commit 2d560306096739e2251329ab5c16059311a151b0 upstream.
Warning:
In file included from scripts/kconfig/zconf.tab.c:2537:0:
scripts/kconfig/menu.c: In function ‘get_symbol_str’:
scripts/kconfig/menu.c:590:18: warning: ‘jump’ may be used uninitialized in this function [-Wmaybe-uninitialized]
jump->offset = strlen(r->s);
Simplifies the test logic because (head && local) means (jump != 0)
and makes GCC happy when checking if the jump pointer was initialized.
Signed-off-by: Peter Kümmel <syntheticpp@gmx.net>
[ dileks: v2: Backported to fit v3.10 ]
Cc: Sedat Dilek <sedat.dilek@gmail.com>
commit 1caf6aaaa47471831d77c75f094d4e00ad1ec808 upstream.
Compiling SH with gcc-4.8 fails due to the -m32 option not being
supported.
From http://buildd.debian-ports.org/status/fetch.php?pkg=linux&arch=sh4&ver=3.16.7-ckt4-1&stamp=1421425783
CC init/main.o
gcc-4.8: error: unrecognized command line option '-m32'
ld: cannot find init/.tmp_mc_main.o: No such file or directory
objcopy: 'init/.tmp_mx_main.o': No such file
rm: cannot remove 'init/.tmp_mx_main.o': No such file or directory
rm: cannot remove 'init/.tmp_mc_main.o': No such file or directory
Link: http://lkml.kernel.org/r/1421537778-29001-1-git-send-email-kernel@mkarcher.dialup.fu-berlin.de
Link: http://lkml.kernel.org/r/54BCBDD4.10102@physik.fu-berlin.de
Cc: Matt Fleming <matt@console-pimps.org>
Reported-by: John Paul Adrian Glaubitz <glaubitz@physik.fu-berlin.de>
Signed-off-by: Michael Karcher <kernel@mkarcher.dialup.fu-berlin.de>
commit 7b990789a4c3420fa57596b368733158e432d444 upstream.
The change from \d+ to .+ inside __aligned() means that the following
structure:
struct test {
u8 a __aligned(2);
u8 b __aligned(2);
essentially gets modified to
struct test {
u8 a;
for purposes of kernel-doc, thus dropping a struct member, which in
turns causes warnings and invalid kernel-doc generation.
Fix this by replacing the catch-all (".") with anything that's not a
semicolon ("[^;]").
Fixes: 9dc30918b23f ("scripts/kernel-doc: handle struct member __aligned without numbers")
Cc: Nishanth Menon <nm@ti.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Michal Marek <mmarek@suse.cz>
commit 91ad11d7cc6f4472ebf177a6252fbf0fd100d798 upstream.
On MIPS calls to _mcount in modules generate 2 instructions to load
the _mcount address (and therefore 2 relocations). The mcount_loc
table should only reference the first of these, so the second is
filtered out by checking the relocation offset and ignoring ones that
immediately follow the previous one seen.
However if a module has an _mcount call at offset 0, the second
relocation would not be filtered out due to old_r_offset == 0
being taken to mean that the current relocation is the first one
seen, and both would end up in the mcount_loc table.
This results in ftrace_make_nop() patching both (adjacent)
instructions to branches over the _mcount call sequence like so:
0xffffffffc08a8000: 04 00 00 10 b 0xffffffffc08a8014
0xffffffffc08a8004: 04 00 00 10 b 0xffffffffc08a8018
0xffffffffc08a8008: 2d 08 e0 03 move at,ra
The second branch is in the delay slot of the first, which is
defined to be unpredictable - on the platform on which this bug was
encountered, it triggers a reserved instruction exception.
Fix by initializing old_r_offset to ~0 and using that instead of 0
to determine whether the current relocation is the first seen.
Signed-off-by: Alex Smith <alex.smith@imgtec.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/7098/
commit 8fe9c93e7453e67b8bd09f263ec1bb0783c733fc upstream.
GCC 4.8 now generates out-of-line vr save/restore functions when
optimizing for size. They are needed for the raid6 altivec support.
Signed-off-by: Andreas Schwab <schwab@linux-m68k.org>
commit c0ff68f1611d6855a06d672989ad5cfea160a4eb upstream.
