path: root/scripts
2013-05-11menuconfig: Fix memory leak introduced by jump keys featureBenjamin Poirier
commit edb749f4390b3c1604233dc7c4fb0361f472e712 upstream. Fixes the memory leak of struct jump_key allocated in get_prompt_str() Signed-off-by: Benjamin Poirier <bpoirier@suse.de> Tested-by: "Yann E. MORIN" <yann.morin.1998@free.fr> Reviewed-by: "Yann E. MORIN" <yann.morin.1998@free.fr> Signed-off-by: "Yann E. MORIN" <yann.morin.1998@free.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07localmodconfig: Process source kconfig files as they are foundSteven Rostedt
commit ced9cb1af1e3486cc14dca755a1b3fbadf06e90b upstream. A bug was reported that caused localmodconfig to not keep all the dependencies of ATH9K. This was caused by the kconfig file: In drivers/net/wireless/ath/Kconfig:
2013-04-17checkpatch: fix stringification macro defectJoe Perches
Fix checkpatch misreporting defect with stringification macros ERROR: Macros with complex values should be enclosed in parenthesis #27: FILE: arch/arm/include/asm/kgdb.h:41: +#define ___to_string(X) #X Signed-off-by: Joe Perches <joe@perches.com> Reported-by: Vincent Stehlé <v-stehle@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-15Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild fix from Michal Marek: "One fix for for make headers_install/headers_check to not require make 3.81. The requirement has been accidentally introduced in 3.7." * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: fix make headers_check with make 3.80
2013-03-05kbuild: fix make headers_check with make 3.80Sam Ravnborg
Commit 10b63956 ("UAPI: Plumb the UAPI Kbuilds into the user header installation and checking") introduced a dependency of make 3.81 due to use of $(or ...) We do not want to lift the requirement to gmake 3.81 just yet... Included are a straightforward conversion to $(if ...) Bisected-and-tested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: <stable@vger.kernel.org> [v3.7+] Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-03-03Merge tag 'metag-v3.9-rc1-v4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag Pull new ImgTec Meta architecture from James Hogan: "This adds core architecture support for Imagination's Meta processor cores, followed by some later miscellaneous arch/metag cleanups and fixes which I kept separate to ease review: - Support for basic Meta 1 (ATP) and Meta 2 (HTP) core architecture - A few fixes all over, particularly for symbol prefixes - A few privilege protection fixes - Several cleanups (setup.c includes, split out a lot of metag_ksyms.c) - Fix some missing exports - Convert hugetlb to use vm_unmapped_area() - Copy device tree to non-init memory - Provide dma_get_sgtable()" * tag 'metag-v3.9-rc1-v4' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag: (61 commits) metag: Provide dma_get_sgtable() metag: prom.h: remove declaration of metag_dt_memblock_reserve() metag: copy devicetree to non-init memory metag: cleanup metag_ksyms.c includes metag: move mm/init.c exports out of metag_ksyms.c metag: move usercopy.c exports out of metag_ksyms.c metag: move setup.c exports out of metag_ksyms.c metag: move kick.c exports out of metag_ksyms.c metag: move traps.c exports out of metag_ksyms.c metag: move irq enable out of irqflags.h on SMP genksyms: fix metag symbol prefix on crc symbols metag: hugetlb: convert to vm_unmapped_area() metag: export clear_page and copy_page metag: export metag_code_cache_flush_all metag: protect more non-MMU memory regions metag: make TXPRIVEXT bits explicit metag: kernel/setup.c: sort includes perf: Enable building perf tools for Meta metag: add boot time LNKGET/LNKSET check metag: add __init to metag_cache_probe() ...
