path: root/scripts
2010-03-15scripts/get_maintainer.pl: fix possible infinite loopJoe Perches
commit 3c840c18bcd8efb37f1a565e83a9509e1ea5d105 upstream. If MAINTAINERS section entries are misformatted, it was possible to have an infinite loop. Correct the defect by always moving the index to the end of section + 1 Also, exit check for exclude as soon as possible. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-02markup_oops.pl: fix $func_offset error with x86_64Hui Zhu
When I use markup_oops.pl parse a x8664 oops, I got: objdump: --start-address: bad number: NaN No matching code found This is because: main::(./m.pl:228): open(FILE, "objdump -dS --adjust-vma=$vmaoffset --start-address=$decodestart --stop-address=$decodestop $filename |") || die "Cannot start objdump"; DB<3> p $decodestart NaN This NaN is from: main::(./m.pl:176): my $decodestart = Math::BigInt->from_hex("0x$target") - Math::BigInt->from_hex("0x$func_offset"); DB<2> p $func_offset 0x175 There is already a "0x" in $func_offset, another 0x makes it a NaN. The $func_offset is from line: if ($line =~ /RIP: 0010:\[\<[0-9a-f]+\>\] \[\<[0-9a-f]+\>\] ([a-zA-Z0-9\_]+)\+(0x[0-9a-f]+)\/0x[a-f0-9]/) { $function = $1; $func_offset = $2; } I make a patch to change "(0x[0-9a-f]+)\/0x[a-f0-9]/)" to "0x([0-9a-f]+)\/0x[a-f0-9]/)". Signed-off-by: Hui Zhu <teawater@gmail.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-02get_maintainer.pl: teach git log to use --no-colorRichard Kennedy
When git has been set to always use color in .gitconfig then I get the warning message Bad divisor in main::vcs_assign: 0 This is caused by vcs_file_signoffs not matching any commits due to the pattern not understand the colour codes. Fix this by telling git log to never use colour. Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk> Acked-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-17modpost: fix segfault in sym_is() with prefixed archesMike Frysinger
The sym_is() compares a symbol in an attempt to automatically skip symbol prefixes. It does this first by searching the real symbol with the normal unprefixed symbol. But then it uses the length of the original symbol to check the end of the substring instead of the length of the symbol it is looking for. On non-prefixed arches, this is effectively the same thing, so there is no problem. On prefixed-arches, since this is exceeds by just one byte, a crash is rare and it is usually a NUL byte anyways. But every once in a blue moon, you get the right page alignment and it segfaults. For example, on the Blackfin arch, sym_is() will be called with the real symbol "___mod_usb_device_table" as "symbol" when looking for the normal symbol "__mod_usb_device_table" as "name". The substring will thus return one byte into "symbol" and store it into "match". But then "match" will be indexed with the length of "symbol" instead of "name" and so we will exceed the storage. i.e. the code ends up doing: char foo[] = "abc"; return foo[strlen(foo)+1] == '\0'; Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-16Merge branch 'tracing-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: tracing/filters: Add comment for match callbacks tracing/filters: Fix MATCH_FULL filter matching for PTR_STRING tracing/filters: Fix MATCH_MIDDLE_ONLY filter matching lib: Introduce strnstr() tracing/filters: Fix MATCH_END_ONLY filter matching tracing/filters: Fix MATCH_FRONT_ONLY filter matching ftrace: Fix MATCH_END_ONLY function filter tracing/x86: Derive arch from bits argument in recordmcount.pl ring-buffer: Add rb_list_head() wrapper around new reader page next field ring-buffer: Wrap a list.next reference with rb_list_head()
2010-01-16markup_oops.pl: fix error with x86Hui Zhu
When I try to use markup_oops.pl in x86, I always get: cat 1 | perl markup_oops.pl ./vmlinux objdump: --start-address: bad number: NaN No matching code found This is because in line: if ($line =~ /EIP is at ([a-zA-Z0-9\_]+)\+0x([0-9a-f]+)\/[a-f0-9]/) { $function = $1; $func_offset = $2; } $func_offset will get a number like "0x2" But in follow code: my $decodestart = Math::BigInt->from_hex("0x$target") - Math::BigInt->from_hex("0x$func_offset"); It add other ox to ox2. Then this value will be set to NaN. So I made a small patch to fix it. Signed-off-by: Hui Zhu <teawater@gmail.com> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-13kbuild: really fix bzImage build with non-bash shJonathan Nieder
