commit 99e3a1eb3c22bb671c6f3d22d8244bfc9fad8185 upstream.
While building the kernel, we end-up calling modpost with -K and -M
options for the same file (Modules.markers). This is resulting in
modpost's main function calling read_markers() and then write_markers() on
the same file.
We then have read_markers() mmap'ing the file, and writer_markers()
opening that same file for writing.
The issue is that read_markers() exits without munmap'ing the file and is
as a matter holding a reference on Modules.markers. When write_markers()
is opening that very same file for writing, we still have a reference on
it and cygwin (Windows?) is then making fopen() fail with EPERM.
Calling release_file() before exiting read_markers() clears that reference
(and memory leak) and fopen() then succeeds.
Tested on both cygwin (1.3.22) and Linux. Also ran modpost within
valgrind on Linux to make sure that the munmap'ed file was not accessed
after read_markers()
Signed-off-by: Cedric Hombourger <chombourger@gmail.com>
Cc: <stable@kernel.org>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
'make randconfig' uses glibc's rand function, and the seed of
that PRNG is set via:
srand(time(NULL));
But 'time()' only increases once every second - freezing the
randconfig result within a single second.
My Nehalem testbox does randconfig much faster than 1 second
and i have a few scripts that do 'randconfig until condition X'
loops.
Those scripts currently waste a lot of CPU time due to randconfig
changing its seed only once per second currently.
Change the seed to be micrseconds based. (I checked the statistical
spread of the seed - the now.tv_sec*now.tv_usec multiplication
there further improves it.)
Cc: Roman Zippel <zippel@linux-m68k.org>
[sam: fix for systems where usec is zero - noticed by Geert Uytterhoeven]
Ingo Molnar reported that 'make randconfig' was not covering
choice blocks properly, resulting in certain config options
being left out of randconfig testing altogether.
With the following patch we:
- properly randomize choice value for normal choice blocks
- properly randomize for multi choice blocks
- added several comments to explain what is going on
The root cause of the bug was that SYMBOL_VALID was set on the
symbol representing the choice block so clearing this did
the trick initially.
But testign revealed a few more issues that is now fixed.
Reported-by: Ingo Molnar <mingo@elte.hu>
Running 'make rpm' fails when CONFIG_LOCALVERSION_AUTO=y and using a kernel source
tree under SCM. This is due to KERNELRELEASE being different when the initial make
is run and when make is run from rpmbuild.
mkspec creates kernel.spec using KERNELRELEASE:
<mkspec>
echo "%files"
echo '%defattr (-, root, root)'
echo "%dir /lib/modules"
echo "/lib/modules/$KERNELRELEASE"
echo "/lib/firmware"
echo "/boot/*"
echo ""
</mkspec>
When CONFIG_LOCALVERSION_AUTO=y scripts/setlocalversion is called and grabs any
additional version info from SCM. Next, the srctree is tarred up and SCM
information is excluded.
rpmbuild reruns make and in the process generates a new include/config/kernel.release
and thus a new KERNELRELEASE. However this time the SCM information is gone so
KERNELRELEASE no longer has the additional version information. When "make modules_install"
runs, it uses the new KERNELRELEASE value to determine where to install the modules.
This conflicts with where the spec file assumes they are going because of the
mis-matching KERNELRELEASE versions.