2013-03-02genksyms: fix metag symbol prefix on crc symbolsJames Hogan
Meta uses symbol prefixes, so add "metag" to the list of architectures to set the mod_prefix to "_" for. This fixes __crc_* symbols to add the extra underscore to match _CRC_SYMBOL macro in <linux/export.h> and so that modpost finds them. Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02scripts/checkstack.pl: Add metag supportJames Hogan
Adapt checkstack.pl so that it works for metag. Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: ftrace supportJames Hogan
Add ftrace support for metag. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
2013-02-27Merge branch 'akpm' (final batch from Andrew)Linus Torvalds
Merge third patch-bumb from Andrew Morton: "This wraps me up for -rc1. - Lots of misc stuff and things which were deferred/missed from patchbombings 1 & 2. - ocfs2 things - lib/scatterlist - hfsplus - fatfs - documentation - signals - procfs - lockdep - coredump - seqfile core - kexec - Tejun's large IDR tree reworkings - ipmi - partitions - nbd - random() things - kfifo - tools/testing/selftests updates - Sasha's large and pointless hlist cleanup" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (163 commits) hlist: drop the node parameter from iterators kcmp: make it depend on CHECKPOINT_RESTORE selftests: add a simple doc tools/testing/selftests/Makefile: rearrange targets selftests/efivarfs: add create-read test selftests/efivarfs: add empty file creation test selftests: add tests for efivarfs kfifo: fix kfifo_alloc() and kfifo_init() kfifo: move kfifo.c from kernel/ to lib/ arch Kconfig: centralise CONFIG_ARCH_NO_VIRT_TO_BUS w1: add support for DS2413 Dual Channel Addressable Switch memstick: move the dereference below the NULL test drivers/pps/clients/pps-gpio.c: use devm_kzalloc Documentation/DMA-API-HOWTO.txt: fix typo include/linux/eventfd.h: fix incorrect filename is a comment mtd: mtd_stresstest: use prandom_bytes() mtd: mtd_subpagetest: convert to use prandom library mtd: mtd_speedtest: use prandom_bytes mtd: mtd_pagetest: convert to use prandom library mtd: mtd_oobtest: convert to use prandom library ...
2013-02-27get_maintainer: allow keywords to match filenamesStephen Warren
Allow K: entries in MAINTAINERS to match directly against filenames; either those extracted from patch +++ or --- lines, or those specified on the command-line using the -f option. This potentially allows fewer lines in a MAINTAINERS entry, if all the relevant files are scattered throughout the whole kernel tree, yet contain some common keyword. An example would be using an ARM SoC name as the keyword to catch all related drivers. I don't think setting exact_pattern_match_hash would be appropriate here; at least for intended Tegra use case, this feature is to ensure that all Tegra-related driver changes get Cc'd to the Tegra mailing list. Setting exact_pattern_match_hash would prevent git history parsing for e.g. S-o-b tags, which still seems like it would be useful. Hence, this flag isn't set. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27scripts/kernel-doc: handle struct member __aligned without numbersNishanth Menon
Commit ef5da59f1260 ("scripts/kernel-doc: handle struct member __aligned") permits "char something [123] __aligned(8);". However, by using \d we constraint ourselves with integers. This is not always the case. In fact, it might be better to do char something[123] __aligned(sizeof(u16)); For example, With wireless_dev defining: u8 address[ETH_ALEN] __aligned(sizeof(u16)); With \d, scripts/kernel-doc erroneously says: Warning(include/net/cfg80211.h:2618): Excess struct/union/enum/typedef member 'address' description in 'wireless_dev' This is because the regex __aligned\s*\(\d+\) fails match at \d as sizeof is used. So replace \d with . to indicate "something" in kernel-doc to ignore __aligned(SOMETHING) in structs. With this change, we can use integers OR sizeof() or macros as we please. Signed-off-by: Nishanth Menon <nm@ti.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Johannes Berg <johannes.berg@intel.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27checkpatch: improve CamelCase test for PageJoe Perches
