path: root/scripts
2009-07-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixesLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes: kbuild: finally remove the obsolete variable $TOPDIR gitignore: ignore scripts/ihex2fw Kbuild: Disable the -Wformat-security gcc flag gitignore: ignore gcov output files kbuild: deb-pkg ship changelog Add new __init_task_data macro to be used in arch init_task.c files. asm-generic/vmlinux.lds.h: shuffle INIT_TASK* macro names in vmlinux.lds.h Add new macros for page-aligned data and bss sections. asm-generic/vmlinux.lds.h: Fix up RW_DATA_SECTION definition.
2009-07-01kernel-doc: move ignoring kmemcheckRandy Dunlap
Somehow I managed to generate a diff that put these 2 lines into the wrong function: should have been in dump_struct() instead of in dump_enum(). Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-30fbdev: work around old compiler bugStephen Rothwell
When building with a 4.1.x compiler on powerpc64 (at least) we get this error: drivers/video/logo/logo_linux_mono.c:81: error: logo_linux_mono causes a section type conflict This was introduced by commit ae52bb2384f721562f15f719de1acb8e934733cb ("fbdev: move logo externs to header file"). This is a partial revert of that commit sufficient to not hit the compiler bug. Also convert _clut arrays from __initconst to __initdata. Sam said: Al analysed this some time ago. When we say something is const then _sometimes_ gcc annotate the section as const(?) - sometimes not. So if we have two variables/functions annotated __*const and gcc decides to annotate the section const only in one case we get a section type conflict. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-27gitignore: ignore scripts/ihex2fwJaswinder Singh Rajput
scripts/ihex2fw is a generated binary and should be ignored Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-06-27kbuild: deb-pkg ship changelogmaximilian attems
In the series for 2.6.31 it was noticed to ship the copyright, but the generated changelog got lost somehow. As bonus the generated linux-image deb packages are Lenny lintian clean. Cc: Frans Pop <elendil@planet.nl> Cc: Andres Salomon <dilinger@debian.org> Signed-off-by: maximilian attems <max@stro.at> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-06-26powerpc: Have git ignore generated files from dtc compileJon Smirl
Have git ignore generated files from dtc compile Signed-off-by: Jon Smirl <jonsmirl@gmail.com> Acked-by: David Gibson <david@gibson.dropbear.id.au> Acked-by: Sean MacLennan <smaclennan@pikatech.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-20kernel-doc: fix param matching for array paramsRandy Dunlap
Fix function actual parameter vs. kernel-doc description matching so that a warning is not printed when it should not be: Warning(include/linux/etherdevice.h:199): Excess function parameter 'addr' description in 'is_etherdev_addr' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-06-20kernel-doc: ignore kmemcheck_bitfield_begin/endRandy Dunlap
Teach kernel-doc to ignore kmemcheck_bitfield_{begin,end} sugar so that it won't generate warnings like this: Warning(include/net/sock.h:297): No description found for parameter 'kmemcheck_bitfield_begin(flags)' Warning(include/net/sock.h:297): No description found for parameter 'kmemcheck_bitfield_end(flags)' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-06-20kallsyms: fix inverted valid symbol checkingMike Frysinger
The previous commit (17b1f0de) introduced a slightly broken consolidation of the memory text range checking. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-06-20kbuild: fix build error during make htmldocsAmerigo Wang
Fix the following build error when do 'make htmldocs': DOCPROC Documentation/DocBook/debugobjects.xml exec /scripts/kernel-doc: No such file or directory exec /scripts/kernel-doc: No such file or directory Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: WANG Cong <amwang@redhat.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-06-18gcov: add gcov profiling infrastructurePeter Oberparleiter