In an x86 build with CONFIG_KERNEL_LZMA enabled and dash as sh, arch/x86/boot/compressed/vmlinux.bin.lzma ends with '\xf0\x7d\x39\x00' (16 bytes) instead of the 4 bytes intended and the resulting vmlinuz fails to boot. This improves on the previous behavior, in which the file contained the characters '-ne ' as well, but not by much. Previous commits replaced "echo -ne" first with "/bin/echo -ne", then "printf" in the hope of improving portability, but none of these commands is guaranteed to support hexadecimal escapes on POSIX systems. So use the shell to convert from hexadecimal to octal. With this change, an LZMA-compressed kernel built with dash as sh boots correctly again. Reported-by: Sebastian Dalfuß <sd@sedf.de> Reported-by: Oliver Hartkopp <oliver@hartkopp.net> Reported-by: Michael Guntsche <mike@it-loops.com> Signed-off-by: Jonathan Nieder <jrnieder@gmail.com> Cc: Michael Tokarev <mjt@tls.msk.ru> Cc: Alek Du <alek.du@intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-01-12remove my email address from checkpatch.Dave Jones
Maybe this will stop people emailing me about it. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11tracing/x86: Derive arch from bits argument in recordmcount.plJan Kiszka
Let the arch argument be overruled by bits. Otherwise, building of external modules against a i386 target on a x86-64 host (and likely vice versa as well) fails unless ARCH=i386 is explicitly passed to make. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> LKML-Reference: <4B4AFE10.8050109@siemens.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-01-11scripts/get_maintainer.pl: fix file exclusion X: logicJoe Perches
The following command doesn't generate any output. `./scripts/get_maintainer.pl --no-git -f drivers/net/wireless/wl12xx/wl1271_acx.c` An excluded "X:" pattern match in any section would cause a file not to match any other section. Signed-off-by: Joe Perches <joe@perches.com> Reported-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11lib: add support for LZO-compressed kernelsAlbin Tonnerre
This patch series adds generic support for creating and extracting LZO-compressed kernel images, as well as support for using such images on the x86 and ARM architectures, and support for creating and using LZO-compressed initrd and initramfs images. Russell King said: : Testing on a Cortex A9 model: : - lzo decompressor is 65% of the time gzip takes to decompress a kernel : - lzo kernel is 9% larger than a gzip kernel : : which I'm happy to say confirms your figures when comparing the two. : : However, when comparing your new gzip code to the old gzip code: : - new is 99% of the size of the old code : - new takes 42% of the time to decompress than the old code : : What this means is that for a proper comparison, the results get even better: : - lzo is 7.5% larger than the old gzip'd kernel image : - lzo takes 28% of the time that the old gzip code took : : So the expense seems definitely worth the effort. The only reason I : can think of ever using gzip would be if you needed the additional : compression (eg, because you have limited flash to store the image.) : : I would argue that the default for ARM should therefore be LZO. This patch: The lzo compressor is worse than gzip at compression, but faster at extraction. Here are some figures for an ARM board I'm working on: Uncompressed size: 3.24Mo gzip 1.61Mo 0.72s lzo 1.75Mo 0.48s So for a compression ratio that is still relatively close to gzip, it's much faster to extract, at least in that case. This part contains: - Makefile routine to support lzo compression - Fixes to the existing lzo compressor so that it can be used in compressed kernels - wrapper around the existing lzo1x_decompress, as it only extracts one block at a time, while we need to extract a whole file here - config dialog for kernel compression [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: cleanup] Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Tested-by: Wu Zhangjin <wuzhangjin@gmail.com> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Tested-by: Russell King <rmk@arm.linux.org.uk> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-17Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: (71 commits) MIPS: Lasat: Fix botched changes to sysctl code. RTC: rtc-cmos.c: Fix warning on MIPS MIPS: Cleanup random differences beween lmo and Linus' kernel. MIPS: No longer hardwire CONFIG_EMBEDDED to y MIPS: Fix and enhance built-in kernel command line MIPS: eXcite: Remove platform. MIPS: Loongson: Cleanups of serial port support MIPS: Lemote 2F: Suspend CS5536 MFGPT Timer MIPS: Excite: move iodev_remove to .devexit.text MIPS: Lasat: Convert to proc_fops / seq_file MIPS: Cleanup signal code initialization MIPS: Modularize COP2 handling MIPS: Move EARLY_PRINTK to Kconfig.debug MIPS: Yeeloong 2F: Cleanup reset logic using the new ec_write function MIPS: Yeeloong 2F: Add LID open event as the wakeup event MIPS: Yeeloong 2F: Add basic EC operations MIPS: Move several variables from .bss to .init.data MIPS: Tracing: Make function graph tracer work with -mmcount-ra-address MIPS: Tracing: Reserve $12(t0) for mcount-ra-address of gcc 4.5 MIPS: Tracing: Make ftrace for MIPS work without -fno-omit-frame-pointer ...