If headers_install is executed from a deep/long directory structure, the
shell's maximum argument length can be execeeded, which breaks the operation
with:
| make[2]: execvp: /bin/sh: Argument list too long
| make[2]: ***
Instead of passing each files name with the entire path, I give only the file
name without the source path and give this path as a new argument to
headers_install.pl.
Because there is three possible paths, I have tree input-files list, one per
path.
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Tested-by: Bruce Ashfield <bruce.ashfield@windriver.com>
Cc: Wang Nan <wangnan0@huawei.com>
commit f8ce239dfc7ba9add41d9ecdc5e7810738f839fa upstream.
builddeb generates a control file that says the linux-headers package
can only be built for the build system primary architecture. This
breaks cross-building configurations. We should use $debarch for this
instead.
Since $debarch is not yet set when generating the control file, set
Architecture: any and use control file variables to fill in the
description.
Fixes: cd8d60a20a45 ('kbuild: create linux-headers package in deb-pkg')
Reported-and-tested-by: "Niew, Sh." <shniew@gmail.com>
commit 03b56329f9bb5a1cb73d7dc659d529a9a9bf3acc upstream.
Commit afe2dab4f6 ("USB: add hex/bcd detection to usb modalias generation")
changed the routine that generates alias ranges. Before that change, only
digits 0-9 were supported; the commit tried to fix the case when the range
includes higher values than 0x9.
Unfortunately, the commit didn't fix the case when the range includes both
0x9 and 0xA, meaning that the final range must look like [x-9A-y] where
x <= 0x9 and y >= 0xA -- instead the [x-9A-x] range was produced.
Modprobe doesn't complain as it sees no difference between no-match and
bad-pattern results of fnmatch().
Fixing this simple bug to fix the aliases.
Also changing the hardcoded beginning of the range to uppercase as all the
other letters are also uppercase in the device version numbers.
Fortunately, this affects only the dvb-usb-dib0700 module, AFAIK.
Signed-off-by: Jan Moskyto Matejka <mq@suse.cz>
commit f6537f2f0eba4eba3354e48dbe3047db6d8b6254 upstream.
This patch uses CONFIG_PAGE_OFFSET to filter symbols which
are not in kernel address space because these symbols are
generally for generating code purpose and can't be run at
kernel mode, so we needn't keep them in /proc/kallsyms.
For example, on ARM there are some symbols which may be
linked in relocatable code section, then perf can't parse
symbols any more from /proc/kallsyms, this patch fixes the
problem (introduced b9b32bf70f2fb710b07c94e13afbc729afe221da)
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
Previously, the #line parsing regex ended with ({WS}+[0-9]+)?. The {WS}
could match line-break characters. If the #line directive did not contain
the optional flags field at the end, this could cause any integer data on
the next line to be consumed as part of the #line directive parsing. This
could cause syntax errors (i.e. #line parsing consuming the leading 0
from a hex literal 0x1234, leaving x1234 to be parsed as cell data,
which is a syntax error), or invalid compilation results (i.e. simply
consuming literal 1234 as part of the #line processing, thus removing it
from the cell data).
Fix this by replacing {WS} with [ \t] so that it can't match line-breaks.
Convert all instances of {WS}, even though the other instances should be
irrelevant for any well-formed #line directive. This is done for
consistency and ultimate safety.
[Cherry picked from DTC commit a1ee6f068e1c8dbc62873645037a353d7852d5cc]
Reported-by: Ian Campbell <Ian.Campbell@citrix.com>
Acked-by: David Gibson <david@gibson.dropbear.id.au>
This patch merely updates the generated dtc parser and lexer files to
the output generated by Bison 2.5. The previous versions were generated
from version 2.4.1. The only reason for this commit is to minimize the
diff on the next commit which fixes a bug in the DTC #line directive
parsing. Otherwise the Bison changes would be intermingled with the
functional changes.
Various temporary files used when building DTB files were not suffixed with
.tmp and therefore were not cleaned up by "make clean".
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Signed-off-by: Grant Likely <grant.likely@linaro.org>
git://gitorious.org/linux-kconfig/linux-kconfig into kbuild/rc-fixes
menu_add_prop() applies upper menus' visibilities to actual prompts
by AND-ing the prompts visibilities with the upper menus ones.