Enable the use of GCC's coverage testing tool gcov [1] with the Linux kernel. gcov may be useful for: * debugging (has this code been reached at all?) * test improvement (how do I change my test to cover these lines?) * minimizing kernel configurations (do I need this option if the associated code is never run?) The profiling patch incorporates the following changes: * change kbuild to include profiling flags * provide functions needed by profiling code * present profiling data as files in debugfs Note that on some architectures, enabling gcc's profiling option "-fprofile-arcs" for the entire kernel may trigger compile/link/ run-time problems, some of which are caused by toolchain bugs and others which require adjustment of architecture code. For this reason profiling the entire kernel is initially restricted to those architectures for which it is known to work without changes. This restriction can be lifted once an architecture has been tested and found compatible with gcc's profiling. Profiling of single files or directories is still available on all platforms (see config help text). [1] http://gcc.gnu.org/onlinedocs/gcc/Gcov.html Signed-off-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Huang Ying <ying.huang@intel.com> Cc: Li Wei <W.Li@Sun.COM> Cc: Michael Ellerman <michaele@au1.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Heiko Carstens <heicars2@linux.vnet.ibm.com> Cc: Martin Schwidefsky <mschwid2@linux.vnet.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: WANG Cong <xiyou.wangcong@gmail.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16Merge branch 'akpm'Linus Torvalds
* akpm: (182 commits) fbdev: bf54x-lq043fb: use kzalloc over kmalloc/memset fbdev: *bfin*: fix __dev{init,exit} markings fbdev: *bfin*: drop unnecessary calls to memset fbdev: bfin-t350mcqb-fb: drop unused local variables fbdev: blackfin has __raw I/O accessors, so use them in fb.h fbdev: s1d13xxxfb: add accelerated bitblt functions tcx: use standard fields for framebuffer physical address and length fbdev: add support for handoff from firmware to hw framebuffers intelfb: fix a bug when changing video timing fbdev: use framebuffer_release() for freeing fb_info structures radeon: P2G2CLK_ALWAYS_ONb tested twice, should 2nd be P2G2CLK_DAC_ALWAYS_ONb? s3c-fb: CPUFREQ frequency scaling support s3c-fb: fix resource releasing on error during probing carminefb: fix possible access beyond end of carmine_modedb[] acornfb: remove fb_mmap function mb862xxfb: use CONFIG_OF instead of CONFIG_PPC_OF mb862xxfb: restrict compliation of platform driver to PPC Samsung SoC Framebuffer driver: add Alpha Channel support atmel-lcdc: fix pixclock upper bound detection offb: use framebuffer_alloc() to allocate fb_info struct ... Manually fix up conflicts due to kmemcheck in mm/slab.c
2009-06-16fbdev: move logo externs to header fileGeert Uytterhoeven
Now we have __initconst, we can finally move the external declarations for the various Linux logo structures to <linux/linux_logo.h>. James' ack dates back to the previous submission (way to long ago), when the logos were still __initdata, which caused failures on some platforms with some toolchain versions. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: James Simmons <jsimmons@infradead.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16scripts/get_maintainer.pl: change "die" to "warn" when command line file is ↵Joe Perches
not a patch fixes git send-email with a cover letter Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16scripts/get_maintainer.pl: allow 8 bit characters in email addressesJoe Perches
2009-06-16scripts/get_maintainer.pl: don't print maintainers when not requestedJoe Perches
Fixed bug introduced after using rfc822 address checking. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16scripts/get_maintainer.pl: support both "P:/M:" and integrated "M:" linesJoe Perches
2009-06-16scripts/get_maintainer.pl: better email name quotingJoe Perches
2009-06-16scripts/get_maintainer.pl: support M: lines with names and multiple entries ↵Joe Perches
per M: line Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16scripts/get_maintainer.pl: warn on missing git or git repositoryJoe Perches
support older versions of grep (use -E not -P) no need to return data in routine recent_git_signoffs Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16scripts/get_maintainer.pl: improve --git-chief-penquins (Linus Torvalds) ↵Joe Perches
filtering Moved linux-kernel@vger.kernel.org to MAINTAINERS lkml will be added to all CC lists via F: pattern match Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16scripts/get_maintainer.pl: better fix for subscriber-only mailing listsJoe Perches
2009-06-16scripts/get_maintainer.pl: output first field only in mailing lists and ↵Joe Perches
after maintainers. Fix mailing lists that are described, but not "(subscriber-only)" Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: add a gfp-translate script to help understand page allocation failure ↵Mel Gorman