<snippet>
+ INSTALL_MOD_PATH=/var/tmp/kernel-2.6.29rc4tip01479g5d85422-root
+ make -j16 modules_install
INSTALL crypto/aead.ko
INSTALL crypto/cbc.ko
INSTALL crypto/chainiv.ko
INSTALL crypto/crc32c.ko
INSTALL crypto/crypto_algapi.ko
INSTALL crypto/crypto_blkcipher.ko
INSTALL crypto/crypto_hash.ko
INSTALL crypto/cryptomgr.ko
INSTALL crypto/ecb.ko
INSTALL crypto/eseqiv.ko
INSTALL crypto/krng.ko
INSTALL crypto/md5.ko
INSTALL crypto/pcbc.ko
INSTALL crypto/rng.ko
INSTALL drivers/block/cciss.ko
INSTALL drivers/hid/hid-dummy.ko
INSTALL drivers/scsi/iscsi_tcp.ko
INSTALL drivers/scsi/libiscsi.ko
INSTALL drivers/scsi/libiscsi_tcp.ko
INSTALL drivers/scsi/scsi_transport_iscsi.ko
INSTALL drivers/scsi/scsi_wait_scan.ko
INSTALL fs/lockd/lockd.ko
INSTALL fs/nfs/nfs.ko
INSTALL fs/nfsd/nfsd.ko
INSTALL lib/libcrc32c.ko
INSTALL net/sunrpc/sunrpc.ko
DEPMOD 2.6.29-rc4-tip
+ cp arch/x86/boot/bzImage
/var/tmp/kernel-2.6.29rc4tip01479g5d85422-root/boot/vmlinuz-2.6.29-rc4-tip-01479-g5d85422
+ cp System.map
/var/tmp/kernel-2.6.29rc4tip01479g5d85422-root/boot/System.map-2.6.29-rc4-tip-01479-g5d85422
+ cp .config
/var/tmp/kernel-2.6.29rc4tip01479g5d85422-root/boot/config-2.6.29-rc4-tip-01479-g5d85422
+ cp vmlinux vmlinux.orig
+ bzip2 -9 vmlinux
+ mv vmlinux.bz2
/var/tmp/kernel-2.6.29rc4tip01479g5d85422-root/boot/vmlinux-2.6.29-rc4-tip-01479-g5d85422.bz2
+ mv vmlinux.orig vmlinux
+ /usr/lib/rpm/brp-compress
Processing files: kernel-2.6.29rc4tip01479g5d85422-2
error: File not found:
/var/tmp/kernel-2.6.29rc4tip01479g5d85422-root/lib/modules/2.6.29-rc4-tip-01479-g5d85422
RPM build errors:
File not found:
make[1]: *** [rpm] Error 1
make: *** [rpm] Error 2
</snippet>
I have tested this patch on git -tip, Linus' git tree, and the kernel.org tar files, both
with and without CONFIG_LOCALVERSION_AUTO=y.
Signed-off-by: Josh Hunt <josh@scalex86.org>
The contents of the %clean section in mkspec is currently commented
out leaving RPM_BUILD_ROOT and its contents on the build machine.
This patch removes it once the rpm build process is complete.
This fixes an error when compiling the kernel.
CHK include/linux/version.h
HOSTCC scripts/unifdef
scripts/unifdef.c:209: error: conflicting types for 'getline'
/usr/include/stdio.h:651: note: previous declaration of 'getline' was here
make[1]: *** [scripts/unifdef] Error 1
make: *** [__headers] Error 2
Signed-off-by: Andy Whitcroft <apw@canonical.com>
Add __ref as a sparse modifier.
We should allow testing of all modifiers not just attributes. Extend
testing and test for all the know modifiers.
We must make sure we do not misrecognise a modifier as an Identifier
when trying to match types. Prevent us matching this:
void * __ref
We may have any modifier following a pointer type star. Handle this:
void * __user * __user foo;
We need to handle interspersed modifiers in the middle of pointer types,
for example:
void * __user * __user bar;
We are triggering the -p0 check for our own diffs generated using --file
command line option. Suppress this check for files.
We say that in_atomic() is ok in the core kernel, but then always report
it regardless of where in the kernel it is. Keep quiet if it is used in
kernel/*.
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes:
kbuild: create the source symlink earlier in the objdir
scripts: add x86 64 bit support to the markup_oops.pl script
scripts: add x86 register parser to markup_oops.pl
kbuild: add sys_* entries for syscalls in tags
kbuild: fix tags generation of config symbols
bootgraph: fix for use with dot symbols
kbuild: add vmlinux to kernel rpm
kbuild,setlocalversion: shorten the make time when using svn
Fix endianness of bus member of hid_device_id in modpost.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Reported-by: Nye Liu <nyet@mrv.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
An oops dump also contains the register values.
This patch parses these for (32 bit) x86, and then annotates the
disassembly with these values; this helps in analysis of the oops by the
developer, for example, NULL pointer or other pointer bugs show up clearly
this way.
Currently, it is no longer possible to use the tags file to jump to
system call function definitions with sys_foo, because the definitions
are obscured by use of the SYSCALL_DEFINE* macros.
This patch adds the appropriate option to ctags to make it see through
the macro. Also, it adds the ENTRY() work already done for Exuberant
to Emacs too.
Signed-off-by: Rabin Vincent <rabin@rab.in>
commit 4f628248a578585472e19e4cba2c604643af8c6c aka "kbuild: reintroduce
ALLSOURCE_ARCHS support for tags/cscope" breaks tags generation for
Kconfig symbols.
Steps to reproduce:
make tags
vi -t PROC_FS
It should jump to 'config PROC_FS' line.