This creates a further reference to the menu's visibilities and when
the expression reduction functions do their work, they may remove or
modify expressions that have multiple references, thus causing
unpredictable side-effects.
The following example Kconfig constructs a case where this causes
problems: a menu and a prompt which's visibilities depend on the same
symbol. When invoking mconf with this Kconfig and pressing "Z" we
see a problem caused by a free'd expression still referenced by the
menu's visibility:
mainmenu "Kconfig Testing Configuration"
config VISIBLE
def_bool n
config Placeholder
bool "Place holder"
menu "Invisible"
visible if VISIBLE
config TEST_VAR
bool "Test option" if VISIBLE
endmenu
This patch fixes this problem by creating copies of the menu's
visibility expressions before AND-ing them with the prompt's one.
Signed-off-by: Dirk Gouders <dirk@gouders.net>
[yann.morin.1998@free.fr: move variable into its block-scope,
keep lines <80 chars, typo]
Tested-by: "Yann E. MORIN" <yann.morin.1998@free.fr>
Reviewed-by: "Yann E. MORIN" <yann.morin.1998@free.fr>
Signed-off-by: "Yann E. MORIN" <yann.morin.1998@free.fr>
When entering an empty dialog, using the movement keys resulted in
unexpected characters beeing displayed, other keys like "z" and "h"
did not work as expected.
This patch handles the movement keys as well as other keys, especially
"z", "h" and "/".
[yann.morin.1998@free.fr: keep lines <80 chars, so reorder test]
In commit b40b25ff (kbuild: always run gcc -E on *.dts, remove cmd_dtc_cpp),
dts building was changed to always use the C preprocessor. This meant
that the .dts file passed to dtc is not the original, but the
preprocessed one.
When compiling with a separate build directory (i.e., with O=), this
preprocessed file will not live in the same directory as the original.
When the .dts file includes .dtsi files, dtc will look for them in the
build directory, not in the source directory and compilation will fail.
The commit referenced above tried to fix this by passing arch/*/boot/dts
as an include path to dtc. However, for mips, the .dts files are not in
this directory, so dts compilation on mips breaks for some targets.
Instead of hardcoding this particular include path, this commit just
uses the directory of the .dts file that is being compiled, which
effectively restores the previous behaviour wrt includes. For most .dts
files, this path is just the same as the previous hardcoded
arch/*/boot/dts path.
This was tested on a mips (rt3052) and an arm (bcm2835) target.
Signed-off-by: Matthijs Kooijman <matthijs@stdin.nl>
options
When --*-after options are used, two parameters are parsed from the
command-line before the adequate function is called:
- the `before' option, after which the new option will be inserted,
- the name of the option to enable/disable/modularise.
With the short version of --*-after options (namely -E, -D, -M), the
parsing step is not performed which leads to processing unset variables.
Add options -E, -D, -M to the test that triggers assignment of parameters
for --*-after options.
Signed-off-by: Clement Chauplannaz <chauplac@gmail.com>
Acked-by: Andi Kleen <ak@linux.intel.com>
Signed-off-by: Yann E. MORIN <yann.morin.1998@free.fr>
Commit 6501320311664e11ad5489fedb17ea1f817c2617 dropped the rpm spec as a
prerequisite for the binrpm-pkg target but forgot to update $< usage,
which causes the rule to break.
This commit fixes that by replacing $< with the spec name.
Signed-off-by: Luiz Capitulino <lcapitulino@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull misc kbuild updates from Michal Marek:
"Non-critical kbuild changes:
- make coccicheck improvements, but no new semantic patches this time
- make rpm improvements
- make tar-pkg change to include the architecture in the filename.
This is a deliberate incompatibility, but nobody has complained so
far and it is useful if you build for different architectures. It
also matches what the deb-pkg and rpm-pkg targets produce.