reports The page allocation failure messages include a line that looks like page allocation failure. order:1, mode:0x4020 The mode is easy to translate but irritating for the lazy and a bit error prone. This patch adds a very simple helper script gfp-translate for the mode: portion of the page allocation failure messages. An example usage looks like mel@machina:~/linux-2.6 $ scripts/gfp-translate 0x4020 Source: /home/mel/linux-2.6 Parsing: 0x4020 #define __GFP_HIGH (0x20) /* Should access emergency pools? */ #define __GFP_COMP (0x4000) /* Add compound page metadata */ The script is not a work of art but it has come in handy for me a few times so I thought I would share. [akpm@linux-foundation.org: clarify an error message] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Christoph Hellwig <hch@infradead.org> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (64 commits) debugfs: use specified mode to possibly mark files read/write only debugfs: Fix terminology inconsistency of dir name to mount debugfs filesystem. xen: remove driver_data direct access of struct device from more drivers usb: gadget: at91_udc: remove driver_data direct access of struct device uml: remove driver_data direct access of struct device block/ps3: remove driver_data direct access of struct device s390: remove driver_data direct access of struct device parport: remove driver_data direct access of struct device parisc: remove driver_data direct access of struct device of_serial: remove driver_data direct access of struct device mips: remove driver_data direct access of struct device ipmi: remove driver_data direct access of struct device infiniband: ehca: remove driver_data direct access of struct device ibmvscsi: gadget: at91_udc: remove driver_data direct access of struct device hvcs: remove driver_data direct access of struct device xen block: remove driver_data direct access of struct device thermal: remove driver_data direct access of struct device scsi: remove driver_data direct access of struct device pcmcia: remove driver_data direct access of struct device PCIE: remove driver_data direct access of struct device ... Manually fix up trivial conflicts due to different direct driver_data direct access fixups in drivers/block/{ps3disk.c,ps3vram.c}
2009-06-16sparc64: Add proper dynamic ftrace support.David S. Miller
Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-06-15debugfs: Fix terminology inconsistency of dir name to mount debugfs filesystem.GeunSik Lim
Many developers use "/debug/" or "/debugfs/" or "/sys/kernel/debug/" directory name to mount debugfs filesystem for ftrace according to ./Documentation/tracers/ftrace.txt file. And, three directory names(ex:/debug/, /debugfs/, /sys/kernel/debug/) is existed in kernel source like ftrace, DRM, Wireless, Documentation, Network[sky2]files to mount debugfs filesystem. debugfs means debug filesystem for debugging easy to use by greg kroah hartman. "/sys/kernel/debug/" name is suitable as directory name of debugfs filesystem. - debugfs related reference: http://lwn.net/Articles/334546/ Fix inconsistency of directory name to mount debugfs filesystem. * From Steven Rostedt - find_debugfs() and tracing_files() in this patch. Signed-off-by: GeunSik Lim <geunsik.lim@samsung.com> Acked-by : Inaky Perez-Gonzalez <inaky@linux.intel.com> Reviewed-by : Steven Rostedt <rostedt@goodmis.org> Reviewed-by : James Smart <james.smart@emulex.com> CC: Jiri Kosina <trivial@kernel.org> CC: David Airlie <airlied@linux.ie> CC: Peter Osterlund <petero2@telia.com> CC: Ananth N Mavinakayanahalli <ananth@in.ibm.com> CC: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> CC: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-14Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (53 commits) .gitignore: ignore *.lzma files kbuild: add generic --set-str option to scripts/config kbuild: simplify argument loop in scripts/config kbuild: handle non-existing options in scripts/config kallsyms: generalize text region handling kallsyms: support kernel symbols in Blackfin on-chip memory documentation: make version fix kbuild: fix a compile warning gitignore: Add GNU GLOBAL files to top .gitignore kbuild: fix delay in setlocalversion on readonly source README: fix misleading pointer to the defconf directory vmlinux.lds.h update kernel-doc: cleanup perl script Improve vmlinux.lds.h support for arch specific linker scripts kbuild: fix headers_exports with boolean expression kbuild/headers_check: refine extern check kbuild: fix "Argument list too long" error for "make headers_check", ignore *.patch files Remove bashisms from scripts menu: fix embedded menu presentation ...
