path: root/scripts
2012-02-27mod/file2alias: make modpost compile on darwin againAndreas Bießmann
commit e49ce14150c64b29a8dd211df785576fa19a9858 breaks cross compiling the linux kernel on darwin hosts. This fix introduce some minimal glue to adopt linker section handling for darwin hosts. Signed-off-by: Andreas Bießmann <andreas@biessmann.de> CC: Rusty Russell <rusty@rustcorp.com.au> CC: Greg Kroah-Hartman <gregkh@linuxfoundation.org> CC: Jochen Friedrich <jochen@scram.de> CC: Samuel Ortiz <sameo@linux.intel.com> CC: "K. Y. Srinivasan" <kys@microsoft.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Tested-by: Bernhard Walle <bernhard@bwalle.de>
2012-02-25Merge branch 'rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild three kbuild fixes for 3.3: - make deb-pkg symlink race fix. - make coccicheck fix. - Dropping the check for modutils. This is not a regression, but allows the module-init-tools replacement kmod work with the 3.3 kernel. * 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: coccicheck: change handling of C={1,2} when M= is set builddeb: Don't create files in /tmp with predictable names kbuild: do not check for ancient modutils tools
2012-02-24coccicheck: change handling of C={1,2} when M= is setGreg Dietsche
This patch reverts a portion of d0bc1fb4 so that coccicheck will work properly when C=1 or C=2. Reported-and-tested-by: Brice Goglin <Brice.Goglin@inria.fr> Signed-off-by: Greg Dietsche <Gregory.Dietsche@cuw.edu> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-02-18builddeb: Don't create files in /tmp with predictable namesBen Hutchings
The current use of /tmp for file lists is insecure. Put them under $objtree/debian instead. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: stable@vger.kernel.org # 2.6.39+ Acked-by: maximilian attems <max@stro.at> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-02-15ARM: 7324/1: modpost: Fix section warnings for ARM for many compilersTony Lindgren
It turns out that many compilers don't show section warnings on ARM currently because handling for ARM_CALL relocs are missing from modpost.c. Based on commit c2e26114 ([ARM] 3205/1: Handle new EABI relocations when loading kernel modules) it seems that R_ARM_PC24, R_ARM_CALL and R_ARM_JUMP24 can be handled the same way. Note that at least Debian libc6-dev is missing defines for both R_ARM_CALL and R_ARM_JUMP24 in /usr/include/elf.h. So for now we need to define them in modpost.c if not defined. Acked-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Anders Kaseorg <andersk@ksplice.com> Cc: Greg KH <gregkh@linuxfoundation.org> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-02-14module: fix broken isapnp handling in file2aliasOndrej Zary
Handling of isapnp module aliases was broken by commit 626596e295d477c0fefa08cd5daa7dd011b1bb2c by changing "isapnp" string to "isa". The code was then modified by commit e49ce14150c64b29a8dd211df785576fa19a9858 but this bug remained. Change the string back to "isapnp". Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-02-07checkpatch: Warn on code with 6+ tab indentationJoe Perches
Overly indented code should be refactored. Suggest refactoring excessive indentation of of if/else/for/do/while/switch statements. For example: $ cat t.c #include <stdio.h> #include <stdlib.h> int main(int argc, char **argv) { if (1) if (2) if (3) if (4) if (5) if (6) if (7) if (8) ; return 0; } $ ./scripts/checkpatch.pl -f t.c WARNING: Too many leading tabs - consider code refactoring #12: FILE: t.c:12: + if (6) WARNING: Too many leading tabs - consider code refactoring #13: FILE: t.c:13: + if (7) WARNING: Too many leading tabs - consider code refactoring #14: FILE: t.c:14: + if (8) total: 0 errors, 3 warnings, 17 lines checked t.c has style problems, please review. If any of these errors are false positives, please report them to the maintainer, see CHECKPATCH in MAINTAINERS. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-28Merge branch 'fixes' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
