflicts in kernel/extable.c manually.
Signed-off-by: Helge Deller <deller@gmx.de>
Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
include/linux/slub_def.h
lib/Kconfig.debug
mm/slob.c
mm/slub.c
Impact: Cleanup
We use scripts/tracing/ to contain tracing scripts.
Use one directory only instead of two.
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Steven Rostedt <srostedt@redhat.com>
LKML-Reference: <49D06B9C.3070209@cn.fujitsu.com>
With CONFIG_MODVERSIONS, we version 'struct module' using a dummy
export, but other things matter too:
1) 'struct modversion_info' determines the layout of the __versions section,
2) 'struct kernel_param' determines the layout of the __params section,
3) 'struct kernel_symbol' determines __ksymtab*.
4) 'struct marker' determines __markers.
5) 'struct tracepoint' determines __tracepoints.
So we rename 'struct_module' to 'module_layout' and include these in
the signature. Now it's general we can add others later on without
confusion.
arch/parisc/kernel/irq.c
arch/x86/include/asm/fixmap_64.h
arch/x86/include/asm/setup.h
kernel/irq/handle.c
Semantic merge:
arch/x86/include/asm/fixmap.h
* 'header-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (50 commits)
x86: headers cleanup - setup.h
emu101k1.h: fix duplicate include of <linux/types.h>
compiler-gcc4: conditionalize #error on __KERNEL__
remove __KERNEL_STRICT_NAMES
make netfilter use strict integer types
make drm headers use strict integer types
make MTD headers use strict integer types
make most exported headers use strict integer types
make exported headers use strict posix types
unconditionally include asm/types.h from linux/types.h
make linux/types.h as assembly safe
Neither asm/types.h nor linux/types.h is required for arch/ia64/include/asm/fpu.h
headers_check fix cleanup: linux/reiserfs_fs.h
headers_check fix cleanup: linux/nubus.h
headers_check fix cleanup: linux/coda_psdev.h
headers_check fix: x86, setup.h
headers_check fix: x86, prctl.h
headers_check fix: linux/reinserfs_fs.h
headers_check fix: linux/socket.h
headers_check fix: linux/nubus.h
Manually fix trivial conflicts in:
include/linux/netfilter/xt_limit.h
include/linux/netfilter/xt_statistic.h
This patch combines Greg Bank's dprintk() work with the existing dynamic
printk patchset, we are now calling it 'dynamic debug'.
The new feature of this patchset is a richer /debugfs control file interface,
(an example output from my system is at the bottom), which allows fined grained
control over the the debug output. The output can be controlled by function,
file, module, format string, and line number.
for example, enabled all debug messages in module 'nf_conntrack':
echo -n 'module nf_conntrack +p' > /mnt/debugfs/dynamic_debug/control
to disable them:
echo -n 'module nf_conntrack -p' > /mnt/debugfs/dynamic_debug/control
A further explanation can be found in the documentation patch.
Signed-off-by: Greg Banks <gnb@sgi.com>
Signed-off-by: Jason Baron <jbaron@redhat.com>
Now platform_device is being widely used on SoC processors where the
peripherals are attached to the system bus, which is simple enough.
However, silicon IPs for these SoCs are usually shared heavily across
a family of processors, even products from different companies. This
makes the original simple driver name based matching insufficient, or
simply not straight-forward.
Introduce a module id table for platform devices, and makes it clear
that a platform driver is able to support some shared IP and handle
slight differences across different platforms (by 'driver_data').
Module alias is handled automatically when a MODULE_DEVICE_TABLE()
is defined.
To not disturb the current platform drivers too much, the matched id
entry is recorded and can be retrieved by platform_get_device_id().
Signed-off-by: Eric Miao <eric.miao@marvell.com>
Cc: Kay Sievers <kay.sievers@vrfy.org>
Cc: Ben Dooks <ben-linux@fluff.org>
'make randconfig' uses glibc's rand function, and the seed of
that PRNG is set via:
srand(time(NULL));
But 'time()' only increases once every second - freezing the
randconfig result within a single second.
My Nehalem testbox does randconfig much faster than 1 second
and i have a few scripts that do 'randconfig until condition X'
loops.
Those scripts currently waste a lot of CPU time due to randconfig
changing its seed only once per second currently.
Change the seed to be micrseconds based. (I checked the statistical
spread of the seed - the now.tv_sec*now.tv_usec multiplication
there further improves it.)
Cc: Roman Zippel <zippel@linux-m68k.org>
[sam: fix for systems where usec is zero - noticed by Geert Uytterhoeven]
Ingo Molnar reported that 'make randconfig' was not covering
choice blocks properly, resulting in certain config options
being left out of randconfig testing altogether.
With the following patch we:
- properly randomize choice value for normal choice blocks
- properly randomize for multi choice blocks
- added several comments to explain what is going on
The root cause of the bug was that SYMBOL_VALID was set on the
symbol representing the choice block so clearing this did
the trick initially.
But testign revealed a few more issues that is now fixed.
Reported-by: Ingo Molnar <mingo@elte.hu>
Impact: bugfix, output more reliable symbol lookup result
Debug tools(dump_stack(), ftrace...) are like to print out symbols.
But it is always print out the first aliased symbol.(Aliased symbols
are symbols with the same address), and the first aliased symbol is
sometime not proper.
# echo function_graph > current_tracer
# cat trace
1) 1.923 us | select_nohz_load_balancer();
1) + 76.692 us | }
1) | default_idle() {
1) ==========> | __irqentry_text_start() {
1) 0.000 us | native_apic_mem_write();
1) | irq_enter() {
1) 0.000 us | idle_cpu();
1) | tick_check_idle() {
1) 0.000 us | tick_check_oneshot_broadcast();
1) | tick_nohz_stop_idle() {
It's very embarrassing, it ouputs "__irqentry_text_start()",
actually, it should output "smp_apic_timer_interrupt()".