2009-06-14kbuild: add generic --set-str option to scripts/configMichal Marek
Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-06-14kbuild: simplify argument loop in scripts/configMichal Marek
2009-06-14kbuild: handle non-existing options in scripts/configMichal Marek
If an option does not exist in .config, set it at the end of the file. Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-06-14kallsyms: generalize text region handlingMike Frysinger
2009-06-14kallsyms: support kernel symbols in Blackfin on-chip memoryRobin Getz
The Blackfin arch has a discontiguous .text layout due to having on-chip instruction memory and no virtual memory support. As such, we need to add explicit checks for these additional .text regions. Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-06-14kbuild: fix a compile warningAmerigo Wang
gcc-4.4.1: HOSTCC scripts/basic/fixdep scripts/basic/fixdep.c: In function 'traps': scripts/basic/fixdep.c:377: warning: dereferencing type-punned pointer will break strict-aliasing rules scripts/basic/fixdep.c:379: warning: dereferencing type-punned pointer will break strict-aliasing rules (Apparently -fno-strict-aliasing will fix this too) Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-06-14kbuild: fix delay in setlocalversion on readonly sourceNico Schottelius
Do not update index on read only media. Idea published by Christian Kujau <lists@nerdbynature.de>. Cc: Nico Schottelius <nico@ikn.schottelius.org> Cc: Christian Kujau <lists@nerdbynature.de>
2009-06-12Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: (30 commits) [S390] wire up sys_perf_counter_open [S390] wire up sys_rt_tgsigqueueinfo [S390] ftrace: add system call tracer support [S390] ftrace: add function graph tracer support [S390] ftrace: add function trace mcount test support [S390] ftrace: add dynamic ftrace support [S390] kprobes: use probe_kernel_write [S390] maccess: arch specific probe_kernel_write() implementation [S390] maccess: add weak attribute to probe_kernel_write [S390] profile_tick called twice [S390] dasd: forward internal errors to dasd_sleep_on caller [S390] dasd: sync after async probe [S390] dasd: check_characteristics cleanup [S390] dasd: no High Performance FICON in 31-bit mode [S390] dcssblk: revert devt conversion [S390] qdio: fix access beyond ARRAY_SIZE of irq_ptr->{in,out}put_qs [S390] vmalloc: add vmalloc kernel parameter support [S390] uaccess: use might_fault() instead of might_sleep() [S390] 3270: lock dependency fixes [S390] 3270: do not register with tty_register_device ...
2009-06-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: add generic lib/checksum.c asm-generic: add a generic uaccess.h asm-generic: add generic NOMMU versions of some headers asm-generic: add generic atomic.h and io.h asm-generic: add legacy I/O header files asm-generic: add generic versions of common headers asm-generic: make bitops.h usable asm-generic: make pci.h usable directly asm-generic: make get_rtc_time overridable asm-generic: rename page.h and uaccess.h asm-generic: rename atomic.h to atomic-long.h asm-generic: add a generic unistd.h asm-generic: add generic ABI headers asm-generic: add generic sysv ipc headers asm-generic: introduce asm/bitsperlong.h asm-generic: rename termios.h, signal.h and mman.h
2009-06-12virtio: enhance id_matching for virtio driversChristian Borntraeger
This patch allows a virtio driver to use VIRTIO_DEV_ANY_ID for the device id. This will be used by a test module that can be bound to any virtio device. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-06-12asm-generic: merge branch 'master' of torvalds/linux-2.6Arnd Bergmann
Fixes a merge conflict against the x86 tree caused by a fix to atomic.h which I renamed to atomic_long.h. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-12[S390] ftrace: add dynamic ftrace supportHeiko Carstens
Dynamic ftrace support for s390. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-06-11asm-generic: add a generic unistd.hArnd Bergmann
A new architecture should only define a minimal set of system calls while still providing the full functionality. This version of unistd.h has gone through intensive review to make sure that by default it only enables syscalls that do not already have a more featureful replacement. It is modeled after the x86-64 version of unistd.h, which unifies the syscall number definition and the actual system call table in a single file, in order to keep them synchronized much more easily. This first version still keeps legacy system call definitions around, guarded by various #ifdefs, and with numbers larger than 1024. The idea behind this is to make it easier for new architectures to transition from a full list to the reduced set. In particular, the new microblaze architecture that should migrate to using the generic ABI headers can at least use an existing uClibc source tree without major rewrites during the conversion. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-10Merge branch 'tracing-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (244 commits) Revert "x86, bts: reenable ptrace branch trace support" tracing: do not translate event helper macros in print format ftrace/documentation: fix typo in function grapher name tracing/events: convert block trace points to TRACE_EVENT(), fix !CONFIG_BLOCK tracing: add protection around module events unload tracing: add trace_seq_vprint interface tracing: fix the block trace points print size tracing/events: convert block trace points to TRACE_EVENT() ring-buffer: fix ret in rb_add_time_stamp ring-buffer: pass in lockdep class key for reader_lock tracing: add annotation to what type of stack trace is recorded tracing: fix multiple use of __print_flags and __print_symbolic tracing/events: fix output format of user stack tracing/events: fix output format of kernel stack tracing/trace_stack: fix the number of entries in the header ring-buffer: discard timestamps that are at the start of the buffer ring-buffer: try to discard unneeded timestamps ring-buffer: fix bug in ring_buffer_discard_commit ftrace: do not profile functions when disabled tracing: make trace pipe recognize latency format flag ...