* 'fixes' of git://git.linaro.org/people/rmk/linux-arm: (31 commits) ARM: 7304/1: ioremap: fix boundary check when reusing static mapping ARM: 7301/1: Rename the T() macro to TUSER() to avoid namespace conflicts ARM: 7299/1: ftrace: clear zero bit in reported IPs for Thumb-2 ARM: 7298/1: realview: fix mapping of MPCore private memory region PCMCIA: fix sa1111 oops on remove ARM: 7288/1: mach-sa1100: add missing module_init() call ARM: 7297/1: smp_twd: make sure timer is stopped before registering it ARM: 7296/1: proc-v7.S: remove HARVARD_CACHE preprocessor guards ARM: 7295/1: cortex-a7: move proc_info out of !CONFIG_ARM_LPAE block ARM: 7293/1: logical_cpu_map: decouple CPU mapping from SMP ARM: 7291/1: cache: assume 64-byte L1 cachelines for ARMv7 CPUs ARM: 7290/1: vmlinux.lds.S: align the exception fixup table to a 4-byte boundary ARM: 7289/1: vmlinux.lds.S: do not hardcode cacheline size as 32 bytes MFD: ucb1x00-ts: fix resume failure MFD: ucb1x00-core: fix gpiolib direction_output handling MFD: ucb1x00-core: fix missing restore of io output data on resume MFD: mcp-core: fix mcp_priv() to be more type safe MFD: mcp-core: fix complaints from the genirq layer Revert "ARM: sa11x0: Implement autoloading of codec and codec pdata for mcp bus." Revert "ARM: sa1100: Refactor mcp-sa11x0 to use platform resources." ... Fix up conflict due to arch/arm/mach-mx5/Kconfig having been merged into mach-imx5 (commit 784a90c0a7d8: "ARM i.MX: Merge i.MX5 support into mach-imx"), but the ARM_L1_CACHE_SHIFT_6 entry was moved to be driven by the CPU_V7 logic from it in the old location in rmk's branch (commit a092f2b15399: "ARM: 7291/1: cache: assume 64-byte L1 cachelines for ARMv7 CPUs").
2012-01-23scripts/kernel-doc: fix fatal error caused by cfg80211.hRandy Dunlap
include/net/cfg80211.h uses __must_check in functions that have kernel-doc notation. This was confusing scripts/kernel-doc, so have scripts/kernel-doc ignore "__must_check". Error(include/net/cfg80211.h:2702): cannot understand prototype: 'struct cfg80211_bss * __must_check cfg80211_inform_bss(...) Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-23kbuild: do not check for ancient modutils toolsLucas De Marchi
scripts/depmod.sh checks for the output of '-V' expecting that it has module-init-tools in it. It's a hack to prevent users from using modutils instead of module-init-tools, that only works with 2.4.x kernels. This however prints an annoying warning for kmod tool, that is currently replacing module-init-tools. Rather than putting another check for kmod's version, just remove it since users of 2.4.x kernel are unlikely to upgrade to 3.x, and if they do, let depmod fail in that case because they should know what they are doing. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Acked-by: WANG Cong <amwang@redhat.com> Acked-By: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-01-20Revert "ARM: sa11x0: Implement autoloading of codec and codec pdata for mcp ↵Russell King
bus." This reverts commit 5dd7bf59e0e8563265b3e5b33276099ef628fcc7. Conflicts: scripts/mod/file2alias.c This change is wrong on many levels. First and foremost, it causes a regression. On boot on Assabet, which this patch gives a codec id of 'ucb1x00', it gives: ucb1x00 ID not found: 1005 0x1005 is a valid ID for the UCB1300 device. Secondly, this patch is way over the top in terms of complexity. The only device which has been seen to be connected with this MCP code is the UCB1x00 (UCB1200, UCB1300 etc) devices, and they all use the same driver. Adding a match table, requiring the codec string to match the hardware ID read out of the ID register, etc is completely over the top when we can just read the hardware ID register.