- kbuild documentation fix"
* 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
rpm-pkg: Remove pointless set -e statements
rpm-pkg: Always regenerate the specfile
rpm-pkg: Do not write to the parent directory
rpm-pkg: Do not package the whole source directory
buildtar: Add ARCH to the archive name
Coccinelle: Fix patch output when coccicheck is used with M= and C=
Coccinelle: Add support to the SPFLAGS variable
Coccinelle: Cleanup the setting of the FLAGS and OPTIONS variables
Coccinelle: Restore coccicheck verbosity in ONLINE mode (C=1 or C=2)
scripts/package/Makefile: compare objtree with srctree instead of test KBUILD_OUTPUT
doc: change example to existing Makefile fragment
scripts/tags.sh: Add magic for OFFSET and DEFINE
Pull kconfig updates from Michal Marek:
- use pkg-config to detect curses libraries
- clean up the way curses headers are searched
- Some randconfig fixes, of which one had to be reverted
- KCONFIG_SEED for randconfig debugging
- memuconfig memory leak plugged
- menuconfig > breadcrumbs > navigation
- xconfig compilation fix
- Other minor fixes
* 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
kconfig: fix lists definition for C++
Revert "kconfig: fix randomising choice entries in presence of KCONFIG_ALLCONFIG"
kconfig: implement KCONFIG_PROBABILITY for randconfig
kconfig: allow specifying the seed for randconfig
kconfig: do not override symbols already set
kconfig: fix randconfig tristate detection
kconfig/lxdialog: rationalise the include paths where to find {.n}curses{,w}.h
menuconfig: Add "breadcrumbs" navigation aid
menuconfig: Fix memory leak introduced by jump keys feature
merge_config.sh: Avoid creating unnessary source softlinks
kconfig: optionally use pkg-config to detect ncurses libs
menuconfig: optionally use pkg-config to detect ncurses libs
Pull kbuild changes from Michal Marek:
"Kbuild commits for v3.10-rc1:
- Fix make mrproper after mod/file2alias rework
- Fix ld-option Makefile function
- Rewrite headers_install to shell to drop Perl dependency.
There are some more patches I have to look at, so I might send another
pull request later. Or just queue them for 3.11."
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
Fix cleaning in scripts/mod
headers_install.pl: convert to headers_install.sh
kbuild: fix ld-option function
Searching for PPC_EFIKA results in a segmentation fault, and it's
because get_symbol_prop() returns NULL.
In this case CONFIG_PPC_EFIKA is defined in arch/powerpc/platforms/
52xx/Kconfig, so it won't be parsed if ARCH!=PPC, but menuconfig knows
this symbol when it parses sound/soc/fsl/Kconfig:
config SND_MPC52xx_SOC_EFIKA
tristate "SoC AC97 Audio support for bbplan Efika and STAC9766"
depends on PPC_EFIKA
This bug was introduced by commit bcdedcc1afd6 ("menuconfig: print more
info for symbol without prompts").
Reported-and-tested-by: Borislav Petkov <bp@alien8.de>
Signed-off-by: Li Zefan <lizefan@huawei.com>
Tested-by: Libo Chen <libo.chen@huawei.com>
Make sure devicetable-offsets.h is cleaned in the scripts/mod directory
Tested-by: Geert Uytterhoeven <geert@linux-m68k.org>
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull mudule updates from Rusty Russell:
"We get rid of the general module prefix confusion with a binary config
option, fix a remove/insert race which Never Happens, and (my
favorite) handle the case when we have too many modules for a single
commandline. Seriously, the kernel is full, please go away!"
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
modpost: fix unwanted VMLINUX_SYMBOL_STR expansion
X.509: Support parse long form of length octets in Authority Key Identifier
module: don't unlink the module until we've removed all exposure.
kernel: kallsyms: memory override issue, need check destination buffer length
MODSIGN: do not send garbage to stderr when enabling modules signature
modpost: handle huge numbers of modules.
modpost: add -T option to read module names from file/stdin.
modpost: minor cleanup.
genksyms: pass symbol-prefix instead of arch
module: fix symbol versioning with symbol prefixes
CONFIG_SYMBOL_PREFIX: cleanup.
Pull ARM SoC device-tree updates from Olof Johansson:
"Part 1 of device-tree updates for 3.10. The bulk of the churn in this
branch is due to i.MX moving from C-defined pin control over to device
tree, which is a one-time conversion that will allow greater
flexibility down the road.