Add the ClearPage/SetPage/TestClearPage/TestSetPage variants to the not reported Page CamelCase variables. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kconfig changes from Michal Marek: "I forgot to send a pull request in time for the v3.8-rc1 merge window, so the list is a bit longer this time: - menuconfig enables extended colors in ncurses if the wide-character version is used. - CONFIG_ prefix can be specified in the environment to make life easier for people using kconfig multiple times in a single tree (no functional change in the kernel kconfig usage). - kconfig aborts on OOM. - inputboxes in menuconfig allow to move the cursor. - menuconfig has Save/Load buttons now. - xconfig build fix with new g++ and Qt3. - nconfig color scheme fix and help text update. - make oldconfig prints newlines when output is redirected. - some other minor fixes." * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: Fix missing '\n' for NEW symbols in yes "" | make oldconfig >conf.new kconfig: nconf: rewrite labels of function keys line kconfig: nconf: rewrite help texts kconfig: fix a compiliation error when using make xconfig nconf: function keys line, change background color for better readability menuconfig: Get rid of the top-level entries for "Load an Alternate/Save an Alternate" menuconfig: Add Save/Load buttons kconfig:lxdialog: remove duplicate code menuconfig:inputbox: support navigate input position kconfig: document use of CONFIG_ environment variable scripts/kconfig: ensure we use proper CONFIG_ prefix merge_config.sh: Add option to specify output dir Revert "kconfig-language: add to hints" kconfig: Regenerate lexer kconfig: Fix malloc handling in conf tools kconfig: get CONFIG_ prefix from the environment kconfig: add a function to get the CONFIG_ prefix kconfig: remove CONFIG_ from string constants menuconfig: fix extended colors ncurses support
2013-02-27Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull misc non-critical kbuild changes from Michal Marek: - Fix for make TAGS - Fix for make rpm - Some new coccinelle semantic patches * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: scripts/coccinelle: find constant additions that could be bit ors coccicheck: Allow to show the executed command line coccicheck: Allow the user to give a V= (verbose) argument scripts/coccinelle/misc/memcpy-assign.cocci: Replace memcpy with struct assignment kbuild: clear KBUILD_SRC when calling 'make' in RPM spec scripts/coccinelle/misc/semicolon.cocci: Add unneeded semicolon test scripts/tags.sh: Fix regex syntax for etags
2013-02-27Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild changes from Michal Marek: - Alias generation in modpost is cross-compile safe. - kernel/timeconst.h is now generated using a bc script instead of perl. - scripts/link-vmlinux.sh now works with an alternative $KCONFIG_CONFIG. - destination-y for exported headers is supported in Kbuild files again. - depmod is called with -P $CONFIG_SYMBOL_PREFIX on architectures that need it. - CONFIG_DEBUG_INFO_REDUCED disables var-tracking - scripts/setlocalversion works with too much translated locales ;) * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: Fix reading of .config in link-vmlinux.sh kbuild: Unset language specific variables in setlocalversion script Kbuild: Disable var tracking with CONFIG_DEBUG_INFO_REDUCED depmod: pass -P $CONFIG_SYMBOL_PREFIX kbuild: Fix destination-y for installed headers scripts/link-vmlinux.sh: source variables from KCONFIG_CONFIG kernel: Replace timeconst.pl with a bc script mod/file2alias: make modalias generation safe for cross compiling
2013-02-25Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module update from Rusty Russell: "The sweeping change is to make add_taint() explicitly indicate whether to disable lockdep, but it's a mechanical change." * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: MODSIGN: Add option to not sign modules during modules_install MODSIGN: Add -s <signature> option to sign-file MODSIGN: Specify the hash algorithm on sign-file command line MODSIGN: Simplify Makefile with a Kconfig helper module: clean up load_module a little more. modpost: Ignore ARC specific non-alloc sections module: constify within_module_* taint: add explicit flag to show whether lock dep is still OK. module: printk message when module signature fail taints kernel.
2013-02-25Merge branch 'kbuild/rc-fixes' into kbuild/kconfigMichal Marek
There is one kconfig fix in the rc-fixes branch that I forgot to submit for 3.8, so let's add it to the kconfig branch for 3.9-rc1.