2009-12-17Merge branch 'for-33' of git://repo.or.cz/linux-kbuildLinus Torvalds
* 'for-33' of git://repo.or.cz/linux-kbuild: (29 commits) net: fix for utsrelease.h moving to generated gen_init_cpio: fixed fwrite warning kbuild: fix make clean after mismerge kbuild: generate modules.builtin genksyms: properly consider EXPORT_UNUSED_SYMBOL{,_GPL}() score: add asm/asm-offsets.h wrapper unifdef: update to upstream revision 1.190 kbuild: specify absolute paths for cscope kbuild: create include/generated in silentoldconfig scripts/package: deb-pkg: use fakeroot if available scripts/package: add KBUILD_PKG_ROOTCMD variable scripts/package: tar-pkg: use tar --owner=root Kbuild: clean up marker net: add net_tstamp.h to headers_install kbuild: move utsrelease.h to include/generated kbuild: move autoconf.h to include/generated drop explicit include of autoconf.h kbuild: move compile.h to include/generated kbuild: drop include/asm kbuild: do not check for include/asm-$ARCH ... Fixed non-conflicting clean merge of modpost.c as per comments from Stephen Rothwell (modpost.c had grown an include of linux/autoconf.h that needed to be changed to generated/autoconf.h)
2009-12-17MIPS: Tracing: Add dynamic function tracer supportWu Zhangjin
With dynamic function tracer, by default, _mcount is defined as an "empty" function, it returns directly without any more action . When enabling it in user-space, it will jump to a real tracing function(ftrace_caller), and do the real job for us. Differ from the static function tracer, dynamic function tracer provides two functions ftrace_make_call()/ftrace_make_nop() to enable/disable the tracing of some indicated kernel functions(set_ftrace_filter). In the -v4 version, the implementation of this support is basically the same as X86 version does: _mcount is implemented as an empty function and ftrace_caller is implemented as a real tracing function respectively. But in this version, to support module tracing with the help of -mlong-calls in arch/mips/Makefile: MODFLAGS += -mlong-calls. The stuff becomes a little more complex. We need to cope with two different type of calling to _mcount. For the kernel part, the calling to _mcount(result of "objdump -hdr vmlinux"). is like this: 108: 03e0082d move at,ra 10c: 0c000000 jal 0 <fpcsr_pending> 10c: R_MIPS_26 _mcount 10c: R_MIPS_NONE *ABS* 10c: R_MIPS_NONE *ABS* 110: 00020021 nop For the module with -mlong-calls, it looks like this: c: 3c030000 lui v1,0x0 c: R_MIPS_HI16 _mcount c: R_MIPS_NONE *ABS* c: R_MIPS_NONE *ABS* 10: 64630000 daddiu v1,v1,0 10: R_MIPS_LO16 _mcount 10: R_MIPS_NONE *ABS* 10: R_MIPS_NONE *ABS* 14: 03e0082d move at,ra 18: 0060f809 jalr v1 In the kernel version, there is only one "_mcount" string for every kernel function, so, we just need to match this one in mcount_regex of scripts/recordmcount.pl, but in the module version, we need to choose one of the two to match. Herein, I choose the first one with "R_MIPS_HI16 _mcount". and In the kernel verion, without module tracing support, we just need to replace "jal _mcount" by "jal ftrace_caller" to do real tracing, and filter the tracing of some kernel functions via replacing it by a nop instruction. but as we have described before, the instruction "jal ftrace_caller" only left 32bit length for the address of ftrace_caller, it will fail when calling from the module space. so, herein, we must replace something else. the basic idea is loading the address of ftrace_caller to v1 via changing these two instructions: lui v1,0x0 addiu v1,v1,0 If we want to enable the tracing, we need to replace the above instructions to: lui v1, HI_16BIT_ftrace_caller addiu v1, v1, LOW_16BIT_ftrace_caller If we want to stop the tracing of the indicated kernel functions, we just need to replace the "jalr v1" to a nop instruction. but we need to replace two instructions and encode the above two instructions oursevles. Is there a simpler solution? Yes! Here it is, in this version, we put _mcount and ftrace_caller together, which means the address of _mcount and ftrace_caller is the same: _mcount: ftrace_caller: j ftrace_stub nop ...(do real tracing here)... ftrace_stub: jr ra move ra, at By default, the kernel functions call _mcount, and then jump to ftrace_stub and return. and when we want to do real tracing, we just need to remove that "j ftrace_stub", and it will run through the two "nop" instructions and then do the real tracing job. what about filtering job? we just need to do this: lui v1, hi_16bit_of_mcount <--> b 1f (0x10000004) addiu v1, v1, low_16bit_of_mcount move at, ra jalr v1 nop 1f: (rec->ip + 12) In linux-mips64, there will be some local symbols, whose name are prefixed by $L, which need to be filtered. thanks goes to Steven for writing the mips64-specific function_regex. In a conclusion, with RISC, things becomes easier with such a "stupid" trick, RISC is something like K.I.S.S, and also, there are lots of "simple" tricks in the whole ftrace support, thanks goes to Steven and the other folks for providing such a wonderful tracing framework! Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Cc: Nicholas Mc Guire <der.herr@hofr.at> Cc: zhangfx@lemote.com Cc: Wu Zhangjin <wuzhangjin@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/675/ Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-17MIPS: Tracing: Add an endian argument to scripts/recordmcount.plWu Zhangjin