Besides that, there's PCI-e bindings for Marvell mvebu platforms and a
handful of cleanups to tegra due to the new include file functionality
of the device tree compiler"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (113 commits)
arm: mvebu: PCIe Device Tree informations for Armada XP GP
arm: mvebu: PCIe Device Tree informations for Armada 370 DB
arm: mvebu: PCIe Device Tree informations for Armada 370 Mirabox
arm: mvebu: PCIe Device Tree informations for Armada XP DB
arm: mvebu: PCIe Device Tree informations for OpenBlocks AX3-4
arm: mvebu: add PCIe Device Tree informations for Armada XP
arm: mvebu: add PCIe Device Tree informations for Armada 370
ARM: sunxi: unify osc24M_fixed and osc24M
arm: vt8500: Add SDHC support to WM8505 DT
ARM: dts: Add a 64 bits version of the skeleton device tree
ARM: mvebu: Add Device Bus and CFI flash memory support to defconfig
ARM: mvebu: Add support for NOR flash device on Openblocks AX3 board
ARM: mvebu: Add support for NOR flash device on Armada XP-GP board
ARM: mvebu: Add Device Bus support for Armada 370/XP SoC
ARM: dts: imx6dl-wandboard: Add USB Host support
ARM: dts: imx51 cpu node
ARM: dts: Add missing imx27-phytec-phycore dtb target
ARM: dts: Add NFC support for i.MX27 Phytec PCM038 module
ARM: i.MX51: Add PATA support
ARM: dts: Add initial support for Wandboard Dual-Lite
When we search a config symbol, if it has no prompt the position of this
symbol in the Kconfig file and it's dependencies are not printed. This
can be inconvenient, especially when it's set to n and we want to find out
why.
the following is an example:
before:
Symbol: GENERIC_SMP_IDLE_THREAD [=y]
Type : boolean
Selected by: X86 [=y]
after:
Type : boolean
Defined at arch/Kconfig:213
Signed-off-by: Weng Meiling <wengmeiling.weng@huawei.com>
Signed-off-by: Libo Chen <libo.chen@huawei.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-kconfig
Pull localmodconfig changes from Steven Rostedt:
"A bug was recently found in the make localmodconfig where it would
miss dependencies of config files are include in other config files
inside an if statement.
Also added a debug print that helped in solving this bug."
* tag 'localmodconfig-v3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-kconfig:
localmodconfig: Process source kconfig files as they are found
localmodconfig: Add debug prints for dependencies of module configs
As people started using Suggested-by as standard signature, adding
"Suggested-by" to the standard signature so that checkpatch won't
generate warning when Suggested-by is used in patch signature
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
Cc: Andy Whitcroft <apw@canonical.com>
Cc: Joe Perches <joe@perches.com>
This check was intended to catch extra newlines at the end of a function
definition, but it would trigger on any closing brace, including those
of inline functions and macro definitions, triggering false positives.
Now, only closing braces on a line by themselves trigger this check.
Tested with:
$ cat test.h
/* test.h - Test file */
static inline int foo(void) { return 0; }
static inline int bar(void)
return 1;
$ ./scripts/checkpatch.pl --strict -f test.h # Before this commit
CHECK: Blank lines aren't necessary before a close brace '}'
+static inline int foo(void) { return 0; }
total: 0 errors, 0 warnings, 2 checks, 9 lines checked
$ ./scripts/checkpatch.pl --strict -f test.h # After this commit
total: 0 errors, 0 warnings, 1 checks, 9 lines checked
Acked-by: Joe Perches <joe@perches.com>
Make space before semicolon a warning instead of a --strict CHK test.
Complain about files with an executable bit set that are not in a scripts/
directory and are not type .pl, .py, .awk, or .sh
Based on an initial patch from Stephen.
Acked-by: Stephen Boyd <sboyd@codeaurora.org>
Add a check for seq_printf use with a constant format without additional
arguments. Suggest seq_puts instead.
Suggested-by: Bjorn Helgaas <bhelgaas@google.com>
On Thu, 2013-03-14 at 13:30 +0000, David Woodhouse wrote:
> If krealloc() returns NULL, it *doesn't* free the original. So any code
> of the form 'foo = krealloc(foo, …);' is almost certainly a bug.
