path: root/scripts
2005-11-13[PATCH] DocBook: allow to mark structure members privateMartin Waitz
Many structures contain both an internal part and one which is part of the API to other modules. With this patch it is possible to only include these public members in the kernel documentation. Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] kconfig: stricter error checking for .configRoman Zippel
Add some more checks during the parsing of .config, so that after parsing sym_change_count reflects the correct state whether the .config is correct and in sync with the Kconfig or if it needs saving. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] kconfig: improve error handling in the parserRoman Zippel
Add a few error tokens to the parser to catch common errors and print more descriptive error messages. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] kconfig: simplify symbol type parsingRoman Zippel
This simplifies the parser a bit by merging the various symbol types into a single token and adds the type to the keyword hash. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] kconfig: use gperf for kconfig keywordsRoman Zippel
Use gperf to generate a hash for the kconfig keywords. This greatly reduces the size of the generated scanner and makes it easier to extend kconfig. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] kconfig: update kconfig MakefileRoman Zippel
Remove the long obsolete zconf.tab.h and fix kconfig make rules to generate the correct output files. Setting LKC_GENPARSER will now also update the shipped files. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] kconfig: allow variable argumnts for rangeRoman Zippel
This allows variable arguments in the range option for int and hex config symbols. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] kconfig: preset config during all*configRoman Zippel
Allow to force setting of config variables during all{no,mod,yes,random}config to a specific value. For that conf first checks the KCONFIG_ALLCONFIG environment variable for a file name, otherwise it checks for all{no,mod,yes,random}.config and all.config. The file is a normal config file, which presets the config variables, but they are still subject to normal dependency checks. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] kconfig: fix restart for choice symbolsRoman Zippel
The restart check whether new symbols became visible, didn't always work for choice symbols. Even if a choice symbol itself isn't changable, the childs are. This also requires to update the new status of all choice values, once one of them is set. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] kconfig: Fix Kconfig performance bugDavid Gibson
When doing its recursive dependency check, scripts/kconfig/conf uses the flag SYMBOL_CHECK_DONE to avoid rechecking a symbol it has already checked. However, that flag is only set at the top level, so if a symbol is first encountered as a dependency of another symbol it will be rechecked every time it is encountered until it's encountered at the top level. This patch adjusts the flag setting so that each symbol will only be checked once, regardless of whether it is first encountered at the top level, or while recursing down from another symbol. On complex configurations, this vastly speeds up scripts/kconfig/conf. The config in the powerpc merge tree is particularly bad: this patch reduces the time for 'scripts/kconfig/conf -o arch/powerpc/Kconfig' by a factor of 40 on a G5. That's even including the time to print the config, so the speedup in the actual checking is more likely 2 or 3 orders of magnitude. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] typo correction for fix-build-on-nls-free-systemsYuri Vasilevski
A typo fix for fix-build-on-nls-free-systems.patch that caused all systems to be detected as not having NLS. Signed-off-by: Yuri Vasilevski <yvasilev@duke.math.cinvestav.mx> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-06kconfig: fix xconfig on fedora 2 & 3 (x86_64)Sam Ravnborg
From: Than Ngo <than@redhat.com> qt as installed on fedora core (2 and 3) does not work with vanilla kernel. The linker fails to locate the qt lib: Actual Results: # make xconfig HOSTLD scripts/kconfig/qconf /usr/bin/ld: cannot find -lqt collect2: ld returned 1 exit status Than Ngo has provided following fix for the bug. Cc: Than Ngo <than@redhat.com> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-10-30[PATCH] fix build on nls free systemsYuri Vasilevski