2013-02-25kbuild: Fix reading of .config in link-vmlinux.shMichal Marek
The shell '.' command is not required to search the current directory as a fallback and in fact newer versions of bash in sh-mode do not do this. Force reading the file from the current directory if $KCONFIG_CONFIG contains no '/'. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-02-22scripts/coccinelle: find constant additions that could be bit orsJulia Lawall
Semantic patch (http://coccinelle.lip6.fr/) to check for constants that are added but are used elsewhere as bitmasks. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-02-22coccicheck: Allow to show the executed command lineBernd Schubert
On my system one of the tests failed with "Fatal error: exception Failure("No OCaml compiler found! Install either ocamlopt or ocamlopt.opt")". Investigating such issues is easier if the executed command line is being shown. Signed-off-by: Bernd Schubert <bernd.schubert@itwm.fraunhofer.de> CC: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Nicolas Palix <nicolas.palix@imag.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-02-22kbuild: Unset language specific variables in setlocalversion scriptChristophe Leroy
This patch allows the use of setlocalversion script regardless of the language parameters. Otherwise, the `svn info 2>/dev/null | grep '^Last Changed Rev'` returns nothing because for instance, in French the text 'Last Changed Rev' is replaced by 'Révision de la dernière modification' Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-02-22depmod: pass -P $CONFIG_SYMBOL_PREFIXJames Hogan
On architectures which have symbol prefixes, depmod emits lots of warnings like this: WARNING: $module.ko needs unknown symbol $symbol This is because depmod isn't being passed the -P <symbol_prefix> arguments to specify the symbol prefix to ignore. This option is included since the 3.13 release of module-init-tools. Update scripts/depmod.sh to take extra arguments for the symbol prefix (required but may be empty), and update the main Makefile to always pass "$(CONFIG_SYMBOL_PREFIX)" to scripts/depmod.sh. If the provided symbol prefix is non-empty, scripts/depmod.sh checks if depmod --version reports module-init-tools with a version number < 3.13 otherwise it appends -P $SYMBOL_PREFIX to the depmod command line. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Michal Marek <mmarek@suse.cz> Cc: linux-kbuild@vger.kernel.org Cc: Mike Frysinger <vapier@gentoo.org> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: uclinux-dist-devel@blackfin.uclinux.org Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-02-22kbuild: Fix destination-y for installed headersJesper Nilsson
Commit 10b63956fce7f369cc37fd4d994f09bd5203efe4 which plumbed in UAPI broke the destination-y functionality of scripts/Makefile.headersinst. The variable destination-y is used in a := assignment and so is expanded at declaration time, and the include of the Kbuild fragments that set destination-y to something is after this time, so it now always expands empty. There are no in-tree users of destination-y, but it allows any Kbuild-fragment to redirect where headers are installed. Just move the assignment of the variable that uses it below the include of the Kbuild fragment. Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Michal Marek <mmarek@suse.cz> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-02-22coccicheck: Allow the user to give a V= (verbose) argumentBernd Schubert
Do not run with verbosity on/off depending on the ONLINE variable, which gets set with C=1 or C=2, but allow the user to set the verbosity using kernel default make V= paramemter. Verbosity is off by default now. Signed-off-by: Bernd Schubert <bernd.schubert@itwm.fraunhofer.de> CC: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Nicolas Palix <nicolas.palix@imag.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-02-22scripts/coccinelle/misc/memcpy-assign.cocci: Replace memcpy with struct ↵Peter Senna Tschudin