So add a check for it to checkpatch.
Tested-by: Guenter Roeck <linux@roeck-us.net>
Acked-by: Guenter Roeck <linux@roeck-us.net>
Cc: Jean Delvare <khali@linux-fr.org>
Create a new N: entry type in MAINTAINERS which performs a regex match
against filenames; either those extracted from patch +++ or --- lines,
or those specified on the command-line using the -f option.
This provides the same benefits as using a K: regex option to match a
set of filenames (see commit eb90d0855b75 "get_maintainer: allow
keywords to match filenames"), but without the disadvantage that
"random" file content, such as comments, will ever match the regex.
Hence, revert most of that commit.
Switch the Tegra entry from using K: to N:
[akpm@linux-foundation.org: fix typo in docs, per Marcin]
Reported-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Suggested-by: Joe Perches <joe@perches.com>
It can accidentally happen that the faulting insn (the exact instruction
bytes) is repeated a little further on in the trace. This causes that
same instruction to be tagged twice, see example below.
What we want to do, however, is to track back from the end of the whole
disassembly so many lines as the slice which starts with the faulting
instruction is long. This leads us to the actual faulting instruction
and *then* we tag it.
While we're at it, we can drop the sed "g" flag because we address only
this one line.
Also, if we point to an instruction which changes decoding depending on
the slice being objdumped, like a Jcc insn, for example, we do not even
tag it as a faulting instruction because the instruction decode changes
in the second slice but we use that second format as a regex on the
fsrst disassembled buffer and more often than not that instruction
doesn't match.
Again, simply tag the line which is deduced from the original "<>"
marking we've received from the kernel.
This also solves the pathologic issue of multiple tagging like this:
29:* 0f 0b ud2 <-- trapping instruction
2b:* 0f 0b ud2 <-- trapping instruction
2d:* 0f 0b ud2 <-- trapping instruction
Double tagging example:
Code: 34 dd 40 30 ad 81 48 c7 c0 80 f6 00 00 48 8b 3c 30 48 01 c6 b8 ff ff ff ff 48 8d 57 f0 48 39 f7 74 2f 49 8b 4c 24 08 48 8b 47 f0 <48> 39 48 08 75 0e eb 2a 66 90 48 8b 40 f0 48 39 48 08 74 1e 48
All code
0: 34 dd xor $0xdd,%al
2: 40 30 ad 81 48 c7 c0 xor %bpl,-0x3f38b77f(%rbp)
9: 80 f6 00 xor $0x0,%dh
c: 00 48 8b add %cl,-0x75(%rax)
f: 3c 30 cmp $0x30,%al
11: 48 01 c6 add %rax,%rsi
14: b8 ff ff ff ff mov $0xffffffff,%eax
19: 48 8d 57 f0 lea -0x10(%rdi),%rdx
1d: 48 39 f7 cmp %rsi,%rdi
20: 74 2f je 0x51
22: 49 8b 4c 24 08 mov 0x8(%r12),%rcx
27: 48 8b 47 f0 mov -0x10(%rdi),%rax
2b:* 48 39 48 08 cmp %rcx,0x8(%rax) <-- trapping instruction
2f: 75 0e jne 0x3f
31: eb 2a jmp 0x5d
33: 66 90 xchg %ax,%ax
35: 48 8b 40 f0 mov -0x10(%rax),%rax
39:* 48 39 48 08 cmp %rcx,0x8(%rax) <-- trapping instruction
3d: 74 1e je 0x5d
3f: 48 rex.W
A bug was reported that caused localmodconfig to not keep all the
dependencies of ATH9K. This was caused by the kconfig file:
In drivers/net/wireless/ath/Kconfig:
if ATH_CARDS
config ATH_DEBUG
bool "Atheros wireless debugging"
---help---
Say Y, if you want to debug atheros wireless drivers.
Right now only ath9k makes use of this.
source "drivers/net/wireless/ath/ath5k/Kconfig"
source "drivers/net/wireless/ath/ath9k/Kconfig"
source "drivers/net/wireless/ath/carl9170/Kconfig"
source "drivers/net/wireless/ath/ath6kl/Kconfig"
source "drivers/net/wireless/ath/ar5523/Kconfig"
source "drivers/net/wireless/ath/wil6210/Kconfig"
endif
The current way kconfig works, it processes new source files after the
first file is completed. It creates an array of new source config files
and when the one file is finished, it continues with the next file.