I made a patch that detects if libintl.h (needed for nls) is present on the host system and if it's not, it nls support is disabled by providing dummies for the used nls functions. This way if there is nls support on the host system the *config targets will build according to Arnaldo Carvalho de Melo's i18n modifications, else it just uses the original English messages. I have also made a bug report at kernel's bugzilla: http://bugzilla.kernel.org/show_bug.cgi?id=5501 And there is a discussion about this problem in Gentoo's bugzilla: http://bugs.gentoo.org/show_bug.cgi?id=99810 Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] clarify menuconfig /(search) help textRandy Dunlap
Add explicit text about - where menuconfig '/' (search) searches for strings, - that substrings are allowed, and - that regular expressions are supported. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] I2C: add i2c module alias for i2c drivers to useGreg Kroah-Hartman
This is the start of adding hotplug-like support for i2c devices. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-18Add some basic .gitignore filesLinus Torvalds
This still leaves driver and architecture-specific subdirectories alone, but gets rid of the bulk of the "generic" generated files that we should ignore. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-26[PATCH] pcmcia: fix cross-platform issues with pcmcia module aliasesKars de Jong
- Added a missing TO_NATIVE call to scripts/mod/file2alias.c:do_pcmcia_entry() - Add an alignment attribute to struct pcmcia_device_no to solve an alignment issue seen when cross-compiling on x86 for m68k. Signed-off-by: Kars de Jong <jongk@linux-m68k.org> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2005-09-11[SPARC]: Fix dot-symbol exporting for good.Al Viro
From: Al Viro <viro@ZenIV.linux.org.uk> Instead of playing all of these hand-coded assembler aliasing games, just translate symbol names in the name space ".sym" to "_Sym" at module load time. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-10kbuild: add objectifySam Ravnborg
Use foo := $(call objectify, $(foo)) to prefix $(foo) with $(obj)/ unless $(foo) is an absolute path. For now no in-tree users - soon to come. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-09-10[PATCH] kbuild: ignore all debugging info sections in ↵Roland McGrath
scripts/reference_discarded.pl GCC 4 emits more DWARF debugging information than before and there is now a .debug_loc section as well. This causes "make buildcheck" to fail. Rather than just add that one to the special case list, I used a regexp to ignore any .debug_ANYTHING sections in case more show up in the future. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-09-07[PATCH] Adapt scripts/ver_linux to new util-linux version stringsAlexey Dobriyan
Tested with 2.12i and 2.13-pre2. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Strip local symbols from kallsymsRalf Baechle
Local symbols generated by gcc start with a `$'; no point in including them in the kernel. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] kallsyms: change compression algorithmPaulo Marques
This patch changes the way the compression algorithm works. The base algorithm is similiar to the previous but we force the compressed token size to 2. Having a fixed size compressed token allows for a lot of optimizations, and that in turn allows this code to run over *all* the symbols faster than it did before over just a subset. Having it work over all the symbols will make it behave better when symbols change positions between passes, and the "inconsistent kallsyms" messages should become less frequent. In my tests the compression ratio was degraded by about 0.5%, but the results will depend greatly on the number of symbols to compress. Signed-off-by: Paulo Marques <pmarques@grupopie.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-06Merge master.kernel.org:/pub/scm/linux/kernel/git/sam/kbuild Linus Torvalds
2005-09-05[PATCH] kconfig: linux.pot for all archEgry Gabor
The 'make update-po-config' creates the .pot file for the default arch. This patch enhances it with all arch. Signed-off-by: Egry Gabor <gaboregry@t-online.hu> Cc: Arnaldo Carvalho de Melo <acme@conectiva.com.br> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] kconfig: kxgettext: EOL fixEgry Gabor
The end of line character doesn't exist on end of help in all case, check it first. Signed-off-by: Egry Gabor <gaboregry@t-online.hu> Cc: Arnaldo Carvalho de Melo <acme@conectiva.com.br> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] kconfig: kxgettext: message fixEgry Gabor