Tested-by: Pete Wyckoff <pw@padd.com>
powerpc has dot symbols, so the dmesg output looks like:
<4>[ 0.327310] calling .migration_init+0x0/0x9c @ 1
<4>[ 0.327595] initcall .migration_init+0x0/0x9c returned 1 after 0 usecs
The below fixes bootgraph.pl so it handles this correctly.
Signed-off-by: Michael Neuling <mikey@neuling.org>
We are building an automated system to test kernels weekly and need to
provide an rpm to our QA dept. We would like to use the ability to create
kernel rpms already in the kernel's Makefile, but need the vmlinux file
included in the rpm for later debugging.
This patch adds a compressed vmlinux to the kernel rpm when doing a
make rpm-pkg or binrpm-pkg and upon install places the vmlinux file in /boot.
Don't bother doing `svn st` as it takes a retarded amount of time when
the source is cold
Signed-off-by: Mike Frysinger <vapier.adi@gmail.com>
Signed-off-by: Bryan Wu <cooloney@kernel.org>
Fix kernel-doc processing of SYSCALL wrappers.
The SYSCALL wrapper patches played havoc with kernel-doc for
syscalls. Syscalls that were scanned for DocBook processing
reported warnings like this one, for sys_tgkill:
Warning(kernel/signal.c:2285): No description found for parameter 'tgkill'
Warning(kernel/signal.c:2285): No description found for parameter 'pid_t'
Warning(kernel/signal.c:2285): No description found for parameter 'int'
because the macro parameters all "look like" function parameters,
although they are not:
* sys_tgkill - send signal to one specific thread
* @tgid: the thread group ID of the thread
* @pid: the PID of the thread
* @sig: signal to be sent
* This syscall also checks the @tgid and returns -ESRCH even if the PID
* exists but it's not belonging to the target process anymore. This
* method solves the problem of threads exiting and PIDs getting reused.
SYSCALL_DEFINE3(tgkill, pid_t, tgid, pid_t, pid, int, sig)
This patch special-cases the handling SYSCALL_DEFINE* function
prototypes by expanding them to
long sys_foobar(type1 arg1, type1 arg2, ...)
kbuild: fix kbuild.txt typos
kbuild: print usage with no arguments in scripts/config
Revert "kbuild: strip generated symbols from *.ko"
Based on a patch from Brian, who identified the issue.
Signed-off-by: Bryan Kadzban <bryan@kadzban.is-a-geek.net>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
In the general use case struct seq_operations should be a const object.
Check for and warn where it is not.
We should not be continuing a braced section with an if, for example:
if (...) {
} if (...) {
Detect this and suggest adding a newline.
When we allow return to have surrounding parentheses when containing
comparison operators we are not correctly handling the case where the
values contain array sufffixes. Squash them.
We should not be complaining about the prefix spacing for types and casts.
We are triggering here because the check for spacing between '*'s is
overly loose. Tighten this up.
If the #if opening statement is not in the context then the context stack
can be empty. Handle this by ensuring there is always a blank entry in
the stack.
Tested-by: Dhaval Giani <dhaval@linux.vnet.ibm.com>
Requested by Sam.
This reverts commit ad7a953c522ceb496611d127e51e278bfe0ff483.
And commit: ("allow stripping of generated symbols under CONFIG_KALLSYMS_ALL")
9bb482476c6c9d1ae033306440c51ceac93ea80c
These stripping patches has caused a set of issues:
1) People have reported compatibility issues with binutils due to
lack of support for `--strip-unneeded-symbols' with objcopy 2.15.92.0.2
Reported by: Wenji
2) ccache and distcc no longer works as expeced
Reported by: Ted, Roland, + others
3) The installed modules increased a lot in size
Reported by: Ted, Davej + others
Reported-by: Wenji Huang <wenji.huang@oracle.com>
Reported-by: "Theodore Ts'o" <tytso@mit.edu>
Reported-by: Dave Jones <davej@redhat.com>
Reported-by: Roland McGrath <roland@redhat.com>
There has been some light flamewar on lkml about decoding oopses
in modules (as part of the crashdump flamewar).
Now this isn't rocket science, just the markup_oops.pl script
cheaped out and didn't handle modules. But really; a flamewar
all about that?? What happened to C++ in the kernel or reading
files from inside the kernel?
This patch adds module support to markup_oops.pl; it's not the
most pretty perl but it works for my testcases...