assignment There are error-prone memcpy() that can be replaced by struct assignment that are type-safe and much easier to read. This semantic patch looks for memcpy() that can be replaced by struct assignment. Inspired by patches sent by Ezequiel Garcia <elezegarcia@gmail.com> Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-02-22kbuild: clear KBUILD_SRC when calling 'make' in RPM specDavid R. Bild
'make rpm-pkg' and 'make binrpm-pkg' fail when the kernel source is read-only. Specifically, when the RPM spec generated by scripts/package/mkspec is run, KBUILD_SRC happens to be set to the source location and thus the invocation of 'make headers_install' fails when an internal call to 'filechk' tries to write a file into the source tree. The fix is to clear KBUILD_SRC for the 'make headers_install' invocation in the spec file, as is already done for the 'make modules_install' invocation. Signed-off-by: David R. Bild <drbild@umich.edu> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-02-22scripts/link-vmlinux.sh: source variables from KCONFIG_CONFIGMichael Grzeschik
Its possible to superseed the config file with KCONFIG_CONFIG and have completely no .config in the tree. The current script is sourcing .config in every case, so the kernel will never build succesfully. This patch fixes that issue by sourcing KCONFIG_CONFIG instead. Signed-off-by: Michael Grzeschik <m.grzeschik@pengutronix.de> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-02-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "Assorted tiny fixes queued in trivial tree" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (22 commits) DocBook: update EXPORT_SYMBOL entry to point at export.h Documentation: update top level 00-INDEX file with new additions ARM: at91/ide: remove unsused at91-ide Kconfig entry percpu_counter.h: comment code for better readability x86, efi: fix comment typo in head_32.S IB: cxgb3: delay freeing mem untill entirely done with it net: mvneta: remove unneeded version.h include time: x86: report_lost_ticks doesn't exist any more pcmcia: avoid static analysis complaint about use-after-free fs/jfs: Fix typo in comment : 'how may' -> 'how many' of: add missing documentation for of_platform_populate() btrfs: remove unnecessary cur_trans set before goto loop in join_transaction sound: soc: Fix typo in sound/codecs treewide: Fix typo in various drivers btrfs: fix comment typos Update ibmvscsi module name in Kconfig. powerpc: fix typo (utilties -> utilities) of: fix spelling mistake in comment h8300: Fix home page URL in h8300/README xtensa: Fix home page URL in Kconfig ...
2013-02-21Merge branch 'akpm' (incoming from Andrew)Linus Torvalds
Merge misc patches from Andrew Morton: - Florian has vanished so I appear to have become fbdev maintainer again :( - Joel and Mark are distracted to welcome to the new OCFS2 maintainer - The backlight queue - Small core kernel changes - lib/ updates - The rtc queue - Various random bits * akpm: (164 commits) rtc: rtc-davinci: use devm_*() functions rtc: rtc-max8997: use devm_request_threaded_irq() rtc: rtc-max8907: use devm_request_threaded_irq() rtc: rtc-da9052: use devm_request_threaded_irq() rtc: rtc-wm831x: use devm_request_threaded_irq() rtc: rtc-tps80031: use devm_request_threaded_irq() rtc: rtc-lp8788: use devm_request_threaded_irq() rtc: rtc-coh901331: use devm_clk_get() rtc: rtc-vt8500: use devm_*() functions rtc: rtc-tps6586x: use devm_request_threaded_irq() rtc: rtc-imxdi: use devm_clk_get() rtc: rtc-cmos: use dev_warn()/dev_dbg() instead of printk()/pr_debug() rtc: rtc-pcf8583: use dev_warn() instead of printk() rtc: rtc-sun4v: use pr_warn() instead of printk() rtc: rtc-vr41xx: use dev_info() instead of printk() rtc: rtc-rs5c313: use pr_err() instead of printk() rtc: rtc-at91rm9200: use dev_dbg()/dev_err() instead of printk()/pr_debug() rtc: rtc-rs5c372: use dev_dbg()/dev_warn() instead of printk()/pr_debug() rtc: rtc-ds2404: use dev_err() instead of printk() rtc: rtc-efi: use dev_err()/dev_warn()/pr_err() instead of printk() ...