The gettext doesn't handle the {CONFIG}:00000 markers as sources. I added a simple comment prefix for them. Signed-off-by: Egry Gabor <gaboregry@t-online.hu> Cc: Arnaldo Carvalho de Melo <acme@conectiva.com.br> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-30[PATCH] Make MODULE_DEVICE_TABLE work for vio devicesStephen Rothwell
Make MODULE_DEVICE_TABLE work for vio devices. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-08-19[SPARC]: Deal with glibc changing macro names in modpost.cBen Colline
GLIBC 2.3.4 and later changed the STT_REGISTER macro to STT_SPARC_REGISTER, so we need to cope with that somehow. Original patch from fabbione, reposted by Ben Collins. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-10[PATCH] kbuild: automatically append a short string to the version based ↵Ryan Anderson
upon the git commit If CONFIG_AUTO_LOCALVERSION is set, the user is using a git-based tree, and the current HEAD is not referred to by any tags in .git/refs/tags/, append -g and the first 8 characters of the commit to the version string. This makes it easier to use git-bisect, and/or to do a daily build, without trampling on your older, working builds, or accidentally setting up conflicting sets of modules. Signed-off-by: Ryan Anderson <ryan@michonline.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-07-28[PATCH] fix gconfig crashJoachim Nilsson
I ran glade-2 on the glade file, fixed two missing stock icons and cleaned up the C code that inserts the single/split/full modes. The rest of the patch is minor cleanups only. I refrained from using all the included xpm icons in images.c (like qconf.cc does) in favour of using the stock Gtk+ icons instead. Oh, yes there was a "back" bug in split mode that I also removed, oh well... It has been tested with success by several people, including Jesper Juhl, Randy Dunlap and myself. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-28[PATCH] kconfig: trivial cleanupblaisorblade@yahoo.it
Replace all menu_add_prop mimicking menu_add_prompt with the latter func. I've had to add a return value to menu_add_prompt for one usage. I've rebuilt scripts/kconfig/zconf.tab.c_shipped by hand to reflect changes in the source (I've not the same Bison version so regenerating it wouldn't have been not a good idea), and compared it with what Roman itself did some time ago, and it's the same. So I guess this can be finally merged. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-07-27[PATCH] kbuild: signed char fixes for scriptsJ.A. Magallon
This time I did not break anything... and they shut up gcc4 ;) Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-07-27[PATCH] kbuild: signed/unsigned char fix for make menuconfigKeenan Pepper
Quiet some silly warnings. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-07-27kbuild: fix building external modulesSam Ravnborg
kbuild failed to locate Makefile for external modules. This brought to my attention how the variables for directories have different values in different usage scenarios. Different kbuild usage scenarios: make - plain make in same directory where kernel source lives make O= - kbuild is told to store output files in another directory make M= - building an external module make O= M= - building an external module with kernel output seperate from src Value assigned to the different variables: |$(src) |$(obj) |$(srctree) |$(objtree) make |reldir to k src |as src |abs path to k src |abs path to k src make O= |reldir to k src |as src |abs path to k src |abs path to output dir make M= |abs path to src |as src |abs path to k src |abs path to k src make O= M= |abs path to src |as src |abs path to k src |abs path to k output path to kbuild file: make | $(srctree)/$(src), $(src) make O= | $(srctree)/$(src) make M= | $(src) make O= M= | $(src) From the table above it can be seen that the only good way to find the home directory of the kbuild file is to locate the one of the two variants that is an absolute path. If $(src) is an absolute path (starts with /) then use it, otherwise prefix $(src) with $(srctree). Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-07-25kbuild: define clean before including kbuild fileSam Ravnborg
Defining clean before including the kbuild file give us knowledge when the kbuild file is included for cleaning. This is rarey usefull - but in a corner case in klibc this proved necessary. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> ---
2005-07-25kbuild: fix make O=...Sam Ravnborg
kbuild failed to locate Kbuild.include. Teach kbuild how to find Kbuild files when using make O=... Signed-off-by: Sam Ravnborg <sam@ravnborg.org> ---
2005-07-25kbuild: introduce Kbuild.includeSam Ravnborg