2012-01-16Merge branch 'x86-syscall-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'x86-syscall-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86: Move <asm/asm-offsets.h> from trace_syscalls.c to asm/syscall.h x86, um: Fix typo in 32-bit system call modifications um: Use $(srctree) not $(KBUILD_SRC) x86, um: Mark system call tables readonly x86, um: Use the same style generated syscall tables as native um: Generate headers before generating user-offsets.s um: Run host archheaders, allow use of host generated headers kbuild, headers.sh: Don't make archheaders explicitly x86, syscall: Allow syscall offset to be symbolic x86, syscall: Re-fix typo in comment x86: Simplify syscallhdr.sh x86: Generate system call tables and unistd_*.h from tables checksyscalls: Use arch/x86/syscalls/syscall_32.tbl as source x86: Machine-readable syscall tables and scripts to process them trace: Include <asm/asm-offsets.h> in trace_syscalls.c x86-64, ia32: Move compat_ni_syscall into C and its own file x86-64, syscall: Adjust comment spacing and remove typo kbuild: Add support for an "archheaders" target kbuild: Add support for installing generated asm headers
2012-01-16Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: scripts/coccinelle: improve the coverage of some semantic patches coccinelle: semantic patches related to devm_ functions (part 2) coccinelle: semantic patches related to devm_ functions (part 1) coccinelle.txt: update documentation to include M= option coccicheck: add M= option to control which dir is processed ctags: remove struct forward declarations scripts/tags.sh: Add Page flag function magic
2012-01-16Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: menuconfig: fix a regression when canceling the prompt dialog at exit kbuild: Fix compiler warning with assertion when calling 'fwrite' Improve update-po-config output menuconfig: let make not report error when not save configuration merge_config.sh: fix bug in final check merge_config.sh: whitespace cleanup merge_config.sh: use signal names compatible with dash and bash kconfig: add merge_config.sh script kconfig: use xfwrite wrapper function to silence warnings kconfig: fix set but not used warnings kconfig: fix warnings by specifing format arguments
2012-01-16Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: Kbuild: Use dtc's -d (dependency) option dtc: Implement -d option to write out a dependency file kbuild: Fix comment in Makefile.lib scripts/genksyms: clean lex/yacc generated files kbuild: Correctly deal with make options which contain an "s"
2012-01-16menuconfig: fix a regression when canceling the prompt dialog at exitLi Zefan
This commit fixes a bug, while introducing a new one.. commit 7203ddbd4be9720649e47d756a001e0c7d7f8ae2 Author: Wang YanQing <udknight@gmail.com> Date: Thu Jan 12 11:31:32 2012 +0800 menuconfig: let make not report error when not save configuration Pressing ESC should cancel the yes/no dialog and return back to the main menu, but not exit from menuconfig. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Wang YanQing <udknight@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-01-15Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (39 commits) perf tools: Fix compile error on x86_64 Ubuntu perf report: Fix --stdio output alignment when --showcpuutilization used perf annotate: Get rid of field_sep check perf annotate: Fix usage string perf kmem: Fix a memory leak perf kmem: Add missing closedir() calls perf top: Add error message for EMFILE perf test: Change type of '-v' option to INCR perf script: Add missing closedir() calls tracing: Fix compile error when static ftrace is enabled recordmcount: Fix handling of elf64 big-endian objects. perf tools: Add const.h to MANIFEST to make perf-tar-src-pkg work again perf tools: Add support for guest/host-only profiling perf kvm: Do guest-only counting by default perf top: Don't update total_period on process_sample perf hists: Stop using 'self' for struct hist_entry perf hists: Rename total_session to total_period x86: Add counter when debug stack is used with interrupts enabled x86: Allow NMIs to hit breakpoints in i386 x86: Keep current stack in NMI breakpoints ...