2013-02-21checkpatch: fix USLEEP_RANGE testBruce Allan
Do not test udelay() for a value less than 10usec when passed a variable instead of a hard-coded number; there is no way for checkpatch to know the value of the variable. As it is today, it will complain about variables with alphanumeric characters plus '_', e.g. foo_bar, but not variables with other characters, eg. foo->bar. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Cc: Andy Whitcroft <apw@canonical.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21checkpatch: Add check for kcalloc argument orderJoe Perches
kcalloc is sometimes misused with the first and second arguments switched. Same issue with kmalloc_array too. Bleat if sizeof is the first argument Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21checkpatch: don't emit the CamelCase warning for PageFooJoe Perches
I'm getting a ton of these: WARNING: Avoid CamelCase: <PageTransHuge> #140: FILE: mm/migrate.c:1576: + if (PageTransHuge(page) && page_count(page) != 3) { So exclude anything which starts with "Page". Tested-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21checkpatch: warn on unnecessary __dev<foo> section markingsJoe Perches
Get people to stop adding __devinit and __devexit section markings. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Andy Whitcroft <apw@canonical.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21checkpatch: prefer dev_<level>( to dev_printk(KERN_<LEVEL>Joe Perches
Add YA check to printk style. dev_<level> uses are functions and generate smaller object code than dev_printk(KERN_<LEVEL>. Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21get_maintainer.pl: find maintainers for removed filesGeert Uytterhoeven
For removed files, get_maintainer.pl doesn't find any maintainers (besides the default linux-kernel@vger.kernel.org), as it only looks at the "+++" lines, which are "/dev/null" for removals. Fix this by extending the parsing to the "---" lines. E.g. for the two line test patch below the real score maintainers will now be found: --- a/arch/score/include/asm/dma-mapping.h +++ /dev/null Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21scripts/tags.sh: add ctags magic for declarations of popular kernel typeKirill Tkhai
- Add magic for declarations of variables of popular kernel type like spinlock_t, list_head, wait_queue_head_t and other. - Add a set of specially handled declaration extentions like __attribute, __aligned and other. - Simplify pci_bus_* magic Signed-off-by: Kirill V Tkhai <tkhai@yandex.ru> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21Merge tag 'fixes-non-critical' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull non-critical ARM SoC bug fixes from Arnd Bergmann: "Bug fixes that did not make it into v3.8, mostly because they were not considered important enough, and in some cases because bugs only show up in combination with other patches destined for 3.9. This includes a few larger patches for GPIO on the Marvell PXA platform and a lot of Samsung specific bug fixes, as well as a series from Arnd to fix older build warnings." * tag 'fixes-non-critical' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (54 commits) ARM: SPEAr13xx: Enable CONFIG_ARCH_HAS_CPUFREQ ARM: imx: MACH_MX31ADS_WM1133_EV1 needs REGULATOR_WM8350 scripts/sortextable: silence script output ARM: s3c: i2c: add platform_device forward declaration ARM: mvebu: allow selecting mvebu without Armada XP ARM: pick Versatile by default for !MMU ARM: integrator: fix build with INTEGRATOR_AP off ARM: integrator/versatile: fix NOMMU warnings ARM: sa1100: don't warn about mach/ide.h ARM: shmobile: fix defconfig warning on CONFIG_USB ARM: w90x900: fix legacy assembly syntax ARM: samsung: fix assembly syntax for new gas ARM: disable virt_to_bus/virt_to_bus almost everywhere ARM: dts: Correct pin configuration of SD 4 for exynos4x12-pinctrl ARM: SAMSUNG: Silence empty switch warning in fimc-core.h ARM: SAMSUNG: Silence empty switch warning in sdhci.h ARM: msm: proc_comm_boot_wait should not be __init arm: vt8500: Update MAINTAINERS entry for arch-vt8500 ARM: integrator: ensure ap_syscon_base is initialised when !CONFIG_MMU ARM: S5PV210: Fix early uart output in fifo mode ...