Unfortunately, this means that it loses the fact that the source file is
within an "if" statement, and this means that each of these source file's
configs will not have the proper dependencies set.
As ATH9K requires ATH_CARDS set, the localmodconfig did not see that
dependency, and did not enable ATH_CARDS. When the oldconfig was run, it
forced ATH9K to be disabled.
Link: http://lkml.kernel.org/r/alpine.DEB.2.02.1304291022320.9234@oneiric
Cc: stable@vger.kernel.org # 3.8+
Reported-by: Robert P. J. Day <rpjday@crashcourse.ca>
Tested-by: Robert P. J. Day <rpjday@crashcourse.ca>
When a config for a module is added to the list to save in the final
config file, add a print to show what dependencies are used. This is
useful to debug when a config is disabled by the make oldconfig after
localmodconfig is finished.
This print only appears if the environment variable LOCALMODCONFIG_DEBUG
is defined.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver update from Greg Kroah-Hartman:
"Here's the big char / misc driver update for 3.10-rc1
A number of various driver updates, the majority being new
functionality in the MEI driver subsystem (it's now a subsystem, it
started out just a single driver), extcon updates, memory updates,
hyper-v updates, and a bunch of other small stuff that doesn't fit in
any other tree.
All of these have been in linux-next for a while"
* tag 'char-misc-3.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (148 commits)
Tools: hv: Fix a checkpatch warning
tools: hv: skip iso9660 mounts in hv_vss_daemon
tools: hv: use FIFREEZE/FITHAW in hv_vss_daemon
tools: hv: use getmntent in hv_vss_daemon
tools: hv: fix checks for origin of netlink message in hv_vss_daemon
Tools: hv: fix warnings in hv_vss_daemon
misc: mark spear13xx-pcie-gadget as broken
mei: fix krealloc() misuse in in mei_cl_irq_read_msg()
mei: reduce flow control only for completed messages
mei: reseting -> resetting
mei: fix reading large reposnes
mei: revamp mei_irq_read_client_message function
mei: revamp mei_amthif_irq_read_message
mei: revamp hbm state machine
Revert "drivers/scsi: use module_pcmcia_driver() in pcmcia drivers"
Revert "scsi: pcmcia: nsp_cs: remove module init/exit function prototypes"
mei: wd: fix line over 80 characters
misc: tsl2550: Use dev_pm_ops
The C++ compiler is more strict in that it refuses to assign
a void* to a struct list_head*.
Fix that by explicitly casting the poisonning constants.
(Tested with all 5 frontends, now.)
Reported-by: Randy Dunlap <rdunlap@infradead.org>
Cc: Benjamin Poirier <bpoirier@suse.de>
Commit a4b6a77b77ba4f526392612c2365797fab956014 ("module: fix symbol
versioning with symbol prefixes") broke the MODVERSIONS loading of any
module using memcmp (e.g. ipv6) on x86_32, as it's defined to
__builtin_memcmp which is expanded by VMLINUX_SYMBOL_STR. Use
__VMLINUX_SYMBOL_STR instead which doesn't expand the argument.
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Reported-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Tested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Tested-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: <stable@vger.kernel.org> # 3.9
KCONFIG_ALLCONFIG"
This reverts commit 422c809f03f043d0950d8362214818e956a9daee.
It causes more harm than it solves issues.
Reported-by: Sedat Dilek <sedat.dilek@gmail.com>
Tested-by: Sedat Dilek <sedat.dilek@gmail.com>
Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: Greg KH <greg@kroah.com>
Currently the odds to set each symbol is (rounded):
booleans: y: 50% n: 50%
tristates: y: 33% m: 33% n: 33%
Introduce a KCONFIG_PROBABILITY environment variable to tweak the
probabilities (in percentage), as such:
KCONFIG_PROBABILITY y:n split y:m:n split
[1] unset or empty 50 : 50 33 : 33 : 34
[2] N N : 100-N N/2 : N/2 : 100-N
N:M N+M : 100-(N+M) N : M : 100-(N+M)
N:M:L N : 100-N M : L : 100-(M+L)
[1] The current behaviour is kept as default, for backward compatibility
[2] The solution initially implemented by Peter for Buildroot, see:
http://git.buildroot.org/buildroot/commit/?id=3435c1afb5
Signed-off-by: Peter Korsgaard <jacmet@uclibc.org>
[yann.morin.1998@free.fr: add to Documentation/]
For reproducibility, it can be useful to be able to specify the
seed to use to seed the RNG.