MIPS and some other architectures need this argument to handle big/little endian respectively. Signed-off-by: Wu Zhangjin <wuzj@lemote.com> Cc: Nicholas Mc Guire <der.herr@hofr.at> Cc: zhangfx@lemote.com Cc: Wu Zhangjin <wuzhangjin@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/674/ Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-16Merge branch 'module' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus * 'module' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: modpost: fix segfault with short symbol names module: handle ppc64 relocating kcrctabs when CONFIG_RELOCATABLE=y Kbuild: clear marker out of modpost module: make MODULE_SYMBOL_PREFIX into a CONFIG option ARM: unexport symbols used to implement floating point emulation ARM: use unified discard definition in linker script x86: don't export inline function sparc64: don't export static inline pci_ functions
2009-12-15scripts/get_maintainer.pl: support multiple VCSs - add mercurialJoe Perches
Restructure a bit for multiple version control systems support. Use a hash for each supported VCS that contains the commands and patterns used to find commits, logs, and signers. --git command line options are still used for hg except for --git-since. Use --hg-since instead. The number of commits can differ for git and hg, so --rolestats might be different. Style changes: Use common push style push(@foo...), simplify a return Bumped version to 0.23. Signed-off-by: Joe Perches <joe@perches.com> Cc: Marti Raudsepp <marti@juffo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15scripts/get_maintainer.pl: fix --non with --git-blame and cleanupsJoe Perches
Fix email matching without name --n and --git-blame Using --non and --git-blame caused maintainer signature matching to fail. Fixed that by adding 3rd argument to sub format_email to control show/hide name portion of address Slurp -f file instead of reading line-by-line for K: pattern matching. Suggested by Wolfram Sang as more efficient Refactor git command execution Break into 2 functions, execute/analyze Share code between --git and --git-blame Don't warn multiple times when git isn't installed Improve stats reporting --git-min-percent and -- rolestats now count the total number of commits for either the period of --git-since or if using --git-blame the commits used by the current file and calculate commit % as # of commits signed / total commits * 100 Code style cleaning Use consistent sub foo { my (args...) = @_; Signed-off-by: Joe Perches <joe@perches.com> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Greg KH <greg@kroah.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15scripts/get_maintainer.pl: add --roles and --rolestatsJoe Perches
--roles shows the role of each email address, i.e. why it was selected. --rolestats selects --roles and adds git log/blame signers #'s and % Multiple roles are possible (supporter, maintainer, git-signer...) --roles or --rolestats is meant to help identify appropriate maintainers to notify and should not be used with "git send-email --cc-cmd" Example output: Existing: $ ./scripts/get_maintainer.pl -f arch/x86/kernel/acpi/boot.c Corentin Chary <corentincj@iksaif.net> Karol Kozimor <sziwan@users.sourceforge.net> Len Brown <len.brown@intel.com> Pavel Machek <pavel@ucw.cz> Rafael J. Wysocki <rjw@sisk.pl> Thomas Gleixner <tglx@linutronix.de> Ingo Molnar <mingo@redhat.com> H. Peter Anvin <hpa@zytor.com> x86@kernel.org Yinghai Lu <yhlu.kernel@gmail.com> Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> acpi4asus-user@lists.sourceforge.net linux-pm@lists.linux-foundation.org linux-kernel@vger.kernel.org With --roles $ ./scripts/get_maintainer.pl --roles -f arch/x86/kernel/acpi/boot.c Corentin Chary <corentincj@iksaif.net> (maintainer:ASUS ACPI EXTRAS...) Karol Kozimor <sziwan@users.sourceforge.net> (maintainer:ASUS ACPI EXTRAS...) Len Brown <len.brown@intel.com> (supporter:SUSPEND TO RAM,git-signer) Pavel Machek <pavel@ucw.cz> (supporter:SUSPEND TO RAM) Rafael J. Wysocki <rjw@sisk.pl> (supporter:SUSPEND TO RAM) Thomas Gleixner <tglx@linutronix.de> (maintainer:X86 ARCHITECTURE...) Ingo Molnar <mingo@redhat.com> (maintainer:X86 ARCHITECTURE...,git-signer) H. Peter Anvin <hpa@zytor.com> (maintainer:X86 ARCHITECTURE...) x86@kernel.org (maintainer:X86 ARCHITECTURE...) Yinghai Lu <yhlu.kernel@gmail.com> (git-signer) Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> (git-signer) acpi4asus-user@lists.sourceforge.net (open list:ASUS ACPI EXTRAS...) linux-pm@lists.linux-foundation.org (open list:SUSPEND TO RAM) linux-kernel@vger.kernel.org (open list) With --rolestats $ ./scripts/get_maintainer.pl --rolestats -f arch/x86/kernel/acpi/boot.c Corentin Chary <corentincj@iksaif.net> (maintainer:ASUS ACPI EXTRAS...) Karol Kozimor <sziwan@users.sourceforge.net> (maintainer:ASUS ACPI EXTRAS...) Len Brown <len.brown@intel.com> (supporter:SUSPEND TO RAM,git-signer:16/79=20%) Pavel Machek <pavel@ucw.cz> (supporter:SUSPEND TO RAM) Rafael J. Wysocki <rjw@sisk.pl> (supporter:SUSPEND TO RAM) Thomas Gleixner <tglx@linutronix.de> (maintainer:X86 ARCHITECTURE...) Ingo Molnar <mingo@redhat.com> (maintainer:X86 ARCHITECTURE...,git-signer:29/79=37%) H. Peter Anvin <hpa@zytor.com> (maintainer:X86 ARCHITECTURE...) x86@kernel.org (maintainer:X86 ARCHITECTURE...) Yinghai Lu <yhlu.kernel@gmail.com> (git-signer:12/79=15%) Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> (git-signer:6/79=8%) acpi4asus-user@lists.sourceforge.net (open list:ASUS ACPI EXTRAS...) linux-pm@lists.linux-foundation.org (open list:SUSPEND TO RAM) linux-kernel@vger.kernel.org (open list) With --rolestats and --git-blame $ ./scripts/get_maintainer.pl --rolestats --git-blame -f arch/x86/kernel/acpi/boot.c Corentin Chary <corentincj@iksaif.net> (maintainer:ASUS ACPI EXTRAS...) Karol Kozimor <sziwan@users.sourceforge.net> (maintainer:ASUS ACPI EXTRAS...) Len Brown <len.brown@intel.com> (supporter:SUSPEND TO RAM,git-signer:16/79=20%,commits:22/154=14%) Pavel Machek <pavel@ucw.cz> (supporter:SUSPEND TO RAM) Rafael J. Wysocki <rjw@sisk.pl> (supporter:SUSPEND TO RAM) Thomas Gleixner <tglx@linutronix.de> (maintainer:X86 ARCHITECTURE...) Ingo Molnar <mingo@redhat.com> (maintainer:X86 ARCHITECTURE...,git-signer:29/79=37%,commits:36/154=23%) H. Peter Anvin <hpa@zytor.com> (maintainer:X86 ARCHITECTURE...) x86@kernel.org (maintainer:X86 ARCHITECTURE...) Yinghai Lu <yhlu.kernel@gmail.com> (git-signer:12/79=15%,commits:9/154=6%) Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> (git-signer:6/79=8%) Andi Kleen <ak@suse.de> (commits:11/154=7%) Andrew Morton <akpm@osdl.org> (commits:10/154=6%) acpi4asus-user@lists.sourceforge.net (open list:ASUS ACPI EXTRAS...) linux-pm@lists.linux-foundation.org (open list:SUSPEND TO RAM) linux-kernel@vger.kernel.org (open list) Other changes: Format git-signers email addresses a bit to reduce bad signatures Command line bad arguments emitted a verbose usage(), just show --help Version number bumped to .22 Ben Hutchings had the idea and created a good deal of this implementation. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15modpost: fix segfault with short symbol namesMichal Marek
memcmp() is wrong here, the symbol name can be shorter than KSYMTAB_PFX or CRC_PFX. Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-12-15Kbuild: clear marker out of modpostWenji Huang
Remove the unnecessary functions and variables. Signed-off-by: Wenji Huang <wenji.huang@oracle.com> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-12-15module: make MODULE_SYMBOL_PREFIX into a CONFIG optionAlan Jenkins
The next commit will require the use of MODULE_SYMBOL_PREFIX in .tmp_exports-asm.S. Currently it is mixed in with C structure definitions in "asm/module.h". Move the definition of this arch option into Kconfig, so it can be easily accessed by any code. This also lets modpost.c use the same definition. Previously modpost relied on a hardcoded list of architectures in mk_elfconfig.c. A build test for blackfin, one of the two MODULE_SYMBOL_PREFIX archs, showed the generated code was unchanged. vmlinux was identical save for build ids, and an apparently randomized suffix on a single "__key" symbol in the kallsyms data). Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Acked-by: Mike Frysinger <vapier@gentoo.org> (blackfin) CC: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-12-14microblaze: ftrace: Add dynamic trace supportMichal Simek
With dynamic function tracer, by default, _mcount is defined as an "empty" function, it returns directly without any more action. When enabling it in user-space, it will jump to a real tracing function(ftrace_caller), and do the real job for us. Differ from the static function tracer, dynamic function tracer provides two functions ftrace_make_call()/ftrace_make_nop() to enable/disable the tracing of some indicated kernel functions(set_ftrace_filter). In the kernel version, there is only one "_mcount" string for every kernel function, so, we just need to match this one in mcount_regex of scripts/recordmcount.pl. For more information please look at code and Documentation/trace folder. Steven ACK that scripts/recordmcount.pl part. Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-12kbuild: generate modules.builtinMichal Marek