(these two symbol are the same address, but "__irqentry_text_start"
is deemed to the first aliased symbol by scripts/kallsyms)
This patch puts symbols like "__irqentry_text_start" to the second
aliased symbols. And a more proper symbol name becomes the first.
Aliased symbols mostly come from linker script. The solution is
guessing "is this symbol defined in linker script", the symbols
defined in linker script will not become the first aliased symbol.
And if symbols are found to be equal in this "linker script provided"
criteria, symbols are sorted by the number of prefix underscores.
Reviewed-by: Paulo Marques <pmarques@grupopie.com>
LKML-Reference: <49BA06E2.7080807@cn.fujitsu.com>
Running 'make rpm' fails when CONFIG_LOCALVERSION_AUTO=y and using a kernel source
tree under SCM. This is due to KERNELRELEASE being different when the initial make
is run and when make is run from rpmbuild.
mkspec creates kernel.spec using KERNELRELEASE:
<mkspec>
echo "%files"
echo '%defattr (-, root, root)'
echo "%dir /lib/modules"
echo "/lib/modules/$KERNELRELEASE"
echo "/lib/firmware"
echo "/boot/*"
echo ""
</mkspec>
When CONFIG_LOCALVERSION_AUTO=y scripts/setlocalversion is called and grabs any
additional version info from SCM. Next, the srctree is tarred up and SCM
information is excluded.
rpmbuild reruns make and in the process generates a new include/config/kernel.release
and thus a new KERNELRELEASE. However this time the SCM information is gone so
KERNELRELEASE no longer has the additional version information. When "make modules_install"
runs, it uses the new KERNELRELEASE value to determine where to install the modules.
This conflicts with where the spec file assumes they are going because of the
mis-matching KERNELRELEASE versions.
<snippet>
+ INSTALL_MOD_PATH=/var/tmp/kernel-2.6.29rc4tip01479g5d85422-root
+ make -j16 modules_install
INSTALL crypto/aead.ko
INSTALL crypto/cbc.ko
INSTALL crypto/chainiv.ko
INSTALL crypto/crc32c.ko
INSTALL crypto/crypto_algapi.ko
INSTALL crypto/crypto_blkcipher.ko
INSTALL crypto/crypto_hash.ko
INSTALL crypto/cryptomgr.ko
INSTALL crypto/ecb.ko
INSTALL crypto/eseqiv.ko
INSTALL crypto/krng.ko
INSTALL crypto/md5.ko
INSTALL crypto/pcbc.ko
INSTALL crypto/rng.ko
INSTALL drivers/block/cciss.ko
INSTALL drivers/hid/hid-dummy.ko
INSTALL drivers/scsi/iscsi_tcp.ko
INSTALL drivers/scsi/libiscsi.ko
INSTALL drivers/scsi/libiscsi_tcp.ko
INSTALL drivers/scsi/scsi_transport_iscsi.ko
INSTALL drivers/scsi/scsi_wait_scan.ko
INSTALL fs/lockd/lockd.ko
INSTALL fs/nfs/nfs.ko
INSTALL fs/nfsd/nfsd.ko
INSTALL lib/libcrc32c.ko
INSTALL net/sunrpc/sunrpc.ko
DEPMOD 2.6.29-rc4-tip
+ cp arch/x86/boot/bzImage
/var/tmp/kernel-2.6.29rc4tip01479g5d85422-root/boot/vmlinuz-2.6.29-rc4-tip-01479-g5d85422
+ cp System.map
/var/tmp/kernel-2.6.29rc4tip01479g5d85422-root/boot/System.map-2.6.29-rc4-tip-01479-g5d85422
+ cp .config
/var/tmp/kernel-2.6.29rc4tip01479g5d85422-root/boot/config-2.6.29-rc4-tip-01479-g5d85422
+ cp vmlinux vmlinux.orig
+ bzip2 -9 vmlinux
+ mv vmlinux.bz2
/var/tmp/kernel-2.6.29rc4tip01479g5d85422-root/boot/vmlinux-2.6.29-rc4-tip-01479-g5d85422.bz2
+ mv vmlinux.orig vmlinux
+ /usr/lib/rpm/brp-compress
Processing files: kernel-2.6.29rc4tip01479g5d85422-2
error: File not found:
/var/tmp/kernel-2.6.29rc4tip01479g5d85422-root/lib/modules/2.6.29-rc4-tip-01479-g5d85422
RPM build errors:
File not found:
make[1]: *** [rpm] Error 1
make: *** [rpm] Error 2
</snippet>
I have tested this patch on git -tip, Linus' git tree, and the kernel.org tar files, both
with and without CONFIG_LOCALVERSION_AUTO=y.
Signed-off-by: Josh Hunt <josh@scalex86.org>
The contents of the %clean section in mkspec is currently commented
out leaving RPM_BUILD_ROOT and its contents on the build machine.
This patch removes it once the rpm build process is complete.
This fixes an error when compiling the kernel.
CHK include/linux/version.h
HOSTCC scripts/unifdef
scripts/unifdef.c:209: error: conflicting types for 'getline'
/usr/include/stdio.h:651: note: previous declaration of 'getline' was here
make[1]: *** [scripts/unifdef] Error 1
make: *** [__headers] Error 2
arch/x86/Kconfig
block/blktrace.c
kernel/irq/handle.c
Semantic conflict:
kernel/trace/blktrace.c
'x86/setup-lzma', 'x86/signal' and 'x86/urgent' into x86/core
tracing/core