2009-06-10Merge branch 'x86-kbuild-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-kbuild-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (46 commits) x86, boot: add new generated files to the appropriate .gitignore files x86, boot: correct the calculation of ZO_INIT_SIZE x86-64: align __PHYSICAL_START, remove __KERNEL_ALIGN x86, boot: correct sanity checks in boot/compressed/misc.c x86: add extension fields for bootloader type and version x86, defconfig: update kernel position parameters x86, defconfig: update to current, no material changes x86: make CONFIG_RELOCATABLE the default x86: default CONFIG_PHYSICAL_START and CONFIG_PHYSICAL_ALIGN to 16 MB x86: document new bzImage fields x86, boot: make kernel_alignment adjustable; new bzImage fields x86, boot: remove dead code from boot/compressed/head_*.S x86, boot: use LOAD_PHYSICAL_ADDR on 64 bits x86, boot: make symbols from the main vmlinux available x86, boot: determine compressed code offset at compile time x86, boot: use appropriate rep string for move and clear x86, boot: zero EFLAGS on 32 bits x86, boot: set up the decompression stack as early as possible x86, boot: straighten out ranges to copy/zero in compressed/head*.S x86, boot: stylistic cleanups for boot/compressed/head_64.S ... Fixed trivial conflict in arch/x86/configs/x86_64_defconfig manually
2009-06-09kernel-doc: cleanup perl scriptRandy Dunlap
Various cleanups of scripts/kernel-doc: - don't use **/ as an ending kernel-doc block since it's not preferred; - typos/spellos - add whitespace around ==, after comma, & around . operator; Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-06-09kbuild: fix headers_exports with boolean expressionRussell King
When we had code like this in a header unifdef failed to deduct that the expression was always false - and we had code exported that was not intended for userspace. #if defined(__KERNEL__) && !defined(__ASSEMBLY__) int a; #endif This commit implment support in unidef which allows it to work out if an #if expression always evaluates true or false for symbols which are being undefined/always defined. The patch is slightly more complicated than I'd hoped because unifdef needs to see lines fully evaluated - doing otherwise causes it to mark the line as "dirty" and copy it over no matter what. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-06-09kbuild/headers_check: refine extern checkAmerigo Wang
'extern' checking information is not clear, refine it. Plus, fix a comment. Signed-off-by: WANG Cong <amwang@redhat.com> [sam: redid the extern error message] Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-06-09kbuild: fix "Argument list too long" error for "make headers_check",Sergei Poselenov
I'm trying to install kernel headers to build a cross-toolchain, but got the following: make ARCH=arm INSTALL_HDR_PATH=/work/psl/eldk-builds/arm-2009-04-21/work/var/tmp/crosstool-0.43-3-root/usr/crosstool/gcc-4.2.2-glibc-20070515T2025-eldk/ +arm-linux-gnueabi/arm-linux-gnueabi/ headers_check ... CHECK include/linux/raid (2 files) CHECK include/linux/spi (1 files) CHECK include/linux/sunrpc (1 files) CHECK include/linux/tc_act (6 files) CHECK include/linux/tc_ematch (4 files) CHECK include/linux/usb (8 files) make[2]: execvp: /bin/sh: Argument list too long make[2]: *** [/work/psl/eldk-builds/arm-2009-04-21/work/var/tmp/crosstool-0.43-3-root/usr/crosstool/gcc-4.2.2-glibc-20070515T2025-eldk/arm-linux-gnueab +i/arm-linux-gnueabi//include/linux/.check] Error 127 make[1]: *** [linux] Error 2 make: *** [headers_check] Error 2 -> Introduce use of xargs to fix this. Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-06-09Remove bashisms from scriptsdann frazier
The '-e' option to echo and brace expansion are not guaranteed to be supported by a POSIX-compliant /bin/sh (e.g. dash) Signed-off-by: dann frazier <dannf@debian.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-06-09kbuild: add hint about __refdata to modpostSam Ravnborg
As requested by Guennadi Liakhovetski Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-06-09scripts/headers_check.pl: correct RE in header CONFIG leak checkRobert P. J. Day
Correct the regular expression in scripts/headers_check.pl to include '_' as a valid character in the class; otherwise, the check will report a "leaked" symbol of CONFIG_A_B_C as merely CONFIG_A. This patch will make no difference whatsoever in the current kernel tree as the call to the perl routine that does that check is currently commented out: &check_include(); &check_asm_types(); &check_sizetypes(); &check_prototypes(); # Dropped for now. Too much noise &check_config(); However, I noticed that problem when I was building the yum downloadable kernel source rpm for fedora 11 (beta), which *does* run that check, and that's where the problem became obvious. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