2012-01-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-kconfig * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-kconfig: kconfig/streamline-config.pl: Fix parsing Makefile with variables kconfig/streamline-config.pl: Simplify backslash line concatination
2012-01-15kbuild: Fix compiler warning with assertion when calling 'fwrite'Arnaud Lacombe
Reinhard Tartler discovered a corner case of calling xfwrite() where the length of the string is zero. Arnaud Lacombe suggested to use assertion for the corner case, as fwrite(3) is currently used: 1) in comment printers. Empty comment are not allowed. 2) in a callback passed to expr_print(), where the string printed is either NULL OR non-empty. 3) in the lexer, auto-generated, and unused. I feel using assertion is a good solution: 1) It cleanly takes care of the above-mentioned corner case. 2) It can be easily disabled by defining NDEBUG. 3) It asserts xfwrite() is simply a wrapper for fwrite(). Reported-by: Reinhard Tartler <Reinhard.Tartler@informatik.uni-erlangen.de> Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Signed-off-by: Jean Sacren <sakiwit@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-01-15Improve update-po-config outputPeter Foley
Make the V=0 output from update-po-config be aligned correctly. Also remove an outdated comment and add a "GEN" statement. Signed-off-by: Peter Foley <pefoley2@verizon.net> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-01-15scripts/coccinelle: improve the coverage of some semantic patchesJulia Lawall
This patch ensures that all semantic patches in the scripts/coccinelle directory provide the report option. Report messages that include line numbers now have the line number preceded by "line" for easier subsequent processing. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-01-15Kbuild: Use dtc's -d (dependency) optionStephen Warren
This hooks dtc into Kbuild's dependency system. Thus, for example, "make dtbs" will rebuild tegra-harmony.dtb if only tegra20.dtsi has changed yet tegra-harmony.dts has not. The previous lack of this feature recently caused me to have very confusing "git bisect" results. For ARM, it's obvious what to add to $(targets). I'm not familiar enough with other architectures to know what to add there. Powerpc appears to already add various .dtb files into $(targets), but the other archs may need something added to $(targets) to work. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Shawn Guo <shawn.guo@linaro.org> [mmarek: Dropped arch/c6x part to avoid merging commits from the middle of the merge window] Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-01-14dtc: Implement -d option to write out a dependency fileStephen Warren
This will allow callers to rebuild .dtb files when any of the /include/d .dtsi files are modified, not just the top-level .dts file. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-01-14coccinelle: semantic patches related to devm_ functions (part 2)Julia Lawall
devm_ functions allocate memory that is to remain allocated until the device is detached. This patch checks for freeing of such memory using standard memory freeing functions. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-01-14coccinelle: semantic patches related to devm_ functions (part 1)Julia Lawall
devm_ functions allocate memory that is to remain allocated until the device is detached. This patch checks for opportunities for using the function devm_request_and_ioremap. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-01-14coccicheck: add M= option to control which dir is processedGreg Dietsche
Examples: make coccicheck M=drivers/net/wireless/ make coccicheck SUBDIRS=drivers/net/wireless/ Version 2: fix patch file names when using M= tell coccinelle where the include files are Version 3: Add second include option to support out of tree development Fix error message Signed-off-by: Greg Dietsche <Gregory.Dietsche@cuw.edu> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-01-14menuconfig: let make not report error when not save configurationWang YanQing
I find every time when I choice the 'NO' button at the dialog which let me choice whether to save the configuration before exit menuconfig, it always report the blow: " GEN /mnt/sda7/home/build/test/Makefile HOSTCC scripts/kconfig/mconf.o HOSTLD scripts/kconfig/mconf scripts/kconfig/mconf Kconfig Your configuration changes were NOT saved. make[2]: *** [menuconfig] Error 1 make[1]: *** [menuconfig] Error 2 make: *** [sub-make] Error 2 " This patch repair it. Signed-off-by: Wang YanQing <udknight@gmail.com> Acked-by: Davidlohr Bueso <dave@gnu.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-01-14merge_config.sh: fix bug in final checkJohn Stultz