2013-02-21Merge tag 'driver-core-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg Kroah-Hartman: "Here is the big driver core merge for 3.9-rc1 There are two major series here, both of which touch lots of drivers all over the kernel, and will cause you some merge conflicts: - add a new function called devm_ioremap_resource() to properly be able to check return values. - remove CONFIG_EXPERIMENTAL Other than those patches, there's not much here, some minor fixes and updates" Fix up trivial conflicts * tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits) base: memory: fix soft/hard_offline_page permissions drivercore: Fix ordering between deferred_probe and exiting initcalls backlight: fix class_find_device() arguments TTY: mark tty_get_device call with the proper const values driver-core: constify data for class_find_device() firmware: Ignore abort check when no user-helper is used firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER firmware: Make user-mode helper optional firmware: Refactoring for splitting user-mode helper code Driver core: treat unregistered bus_types as having no devices watchdog: Convert to devm_ioremap_resource() thermal: Convert to devm_ioremap_resource() spi: Convert to devm_ioremap_resource() power: Convert to devm_ioremap_resource() mtd: Convert to devm_ioremap_resource() mmc: Convert to devm_ioremap_resource() mfd: Convert to devm_ioremap_resource() media: Convert to devm_ioremap_resource() iommu: Convert to devm_ioremap_resource() drm: Convert to devm_ioremap_resource() ...
2013-02-20Merge tag 'dt-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull device tree changes from Grant Likely: "All around device tree changes destined for v3.8. Aside from the documentation updates the highlights in this branch include: - Kbuild changes for using CPP with .dts files - locking fix from preempt_rt patchset - include DT alias names in device uevent - Selftest bugfixes and improvements - New function for counting phandles stanzas in a property - constify argument to of_node_full_name() - Various bug fixes This tree did also contain a commit to use platform_device_add instead of open-coding the device add code, but it caused problems with amba devices and needed to be reverted." * tag 'dt-for-linus' of git://git.secretlab.ca/git/linux: (23 commits) Revert "of: use platform_device_add" kbuild: limit dtc+cpp include path gpio: Make of_count_named_gpios() use new of_count_phandle_with_args() of: Create function for counting number of phandles in a property of/base: Clean up exit paths for of_parse_phandle_with_args() of/selftest: Use selftest() macro throughout of/selftest: Fix GPIOs selftest to cover the 7th case of: fix recursive locking in of_get_next_available_child() documentation/devicetree: Fix a typo in exynos-dw-mshc.txt OF: convert devtree lock from rw_lock to raw spinlock of/exynos_g2d: Add Bindings for exynos G2D driver kbuild: create a rule to run the pre-processor on *.dts files input: Extend matrix-keypad device tree binding devicetree: Move NS2 LEDs binding into LEDs directory of: use platform_device_add powerpc/5200: Fix size to request_mem_region() call documentation/devicetree: Fix typos of: add 'const' to of_node_full_name parameter of: Output devicetree alias names in uevent DT: add vendor prefixes for Renesas and Toshiba ...