It is useful for diagnosing boot performance to see where async function
calls are waiting on serialization... this patch adds this
functionality to the bootgraph.pl script.
The waiting time is shown as a half transparent, gray bar through the
block that is waiting.
I often change single options in .config files. Instead of using
an editor or one of the frontends it's convenient to do this from
the command line. It's also useful to do from automated build scripts
when building different variants from a base config file.
I extracted most of the CONFIG manipulation code from one of my
build scripts into a new shell script scripts/config
The script is not integrated with the normal Kconfig machinery
and doesn't do any checking against Kconfig files, but just manipulates
that text format. This is always done at make time anyways.
I believe this script would be a useful standard addition for scripts/*
Sample usage:
./scripts/config --disable smp
Disable SMP in .config file
./scripts/config --file otherdir/.config --module e1000e
Enable E1000E as module in otherdir/.config
./scripts/config --state smp
y
Check state of config option CONFIG_SMP
After merging into git please make scripts/config executable
This patch reintroduce the ALLSOURCE_ARCHS support for tags/TAGS/
cscope targets. The Kbuild previously has this feature, but after
moving the targets into scripts/tags.sh, ALLSOURCE_ARCHS disappears.
It's something like this:
$ make ALLSOURCE_ARCHS="x86 mips arm" tags cscope
Signed-off-by: Jike Song <albcamus@gmail.com>
Dave Jones, in his blog, had some feedback about the bootchart script:
Primarily his complaint was that shorter delays weren't visualized.
The reason for that was that too small delays will have their labels
mixed up in the graph in an unreadable mess.
This patch has a fix for this; for one, it makes the output wider,
so more will fit.
The second part is that smaller delays are now shown with a
much smaller font for the label; while this isn't per se
readable at a 1:1 zoom, at least you can zoom in with most SVG
viewing applications and see what it is you are looking at.
Rafael reported:
I get the following error from 'make modules_install' on my test boxes:
HOSTCC firmware/ihex2fw
/home/rafael/src/linux-2.6/firmware/ihex2fw.c:268: fatal error: opening dependency file firmware/.ihex2fw.d: Read-only file system
compilation terminated.
make[3]: *** [firmware/ihex2fw] Error 1
make[2]: *** [_modinst_post] Error 2
make[1]: *** [sub-make] Error 2
make: *** [all] Error 2
where the configuration is that the kernel is compiled on a build box
with 'make O=<destdir> -j5' and then <destdir> is mounted over NFS read-only by
each test box (full path to this directory is the same on the build box and on
the test boxes). Then, I cd into <destdir>, run 'make modules_install' and get
the error above.
The issue turns out to be that we when we install firmware pick
up the list of firmware blobs from firmware/Makefile.
And this triggers the Makefile rules to update ihex2fw.
There were two solutions for this issue:
1) Move the list of firmware blobs to a separate file
2) Avoid ihex2fw rebuild by moving it to scripts
As I seriously beleive that the list of firmware blobs should be
done in a fundamental different way solution 2) was selected.
Reported-and-tested-by: "Rafael J. Wysocki" <rjw@sisk.pl>
Clean up checkpatch using perlcritic.
In the general use case struct file_operations should be a const object.
Check for and warn where it is not. As suggested by Steven and Ingo.
Acked-by: Steven Rostedt <rostedt@goodmis.org>
When checking for assignments within if conditionals we check the whole of
the condition, but the match is performed using a line constrained regular
expression. This means we can miss split conditionals or those on the
second line. Allow the check to span lines.
Ensure we do not report identifiers containing the word static as static
declarations. For example this should not be reported as an unecessary
assignement of 0:
long nr_static = 0;
When picking up a complete statement or block for analysis we cannot
simply track open/close/etc parenthesis we must take into account
preprocessor section boundaries.
We are miscategorising a continuation fragment following an operator
which may lead to us thinking that there is a space after it when there is
not. Fix this up.
Loosen spacing checks to correctly detect this valid use of a typedef:
typedef struct rcu_data *(*get_data_func)(int);
Seems like every other release we have someone who updates vmlinux.lds.h
and adds C-visible symbols without VMLINUX_SYMBOL() around them. So start
checking the file and reject assignments which have plain symbols on
either side.
[apw@canonical.com: soften the check, add tests]
It seems to be a common idiom to include braces on conditionals in all
contexts including return. Allow this exception to the return is not a
function checks. Reported by Kay Sievers.
Cc: Kay Sievers <kay.sievers@vrfy.org>