Arnaud Lacombe pointed out the final checking that the requested configs were included in the final .config was broken. The example was that if you had a fragment that disabled CONFIG_DECOMPRESS_GZIP applied to a normal defconfig, there would be no final warning that CONFIG_DECOMPRESS_GZIP was acutally set in the final .config. This bug was introduced by me in v3 of the original patch, and the following patch reverts the invalid change. Signed-off-by: John Stultz <john.stultz@linaro.org> Reported-by: Arnaud Lacombe <lacombar@gmail.com> Cc: Darren Hart <dvhart@linux.intel.com> Cc: Michal Marek <mmarek@suse.cz> Cc: Arnaud Lacombe <lacombar@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-01-14merge_config.sh: whitespace cleanupDarren Hart
Fix whitespace usage in the clean_up routine. Signed-off-by: Darren Hart <dvhart@linux.intel.com> Acked-by: John Stultz <john.stultz@linaro.org> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-01-14merge_config.sh: use signal names compatible with dash and bashDarren Hart
The SIGHUP SIGINT and SIGTERM names caused failures when running merge_config.sh with the dash shell. Dropping the "SIG" component makes the script work in both bash and dash. Signed-off-by: Darren Hart <dvhart@linux.intel.com> Acked-by: John Stultz <john.stultz@linaro.org> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-01-14kconfig: add merge_config.sh scriptjohn stultz
After noticing almost every distro has their own method of managing config fragments, I went looking at some best practices, and wanted to try to consolidate some of the different approaches so this fairly simple infrastructure can be shared (and new distros/build systems don't have to implement yet another config fragment merge script). This script is most influenced by the Windriver tools used in the Yocto Project, reusing some portions found there. This script merges multiple config fragments, warning on any overridden values. It then sets any unspecified values to their default, then finally checks to make sure no specified value was dropped due to unsatisfied dependencies. I'm sure this implementation won't work for everyone, and I expect it will need to evolve to adapt for various use cases. But I think its a reasonable starting point. Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Greg Thelen <gthelen@google.com> Cc: Reinhard Tartler <Reinhard.Tartler@informatik.uni-erlangen.de> Cc: Dmitry Fink <Dmitry.Fink@palm.com> Cc: Darren Hart <dvhart@linux.intel.com> Cc: Eric B Munson <ebmunson@us.ibm.com> Cc: Bruce Ashfield <Bruce.Ashfield@windriver.com> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-01-14Merge tag 'for-linus' of git://github.com/rustyrussell/linuxLinus Torvalds
Autogenerated GPG tag for Rusty D1ADB8F1: 15EE 8D6C AB0E 7F0C F999 BFCB D920 0E6C D1AD B8F1 * tag 'for-linus' of git://github.com/rustyrussell/linux: module_param: check that bool parameters really are bool. intelfbdrv.c: bailearly is an int module_param paride/pcd: fix bool verbose module parameter. module_param: make bool parameters really bool (drivers & misc) module_param: make bool parameters really bool (arch) module_param: make bool parameters really bool (core code) kernel/async: remove redundant declaration. printk: fix unnecessary module_param_name. lirc_parallel: fix module parameter description. module_param: avoid bool abuse, add bint for special cases. module_param: check type correctness for module_param_array modpost: use linker section to generate table. modpost: use a table rather than a giant if/else statement. modules: sysfs - export: taint, coresize, initsize kernel/params: replace DEBUGP with pr_debug module: replace DEBUGP with pr_debug module: struct module_ref should contains long fields module: Fix performance regression on modules with large symbol tables module: Add comments describing how the "strmap" logic works Fix up conflicts in scripts/mod/file2alias.c due to the new linker- generated table approach to adding __mod_*_device_table entries. The ARM sa11x0 mcp bus needed to be converted to that too.