2013-02-19kbuild: Fix missing '\n' for NEW symbols in yes "" | make oldconfig >conf.newBen Hutchings
According to Documentation/kbuild/kconfig.txt, the commands: yes "" | make oldconfig >conf.new grep "(NEW)" conf.new should list the new config symbols with their default values. However, currently there is no line break after each new symbol. When kconfig is interactive the user will type a new-line at this point, but when non-interactive kconfig must print it. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Reference: http://bugs.debian.org/636029 [regid23@nt1.in: Adjusted Ben's work to apply cleanly to this tree] Reported-and-tested-by: Regid Ichira <regid23@nt1.in> Reviewed-by: Jonathan Nieder <jrnieder@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-02-14scripts/sortextable: silence script outputArnd Bergmann
The exception table sorter outputs one line every time it gets called, e.g. 'sort done marker at 66dc00', which is slightly annoying when doing 'make -s' which is otherwise completely silent. Since that output is not helpful to most people building the kernel, turn it off by default. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: David Daney <david.daney@cavium.com> Cc: "H. Peter Anvin" <hpa@zytor.com>
2013-02-13kbuild: limit dtc+cpp include pathStephen Warren
Device tree source files may now include header files. The intent is that those header files define/name constants used as part of the DT bindings. Currently this feature is open to abuse, since any kernel header file at all can be included, This could allow device tree files to become dependant on kernel headers files, and thus make them no longer OS-independent. This would also prevent separating the device tree source files from the kernel repository. Solve this by limiting the cpp include path for device tree files to separate directories. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2013-02-09kconfig: nconf: rewrite labels of function keys lineRoland Eggner
>From: Roland Eggner <edvx1@systemanalysen.net> More reasonable labels of function keys line. Rename labels and keep menu width, as required for fitting on COLUMNS=80 terminals: • s/Insts/Help 2/ • s/Config/ShowAll/ Signed-off-by: Roland Eggner <edvx1@systemanalysen.net> Reviewed-by: "Yann E. MORIN" <yann.morin.1998@free.fr> Signed-off-by: "Yann E. MORIN" <yann.morin.1998@free.fr>
2013-02-09kconfig: nconf: rewrite help textsRoland Eggner
>From: Roland Eggner <edvx1@systemanalysen.net> Rewrite all help texts. During several years lazy (incomplete) updates have left behind a rather thick layer of dust. Intentions: (1) Global help called by <F1> should document all _currently_ implemented keybindings. (2) Different help texts called by <F3> resp. <F8><F1> should be consistent with (1) and with implementation: • on plain menu entry • in radiolist window • in input windows for text, decimal or hexadecimal values • in filename selection windows <F6> <F7> • SymSearch specific help called by <F8> followed by <F1> (3) More reasonable window titles: Rename window title s/README/Global help/ Rename variable s/nconf_readme/nconf_global_help/ Rename window title s/Instructions/Short help/ (4) Consider which hints are most useful for first-time-users. Signed-off-by: Roland Eggner <edvx1@systemanalysen.net> Reviewed-by: "Yann E. MORIN" <yann.morin.1998@free.fr> [yann.morin.1998@free.fr: a few additional fixes] Signed-off-by: "Yann E. MORIN" <yann.morin.1998@free.fr>
2013-02-08kbuild: create a rule to run the pre-processor on *.dts filesStephen Warren
Create cmd_dtc_cpp to run the C pre-processor on *.dts file before passing them to dtc for final compilation. This allows the use of #define and #include within the .dts file. Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Michal Marek <mmarek@suse.cz> Acked-by: Srinivas Kandagatla <srinivas.kandagatla@st.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2013-02-05checkpatch: fix $Float creation of match variablesJoe Perches
Commit 74349bccedb3 ("checkpatch: add support for floating point constants") added an unnecessary match variable that caused tests that used a $Constant or $LvalOrFunc to have one too many matches. This causes problems with usleep_range, min/max and other extended tests. Avoid using match variables in $Float. Avoid using match variables in $Assignment too. Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-30kconfig: fix a compiliation error when using make xconfigTiana Rakotovao Andriamahefa
When using make xconfig, the following compilation error appears : /usr/include/qt3/qvaluelist.h:427:13: error: ‘ptrdiff_t’ does not name a type Including stddef.h in scripts/kconfig/qconf.cc permits to avoid this error. Signed-off-by: Tiana Rakotovao Andriamahefa <rkmahefa@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-01-29Merge branch 'master' into for-nextJiri Kosina
Conflicts: drivers/devfreq/exynos4_bus.c Sync with Linus' tree to be able to apply patches that are against newer code (mvneta).
2013-01-25MODSIGN: Add -s <signature> option to sign-fileMichal Marek
This option allows to append an externally computed singature to the module. This is needed in setups, where the private key is not directly available, but a service exists that returns signatures for given files. Signed-off-by: Michal Marek <mmarek@suse.cz> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