Add a new KCONFIG_SEED environment variable which can be set to
the seed to use:
$ make KCONFIG_SEED=42 randconfig
$ sha1sum .config
70a128c8dcc61303069e1be352cce64114dfcbca .config
$ sha1sum .config
It's very usefull for eg. debugging the kconfig parser.
Currently, randconfig does randomise choice entries, unless KCONFIG_ALLCONFIG
is specified.
For example, given those two files (Thomas' test-case):
---8<--- Config.test.in
config OPTIONA
bool "Option A"
choice
prompt "This is a choice"
config CHOICE_OPTIONA
bool "Choice Option A"
config CHOICE_OPTIONB
bool "Choice Option B"
endchoice
config OPTIONB
bool "Option B"
---8<--- config.defaults
CONFIG_OPTIONA=y
And running:
./scripts/kconfig/conf --randconfig Config.test.in
does properly randomise the two choice symbols (and the two booleans).
However, running:
KCONFIG_ALLCONFIG=config.defaults \
does *not* reandomise the two choice entries, and only CHOICE_OPTIONA
will ever be selected. (OPTIONA will always be set (expected), and
OPTIONB will be be properly randomised (expected).)
This patch defers setting that a choice has a value until a symbol for
that choice is indeed set, so that choices are properly randomised when
KCONFIG_ALLCONFIG is set, but not if a symbol for that choice is set.
Also, as a side-efect, this patch fixes the following case:
---8<---
choice
config OPTION_A
bool "Option A"
config OPTION_B
bool "Option B"
config OPTION_C
bool "Option C"
endchoice
---8<---
which could previously generate such .config files:
---8<--- ---8<---
CONFIG_OPTION_A=y CONFIG_OPTION_A=y
CONFIG_OPTION_B=y # CONFIG_OPTION_B is not set
# CONFIG_OPTION_C is not set CONFIG_OPTION_C=y
---8<--- ---8<---
Ie., the first entry in a choice is always set, plus zero or one of
the other options may be set.
This patch ensures that only one option may be set for a choice.
Reported-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: Arnaud Lacombe <lacombar@gmail.com>
Changes v2 -> v3
- ensure only one symbol is set in a choice
Changes v1 -> v2:
- further postpone setting that a choice has a value until
one is indeed set
- do not print symbols that are part of an invisible choice
For randconfig, if a list of required symbols is specified with
KCONFIG_ALLCONFIG, such symbols do not "have a value" as per
sym_has_value(), but have the "valid" flag set.
Because the modules' symbole (CONFIG_MODULES) may not yet be set when
we check a symbol's tristate capabilty, we'll always find that tristate
symbols are booleans, even if we randomly decided that to enable modules:
sym_get_type(sym) always return boolean for tristates when modules_sym
has not been previously set to 'y' *and* its value calculated *and* its
visibility calculated, both of which only occur after we randomly assign
values to symbols.
Fix that by looking at the raw type of symbols. Tristate set to 'm' will
be promoted to 'y' when their values will be later calculated.
The *pkg targets are always run, so it makes no sense to cache the
generated specfile. This also fixes build errors when the specfile
becomes out of date, without the Makefile noticing it:
$ make rpm
works
$ echo yadadada >localversion-test
$ make rpm
fails, because kernel.spec assumes the old kernel release string
Now that we only package explicitly listed files to the tarball, there
is no need to abuse the parent directory.
The source tree can contain lots of uninteresting data like tag or
cscope files, packaging which slows down make rpm needlessly. It can
also break the build, if the tree contains an unrelated file named
*.spec. The downside of this change is that new subdirectories have to
be added to the KBUILD_ALLDIRS variable in the top-level Makefile. The
upside is that the behavior is more predictable.