2012-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (59 commits) rtc: max8925: Add function to work as wakeup source mfd: Add pm ops to max8925 mfd: Convert aat2870 to dev_pm_ops mfd: Still check other interrupts if we get a wm831x touchscreen IRQ mfd: Introduce missing kfree in 88pm860x probe routine mfd: Add S5M series configuration mfd: Add s5m series irq driver mfd: Add S5M core driver mfd: Improve mc13xxx dt binding document mfd: Fix stmpe section mismatch mfd: Fix stmpe build warning mfd: Fix STMPE I2c build failure mfd: Constify aat2870-core i2c_device_id table gpio: Add support for stmpe variant 801 mfd: Add support for stmpe variant 801 mfd: Add support for stmpe variant 610 mfd: Add support for STMPE SPI interface mfd: Separate out STMPE controller and interface specific code misc: Remove max8997-muic sysfs attributes mfd: Remove unused wm831x_irq_data_to_mask_reg() ... Fix up trivial conflict in drivers/leds/Kconfig due to addition of LEDS_MAX8997 and LEDS_TCA6507 next to each other.
2012-01-13kconfig/streamline-config.pl: Fix parsing Makefile with variablesSteven Rostedt
Thomas Lange reported that when he did a 'make localmodconfig', his config was missing the brcmsmac driver, even though he had the module loaded. Looking into this, I found the file: drivers/net/wireless/brcm80211/brcmsmac/Makefile had the following in the Makefile: MODULEPFX := brcmsmac obj-$(CONFIG_BRCMSMAC) += $(MODULEPFX).o The way streamline-config.pl works, is parsing all the obj-$(CONFIG_FOO) += foo.o lines to find that CONFIG_FOO belongs to the module foo.ko. But in this case, the brcmsmac.o was not used, but a variable in its place. By changing streamline-config.pl to remember defined variables in Makefiles and substituting them when they are used in the obj-X lines, allows Thomas (and others) to have their brcmsmac module stay configured when it is loaded and running "make localmodconfig". Reported-by: Thomas Lange <thomas-lange2@gmx.de> Tested-by: Thomas Lange <thomas-lange2@gmx.de> Cc: Arend van Spriel <arend@broadcom.com> Cc: stable@vger.kernel.org Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-01-13kconfig/streamline-config.pl: Simplify backslash line concatinationSteven Rostedt
Simplify the way lines ending with backslashes (continuation) in Makefiles is parsed. This is needed to implement a necessary fix. Tested-by: Thomas Lange <thomas-lange2@gmx.de> Cc: stable@vger.kernel.org Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-01-13modpost: use linker section to generate table.Rusty Russell
This means (most) future busses need only have one hunk in their patch. Also took the opportunity to check that function matches the type. Again, inspired by Alessandro's patch series. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Alessandro Rubini <rubini@gnudd.com>
2012-01-13modpost: use a table rather than a giant if/else statement.Rusty Russell
We look for symbols of form __mod_<busname>_device_table, and for all but three cases we use a standard interation function (do_table) to walk over the contents and dump out the aliases. Alessandro Rubini did this first, I just repainted the bikeshed a bit. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Alessandro Rubini <rubini@gnudd.com>
2012-01-10checkpatch: catch all occurences of type and cast spacing errors per lineAndy Whitcroft
Fix up type and cast spacing checks such that all occurences on a line are examined and reported. For example the line below has a valid cast and a bad type, but currently we check the cast first which is good and stop: u16* bar = (u16 *)baz; We will also only report one of the errors in this example: u16* bar = (u16*)bad; Move to iterating across all casts and all types, reporting any failure. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Andy Whitcroft <apw@canonical.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10checkpatch: typeof may have more complex argumentsAndy Whitcroft
typeof may have various more complex forms as its arguement, not just an identifier. For now allow us to leak to the first close perenthesis ')'. Signed-off-by: Andy Whitcroft <apw@canonical.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10checkpatch: ensure cast type is unique in the context parserAndy Whitcroft