Kbuild.include is a placeholder for definitions originally present in both the top-level Makefile and scripts/Makefile.build. There were a slight difference in the filechk definition, so the most videly used version was kept and usr/Makefile was adopted for this syntax. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> ---
2005-07-25kbuild: drop descend - converting existing usersSam Ravnborg
There was only two users left of descend. Fix them so they use $(clean)= and $(build)=. Drop definition of descend. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> ---
2005-07-21[PATCH] kbuild: make help binrpm-pkg fixCoywolf Qi Hunt
This fixes kbuild make help binrpm-pkg missing `''. Signed-off-by: Coywolf Qi Hunt <coywolf@lovecn.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-07-14kbuild: Fix bug in make deb-pkg when using seperate source and output ↵Sam Ravnborg
directories From: Ryan Anderson <ryan@michonline.com> When running "make O=something deb-pkg", I get a failure that claims I haven't configured my kernel (I have). Running it a second time tells me to run "make mrproper" (include/linux/version.h got built on the first run) Original patch from: From: Ajay Patel <patela@gmail.com> With modifications from: Signed-off-By: Ryan Anderson <ryan@michonline.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-07-14uml: Restore proper descriptions in make deb-pkg targetSam Ravnborg
From: Ryan Anderson <ryan@michonline.com> This pulls the description from the Debian user-mode-linux package, and puts $version back in the appropriate places for both descriptions. Signed-off-by: Ryan Anderson <ryan@michonline.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-07-14uml: Make deb-pkg build target build a Debian-style user-mode-linux packageSam Ravnborg
From: Ryan Anderson <ryan@michonline.com> Make the deb-pkg build target understand the "um" arch and set up the package and directory structure to match a mainline-Debian style user-mode-linux package. This is primarily so that it stops matching, exactly, the naming convention used by normal, non-UML kernels generated by this command. Installing "linux-2.6.11" and "linux-2.6.11", where one is a UML kernel doesn't do the right thing. This fixes that. Signed-off-by: Ryan Anderson <ryan@michonline.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-07-14kbuild: fix buildcheckSam Ravnborg
From: Randy Dunlap <rddunlap@osdl.org> I should not have added init.text test here; it's more than useless, it actually degrades the output. Signed-off-by: Randy Dunlap <rddunlap@osdl.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-07-14kbuild: "PREEMPT" in UTS_VERSIONSam Ravnborg
From: Matt Mackall <mpm@selenic.com> Add PREEMPT to UTS_VERSION where enabled as is done for SMP to make preempt kernels easily identifiable. Added SMP PREEMPT as comment in compile.h to force it to be updated when they change (sam). Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-07-14buildcheck: reduce DEBUG_INFO noise from reference* scriptsSam Ravnborg
From: Randy Dunlap <rddunlap@osdl.org> Reduce noise in 'make buildcheck' that is caused by CONFIG_DEBUG_INFO=y. Signed-off-by: Randy Dunlap <rddunlap@osdl.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-07-14kbuild: Fix build as root then userSam Ravnborg
From: Matthew Wilcox <matthew@wil.cx> I inadvertently built a tree as root and then rebuilt it as a user. I got a lot of prompts ... mv: overwrite `drivers/char/drm/drm_auth.o', overriding mode 0644? Using mv -f fixes that. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-07-13[PATCH] scripts/kernel-doc: don't use uninitialized SRCTREERandy Dunlap
Current kernel-doc (perl) script generates this warning: Use of uninitialized value in concatenation (.) or string at scripts/kernel-doc line 1668. So explicitly check for SRCTREE in the ENV before using it, and then if it is set, append a '/' to the end of it, otherwise the SRCTREE + filename can (will) be missing the intermediate '/'. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-07-13[PATCH] Lindent: ignore .indent.proJeff Mahoney
When I recently submitted a Lindent patch, it turned out that my .indent.pro options were also applied to the tree. This patch directs indent(1) to ignore the .indent.pro directives and only use options specified on the command line. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-07-13[PATCH] kbuild: restrain output of "make help" to 80 columnsYum Rayan
This patch fixes the output of "make help" to fit in a 80 column screen. Please push upstream as part of your other patches. Signed-off-by: Yum Rayan <yum.rayan@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