To make it easier for module-init-tools and scripts like mkinitrd to distinguish builtin and missing modules, install a modules.builtin file listing all builtin modules. This is done by generating an additional config file (tristate.conf) with tristate options set to uppercase 'Y' or 'M'. If we source that config file, the builtin modules appear in obj-Y. Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-12genksyms: properly consider EXPORT_UNUSED_SYMBOL{,_GPL}()Jan Beulich
Despite being unused these should also get a CRC calculated. Primarily I view this as a consistency thing. But I also think this is one of the reasons why __crc_* need to be weak (which I think should be avoided, and hence we should have the goal to eliminate this so that failure to calculate a proper CRC for a symbol causes the build to fail). Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Anibal Monsalve Salazar <anibal@debian.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-12unifdef: update to upstream revision 1.190Tony Finch
Fix handling of input files (e.g. with no newline at EOF) that could make unifdef get into an unexpected state and call abort(). The new -B option compresses blank lines around a deleted section so that blank lines around "paragraphs" of code don't get doubled. The evaluator can now handle macros with arguments, and unbracketed arguments to the "defined" operator. Add myself to MAINTAINERS for unifdef. Signed-off-by: Tony Finch <dot@dotat.at> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-12kbuild: specify absolute paths for cscopeDaniel Vetter
Cscope doesn't hadle relative paths when cscope.out is not in $PWD. Use absolute paths when generating cscope.files, which seems to be the recommended way to generate cscope.out, anyway (at least according to cscope.sf.net). The speed and size differences are minimal, the only drawback is that the database needs to be regenerated if the source directory is moved. [mmarek: fixed for O= builds, modified changelog] Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-12kbuild: create include/generated in silentoldconfigMichal Marek
The toplevel Makefile creates the directory if it runs silentoldconfig automatically, but if run manually, it fails: $ make mrproper $ make defconfig && make silentoldconfig *** Default configuration is based on 'x86_64_defconfig' # # configuration written to .config # scripts/kconfig/conf -s arch/x86/Kconfig *** Error during update of the kernel configuration. ... Move the mkdir command to the silentoldconfig target to make it work. Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-12scripts/package: deb-pkg: use fakeroot if availableJonathan Nieder
Running "make deb-pkg" requires setting KBUILD_PKG_ROOTCMD or becoming root oneself or it errors out. Unless already running as root or KBUILD_PKG_ROOTCMD is already set, use fakeroot as a good default. With this patch applied, you can run "make oldconfig deb-pkg" as an ordinary user to build a binary package for an updated kernel tree and it should just work. fakeroot is too zealous by default in treating files as owned by root. Its wrapped stat() sets st_uid and st_gid to 0 for all files, which causes Git to go on a wild goose chase if CONFIG_LOCALVERSION_AUTO is set, checking if any file's content has changed along with its stat information. Avoid this by telling fakeroot to use the actual owner and group for preexisting files, by passing it the -u option. Signed-off-by: Jonathan Nieder <jrnieder@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-12scripts/package: add KBUILD_PKG_ROOTCMD variableJonathan Nieder
Let the deb-pkg target acquire (fake) root privileges before running commands that need them. Without such privileges, deb-pkg errors out because chown fails. The new KBUILD_PKG_ROOTCMD variable, if defined, is used as a command to run other commands with possibly fake elevated privileges. Since this is not needed for the tar-pkg and rpm-pkg targets, it is only used by deb-pkg. If it is not defined, the behavior is as before, and the user will have to rerun make as root. In other words, as a shortcut, instead of running 'make oldconfig && make && fakeroot -u make deb-pkg', one can use the single command 'make oldconfig deb-pkg KBUILD_PKG_ROOTCMD="fakeroot -u"'. Suggested-by: Ryan Anderson <ryan@michonline.com> Signed-off-by: Jonathan Nieder <jrnieder@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-12scripts/package: tar-pkg: use tar --owner=rootMichal Marek
Use the --owner= and --group= options to make sure the entries in the built tar file are owned by root. Without this change, a careless sysadmin using the tar-pkg target can easily end up installing a kernel that is writable by the unprivileged user account used to build the kernel. Test that these options are understood before using them so that non-GNU versions of tar can still be used if the operator is appropriately cautious. Signed-off-by: Jonathan Nieder <jrnieder@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-12kbuild: move autoconf.h to include/generatedSam Ravnborg
Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-12kbuild: do not check for include/asm-$ARCHSam Ravnborg
No architectures uses include/asm-$ARCH now. So drop check for location of include files Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-12kbuild: fix bzImage build for x86Michael Tokarev
As has been discussed previously (and Sam has been CC'ed), the fix is still incorrect. It replaces "echo -ne" with "/bin/echo -ne", but neither of the two are guaranteed to support the necessary arguments and necessary (hexadecimal) escape sequences. What should be used here is printf(1). The trivial patch below (on top of these kbuild changes) fixes this issue. Signed-Off-By: Michael Tokarev <mjt@tls.msk.ru> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-11USB: handle bcd incrementation in usb modalias generationNathaniel McCallum
This patch fixes a bug when incrementing/decrementing on a BCD formatted integer (i.e. 0x09++ should be 0x10 not 0x0A). It just adds a function for incrementing/decrementing BCD integers by converting to decimal, doing the increment/decrement and then converting back to BCD. Signed-off-by: Nathaniel McCallum <nathaniel@natemccallum.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11USB: add hex/bcd detection to usb modalias generationNathaniel McCallum
The current code to generate usb modaliases from usb_device_id assumes that the device's bcdDevice descriptor will actually be in BCD format. While this should be a sane assumption, some devices don't follow spec and just use plain old hex. This causes drivers for these devices to generate invalid modalias lines which will never actually match for the hardware. The following patch adds hex support for bcdDevice in file2alias.c by detecting when a driver uses a hex formatted bcdDevice_(lo|hi) and adjusts the output to hex format accordingly. Drivers for devices which have bcdDevice conforming to BCD will have no change in modalias output. Drivers for devices which don't conform (i.e. ibmcam) should now generate valid modaliases. EXAMPLE OUTPUT (ibmcam; space added to highlight change) Old: usb:v0545p800D d030[10-9] dc*dsc*dp*ic*isc*ip* New: usb:v0545p800D d030a dc*dsc*dp*ic*isc*ip* Signed-off-by: Nathaniel McCallum <nathaniel@natemccallum.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-07Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: kernel/irq/chip.c
2009-12-05Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (470 commits) x86: Fix comments of register/stack access functions perf tools: Replace %m with %a in sscanf hw-breakpoints: Keep track of user disabled breakpoints tracing/syscalls: Make syscall events print callbacks static tracing: Add DEFINE_EVENT(), DEFINE_SINGLE_EVENT() support to docbook perf: Don't free perf_mmap_data until work has been done perf_event: Fix compile error perf tools: Fix _GNU_SOURCE macro related strndup() build error trace_syscalls: Remove unused syscall_name_to_nr() trace_syscalls: Simplify syscall profile trace_syscalls: Remove duplicate init_enter_##sname() trace_syscalls: Add syscall_nr field to struct syscall_metadata trace_syscalls: Remove enter_id exit_id trace_syscalls: Set event_enter_##sname->data to its metadata trace_syscalls: Remove unused event_syscall_enter and event_syscall_exit perf_event: Initialize data.period in perf_swevent_hrtimer() perf probe: Simplify event naming perf probe: Add --list option for listing current probe events perf probe: Add argv_split() from lib/argv_split.c perf probe: Move probe event utility functions to probe-event.c ...
2009-12-05Merge branch 'tracing-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (40 commits) tracing: Separate raw syscall from syscall tracer ring-buffer-benchmark: Add parameters to set produce/consumer priorities tracing, function tracer: Clean up strstrip() usage ring-buffer benchmark: Run producer/consumer threads at nice +19 tracing: Remove the stale include/trace/power.h tracing: Only print objcopy version warning once from recordmcount tracing: Prevent build warning: 'ftrace_graph_buf' defined but not used ring-buffer: Move access to commit_page up into function used tracing: do not disable interrupts for trace_clock_local ring-buffer: Add multiple iterations between benchmark timestamps kprobes: Sanitize struct kretprobe_instance allocations tracing: Fix to use __always_unused attribute compiler: Introduce __always_unused tracing: Exit with error if a weak function is used in recordmcount.pl tracing: Move conditional into update_funcs() in recordmcount.pl tracing: Add regex for weak functions in recordmcount.pl tracing: Move mcount section search to front of loop in recordmcount.pl tracing: Fix objcopy revision check in recordmcount.pl tracing: Check absolute path of input file in recordmcount.pl tracing: Correct the check for number of arguments in recordmcount.pl ...