Ensure the cast type is unique in the context parser, we do not want them to detect as a comma ','. Signed-off-by: Andy Whitcroft <apw@canonical.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10checkpatch: fix complex macros handling of square bracketsAndy Whitcroft
2012-01-10checkpatch: fix 'return is not a function' square bracket handlingAndy Whitcroft
We are incorrectly matching square brackets '[' and ']' leading to false positives on more complex functions as below: return (dt3155_fbuffer[m]->ready_head - dt3155_fbuffer[m]->ready_len + dt3155_fbuffer[m]->nbuffers)% (dt3155_fbuffer[m]->nbuffers); Signed-off-by: Andy Whitcroft <apw@canonical.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10checkpatch: complex macro should allow the empty do while loopAndy Whitcroft
It is common to stub out a function as below, this is triggering a complex macro format incorrectly. Sort this out: #define cma_early_regions_reserve(reserve) do { } while (0) Signed-off-by: Andy Whitcroft <apw@canonical.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10checkpatch: fix EXPORT_SYMBOL handling following a functionAndy Whitcroft
The following fragment defeats the DEVICE_ATTR style handing, check for and ignore the close brace '}' in this context: int foo() { } DEVICE_ATTR(link_power_management_policy, S_IRUGO | S_IWUSR, ata_scsi_lpm_show, ata_scsi_lpm_put); EXPORT_SYMBOL_GPL(dev_attr_link_power_management_policy); Signed-off-by: Andy Whitcroft <apw@canonical.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10checkpatch: only apply kconfig help checks for options which promptAndy Whitcroft
The intent of this check is to catch the options which the user will see and ensure they are properly described. It is also common for internal only options to have a brief description. Allow this form. Reported-by: Steven Rostedt <rostedt@goodmis.org> Tested-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andy Whitcroft <apw@canonical.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10checkpatch: optimise statement scanner when mid-statementAndy Whitcroft
In the middle of a long definition or similar, there is no possibility of finding a smaller sub-statement. Optimise this case by skipping statement aquirey where there are no starts of statement (open brace '{' or semi-colon ';'). We are likely to scan slightly more than needed still but this is safest. Signed-off-by: Andy Whitcroft <apw@canonical.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10checkpatch: ## is not a valid modifierAndy Whitcroft
Inserting a # into the modifiers list will incorrectly add the null string to the modifiers list, leading to an infinite loop. As neither of these is a valid modifier form simply ignore them. Signed-off-by: Andy Whitcroft <apw@canonical.com> Reported-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10checkpatch: improve memset and min/max with cast checkingJoe Perches
Improve the checking of arguments to memset and min/max tests. Move the checking of min/max to statement blocks instead of single line. Change $Constant to allow any case type 0x initiator and trailing ul specifier. Add $FuncArg type as any function argument with or without a cast. Print the whole statement when showing memset or min/max messages. Improve the memset with 0 as 3rd argument error message. There are still weaknesses in the $FuncArg and $Constant code as arbitrary parentheses and negative signs are not generically supported. [akpm@linux-foundation.org: fix per Andy] Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10checkpatch: check for common memset parameter issues against statmentsAndy Whitcroft
Move the memset checks over to work against the statement. Also add checks for 0 and 1 used as lengths. Generally these indicate badly ordered parameters. Signed-off-by: Andy Whitcroft <apw@canonical.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10checkpatch: correctly track the end of preprocessor commands in contextAndy Whitcroft
When looking for a statement we currently run on through preprocessor commands. This means that a header file with just definitions is parsed over and over again combining all of the lines from the current line to the end of file leading to severe performance issues. Fix up context accumulation to track preprocessor commands and stop when reaching the end of them. At the same time vastly simplify the #define handling. Signed-off-by: Andy Whitcroft <apw@canonical.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