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-03Merge branch 'master' into nextJames Morris
2009-12-02tracing: Add DEFINE_EVENT(), DEFINE_SINGLE_EVENT() support to docbookJason Baron
The introduction of the new 'DECLARE_EVENT_CLASS()' obviates the need for the 'TRACE_EVENT()' macro in some cases. Thus, docbook style comments that used to live with 'TRACE_EVENT()' are now moved to 'DEFINE_EVENT()'. Thus, we need to make the docbook system understand the new 'DEFINE_EVENT()' macro. In addition I've tried to futureproof the patch, by also adding support for 'DEFINE_SINGLE_EVENT()', since there has been discussion about renaming: TRACE_EVENT() -> DEFINE_SINGLE_EVENT(). Without this patch the tracepoint docbook fails to build. I've verified that this patch correctly builds the tracepoint docbook which currently covers signals, and irqs. Changes in v2: - properly indent perl 'if' statements Signed-off-by: Jason Baron <jbaron@redhat.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: William Cohen <wcohen@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Masami Hiramatsu <mhiramat@redhat.com> LKML-Reference: <200912011718.nB1HIn7t011371@int-mx04.intmail.prod.int.phx2.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-23SELinux: header generation may hit infinite loopEric Paris
If a permission name is long enough the selinux class definition generation tool will go into a infinite loop. This is because it's macro max() is fooled into thinking it is dealing with unsigned numbers. This patch makes sure the macro always uses signed number so 1 > -1. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-11-20kconfig: Fix make O=<dir> local{mod,yes}configSteven Rostedt
When the output directory is something other than the kernel source, the streamline_config script gets confused. This patch passes in the source directory to the script so that it can find the proper files. Reported-by: Peter Zijlstra <peterz@infradead.org> Tested-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-11-19selinux: Fix warningsAlan Cox
scripts/selinux/genheaders/genheaders.c:20: warning: no previous prototype for ?usage? scripts/selinux/genheaders/genheaders.c:26: warning: no previous prototype for ?stoupperx? Signed-off-by: Alan Cox <alan@linux.intel.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-11-17Merge branch 'hostprogs-wmissing-prototypes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/josh/linux-misc * 'hostprogs-wmissing-prototypes' of git://git.kernel.org/pub/scm/linux/kernel/git/josh/linux-misc: Makefile: Add -Wmising-prototypes to HOSTCFLAGS oss: Mark loadhex static in hex2hex.c dtc: Mark various internal functions static dtc: Set "noinput" in the lexer to avoid an unused function drm: radeon: Mark several functions static in mkregtable arch/sparc/boot/*.c: Mark various internal functions static arch/powerpc/boot/addRamDisk.c: Mark several internal functions static arch/alpha/boot/tools/objstrip.c: Mark "usage" static Documentation/vm/page-types.c: Declare checked_open static genksyms: Mark is_reserved_word static kconfig: Mark various internal functions static kconfig: Make zconf.y work with current bison
2009-11-17tracing: Only print objcopy version warning once from recordmcountSteven Rostedt
If the user has an older version of objcopy, that can not handle converting local symbols to global and vice versa, then some functions will not be part of the dynamic function tracer. The current code in recordmcount.pl will print a warning in this case. Unfortunately, there exists lots of files that may have this issue with older objcopys and this will cause a warning for every file compiled with this issue. This patch solves this overwhelming output by creating a .tmp_quiet_recordmcount file on the first instance the warning is encountered. The warning will not print if this file exists. The temp file is deleted at the beginning of the compile to ensure that the warning will happen once again on new compiles (because the issue is still present). Reported-by: Andrew Morton <akpm@linux-foundation.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-11-15dtc: Mark various internal functions staticJosh Triplett
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
2009-11-15dtc: Set "noinput" in the lexer to avoid an unused functionJosh Triplett
Regenerate the corresponding generated lexer. Regenerating the lexer with current flex also provides prototypes for various yy* functions, making some -Wmissing-prototypes warnings go away as well. Signed-off-by: Josh Triplett <josh@joshtriplett.org>
2009-11-15genksyms: Mark is_reserved_word staticJosh Triplett
The genksyms keyword gperf hash provides a function is_reserved_word. genksyms #includes the resulting generated file keywords.c, so the function gets used only in the same source file that defines it. Mark is_reserved_word static, and regenerate the corresponding generated file. Signed-off-by: Josh Triplett <josh@joshtriplett.org>
